Results 1 to 5 of 5
Thread: 2016 Audi SQ5 Plus Retro fit towbar dedicated electrics coding HELP!
    Aug 2014
    uk
    Hi
    Have fitted a westfalia detachable towbar with 7pin dedicated electrics, the instructions ask the coding to be done via software version managment SVM on ODIS using code 050205. I have tried this with a local agent but wont ecept the code for some reason .
    Now using VCDS have manged to code the required control units except Adaptive cruise, when trying to do this there is no longcoding helper. can anyone help in giving me the correct code to sort this please.
    I understand that not doing it on ODIS wont update the dealer portal but our customer just wants his car back and working.
    Tuesday,22,October,2019,09:58:41:52053
    Dealer/Shop Name: Wagenworx LTD
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 36 3C 42 44 46 47
              52 53 56 5F 62 69 6D 72 A9 AC C0
    VIN: WAUZZZ8R2GA100655   Mileage: 61600km-38276miles
    Address 01: Engine (J623-DEHA)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
       Component: 3.0BTD EDC17  H23 0008
       Revision: 54H23---
       Coding: 2A2A4032257603030000
       Shop #: WSC 07475 003 104857
       ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
       ROD: EV_ECM30BTD0118K5907589C.rod
       VCID: C1CA180350421F4768-8094
    4330 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 61600 km
                        Date: 2019.10.21
                        Time: 17:43:11
                        Coolant temperature: 91 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 12.000 V
                        ACC target acceleration: 0.007 m/s²
                        ACC control module received status-Bits 0-7: 7
                        Active brake system error status-Bits 0-7: 1
                        Status of ACC/CCS acceleration interface-Bits 0-7: 4
                        Acceleration: 0.000 m/s²
                        Engine status: COENG_READY
       Part No SW: 8R0 927 158 BC    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H19 1006
       Revision: --H19---
       Coding: 000001
       VCID: FF4E5EFB6636A9B75E-80AA
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
       Component: ESP8 quattro  H09 0020
       Coding: 38EDCE01
       Shop #: WSC 06335 000 00000
       VCID: 8542CC130CEAF36714-80D0
       Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
       Component: BCM2 2.0      H15 0711
       Coding: 05B54040000000000000
       VCID: 804CDD0713C8D64F27-80D4
       Subsystem 1 - Part No SW: 8K0 959 754 BR    HW: 8K0 959 754 BR
       Serial number: 0816000008761015
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 3215000208250008
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: D1000000    Serial number: 01250120161788
       Coding: 3625028080
       VCID: F8BCB5E74B189E8F1F-80AC
       Revision: 08016001    Serial number: 00001265087702
       Coding: 260000108074AFF2318140C300001D0D0F9DE70827090201000008004400030100000024000000
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 160109  H13 0050
       Serial number: 90243015151109164301
       Coding: 01DD13
       Serial number: 61239233
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001301160374
       Serial number: A1B8CD08000000000001
    Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
       Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
       Component: ACC3          H11 0110
       Coding: 008172
       VCID: B73E76DB068651F7D6-80E2
                        Reset counter: 47
                        Mileage: 61600 km
                        Date: 2019.10.21
                        Time: 17:35:52
                        Temperature: 26.0°C
                        Voltage: 13.06 V
                        Hex Value: 0x005D
                        Lateral Accel.: 0.00 m/s^2
                        Fault Status: 00101101
                        Reset counter: 87
                        Mileage: 61600 km
                        Date: 2019.10.21
                        Time: 17:35:52
                        Temperature: 26.0°C
                        Voltage: 12.93 V
                        Hex Value: 0x00BE
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H49 0610
       Serial number: 003JPDD1EV8+
       Coding: 304A3531313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: C8DC052773782E0FAF-809C
       Serial number: 6334MSME563A4859N
       Serial number: 6344MSME565A4E46S
       Serial number: 6352QSME0E5A256EX
       Serial number: 6362QSME676E3E60Y
       Serial number: 63732SME48510E682
       Serial number: 63832SME45515760X
       Revision: --------    Serial number: 90372PAH000QS
       Coding: 00003F
       VCID: C4C4111747500A6F43-8090
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 951     HW: 8R0 920 951
       Component: KOMBIINSTR.   H35 0567
       Revision: 00200000    Serial number: 03I24JL1H
       Coding: 33A72200A7012600010000
       VCID: F4A481D75770FAEF33-80A0
       Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
       Component: GW-BEM 5CAN-M H11 0070
       Revision: 1Z130032    Serial number: 3241Z161120D45
       Coding: 80CD07FF00
       VCID: FEB0A3FF693CA0BF55-80AA
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 2153078903
       Serial number: 16019004182021200410
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0C0100
       VCID: BA386FEF35944C9F29-80EE
       Revision: AA001002
       Coding: 02022064747464545425363E00
       VCID: FCB4A9F77F20B2AF7B-80A8
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H15 0100
       Serial number: 001301160001019
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: AF2E4EBBF6D699378E-80FA
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0077
       Revision: AA000000    Serial number: 00000180787195
       Coding: 01781B00000000000000
       VCID: C2C8170F5D44045F71-8096
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H07 0071
       Serial number: 0390383126
       Coding: 010312
       Shop #: WSC 06334 000 00000
       VCID: BFCE1EFB26B669B71E-80EA
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H07 0071
       Serial number: 0391820025
       Coding: 010312
       Component: TSG FA        H02 0511
       Revision:             Serial number: 0000182312039
       Coding: 011D12215E01440004
       VCID: CFEE2E3B9E16F937EE-809A
       Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
       Component: RCevo         H53 0702
       Revision: 00000003    Serial number: 0000399876
       Coding: 010000010001
       ASAM Dataset: EV_RCEPSAU48X 104002
       ROD: EV_RCEPSAU48X_104.rod
       VCID: C6C00B1F796C387F5D-8092
       Revision: 00002001    Serial number: 0391591921
       Coding: 013B0E22A0B9309587200536A0040047
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H04 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H04 0090
       Revision: 00005001    Serial number: 94813054879807
       VCID: AD1254B3F4DAEB27BC-80F8
       Revision:             Serial number: 0000183417637
       VCID: CED0333F991CF03FE5-809A
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H03 0005
       Revision: --------    Serial number: 20000000725209
       ROD: EV_ParkiBrake_AU48.rod
       VCID: BA386FEF3D944C9F29-80EE
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109AY0G2527159
       Coding: 010103010000000001
       VCID: AB165AABCACEE517A2-80FE
       Part No SW: 8R2 035 666 K    HW: 8R2 035 666 H
       Component: H-BN-EU       H49 0946
       Revision: --------    Serial number: 515A10GS006321
       Coding: 1A0101060205A9ED75808B5E00000403E40100020000000000
       VCID: C1CA180358421F4768-8094
       Subsystem 1 - Part No: 8R0 060 884 DF
       Component: EUR 2016  2204
       Component: DU7 High  H42 0104
       Serial number: A130AI0G3519201
       Serial number: 00000002453524
       Component: CD-Database  6890
       Component: TSG HL        H02 0510
       Revision:             Serial number: 0000183451368
       Coding: 010C12204001240004
       VCID: C6C00B1F716C387F5D-8092
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
       Component: ConWys Trailer H09 0100
       Revision: 1G001001    Serial number: 00000173782896
       Coding: 0100000000000000
       Shop #: WSC 00375 223 87350
       VCID: B5227CD31C8AA3E7C4-80E0
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H56 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: BD3264F324BA7BA70C-80E8
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H56 0330
       Serial number: 8R0827852D
       Component: TSG HR        H02 0510
       Revision:             Serial number: 0000183451367
       Part No SW: 8R0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0007
       Serial number: 151214201745
       VCID: F9BAB0E37812878760-80AC
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 153290418
       ROD: EV_RDCMA00100_008.rod
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H10 0008
       Serial number: 151026200628
       VCID: B22847CFE5E4B4DFE1-80E6
    End----------(Elapsed Time: 02:21, VBatt start/end: 14.7V/14.5V)-----------
    Current Coding: 008172
    Try: 00816B
  3. Likes wagenworx liked this post
    Aug 2014
    uk
    You my friend are a legend! it worked... thanks
  5. Likes Uwe liked this post
  6. #4
    Mar 2016
    Try: 00816B
    What exactly did that change Uwe?
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dynamic Pack | Matrix Lights | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | N-Vision | BOSE | DVD Changer | Homelink | Soft Door Close | Heat+Sound Ins Glass | Priv Glass | Heated Windscreen | Heated Steer Wheel | Adv Key | Elec Boot Cover | Side Assist | Air Suspension | Ambient Lighting | Heated+Fold Mirrors | Park Assist Pack | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap
    Quote Originally Posted by andyhud View Post
    Trailer Hitch not installed to Trailer Hitch Installed.
    This module uses a wonky coding scheme. It's technically a "long" coding and thus displayed in hexadecimal, but in order to interpret it, you must convert to decimal first, and then it makes sense. Change the last digit from 8 to 1, convert back to hexadecimal and put it in.
  8. Likes andyhud, wagenworx liked this post
