- Joined
- Mar 13, 2018
- Messages
- 22
- Reaction score
- 6
- Location
- Norway
- VCDS Serial number
- C?ID=288196 (NRRT)
Hi, can someone help?
Tuesday,22,October,2019,11:09:48:58635
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ9W555024 License Plate: SU74419
Mileage: 87870km-54599mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W555024 Mileage: 87870km-54599miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 A HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9978
Revision: --H23--- Serial number: 00000000000000
Coding: 00114016030400080000
ASAM Dataset: EV_ECM16TDI02103L906023A 003013
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 2404EF182F3EF46FE3-8070
6395 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [101] - Pump Current Open Circuit
Mileage: 87663 km
Date: 2019.09.07
Time: 16:37:31
Engine speed: 2270.75 /min
Normed load value: 28.2 %
Vehicle speed: 62 km/h
Coolant temperature: 92 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.005 V
Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]: 108
Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor): 0.502 Lambda / 0.000 V
Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1]: 1.00815
Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]: 975.0000 °C
Time too low oxygen sensor voltage-T_VLS_UP_MIN_DIAG_OC_LSL_UP[1]: 0.0 s
Oxygen value calculated-LAMB_EXT_CLC_FIL: 2.4277
Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP: 1105.71 hPa
14355 - Exhaust Gas Temperature Sensor; B1 S3
P242A 00 [175] - Malfunction
Fault Frequency: 13
Mileage: 87587 km
Date: 2019.09.06
Time: 15:11:42
Coolant temperature: 63 °C
Intake air temperature: 26 °C
Voltage terminal 30: 11.746 V
Readiness: 1 1 0 0 0
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B200D092700FF880B04E6901D00403000
Shop #: WSC 30333 002 1048576
VCID: 76A0E550C12236FF8D-8022
Part No SW: 5K0 907 044 AK HW: 5K0 907 044 AK
Component: Climatronic 130 0305
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: 74A4DF58DF5E24EFB3-8020
B10AB F0 [009] - Too Low
Reset counter: 55
Mileage: 72803 km
Date: 2017.10.03
Time: 10:39:20
Part No SW: 1K0 937 084 HW: 1K0 937 084
Component: BCM PQ35 B 020 0358
Revision: 00020000
Coding: 40180A3A90251AC040000080500000E445010088724D8D60648000000000
VCID: 6B96C4248A60FB1762-803E
Component: Wischer 07040 21 0501
Coding: 009795
01598 - Drive Battery Voltage
Reset counter: 86
Mileage: 87587 km
Date: 2014.01.27
Time: 15:08:21
Voltage: 13.80 V
Term 50 Off
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 033 0604
Serial number: 003C2R56633O
Coding: 00003139
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77BEE854CE284FF796-8022
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 222B3647ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 59661147ZZZZZZZZZZZZ
Serial number: 22182909ZZZZZZZZZZZZ
Serial number: 2022223FZZZZZZZZZZZZ
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000004
VCID: 03468C8442F01357BA-8056
Part No SW: 5K0 920 860 E HW: 5K0 920 860 E
Component: KOMBI H21 0030
Coding: 170F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: 2E100D3071F24E3F05-807A
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 010409F2000014
Coding: E9807F06000202000002
VCID: 373E285446A88FF756-8062
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0030
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
Part No SW: 1K0 959 701 AM HW: 1K0 959 701 AM
Component: Tuer-SG 008 2041
Coding: 0000180
VCID: 79BAEE6C303C5987E0-802C
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 69 2501
Revision: 00H15000
VCID: 2C1407388FEE3C2F2B-8078
Part No SW: 1K0 959 702 AM HW: 1K0 959 702 AM
Coding: 0000180
VCID: 7AB8F160353A529FE9-802E
Part No SW: 1K0 035 186 AB HW: 1K0 035 186 AB
Component: Radio RCD310 013 0036
Revision: 00000000 Serial number: VWZ1Z2I6490037
Coding: 0500040004
VCID: 6680B5109182C67F3D-8032
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BB6F4643A006B97F2-802E
End----------(Elapsed Time: 00:58, VBatt start/end: 13.9V/14.2V)-----------
