Hey Guys,
i have an issue with a no communication error with the s-tronic 0B5 TCM,i did a rebuild to the gearbox , also changed the G676 module sensor, also the TCM was replaced with a doner (used) part reason i changed it was a mechanical malfunction on G193, all the necessary steps were taken in place to have the modules up and running(cp removal/ program updated/adaptation and basic settings),
i did test drive and the car drove fine with no issues, after 45mins of driving, i parked and cycled the ignition off and on and to find the P R N D S were not showing on dash, the car started but no gear selections nor indication, i have checked all power source and fuses and no issues there,ran the harness and found no contamination,
i did a scan and found no communication/signal with TCM and Auto trans CANNOT BE REACHED , definitely the TCM is offline, i left the car overnight and went back to start and have a check, the TCM came back online, i got a chance to scan the module and found
7971 TRANSMISSION CONTROL UNIT P1701 LOCKED - INTERMITTENT- CONFIRMED
7993 POWERTRAIN DATABUS U0002 00[044] NO COMMUNICATIONS - INTERMITTENT - CONFIRMED
i erase faults and i test drove the car again for 30 mins perfect shifting with no issues, again i cycled the ignition and i lost the tcm communication, i left it for a few hours and it came back online, what can cause this issue?? any help i would appreciate ! is there anything i may need to check before concluding a bad/faulty TCM?
this is the auto scan after i cleared the module codes when online:
Any help needed! thanks
Saturday,19,October,2019,16:03:23:17560
VCDS Version: 19.6.2.0
VIN: WAUZZZ8R2AA038536 License Plate:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 42 46 47 52 53 55 56
57 5F 62 6C 72
VIN: WAUZZZ8R2AA038536 Mileage: 230700km-143350miles
0E-Media Player 1 -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine (CL0MA-CDNC) Labels:| 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 R HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0002
Revision: E1H15---
Coding: 0121000C240F0060
Shop #: WSC 59640 001 1048576
ASAM Dataset: EV_ECM20TFS0118R0907115R 001002
ROD: EV_ECM20AVS.rod
VCID: 438F620ACAD14057FA-8016
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8R0 927 156 C HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H03 0020
Revision: --H03--- Serial number: 0000001054
Coding: 000001
Shop #: WSC 03333 000 00000
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 3B7F1AEAB2213897B2-806E
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 M HW: 8R0 907 379 M
Component: ESP8 quattro H06 0020
Coding: 025548
Shop #: WSC 06335 000 00000
VCID: 4A914F2EE5FB911F39-801E
Fault Status: 00101101
Reset counter: 26
Mileage: 229920 km
Date: 2019.08.02
Time: 12:49:44
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0016
Hex Value: 0x0297
Hex Value: 0x00FF
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0324
Coding: 051500
VCID: 040DA116875F876F83-8050
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000066848005
7 Faults Found:
03285 - Sensor for Contact with Door Handle; Front Left
Reset counter: 196
Mileage: 229920 km
Date: 2019.08.02
Time: 12:51:52
03286 - Sensor for Contact with Door Handle; Front Right
Reset counter: 196
Mileage: 229920 km
Date: 2019.08.02
Time: 12:51:52
00192 - Rear Left Door Handle Touch Sensor (G417)
Reset counter: 196
Mileage: 229920 km
Date: 2019.08.02
Time: 12:51:52
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 12
Reset counter: 241
Mileage: 229923 km
Date: 2019.08.03
Time: 16:09:46
Fault Frequency: 30
Reset counter: 26
Mileage: 230507 km
Date: 2019.09.02
Time: 07:15:43
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
Reset counter: 30
Mileage: 230708 km
Date: 2009.06.26
Time: 00:02:39
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 30
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:29
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0171
Revision: D1000000 Serial number: 01150920090626
Coding: 64156000
VCID: 77F7C6DAC689DCF796-8022
Reset counter: 246
Mileage: 230708 km
Date: 2009.06.26
Time: 00:02:39
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000349824
Coding: 260010800030AF010001000300001D0D0F1D470802010141000000
Shop #: WSC 60810 741 180568
VCID: 3C7D19F6BF2F3FAFBB-8068
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 090904 H10 0041
Serial number: 90243015090821055735
Coding: 01DD13
Component: RLS H04 0003
Serial number: 10603541
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000001109090683
Fault Frequency: 47
Reset counter: 27
Mileage: 230507 km
Date: 2019.09.02
Time: 07:15:00
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H49 0050
Revision: 00000015
VCID: 2143C882388D724788-8074
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:58
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840926209299
Coding: 300105
VCID: 40856D06D3C75B4FE7-8014
00532 - Supply Voltage B+
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:37:26
Temperature: 32.0°C
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:36
Temperature: 32.0°C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 C HW: 8R0 959 655 C
Component: AirbagVW-AU10 H39 0560
Serial number: 003FQD05CYZE
Coding: 30453331313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 448D6116CFDF476FC3-8010
Serial number: 6334MSME4C010C5FM
Serial number: 6344MSME4B024639D
Serial number: 6352QSME403B3C36J
Serial number: 6362QSME4C3B4506N
Serial number: 63732SME4D3B311C4
Serial number: 63832SME4F3B192CE
13635840 - Supply voltage
U1011 00 [137] - Voltage too Low
Reset counter: 246
Mileage: 230708 km
Date: 2009.06.26
Time: 00:09:30
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90315III000CU
Coding: 000033
VCID: 3D7B14F2A43536A78C-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 B HW: 8R0 920 930 B
Component: KOMBIINSTR. H10 0255
Revision: 00000000 Serial number: CJI61LE99
Coding: 2F0722000200000C010000
Shop #: WSC 06335 123 12345
VCID: 336F32CA9271F0D76A-8066
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0105
Revision: EB800053 Serial number: 5300E0991100C6
Coding: 00C303
VCID: 52A1574E0DABD9DF41-8006
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
Serial number: 00000000004140085935
Reset counter: 30
Mileage: 230708 km
Date: 2009.06.26
Time: 00:05:39
Bin. Bits: 10111
Voltage: 10.60 V
Count: 6
Part No SW: 8R0 959 760 B HW: 8R0 959 760 B
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001001345159
Coding: 00781B00000044440000
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009307059
Coding: 011D12205E01440004
VCID: 458B7C12CCE57E67D4-8010
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:33
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:37:28
Revision: 00002001 Serial number: 0121674467
Coding: 01000E22203904950530050000000000
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE19SKB12 H01 0220
00230 - Transmission Park Selector Switch (F305)
Reset counter: 16
Mileage: 229920 km
Date: 2019.08.02
Time: 13:05:52
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 196
Mileage: 229923 km
Date: 2019.08.02
Time: 13:24:22
02616 - Fuel Tank Cap; Unlock
Reset counter: 196
Mileage: 229923 km
Date: 2019.08.02
Time: 17:24:25
Fault Frequency: 30
Reset counter: 26
Mileage: 230507 km
Date: 2019.09.02
Time: 07:15:43
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AL HW: 8T0 035 223 H
Component: DSP Prem H04 0200
Revision: 00004001 Serial number: 34880005665003
VCID: 78F5C5E6CB97D38F9F-802C
Reset counter: 196
Voltage: 12.10 V
Temperature: 41.0°C
Temperature: 43.0°C
Bin. Bits: 00000100
Reset counter: 196
Voltage: 12.10 V
Temperature: 41.0°C
Temperature: 43.0°C
Bin. Bits: 00000100
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 196
Voltage: 12.10 V
Temperature: 41.0°C
Temperature: 43.0°C
Bin. Bits: 00000100
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 196
Voltage: 12.10 V
Temperature: 41.0°C
Temperature: 43.0°C
Bin. Bits: 00000100
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009328660
VCID: 448D6116C7DF476FC3-8010
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:33
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:37:28
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000456022
VCID: 346D31D6977FF7EF73-8060
Fault Frequency: 11
Reset counter: 26
Mileage: 230662 km
Date: 2019.09.17
Time: 16:47:57
Voltage: 13.90 V
Count: 57
Speed: 6.0 km/h
Hex Value: 0x02E0
Hex Value: 0x0004
Hex Value: 0x0101
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000006
Shop #: WSC 06334 000 00000
VCID: 346D31D6577FF7EF73-8060
Part No SW: 4F0 035 083 A HW: 4F0 035 083
Component: Radio U JP H45 0055
Revision: AB001007 Serial number: 336IU097508122
Coding: 030000010000000001
VCID: 1E39F37E09F34DBFB5-804A
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:37:26
Voltage: 8.70 V
Reset counter: 246
Mileage: 230708 km
Date: 2009.06.26
Time: 00:09:23
Voltage: 9.50 V
Address 57: TV Tuner (R78) Labels: None
Part No SW: 8F0 919 129 E HW: 8F0 919 129
Component: DTV-JP H06 0760
Revision: R0060000 Serial number: 79300600735602
Coding: 100300
VCID: 326137CE6D6BF9DF61-8066
Subsystem 1 - Part No SW: 4F0 919 805 HW: 4F0 919 805
Component: R204 TVKLeser H07 0010
Serial number: 2172800600325808
02261 - Data Medium
Reset counter: 196
Mileage: 229920 km
Date: 2019.08.02
Time: 11:14:27
Part No SW: 8T2 035 678 D HW: 8T2 035 678
Component: H-BN-JP H17 0272
Revision: -------- Serial number: K5FAN158A8MFU
Coding: 01060106000581EF41080B0E00000003
VCID: 3F876EFAAE3924B79E-806A
Subsystem 1 - Part No: 8R0 060 884 H
Component: JPN_10.02.09. P130
Subsystem 2 - Part No SW: 4F0 035 503 C HW: 4F0 035 503 C
Component: ETC-VICS-Ant. H02 0020
Subsystem 3 - Part No SW: 4F0 919 813 C HW: 4F0 919 813 C
Component: Card reader H02 0100
Serial number: 358906080195
Subsystem 4 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356IP091072080
Subsystem 5 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000001160477
Reset counter: 196
Mileage: 229920 km
Date: 2019.08.02
Time: 11:14:29
Voltage: 12.00 V
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101934801
Coding: 010C12204001240004
VCID: 4281670EDDCB495FF1-8016
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:33
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:37:27
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 B HW: 8R0 907 441 B
Component: J772__Rearview 0030
Revision: --H03--- Serial number: 525PA8-J97C091
Coding: 1022010
Shop #: WSC 06325 000 00000
VCID: 356B0CD25C05EEE744-8060
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:30
Reverse OFF
Count: 3
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101934791
Fault Frequency: 23
Reset counter: 29
Mileage: 230145 km
Date: 2019.08.09
Time: 18:30:18
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:36:33
Reset counter: 31
Mileage: 230708 km
Date: 2009.06.26
Time: 00:37:27
End-------------------------(Elapsed Time: 03:50)--------------------------
