Results 1 to 3 of 3
Thread: 09 Passat CC 2.0TSI Running Issues
    Oct 2019
    Hello all,
    This is my first post and I'm a complete beginner when it comes to VCDS so I'm hoping for some help/guidance to solve the issue with my car.
    I'll try to keep the post short but it might go on a bit.
    I only had the car a week and one evening I was driving it to see family then all of a sudden I felt a small loss of power then by the time I got to my end destination the car was really low on power, misfiring and a lot of smoke coming out of the exhaust, I assumed fuel as it was a really pungent smell. The roadside assistance company came and plugged their diagnostics into the car it is showed the following codes:
    P0300 - Random/multiple cylinder misfire
    P0302 - Cylinder 2 misfire
    P0303 - Cylinder 3 misfire
    P120A - Cylinder deactivation
    P2293 - Fuel pressure regulator 2 performance
    Cut a long story short, I got the car recovered to my local garage who were adamant it was a turbo failure and said it was too much for them to take on and would need to go to a specialist.
    I wasn't so sure so rather than scrap the car I wanted to buy VCDS to see what I could find to possibly salvage the car.
    So...the garage cleared the codes, I drove the car home and this is what I got on and auto-scan. No misfires but a MAF sensor issue.
    Tuesday,22,October,2019,18:56:00:45158
    VIN: WVWZZZ3CZ9E560101   License Plate:
    Mileage: 153250km-95225mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 14 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ9E560101   Mileage: 153250km-95225miles
    Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
       Part No SW: 06J 906 026 D    HW: 06J 906 026 D
       Component: MED17.5             2424
       Revision: A7H06---    Serial number: VWZCZ000000000
       Coding: 0404000318070060
       Shop #: WSC 05314 000 00000
       VCID: 2B03077A9F0E363F4C5-807E
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal
                        Mileage: 153242 km
                        Date: 2014.03.02
                        Time: 12:04:59
                        RPM: 1265 /min
                        Load: 28.2 %
                        Temperature: 18.0C
                        Temperature: 15.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.478 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 000 - Supply Voltage - Intermittent
                        Mileage: 153245 km
                        Date: 2014.03.13
                        Time: 18:38:55
                        RPM: 818 /min
                        Load: 24.7 %
                        Temperature: 21.0C
                        Temperature: 11.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.351 V
    Readiness: 0000 0101
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
       Component: J104    C4 440 V2   0013
       Revision: --025---    Serial number: 00000795091653
       Coding: 0003436
       Shop #: WSC 05311 000 00000
       VCID: 2F3B136AAB164A1F60D-807A
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 24
                        Reset counter: 254
                        Mileage: 153242 km
                        Date: 2014.03.02
                        Time: 12:04:59
                        Hex Value: 0x0000
                        Voltage: 14.50 V
                        Bin. Bits: 00011111
                        Count: 217
                        Hex Value: 0x0000
                        Fault Frequency: 10
                        Reset counter: 2
                        Mileage: 152233 km
                        Date: 2014.02.10
                        Time: 15:40:20
                        Hex Value: 0x00C9
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 220
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
       Component: Climatronic   130 0305
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 73B3DF1A0B3E2EFFC45-8026
       Revision: 00H54000    Serial number: 00000009414872
       Coding: E1840F8B00041A0047970F00170000000008FF475C40017C170000000000
       Shop #: WSC 05124 000 00000
       VCID: 33331F1A473E6EFF045-8066
       Subsystem 1 - Part No: 3C8 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 111108 022  0602
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     220913 054  0403
       Coding: 00209069
       Shop #: WSC 05124
    02236 - Stationary Right Cornering Lamp (Right) (M52)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 3
                        Mileage: 149939 km
                        Voltage: 14.50 V
       Part No SW: 3C0 907 376     HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0069
       Revision: 00000000    Serial number: 24020902250001
       Coding: 010180
       VCID: 6695B64E486CCB5753B-8032
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__301 VW10 HI   1916
       Revision: 20013000    Serial number: 003E2P4SLJXK
       Coding: 0012337
       VCID: 44D14CC61290D947ADF-8010
       Subsystem 1 - Serial number: 6332MTS640500559
       Subsystem 2 - Serial number: 6342MTS611090569
       Subsystem 3 - Serial number: 6351HTS647EDV5KJ
       Subsystem 4 - Serial number: 6361HTS6O4OTV5KR
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507BN
       Coding: 0000501
       VCID: 74B1DC0602B029C7DDF-8020
       Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP   H4 0021
       Coding: 00000226
       Part No SW: 3C8 920 970 D    HW: 3C8 920 970 D
       Component: KOMBI         H05 0110
       Coding: 440F00
       Shop #: WSC 05314 115 00000
       VCID: 2D070962AD9A380F521-8078
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P0931006BA
       Coding: F9887F06000202009003
       VCID: 2A0D027E90F42F37B73-807E
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       VCID: 7AADF23E20D45FB7873-802E
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1532
       Revision: 71009005    Serial number: 00000768888615
       Coding: 0000693
       Shop #: WSC 00354 210 83959
       VCID: 40D940D60688C567897-8014
       Part No: 1K0 909 144 E
       Component: EPS_ZFLS Kl. 205    2501
       Revision: 00H15000
       VCID: 2C0104669A00310745F-8078
       Component:    KSG PQ46 ELV 043 0612
       Coding: 01910A0001860E763604941570085FCE107C01
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1534
       Revision: 71009005    Serial number: 00000756098114
       Coding: 0000692
       VCID: 41DF45D20D82CC6F869-8014
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
       Component: J540 EPB3  VW-10498 0003
       Revision:   010       Serial number: 00000000016842
       Coding: 0000057
       VCID: 2809F8768EF81D27A17-807C
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  036 0130
       Revision: 00000001    Serial number: VWZ1Z3I4225753
       Coding: 0500040004
       VCID: 6597B142B56AC04F5A1-8030
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000832333
       Coding: 0000144
       VCID: 313F1512BD225CEF769-8064
       Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Component: J388   TUER-SG HR   0309
       Revision: 43004101    Serial number: 00000000827240
       Coding: 0000144
       VCID: 323D1A1EB82467F70F3-8066
    End----(Elapsed Time: 01:20, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
    I wanted to see how it drove tonight so I cleared the codes before I took the car out with the intention to see what an auto-scan showed following the car being driven. Shortly before I was due to finish my test drive it started to misfire again. The code following the drive is below...
    Tuesday,22,October,2019,19:21:26:45158
    Mileage: 153260km-95231mi   Repair Order:
    VIN: WVWZZZ3CZ9E560101   Mileage: 153260km-95231miles
                   P0300 - 000 -
                        Mileage: 153268 km
                        Date: 2014.03.14
                        Time: 19:15:31
                        RPM: 1198 /min
                        Load: 14.9 %
                        Speed: 17.0 km/h
                        Temperature: 94.0C
                        Temperature: 21.0C
                        Voltage: 14.097 V
    000771 - Cylinder 3
                   P0303 - 000 - Misfire Detected
                        Mileage: 153268 km
                        Date: 2014.03.14
                        Time: 19:15:31
                        RPM: 1198 /min
                        Load: 14.9 %
                        Speed: 17.0 km/h
                        Temperature: 94.0C
                        Temperature: 21.0C
                        Voltage: 14.097 V
    000772 - Cylinder 4
                   P0304 - 000 - Misfire Detected
                        Mileage: 153268 km
                        Date: 2014.03.14
                        Time: 19:15:38
                        RPM: 1492 /min
                        Load: 11.8 %
                        Speed: 21.0 km/h
                        Temperature: 94.0C
                        Temperature: 21.0C
                        Voltage: 14.224 V
       Coding: 0003436
       Coding: 0000000000
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 00209069
       Shop #: WSC 05124
                        Reset counter: 4
                        Mileage: 153254 km
                        Voltage: 14.60 V
       Coding: 010180
    03264 - Functionalty Shut Off
                        Reset counter: 43
                        Error Code: 9
                        Bin. Bits: 00000000
       Coding: 0012337
       Coding: 0000501
       Coding: 00000226
       Coding: 440F00
       Coding: 0000693
       Revision: 00H15000
       Coding: 0000692
       Coding: 0000057
       Coding: 0500040004
       Coding: 0000144
       Coding: 0000144
    End----------(Elapsed Time: 01:17, VBatt start/end: 12.6V/12.5V)-----------
    I've being going round in circles thinking I need a low pressure fuel pump, a high pressure fuel pump, a MAF sensor or even just coils.
    Are these fault codes something that's a definite issue, easily diagnosed or something that is going to need checking one by one? Obviously, that'll take me some time as I can do the checks, it's just trying to understand what the information means or what I need to look out for.
    If anyone can help that'd be great as I'm currently having to borrow a car until I can get this one fixed, I just didn't think it was the turbo and think I should try and salvage the car.
    I see nothing here that indicates it's the turbo.
    I wonder if you have a loose/bad connection to the MAF?
    Oct 2019
    Is this something I check for with a multimeter or just a visual inspection.
