2016 Audi SQ5 Plus Retro fit towbar dedicated electrics coding HELP!
wagenworx
uk
C?ID=89172
Hi
Have fitted a westfalia detachable towbar with 7pin dedicated electrics, the instructions ask the coding to be done via software version managment SVM on ODIS using code 050205. I have tried this with a local agent but wont ecept the code for some reason :banghead:.
Now using VCDS have manged to code the required control units except Adaptive cruise, when trying to do this there is no longcoding helper. can anyone help in giving me the correct code to sort this please.
I understand that not doing it on ODIS wont update the dealer portal but our customer just wants his car back and working.
Tuesday,22,October,2019,09:58:41:52053
Dealer/Shop Name: Wagenworx LTD
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 36 3C 42 44 46 47
          52 53 56 5F 62 69 6D 72 A9 AC C0
VIN: WAUZZZ8R2GA100655   Mileage: 61600km-38276miles
Address 01: Engine (J623-DEHA)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
   Component: 3.0BTD EDC17  H23 0008
   Revision: 54H23---
   Coding: 2A2A4032257603030000
   Shop #: WSC 07475 003 104857
   ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
   ROD: EV_ECM30BTD0118K5907589C.rod
   VCID: C1CA180350421F4768-8094
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 61600 km
                    Date: 2019.10.21
                    Time: 17:43:11
                    Coolant temperature: 91 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.000 V
                    ACC target acceleration: 0.007 m/s²
                    ACC control module received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
   Part No SW: 8R0 927 158 BC    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1006
   Revision: --H19---
   VCID: FF4E5EFB6636A9B75E-80AA
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
   Coding: 38EDCE01
   Shop #: WSC 06335 000 00000
   VCID: 8542CC130CEAF36714-80D0
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05B54040000000000000
   VCID: 804CDD0713C8D64F27-80D4
   Subsystem 1 - Part No SW: 8K0 959 754 BR    HW: 8K0 959 754 BR
   Serial number: 0816000008761015
   Serial number: 3215000208250008
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01250120161788
   Coding: 3625028080
   VCID: F8BCB5E74B189E8F1F-80AC
   Revision: 08016001    Serial number: 00001265087702
   Coding: 260000108074AFF2318140C300001D0D0F9DE70827090201000008004400030100000024000000
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 160109  H13 0050
   Serial number: 90243015151109164301
   Coding: 01DD13
   Serial number: 61239233
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001301160374
   Serial number: A1B8CD08000000000001
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0110
   Coding: 008172
   VCID: B73E76DB068651F7D6-80E2
                    Reset counter: 47
                    Mileage: 61600 km
                    Date: 2019.10.21
                    Time: 17:35:52
                    Temperature: 26.0°C
                    Voltage: 13.06 V
                    Hex Value: 0x005D
                    Lateral Accel.: 0.00 m/s^2
                    Fault Status: 00101101
                    Reset counter: 87
                    Mileage: 61600 km
                    Date: 2019.10.21
                    Time: 17:35:52
                    Temperature: 26.0°C
                    Voltage: 12.93 V
                    Hex Value: 0x00BE
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003JPDD1EV8+
   Coding: 304A3531313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: C8DC052773782E0FAF-809C
   Serial number: 6334MSME563A4859N
   Serial number: 6344MSME565A4E46S
   Serial number: 6352QSME0E5A256EX
   Serial number: 6362QSME676E3E60Y
   Serial number: 63732SME48510E682
   Serial number: 63832SME45515760X
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372PAH000QS
   Coding: 00003F
   VCID: C4C4111747500A6F43-8090
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 951     HW: 8R0 920 951
   Component: KOMBIINSTR.   H35 0567
   Revision: 00200000    Serial number: 03I24JL1H
   Coding: 33A72200A7012600010000
   VCID: F4A481D75770FAEF33-80A0
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z161120D45
   Coding: 80CD07FF00
   VCID: FEB0A3FF693CA0BF55-80AA
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 2153078903
   Serial number: 16019004182021200410
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Coding: 0C0100
   VCID: BA386FEF35944C9F29-80EE
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: FCB4A9F77F20B2AF7B-80A8
   Component: 4 Wheel Drive H15 0100
   Serial number: 001301160001019
   VCID: AF2E4EBBF6D699378E-80FA
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000180787195
   Coding: 01781B00000000000000
   VCID: C2C8170F5D44045F71-8096
   Component: SWA Master    H07 0071
   Serial number: 0390383126
   Coding: 010312
   Shop #: WSC 06334 000 00000
   VCID: BFCE1EFB26B669B71E-80EA
   Component: SWA Slave  H07 0071
   Serial number: 0391820025
   Coding: 010312
   Component: TSG FA        H02 0511
   Revision:             Serial number: 0000182312039
   Coding: 011D12215E01440004
   VCID: CFEE2E3B9E16F937EE-809A
   Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
   Component: RCevo         H53 0702
   Revision: 00000003    Serial number: 0000399876
   Coding: 010000010001
   ASAM Dataset: EV_RCEPSAU48X 104002
   ROD: EV_RCEPSAU48X_104.rod
   VCID: C6C00B1F796C387F5D-8092
   Revision: 00002001    Serial number: 0391591921
   Coding: 013B0E22A0B9309587200536A0040047
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Revision: 00005001    Serial number: 94813054879807
   VCID: AD1254B3F4DAEB27BC-80F8
   Revision:             Serial number: 0000183417637
   VCID: CED0333F991CF03FE5-809A
   Component: EPB-4         H03 0005
   Revision: --------    Serial number: 20000000725209
   ROD: EV_ParkiBrake_AU48.rod
   VCID: BA386FEF3D944C9F29-80EE
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109AY0G2527159
   Coding: 010103010000000001
   VCID: AB165AABCACEE517A2-80FE
   Part No SW: 8R2 035 666 K    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 0946
   Revision: --------    Serial number: 515A10GS006321
   Coding: 1A0101060205A9ED75808B5E00000403E40100020000000000
   VCID: C1CA180358421F4768-8094
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H42 0104
   Serial number: A130AI0G3519201
   Serial number: 00000002453524
   Component: CD-Database  6890
   Component: TSG HL        H02 0510
   Revision:             Serial number: 0000183451368
   Coding: 010C12204001240004
   VCID: C6C00B1F716C387F5D-8092
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Component: ConWys Trailer H09 0100
   Revision: 1G001001    Serial number: 00000173782896
   Coding: 0100000000000000
   Shop #: WSC 00375 223 87350
   VCID: B5227CD31C8AA3E7C4-80E0
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: BD3264F324BA7BA70C-80E8
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H02 0510
   Revision:             Serial number: 0000183451367
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 151214201745
   VCID: F9BAB0E37812878760-80AC
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 153290418
   ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H10 0008
   Serial number: 151026200628
   VCID: B22847CFE5E4B4DFE1-80E6
End----------(Elapsed Time: 02:21, VBatt start/end: 14.7V/14.5V)-----------
Current Coding: 008172
Try: 00816B
wagenworx
uk
C?ID=89172
You my friend are a legend! it worked... thanks
andyhud
C?ID=32695
What exactly did that change Uwe?
Trailer Hitch not installed to Trailer Hitch Installed.
This module uses a wonky coding scheme. It's technically a "long" coding and thus displayed in hexadecimal, but in order to interpret it, you must convert to decimal first, and then it makes sense. Change the last digit from 8 to 1, convert back to hexadecimal and put it in.
