Results 1 to 9 of 9
Thread: VW Passat and ABS problem
    Feb 2017
    Oulu, Finland
    Hey!
    I'm looking at a VW Passat MY02 and its abs malfunction.
    The owner had driven with cool and damp weather their car until the distance between the instrument cluster to become the abs and traction control lights.
    Parts have been replaced / tested:
    - 2 pcs units of ABS (Brain and Hydraulics block)
    - 3 pcs brake pressure sensors
    - 1 pcs new brake pedal sensor
    - The current stationary abs unit has the following non-resettable fault code: 01435 - Brake Pressure Sensor 1 (G201) 57-00 - Electric Circuit Failure.
    - The other ABS unit had not received the coding by the car electrical repair.
    I run out of ideas for this problem. Anyone have any repercussions on how to stop the malfunctioning lights?
    Auto-Scan log
    Tuesday,22,October,2019,19:02:01:00464
    Dealer/Shop Name: J.P
    VIN: WVWZZZ3BZ3P096336   License Plate: ABS PASSAT
    Mileage: 235650km-146426mi   Repair Order:
    Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ3P096336   Mileage: 235650km-146426miles
    Address 01: Engine        Labels: 06B-907-557-ALT.lbl
       Part No SW: 3B0 907 557 R    HW:
       Component: 2.0L R4/5VS         0001
       Coding: 0011501
       Shop #: WSC 00028 000 00000
       VCID: 382928F7BE4396C7317-5160
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       1728
       Coding: 04275
       VCID: 2517F1831CF11B2F9A1-51F2
                35-00 - -
       Part No: 1C0 909 605 B
       Component: 0A AIRBAG VW51 04   0004
       Coding: 12353
       Shop #: WSC 00028
       VCID: 2313EF9B12C5E51FF45-513C
    Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
       Part No: 3B0 920 827
       Component: KOMBI+WEGFAHRSP VDO V08
       Coding: 05115
       VCID: 619FA5934859B70FA69-513C
       WVWZZZ3BZ3P096336     VWZ7Z0B5569029
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00028
       VCID: 70B9D0D793B30E87397-513C
       Part No: 1C0 959 799 A
       Component: 6Z Komfortgerát HLO 0001
       Coding: 00067
       Shop #: WSC 00094
       VCID: 353721C3AC516BAF2A1-4B1E
       Subsystem 1 - Part No: 1C1959801
       Component: 6Z Tőrsteuer.FS KLO 0004
       Subsystem 2 - Part No: 1C1959802
       Component: 6Z Tőrsteuer.BF KLO 0004
                27-00 - Implausible Signal
    End----------(Elapsed Time: 04:42, VBatt start/end: 13.6V/13.6V)-----------
    Sep 2016
    Riga, Latvia
    Have You checked wiring from G201 to ABS module?
    What does MVB 005-3 shows?
  3. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Oulu, Finland
    Quote Originally Posted by MartinsX View Post
    We have not yet checked the electrical connections.
    Does anyone know any websites, which could be studied electrical diagram of the VAG-Group's cars?
    Wednesday,23,October,2019,18:55:25:00464
                    Address 03: ABS Brakes  (4B0 614 517 G)
    18:55:19 Group 005
      -2.5°  Steering Angle Sensor (G85)
      0.00°/s  Rotation Rate
      291.97 bar  Brake Pressure
      0.00 m/s*2  Transverse Acceleration
    Quote Originally Posted by V3lmu View Post
    See:
    https://forums.ross-tech.com/showthread.php?5999
    Sep 2016
    Riga, Latvia
    18:55:19 Group 005
    This looks like open/short to plus condition.
  7. Likes Uwe, Jack@European_Parts liked this post
    Feb 2017
    Oulu, Finland
    Okay. So does this mean that the owner needs to start investigating the electrical connections more closely?
    Sep 2016
    Riga, Latvia
    3 wires, approx 15cm long
  11. #8
    Feb 2017
    Oulu, Finland
    Sounds easy job
  12. #9
    Feb 2017
    Oulu, Finland
    Problem solved!
    Original "repaired" abs unit, replaced by a workshop to another used abs unit. This is followed by coding to the original abs unit and calibration of the G85 sensor.
    There is strong suspicion that the original "repaired" abs unit was not correctly repaired.
    Prior to this operation, the power cords had been checked and there were power cords in good condition and voltages OK.
  13. Likes Uwe liked this post
