2012 VW Jetta Lost ABS Coding (MK60EC1)
Bloughautomotive
C?ID=122717
Car has lost its coding for abs module. Would like to know what software to use to be able to create the coding for this common issue along with the coding needed for the module. I have seen different options for a coding calculator but would like input to which one is the best for VW. Thank you for the support.
Tuesday,22,October,2019,09:09:05:59206
VIN: 3VWLX7AJ0CM463862   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 56 77
VIN: 3VWLX7AJ0CM463862   Mileage: 174970km-108721miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 A    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9740
   Revision: T4H06---    Serial number:
   Coding: 0000075
   VCID: 2C141F3B8FEC712F2B-8078
Readiness: 0110 0101
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2246
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 004C9B8B53E4454FA7-8054
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   VCID: 74A4C75BD75C69EFB3-8020
                    Reset counter: 41
                    Date: 2014.03.07
                    Time: 03:32:06
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 49920
                    Count: 56064
                    Fault Status: 01100101
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:32:04
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 279
                    Count: 50176
                    Count: 56064
                    Count: 65024
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:32:04
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 295
                    Count: 50176
                    Count: 56064
                    Count: 65024
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:32:04
                    Count: 3
                    Count: 12
                    Count: 29184
                    Count: 270
                    Count: 50176
                    Count: 56064
                    Count: 65024
   Part No SW: 5K0 959 434 A    HW: 5K0 959 434 A
   Component: VWKESSYPQ35GP 085 0708
   Revision: 00085000    Serial number: 0000000000
   Coding: 030C0C
   ASAM Dataset: EV_KESSY_PQ35GP A01010
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 332604479AD22ED76A-8066
65826 - No Basic Setting
          B2010 00 [009] - -
   Part No SW: 5C0 820 047 L    HW: 5C0 820 047 L
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000031552
   Shop #: WSC 03068 444 84351
   VCID: 291AE62F801E6407D0-807C
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311172100206
   Coding: 73994B9A08A30B0008382000240884C500C2502E6000000030A000000000
   Shop #: WSC 25807 444 58783
   VCID: 2D12123F74F678273C-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3462
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3462
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH00005AD+
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Serial number: 0003142
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3462
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3462
   Coding: 800000
03440 - Activation of LED for Lock and Unlock
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 00:04:10
00975 - Heated Rear Window (Z1)
            006 - Short to Plus
                    Fault Status: 01100110
                    Fault Frequency: 18
                    Reset counter: 42
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:33:01
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   012 0805
   Serial number: 003END076N47
   Coding: 00003232
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FAEC837B67A4A374E-803A
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1000000BFB05
   Coding: 30314A
   Serial number: 3572MSME2A3A3253ZZZV
   Serial number: 3582MSME60645352ZZZP
   Component: S.Sens.Fahr.H  H01 ----
   Serial number: 3516KSME23575708ZZZQ
   Component: S.Sens.Beif.H  H01 ----
   Serial number: 3526KSME28596208ZZZU
   Component: F.Sens.Fahr  H01 ----
   Serial number: 3556LSME5F540208ZZZX
   Serial number: 3566LSME43251915ZZZP
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270A01
   Shop #: WSC 00066 000 00119
   VCID: 2A1819234D186F1FD9-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70ACCB4BA34455CF57-8024
   Component: IMMO          H04 0604
   Coding: 000007
   VCID: 6A98D9238D98AF1F19-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 04:11:56
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 12000033562004
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E10153371F0033F05-807A
   Revision: A1001003    Serial number: 7668355706
   Coding: 020000
   VCID: 271EE017560A5277C6-8072
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H03 0007
   Serial number: VWZAZ2K8405348
   Coding: 040004210200000000001000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 618ABE0F70AEEC47C8-8034
1048597 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [tweeter front left open load]
                    Reset counter: 42
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
1048598 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [tweeter front right open load]
                    Reset counter: 42
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
1048632 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Frequency: 10
                    Reset counter: 42
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:17
1048669 - Tuner for Satellite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:16
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668271838
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3228014365C827DF61-8066
End----------(Elapsed Time: 01:27, VBatt start/end: 14.3V/14.3V)-----------
Dana
Western PA, USA
Hi Joshua,
That VIN decrypted as a 2012, and I can easily tweak the forum subject line, but do verify the actual VIN is 3VWLX7AJ0CM463862 (to rule out swapped Immo components).
If 3VWLX7AJ0CM463862 is correct I believe the factory installed ABS module was 1K0 907 379 BL. The direct replacement should be 1K0 907 375 BL according to PL24 by VIN. The installed module (1K0 907 379 BC) appears to fit an entirely different VIN split. Temp screen shot link: https://media.trillian.im/media/?m=...xP92nqvWvFLhjDaNUKLFH9PD0BylAZhOJITKXtWFDZQ==
Either way, I believe the factory condition ABS coding was:
B14B400C492808FD8D1302EA921B1061A71000
That may be rejected if the installed module doesn't support HHC.
Next, although I'm not opposed to using to using online calculators for a second opinion or a cross check of my work I don’t use then for building coding that’s sent to customers. Instead, we search our database of scans for identical cars to establish a baseline (with the VIN digits removed) and use that base coding in conjunction with internal label files to fine tune things like steering type, park assist/wheel speed sensors, HHC, TPMS and similar per the PR-Codes of the car in question.
If I cannot locate at least one (5 or more are preferred) baseline scan I won't even attempt to craft up long ABS coding from scratch due to all of the variables and potential liability for Ross-Tech.
Best,
Dana
Vehicle Identification No.3VWLX7AJ0CM463862
ModelJetta
JEM
Date of production05.06.2012
Model year2012
Sales type162XS3
Engine CodeCBTA
Transmission CodePDW
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components7KKVehicle class differentiation -160-
drive-off assistanceUG1Hill hold control
Emission standard7GJEmission standard TIER 2
Trailer hitch1D0without trailer towing
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Storage compartment7N2Sunglass holder
Aerials8L6"diversity" window antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Alternative drive system0K0Without alternative drive system
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8FSports equipment
Brake type in rear1KDDisc brakes in rear
batteriesJ1DBattery 380 A (72 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Beverage holders4M2Beverage holder in center console in front and in storage compartment in rear
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
floor covering3MHDilours floor covering without scuff guard
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U0Without brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ3Chrome package (version 2)
General operating permit, alterationsC09Operating permit, alteration
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG18Shock absorption in front
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0ERInstallation differentiation for transmission AQ250 -- vehicle components --
Theft protection system7AZPreparation for anti-theft alarm system
Inserts5MNDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF8Electric interface for external use
Manufacturing sequence differentiation0FLMexico manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running lights NAR
Fresh air intake for passenger compartment (with particulate filter)2V1dust-pollen filter
Antifreeze1C2Antifreeze up to -35 degree celsius tolerance up to -40 degree C
Vehicle tracing system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Interior noise suppression measures3W0Without additional noise suppression measures for passenger compartment
Alternators8GUAlternator 140 A
Weight category rear axle0YDWeight range 4 installation control only, no requirement forecast
Weight category front axleL13Suspension range 13 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U7Luggage pocket on backrest of right seat
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T2Electronic cruise control system (CCS)
Exterior noise suppression measures2B0without additional exterior noise insulation
Luggage compartment trim5A2Comfort luggage compartment trim
Transmission specificationsG1A6-speed automatic transmission
glove box4Z3Lockable glove compartment door, with light
Brackets3P0Without bracket for first aid kit and warning triangle
handle for hand brake lever6PChandbrake lever grip (leather)
Rear spoiler5J0Without rear spoiler
Rear axle0N9Lightweight rear axle
Rear seats3KBUnsplit rear seat bench, split folding backrest, with center armrest
Heating and air-conditioning system9ABManually controlled air conditioning system
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without individual installation
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Instrument panel4N3Comfort dashboard
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8BNotchback
Luggage compartment floor covering6SFStandard trunk floor covering
coolbox1W0Without refrigerator/glove compartment cooling system
Electronic map cooling systemQS0Without electronic map cooling system
Climatic zones0Y3Cold zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
headrest for seat, rear3Q6Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank treatment2LCFuel tank with special material treatment (coextrusion)
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Radiator grille6KCRadiator grille
License plate lightingKL0Standard license plate lighting
Rear license plate bracket6P2License plate bracket, rear (NAR)
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Steering system arrangementL0LLeft-hand drive
Reading lamp8S1Reading light in front
steering1N1Power steering
Backrest release3H0Without backrest release for front seats
Light control systems8G0Without Light Assist
Lumbar support7P5Manually adjustable lumbar support for left front seat
steering wheels2ZMLeather-wrapped multi-function steering wheel
Speaker installation8RUSound system with subwoofer "branded"
Steering column systems2C5Steering column, adjusted axially and vertically
Headlight range control8Q0without beam length regulator
Center armrest6E4Center armrest in front
Multi-function display/trip computer9Q1Multi-function display/trip computer
Engine cooling8Z6Hot country
Engine specificationsD775-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
Market-specific vehicle versionAW0Version (low)
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4TQVanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
Navigation device7T8Navigation system "RNS315" NAR
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WDIntegrated front fog light
Rear of platform module base4P1Rear floor panel module, type 2
Platform group class7PAPlatform group class 1
Panic switchKP3With additional switch
Hubcaps1NLTrims for alloy wheels
WheelsCK5Alloy wheels 7J x 17
Radios8AYRadio navigation system
Smoker's/non-smoker's package9JFNon-smoking package (NAR)
Tire pressure monitoring system7K6Tire pressure monitoring system
tireH7KAll-season tires 225/45 R17 91H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G4Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
PL4SEL+ package
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SCLabels in English
Tail lamp assemblies8SARear combination lamp, standard design
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Nameplates for sales nameQD3Nameplates for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN2QSeat trim covers in leatherette
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Side lights7R7Side marker lights plus exterior mirror turn signals
Start-stop system/regenerative braking7L3Without start/stop system without regenerative braking
Horns8Y0Single-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
power outlet7B512-volt outlet(s)
Bumper2JGbumper in color of vehicle
Rear stabilizer0BGRear stabilizer
Front stabilizer bar0AGFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Nameplate set0QPNameplate set "SEL"
Door storage compartments in front3YQDoor pockets without insert mats
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4F6Central locking system "Keyless Entry" without deadlock (NAR)
Type approval countries/countries with special requirementsBU1Legal requirements for USA 1 States without CARB requirement
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Door and side trim panels3LJDoor and side trim panel in foam film, insert in leatherette
doors0A24 doors
TV reception/digital radio receptionQU4Satellite radio reception NAR integrated in device
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Telephone / telematics9ZSPreparation for UHV-internal telephone with voice control
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W0without washer water level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZGChrome-plated decorative trims
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Zündanlaß/Schloß-Sperrsystem/ Elektrische Lenksäulenverriegelung0RBIgnition/starter switch locking system
Auxiliary heating system9M0Without auxiliary heater/parking heater
Bloughautomotive
C?ID=122717
3VWLZ7AJ2BM307556 is the vin to the car. I apologize that I did not clarify that previous to my employment a lot of changes were done to the car. From what I have been told the car had an electrical issue that caused ecm failure. We are close to having ODIS and the equipment needed so this type of repair will not happen. The cluster, ignition,ecm and entire column electronics was taken out of a parts car owned by the company to repair this vehicle. I am the lucky one to finish the project as the tech that started the repair no longer works at the shop. Again sorry for the lack of known car history.
The coding that you provided was accepted. The only issue I am having is basic settings for the Lateral Acceleration Sensor (G200) sensor. It comes up with error. The traction control light and the tpms light is on. The key is also never found unless put up to the column
The part number of the abs module in the car is 1K0 614 517 CK
I greatly appreciate the information you provided on the long coding portion. I am able to provide many auto scans to add to you data base if you would like more information.
Here is the current auto scan.
Wednesday,23,October,2019,15:39:00:59206
VIN: 3VWLX7AJ0CM463862   Mileage: 174980km-108727miles
   Coding: 0000075
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 000 -
                    Mileage: 174981 km
                    Date: 2014.03.15
                    Time: 03:37:27
                    Temperature: 71.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 980.0 mbar
Readiness: 1110 0101
   Coding: 0000840
   Revision: 00H30001
   Coding: B14B400C492808FD8D1302EA921B1061A71000
   Shop #: WSC 00066 123 12345
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 16390
                    Count: 48640
                    Count: 256
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 212
                    Count: 48640
                    Count: 256
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 270
                    Count: 48640
                    Count: 256
03197 - Stopping Distance Reduction 2 in ADR Control Module (J428)
                    Reset counter: 46
                    Mileage: 174977 km
                    Date: 2014.03.15
                    Time: 02:10:55
                    Count: 3
                    Count: 32780
                    Count: 12800
                    Count: 8244
                    Count: 48640
                    Count: 256
   Coding: 030C0C
          B2010 00 [009] - -
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:26:46
00532 - Supply Voltage B+
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:26:46
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
6 Faults Found:
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 00:04:10
            006 - Short to Plus
                    Fault Frequency: 42
                    Reset counter: 46
                    Mileage: 174971 km
                    Date: 2014.03.07
                    Time: 03:33:01
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:31:02
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:30:03
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 86
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 86
   Coding: 00003232
   Coding: 30314A
13635840 - Supply voltage
          [Powersupply  lower threshold fall short of]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:09:17
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:32:37
   Coding: 270A01
          [Supply voltage too low]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:28:26
   Coding: 102200
   Coding: 000007
9456681 - Key
                    Fault Frequency: 11
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 04:11:56
          [Under voltage (continued)]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:09:40
                    ELV State: 0C
                    Information Clamps: 77 60
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Vehicle speed: 0.00 km/h
                    Voltage: 49
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:08:37
                    ELV State: 0C
                    CoCo State: B0 01
                    WFS State: 67 1A
                    Voltage: 4B
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          [CAN-Bus off]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:58:38
                    ELV State: 2C
                    CoCo State: F0 01
                    WFS State: 00 1A
                    Vehicle speed: 655.35 km/h
                    Voltage: 2E
   Coding: 020000
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:08:37
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2014.03.15
                    Time: 19:27:55
6 Faults Found:
1048578 - Supply voltage
          [supply voltage lower limit exceeded]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:24:30
1048580 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [restriction due to undervoltage]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:08:40
          B1061 13 [008] - Open Circuit
                    Reset counter: 86
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
          B1064 13 [008] - Open Circuit
                    Reset counter: 86
                    Mileage: 174976 km
                    Date: 2019.10.17
                    Time: 15:53:15
                    Fault Frequency: 30
                    Reset counter: 46
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:17
                    Reset counter: 41
                    Mileage: 174971 km
                    Date: 2019.10.15
                    Time: 03:33:16
   ROD: UHVNA.rod
9457425 - Left audio channel for speech/telephone
          B104F 11 [000] - Short to GND
9457169 - Right audio channel for speech/telephone
          B104E 11 [000] - Short to GND
          [Klemme 30: unterer Grenzwert unterschritten]
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:27:02
          U1400 00 [008] - -
                    Reset counter: 85
                    Mileage: 174976 km
                    Date: 2019.10.23
                    Time: 19:08:48
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Bloughautomotive
C?ID=122717
Update I was able to do the basic setting for the Lateral Acceleration Sensor (G200). Will post completed auto scan tmr. Thanks for your help Dana!
Bloughautomotive
C?ID=122717
Well long story short this peach of a car has had its ups and downs since the last post. The car again has had all IMMO parts replaced...again and to save the time I will not give the long story as to why it had to happen. So unfortunately I am in need of the long coding for the ABS. Thank you for the continued support and as I planned I will upload the the final scan when completed.
Wednesday,06,November,2019,09:48:56:59206
VIN: 3VWLP7AJ7CM397441   License Plate:
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 47 56 77
VIN: 3VWLP7AJ7CM397441   Mileage: 114510km-71153miles
77-Telephone -- Status: Not registered 0001
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CJ    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 3691
   Coding: 0000075
   VCID: 78BCF36B0B340D8F9F-802C
               P1643 - 000 -
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:32:60
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.684 V
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 000 - Short to Ground
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:33:01
                    Temperature: 18.0°C
                    Temperature: 15.0°C
                    Voltage: 11.684 V
Readiness: 1110 1101
   Component: AQ 250 6F           1914
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Revision: 00H30001
                    Reset counter: 36
                    Date: 2014.03.29
                    Time: 00:36:42
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 40704
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Revision: 00085000    Serial number: 0160216723
   Coding: 030C0C
   VCID: 3424075B9FDC29EF73-8060
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371086120476
   Coding: 7B994B9A08AB0B0008382000240884C500C2502E6000000030A000000000
   VCID: 2F2E08377EFA0A370E-807A
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:44
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:47
   Coding: 00003232
   Coding: 30314A
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:45
   Coding: 270A01
   Shop #: WSC 00066 000 00123
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:42
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2014.03.29
                    Time: 00:36:47
   Coding: 000007
   Revision: 00000000    Serial number: 11000264319002
   Coding: 020000
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:43
1048662 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [CAN TO sound booster]
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:48
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:42
Address 47: Sound System
   ROD: UHVNA.rod
End----(Elapsed Time: 01:36, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
PetrolDave
Westbury, UK
C?ID=1423
Will the ABS not accept the coding suggested by Dana in post #2 of this thread which worked last time?
Bloughautomotive
C?ID=122717
The coding he made in his last post did work but that was for the first swapped IMMO parts. I may not have made it clear in the last post but the car has had the IMMO swapped twice now. The coding he created was for the first IMMO swapped parts. Long story short they have been changed a second time thus the long coding he created is not accepted. If you look at the auto scans the vin have changed.
Dana
Western PA, USA
3VWLZ7AJ2BM307556
We're running a 2-tech support team this morning but I can take a crack at that coding at some point. Just to be clear, this is the VIN to the actual vehicle correct?
3VWLZ7AJ2BM307556
Vehicle Identification No.3VWLZ7AJ2BM307556
ModelJetta JEM
Date of production16.08.2010
Model year2011
Sales type162XS3
Engine CodeCBUA
Transmission CodeMAN
Emission standard0GTEmission standard SULEV
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Brake type in rear1KSDisc brakes in rear (Geomet D)
Chrome packageQJ1Chrome package
General operating permit, alterationsC00Operating permit, initial registration
Suspension system in rear1JCRear shock absorption for sports version
Inserts5MJDecorative inserts
Scuff plates7M4Scuff plates in door apertures
Manufacturing sequence differentiation0FAStandard manufacturing sequence
Pedal clusterVF1pedal cluster
Weight category front axleL55Suspension range 55 installation control only, no requirement forecast
Instrument panel4N0Standard dashboard (Leather trimmed minor gauges + Ipod drawer)
Climatic zones0Y2Tropical zones
Fuel tank treatment2LFFuel tank with special material treatment (coextrusion) with changed protective layer
Paint preservative/transit coating5K4Full body cover (shape-adapted system) with additional transport protection measures
Speaker installation8RL6 speakers (passive)
WheelsCC3Alloy wheels 7J x 17
PL3 SEL 3 package
PMCCalifornia emission
Nameplates for sales nameQD3Lettering for sales name
Control number (no PR family)S0CIntroductory volume
Heavy-duty/sports version2UCSports version
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Type approval countries/countries with special requirementsB38Legal requirements California
doors0A24 doors
Telephone / telematics9W7Mobile phone interface (NAR)
Edit; Based on the VIN of 3VWLZ7AJ2BM307556, Part No SW: 1K0 907 379 BC is correct for the car. I believe the factory condition ABS coding was:
B14B400C492208018D1002E9921F1061A70000
Since the Diagnostic VIN is incorrect that won't be accepted. If I flip the VIN Bytes to match the wrong VIN (3VWLP7AJ7CM397441) I end up with:
B14B400C492B08018D0F02E8921A1061A70000
Nerd notes. This is my base (no VIN) coding based on PR-Codes for 3VWLZ7AJ2BM307556:
B1004000490008008D00020092001061A70000
Bloughautomotive
C?ID=122717
The coding was accepted. Again greatly appreciate the support! Here is an upload of the current auto scan.
Monday,11,November,2019,14:39:19:59206
   Coding: 0000075
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:44
                    Temperature: 69.0°C
                    Temperature: 16.0°C
                    Voltage: 11.811 V
   Coding: 0000840
   Revision: 00H30001
   Coding: B14B400C492B08018D0F02E8921A1061A70000
   Coding: 030C0C
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 13 [008] - Open Circuit
                    Reset counter: 76
1057035 - Antenna for Keyless Entry System; Drivers Side
          B116F 13 [009] - Open Circuit
                    Reset counter: 36
                    Mileage: 114514 km
                    Date: 2019.11.11
                    Time: 05:21:12
   Coding: 820000
   Coding: 820000
   Coding: 180000
   Coding: 020000
   Coding: 800000
   Coding: 800000
            006 - Short to Plus
                    Reset counter: 36
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:11
   Coding: 00003232
   Coding: 30314A
   Coding: 270A01
   Revision: B2066001
   Coding: 102200
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:32
                    Reset counter: 36
                    Mileage: 114514 km
                    Date: 2014.04.03
                    Time: 05:28:37
   Coding: 000007
   Coding: 020000
                    Fault Frequency: 10
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:43
          U1111 00 [009] - -
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:48
                    Reset counter: 36
                    Mileage: 114513 km
                    Date: 2019.11.06
                    Time: 00:36:42
   ROD: UHVNA.rod
End----(Elapsed Time: 01:42, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
