Results 1 to 7 of 7
Thread: VW Passat B8 R-line easy open retrofit
    Jan 2017
    Estonia
    I am trying to retrofit Easy Open to a MY2016 VW Passat but unable to clear this final error code:
       Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0906
       Revision: 00036000    Serial number: 0426620270
       Coding: 0F2000070F
       Shop #: WSC 05311 115 00302
       VCID: 3E26345B80F9AE77F85-806A
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11514115
    221445 - Sensor for Rear Lid/Hatch Opening
              B1303 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 38
                        Mileage: 79126 km
                        Date: 2019.10.08
                        Time: 17:06:08
                        ZAT_pressed: OFF
                        Control Module Voltage: 11.722 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Coding information: coded
                        Driver door: Open
                        Front Passenger Door: Open
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    I have followed this thread with the exception of setting all 05 adaption channels equal to similar Passat that has factory Easy open installed.
    https://forums.ross-tech.com/showthr...-Open-Retrofit
    Output test does not clear this error no matter how long I try running it.
    • We have tried using ODIS to clear this error and come to the conclusion that there is no certain process involved but some combination of adaption channels should clear it.
    • Also tried installing parameters from a car that has factory easy open with no success.
    • Tried moving the 05 module to an Arteon that has factory easy open and using ODIS to match it. Worked instantly without any errors.
    Full autoscan (before easy open retrofit and updated 05 to G software after completing this autoscan):
    Tuesday,01,October,2019,19:11:15:57784
    VCDS Version: 19.6.1.0 (x64)  HEX-V2 CB: 0.4513.4
    Dealer/Shop Name: LeVWFreaks.eu
    VIN: WVWZZZ3CZHE******   License Plate:
    Mileage: 78986km-49079mi   Repair Order:
    Chassis Type: 3C-VW48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
              47 4B 52 5F 69 6C 6D 82 A5 BB BC CF D6 D7
    VIN: WVWZZZ3CZ******   Mileage: 78986km-49079miles
    CF-Lane Chge Asst 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D003A2476050B3004
       ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
       ROD: EV_ECM20TFS0203G0906259B_VW48.rod
       VCID: 2B000D0F638B2BDF4FB-807E
    Readiness: 1110 0001
       Part No SW: 0D9 300 014 Q    HW: 02E 927 770 AS
       Component: DQ250-6A MQB  H54 5007
       Revision: 06454104    Serial number: TFK01611050429
       Shop #: WSC 05311 115 00065
       ROD: EV_TCMDQ250021.rod
       VCID: 2616FC3B786916B7905-8072
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 63636000002038
       Coding: 0FEC6B8F542323704780070840CB69F0D62AC4E2E0029675B84250F8CAA9420000000012121212B835351919323200
       Shop #: WSC 00015 115 08193
       ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
       VCID: 79ACE747D957494F8D7-802C
    0297 - Steering Angle Sensor
              B1168 F2 [137] - Not Initialized
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:56
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Coding: 0F2000070F
       VCID: 3C223E5396E5BC67D61-8068
       Part No SW: 5G0 907 044 CK    HW: 5G0 907 044 CK
       Revision: 00001K10
       Coding: 1202000420441101111550020010182A
       VCID: 72BED06B84213A17CCD-8026
       Geber før K‰ltemitteldruck/K‰ltemitteltemperatur:
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0223
       Revision: --------    Serial number: 865811121600JP
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015C8FA7B187118FC57-8054
       Component: WWS    161115  042 0607
       Serial number:         161206065041
       Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: USER\5Q0-955-547.LBL
       Component: RLHS  042 0105
       Serial number: S5Y16M12D08H04M42S03
       Coding: 00A8EE
       Light switch:
       Subsystem 3 - Part No SW: 3G0 941 633 R    HW: 3G0 941 633 R
       Serial number: 29 06 2016  10000340
       Serial number: 000000000ZY1632338M4
       Part No SW: 5QA 919 298 B    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0038
       Serial number: 000308417616344
       Coding: 0A71267151
       ASAM Dataset: EV_EPHVA2CAU3700000 009032
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 4FF8799F375337FF033-801A
    13637426 - Databus
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
    13679386 - Databus
              [Steuerger‰t før Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Component: ACC BOSCH MQB H04 0195
       Coding: 320467DB5DFFC728949C8045
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 35342B77B5CF6D2F29F-8060
    2055 - Databus
              U1122 00 [009] - Implausible Message
              [FAULT_ALP_STEERINGWHEEL_INIT]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
                        Control Module temperature: 20 ∞C
                        Voltage terminal 15: 11.7 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
                        Status_ACC_System: ACC_irreversible error
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
    0800 - Databus
              [FAULT_SWA_RELEVANT_ERROR]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
       Serial number: 18111641350816
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 382A2243A2DD9047329-806C
       Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
       Component: Airbag VW21   004 0306
       Revision: --------    Serial number: 003RAPQ4UYM9
       Coding: 88CCC000008000005C5400CF000800000065
       Shop #: WSC 05314 000 00001
       ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0C42AE9386C54CE7A61-8058
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G1857705G0347Q01290
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G1857706G0341Q00647
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 454 000 812 16
       Serial number: 357000000004274DC02G
       Subsystem 4 - Part No SW: -----------    HW: 454 000 812 16
       Serial number: 358000000005041DC02A
       Subsystem 5 - Part No SW: -----------    HW: 454 800 212 16
       Serial number: 35100A0EEBC0D000000/
       Subsystem 6 - Part No SW: -----------    HW: 454 800 512 16
       Serial number: 352003267CD0D000000N
       Subsystem 7 - Part No SW: -----------    HW: 454 802 311 16
       Serial number: 35500460F6A0D000000O
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:23:28
       Part No SW: 3Q0 953 521 DM    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20161219301282
       Coding: 0C10
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 7EA6F45BC0796E77B85-802A
       Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
       Component: KOMBI         405 2170
       Coding: 07A40818FF8C000801886B2B3001000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 280AF203727D00C7A29-807C
       Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
       Component: STH-MQB       008 0075
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3B203D4F93EBBB5FDFB-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000154953
       Component: GW MQB High   515 5286
       Serial number: 21121610521558
       Coding: 030300347F015900FB00025E9C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F38191F579357FF633-807A
       Serial number: 29160003422500076507
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
       Serial number: 5075702204
       Analog clock:
       Component: Analoguhr  209 2002
       Serial number: HA1-00011.11.16
       Coding: 0301
       VCID: 4ACE688BCC3112D754D-801E
       Serial number: 16000344432008
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BCDF678127010F357-8024
       Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
       Component: Sitzmemory    H05 0021
       Serial number: Y0006PLC17151
       Coding: 0010000000000500818280808080000000008181000000F400
       VCID: 3A2E384B9CD18257C4D-806E
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 C    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0310
       Revision: --------
       Coding: 14C002
       ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
    1188165 - Databus
              [databus unreasonable message - LWI_Lenkradwinkel]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:54
                        Control Module temperature: 21 ∞C
                        Voltage terminal 30: Measured value not available
                        Vehicle speed: 0.00 km/h
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 11.70 V
    267010 - Databus
              [FAULT_SLAVE]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:54
       Serial number: 071216EL522282
       Coding: 003F1A20D200028000001000
       VCID: 43D045AFEB1BC39F97B-8016
       Coding: 9307
       Shop #: WSC 00015 115 00302
       ROD: EV_SteerAssisMQB_013.rod
    16275 - Steering Angle Sensor
              B1168 F2 [009] - Not Initialized
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
                        Motor status: 00
                        Supply voltage: 11.75 V
                        Temperature: 21.0 ∞C
                        KFC: 3F
                        KFA: 00 93
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 11.75 V
                        uAdSensI_SwitchedKl30_xdu16: 11.74 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 01 80
                        RP_VALCNTSAV: activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: activated
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 465     HW: 3Q0 035 465
       Component: MIB2_amp_P_VW H60 0440
       Revision: 00000001    Serial number: VWZ8Z1GJD00D592
       Coding: 1284020001AA0A2AAA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 6B80CD0FA30BEBDF0FB-803E
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Component: FCM MQB Low   001 0285
       Serial number: 18121610801716
       Coding: 000000060100035207004F01020000000000000000000000000000000000
       Shop #: WSC 05311 000 08193
       Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo links  H02 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
       Component: Leimo rechts  H02 0003
       Coding: E02400
       Serial number: 041216EL330236
       Coding: 003F1020DE00028200001000
       VCID: 42DE40ABF401CA979CD-8016
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 043 E    HW: 3G0 035 043
       Component: MU-H-N-EU     H51 0814
       Serial number: A683L0G2514442
       Coding: 028402010000000051110002000808031F0106E4012000009F
       VCID: 1E66D4DB2039CE77D85-804A
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL0643E
       Subsystem 2 - Part No SW: V03 959 800 QS    HW: -----------
       Component: ECE 2018  --- 0166
       Component: Gracenote2---  --- 1013
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0425694147
       Coding: 0100000202000000
       Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
       Component: Areaview 2    H13 0607
       Serial number: C854707JG007570
       Coding: 01840201E30F200000204814
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: 31085168400000
       Coding: 0288
       VCID: 41DC4FA7F107D18F857-8014
       Part No SW: 3G0 919 608 A    HW: 3G0 919 608 A
       Component: HeadupDisplay 040 0207
       Coding: 574060
       ASAM Dataset: EV_HeadUpDisplContiVW481 001013
       ROD: EV_HeadUpDisplContiVW481.rod
       VCID: 2C020E1366852CE7461-8078
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| User\3Q0-980-65X-A5.lbl
       Part No SW: 3Q0 980 653 E    HW: 3Q0 980 653
       Component: MQB_B_MFK     H12 0121
       Serial number: 09121612K10469
       Coding: 00040802000004010026234FC050A100980084300040
    1135140 - Databus
              [APS_03_US_Fehler_HS]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:56
                        Control Module temperature: 22 ∞C
                        Outside air temperature: 19.0 ∞C
                        System run time: 18.3 s
                        mid: 02 65
                        Status of camera: operational
                        Engine_Running_Info: 0
                        Software_Info_4: 1
                        Software_Info_3: 2
                        Software_Info_2: 1
                        Software_Info_1: 0
    1135139 - Databus
              [APS_03_US_Fehler_VS]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:56
                        mid: 02 64
                        Software_Info_4: 1
                        Software_Info_3: 2
                        Software_Info_2: 1
                        Software_Info_1: 0
    1123173 - Databus
              [ESP_21_ESP_Systemstatus]
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:55
                        System run time: 17.6 s
                        mid: 02 E0
                        Software_Info_4: 1
                        Software_Info_3: 2
                        Software_Info_2: 1
                        Software_Info_1: 0
       Serial number: 281116EKS0323B
       Coding: 000E10200100028000001000
       VCID: 45D45BB7E52FFDAFB9F-8010
       Serial number: 281116EKS0807A
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 C    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
    1188165 - Databus
                        Reset counter: 31
                        Mileage: 78986 km
                        Date: 2019.10.01
                        Time: 00:22:54
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
       VCID: 1676CCFBC8098637005-8042
    End----(Elapsed Time: 02:48, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
    05 adaption map
    	SW:3Q0-959-435-E   HW:3Q0-959-435-E ---  Acc/Start Auth.
    	Component:VWKESSYMQB    036 0811, Coding:0F2000070F
    	EV_KessyHellaMQBAB,004039,EV_KessyHellaMQBAB_VW48.rod
    	Tuesday,01,October,2019,20:26:49:57784
    	VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
    IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
    IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
    IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
    IDE03251-Stop release for start-stop function,According to function requirements ,1
    IDE04159-Deactivation of start-stop function,not active ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE09735-CU tailgate opener: sensor 1: threshold value 1,16 ,1
    IDE09736-CU tailgate opener: sensor 1: threshold value 2,16 ,1
    IDE09737-CU tailgate opener: sensor 1: threshold value 3,16 ,1
    IDE09738-CU tailgate opener: sensor 1: threshold value 4,16 ,1
    IDE09739-CU tailgate opener: sensor 1: threshold value 5,16 ,1
    IDE09740-CU tailgate opener: sensor 2: threshold value 1,16 ,1
    IDE09741-CU tailgate opener: sensor 2: threshold value 2,16 ,1
    IDE09742-CU tailgate opener: sensor 2: threshold value 3,16 ,1
    IDE09743-CU tailgate opener: sensor 2: threshold value 4,16 ,1
    IDE09744-CU tailgate opener: sensor 2: threshold value 5,16 ,1
    IDE09745-CU tailgate opener: sensor 1: timer value 1,0 ,1
    IDE09746-CU tailgate opener: sensor 1: timer value 2,64 ,1
    IDE09747-CU tailgate opener: sensor 1: timer value 3,2 ,1
    IDE09748-CU tailgate opener: sensor 1: timer value 4,31 ,1
    IDE09749-CU tailgate opener: sensor 1: timer value 5,5 ,1
    IDE09750-CU tailgate opener: sensor 2: timer value 1,0 ,1
    IDE09751-CU tailgate opener: sensor 2: timer value 2,224 ,1
    IDE09752-CU tailgate opener: sensor 2: timer value 3,66 ,1
    IDE09753-CU tailgate opener: sensor 2: timer value 4,31 ,1
    IDE09754-CU tailgate opener: sensor 2: timer value 5,5 ,1
    IDE09755-CU tailgate opener: sensor 1: burst length,0 ,1
    IDE09756-CU tailgate opener: sensor 1: active screening,17 ,1
    IDE09757-CU tailgate opener: sensor 2: burst length,0 ,1
    IDE09758-CU tailgate opener: sensor 2: active screening,48 ,1
    IDE09759-CU for tailgate opener: reset all counters,Reset ,1
    IDE09760-CU for tailgate opener: check sum,255 ,1
    IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,10 ,1
    IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,9 ,1
    IDE09831-CU for tailgate opener: play protection increments,6 ,1
    IDE09832-CU for tailgate opener: play protection decrements,25 ,1
    IDE09833-CU for tailgate opener: play protection threshold active,255 ,1
    IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1
    IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1
    IDE09836-CU tailgate opener: sensor 1: control parameter,45 ,1
    IDE09837-CU tailgate opener: sensor 2: control parameter,192 ,1
    IDE09838-CU tailgate opener: foot gestic recognition: evaluation,224 ,1
    IDE09839-CU for tailgate opener: parameter set version,65310 ,2
    IDE10844-Control module rear lid opening: duration status query,4960 ms,1
    IDE10845-Control module rear lid opening: vehicle type,1B ,1
    ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
    ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
    ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
    ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
    ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
    ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
    ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
    ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
    ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
    ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
    ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
    ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1
    ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
    ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
    ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
    ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,activated ,1
    ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
    ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
    ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
    ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
    ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
    ENG105462-CAN-timeout service-key message,260 ms,1
    ENG105634-Correction value LED dimming,1.0 ,1
    ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
    ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
    ENG126961-deactivation_time_vip_slidingdoor,15 s,1
    ENG126960-Debounce_time_detection,500 ms,2
    ENG126959-Debounce_time_driver_presence,200 ms,1
    ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
    ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
    ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
    ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
    ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
    ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
    ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
    ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
    ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
    ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
    ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
    ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
    ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
    ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
    ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
    ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
    ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
    ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
    ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
    ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
    ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
    ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
    ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
    ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
    ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
    ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
    ENG105825-Diagnostic: wait time after power on,500 ms,1
    ENG126943-Display_duration_emergency_off,3000 ms,1
    ENG126944-Display_duration_error_mode_2_SPN,10 s,1
    ENG126941-Display_duration_please_engage_P,10 s,1
    ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
    ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
    ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
    ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
    ENG126950-duration_ZAT_debounce,50 ms,1
    ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
    ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
    ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
    ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
    ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
    ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
    ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
    ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,C1 ,5
    ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
    ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
    ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
    ENG126966-environment_scan_cyclic_step1,700 ms,1
    ENG126967-environment_scan_cyclic_step2,2000 ms,1
    ENG126965-environment_scan_duration_step1,300 min,1
    ENG126971-environment_scan_duration_step2,24 H,1
    ENG126969-environment_scan_level_bem,2 ,1
    ENG126968-environment_scan_responselevel_reduction,500 ,1
    ENG126970-environment_scan_startdelay_time,5 s,1
    ENG126958-Ignition_For_Immobilizer,Default ,1
    ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
    ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
    ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
    ENG107052-Interior scan: opening threshold sliding roof,1 %,1
    ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
    ENG107054-Interior scan: Speed - threshold,20 km/h,1
    ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
    ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
    ENG98656-internal,0 B,1
    ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
    ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
    ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
    ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
    ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
    ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
    ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
    ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
    ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
    ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
    ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
    ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
    ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
    ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
    ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
    ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
    ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
    ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,not activated ,1
    ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
    ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
    ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
    ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
    ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
    ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
    ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
    ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
    ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
    ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
    ENG107592-MCTX Pause,1 B,1
    ENG107593-MCTX pause for Go / Key Minder,20 ms,1
    ENG107594-MCTX pause for Go authentification,7 B,1
    ENG107595-MCTX settling phase,7 B,1
    ENG129013-min_receptiontime_vit,0 ms,1
    ENG126945-min_time_for_Terminal_50_request,200 ms,1
    ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
    ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
    ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
    ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
    ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
    ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
    ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
    ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
    ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
    ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
    ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
    ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
    ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
    ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
    ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
    ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
    ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
    ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
    ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
    ENG108309-Proximity Sensor: max. signal-length,120 s,1
    ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
    ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
    ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
    ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
    ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
    ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
    ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
    ENG108317-Proximity Sensor: SP_X2,10 min,1
    ENG108318-Proximity Sensor: SP_X3,1 ,1
    ENG108319-Proximity Sensor: SP_X4,80 ,1
    ENG108320-Proximity Sensor: SP_X5,1 ,1
    ENG108321-Proximity Sensor: SP_X6,30 min,1
    ENG108322-Proximity Sensor: SP_X7,1 ,1
    ENG108323-Proximity Sensor: Time Power On,1960 ms,1
    ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
    ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
    ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
    ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version,0 ,37
    ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1,0 ,37
    ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2,0 ,37
    ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3,1 ,37
    ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4,0 ,37
    ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5,16 ,37
    ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6,16 ,37
    ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7,16 ,37
    ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8,16 ,37
    ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9,16 ,37
    ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10,16 ,37
    ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11,16 ,37
    ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12,16 ,37
    ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13,16 ,37
    ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14,0 ,37
    ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15,0 ,37
    ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16,0 ,37
    ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17,4 ,37
    ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18,2 ,37
    ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19,0 ,37
    ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20,active ,37
    ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21,active ,37
    ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22,Incorrect coding ,37
    ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23,up ,37
    ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24,static ,37
    ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25,0 ,37
    ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26,not active ,37
    ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27,static ,37
    ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28,0 ,37
    ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29,10 ,37
    ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30,active ,37
    ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31,2 ,37
    ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32,1 ,37
    ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33,15 ,37
    ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34,1 ,37
    ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35,Reset ,37
    ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36,45 ,37
    ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37,0 ,37
    ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38,17 ,37
    ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39,192 ,37
    ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40,0 ,37
    ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41,48 ,37
    ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42,10 ,37
    ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43,9 ,37
    ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44,255 ,37
    ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45,15 ,37
    ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46,15 ,37
    ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47,15 ,37
    ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48,15 ,37
    ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49,0 ,37
    ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50,7 ,37
    ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51,6 ,37
    ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52,25 ,37
    ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53,255 ,37
    ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54,5 ,37
    ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55,60 ,37
    ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56,5 ,37
    ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type,5 ,37
    ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation,Activation after 2s ,37
    ENG120045-Reduced current for transponder-ID request,0 Step,1
    ENG126939-rpm_threshold_engine_runnning,100 /min,1
    ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
    ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
    ENG108577-Scan Procedure: Number of Repeats,1 ,1
    ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
    ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
    ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
    ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
    ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
    ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
    ENG108586-ScanProcedure: Timeout Response,100 ms,1
    ENG126963-settime_trigger_entry_vehicle,500 ms,1
    ENG126962-settime_trigger_exit_vehicle,500 ms,1
    ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
    ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
    ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
    ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
    ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
    ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
    ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
    ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
    ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
    ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
    ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
    ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
    ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
    ENG109053-Standard dimming value ZAT,80 %,1
    ENG126938-Terminal_15_adaption_body_control_module,Default ,1
    ENG126946-Terminal_S_Timeout,30 min,1
    ENG102207-Time Sensor Power Off Group 2,3600 min,1
    ENG129027-Time_frame_VIP_kick_forecast,5 ,1
    ENG126942-time_to_drive_cycle_detection,1.00 s,1
    ENG126947-time_to_ignore_ignition_trigger,35 s,1
    ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
    ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
    ENG126949-time_ZAT_actuation_detection,3000 ms,1
    ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
    ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
    ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
    ENG129019-timeout_convenience_coverage_limiting,75 s,1
    ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
    ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
    ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
    ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
    ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
    ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
    ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
    ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
    ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
    ENG120047-ZAT init value,0 %,1
    ENG110364-ZAT nominal voltage,13.0 V,1
    ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
    ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
    ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
    ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
    ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
    ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
    ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
    ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
    ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
    ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
    ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
    ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
    Elapsed Time: 00:58
    Adaption map from a passat with factory easy open installed:
    	SW:3Q0-959-435-G   HW:3Q0-959-435-G ---  Acc/Start Auth.
    	Component:VWKESSYMQB    037 0907, Coding:1F20200723
    	EV_KessyHellaMQBAB,004041,EV_KessyHellaMQBAB_VW48.rod
    	Wednesday,18,September,2019,17:46:03:49581
    	VCID: 3E263465B0FBAF27F85-806A
    IDE09735-CU tailgate opener: sensor 1: threshold value 1,21 ,1
    IDE09747-CU tailgate opener: sensor 1: timer value 3,9 ,1
    IDE09748-CU tailgate opener: sensor 1: timer value 4,34 ,1
    IDE09749-CU tailgate opener: sensor 1: timer value 5,27 ,1
    IDE09754-CU tailgate opener: sensor 2: timer value 5,225 ,1
    IDE09839-CU for tailgate opener: parameter set version,65535 ,2
    ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
    ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,10 %,9
    ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,7.00 s,9
    ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,50 %,9
    ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,05 ,5
    ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,03 ,5
    ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,220 mV/m,5
    ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,40 mV/m,5
    ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
    ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
    Elapsed Time: 00:55
    Adaption map from an Arteon with factory easy open installed:
    	Component:VWKESSYMQB    037 0906, Coding:1F20200723
    	Sunday,10,March,2019,16:20:28:57784
    	VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    	VCID: 3E26345B80F9AE77AC1-806A
    IDE09735-CU tailgate opener: sensor 1: threshold value 1,69 ,1
    IDE09740-CU tailgate opener: sensor 2: threshold value 1,2 ,1
    IDE09741-CU tailgate opener: sensor 2: threshold value 2,31 ,1
    IDE09742-CU tailgate opener: sensor 2: threshold value 3,2 ,1
    IDE09743-CU tailgate opener: sensor 2: threshold value 4,31 ,1
    IDE09744-CU tailgate opener: sensor 2: threshold value 5,224 ,1
    IDE09745-CU tailgate opener: sensor 1: timer value 1,170 ,1
    IDE09746-CU tailgate opener: sensor 1: timer value 2,0 ,1
    IDE09749-CU tailgate opener: sensor 1: timer value 5,47 ,1
    IDE09750-CU tailgate opener: sensor 2: timer value 1,11 ,1
    IDE09751-CU tailgate opener: sensor 2: timer value 2,165 ,1
    IDE09752-CU tailgate opener: sensor 2: timer value 3,147 ,1
    IDE09753-CU tailgate opener: sensor 2: timer value 4,204 ,1
    IDE09754-CU tailgate opener: sensor 2: timer value 5,37 ,1
    IDE09755-CU tailgate opener: sensor 1: burst length,16 ,1
    IDE09756-CU tailgate opener: sensor 1: active screening,16 ,1
    IDE09757-CU tailgate opener: sensor 2: burst length,2 ,1
    IDE09758-CU tailgate opener: sensor 2: active screening,31 ,1
    IDE09759-CU for tailgate opener: reset all counters,Unknown (224),1
    IDE09760-CU for tailgate opener: check sum,170 ,1
    IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2 ,1
    IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31 ,1
    IDE09836-CU tailgate opener: sensor 1: control parameter,16 ,1
    IDE09837-CU tailgate opener: sensor 2: control parameter,16 ,1
    IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0 ,1
    IDE09839-CU for tailgate opener: parameter set version,30 ,2
    IDE10845-Control module rear lid opening: vehicle type,2F ,1
    ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,activated ,1
    ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1,1 ,37
    ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2,1 ,37
    ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3,0 ,37
    ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4,1 ,37
    ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9,2 ,37
    ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10,31 ,37
    ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11,2 ,37
    ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12,31 ,37
    ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13,224 ,37
    ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14,10 ,37
    ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15,10 ,37
    ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17,0 ,37
    ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18,9 ,37
    ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20,not active ,37
    ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22,not active ,37
    ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23,Bottom ,37
    ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24,Dynamic ,37
    ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25,3 ,37
    ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27,Dynamic ,37
    ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28,5 ,37
    ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29,6 ,37
    ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31,19 ,37
    ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32,2 ,37
    ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33,12 ,37
    ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34,4 ,37
    ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35,Do not reset ,37
    ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36,16 ,37
    ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37,16 ,37
    ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38,16 ,37
    ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39,16 ,37
    ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40,2 ,37
    ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41,31 ,37
    ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42,2 ,37
    ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43,31 ,37
    ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44,224 ,37
    ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45,10 ,37
    ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46,10 ,37
    ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47,0 ,37
    ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48,0 ,37
    ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50,0 ,37
    ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56,37 ,37
    ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type,47 ,37
    Elapsed Time: 00:57
    Any help would be greatly appreciated.
    Le VW Freaks
    - 4 guys who are in fond of what Volkswagen has to offer - OEM-retrofit, software updates, projects etc. Check our Facebook and webpage.
  2. Likes golfi_vend, aus liked this post
  3. #2
    May 2016
    Today i have done this to Skoda Suberb. Ordered a complete set at Kufatec. Support is ****. In first time no work. Then I have test the guide here above and worked like a charm.
    Please try those adaption channels. In first time i used also adaption from oem skoda with easy open. Wont work, fault code will not clear.
    Jan 2018
    Cheshire UK
    Had a similar fault when i retrofiited the a6 power tailgate. VCDS would not let me do the basic settings. Used odis offline and worked.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
    Tartu, Estonia
    Hello.
    I'd like to request if someone has adpmap of module 05/B7 from a Passat Wagon with easy open from factory.
    But I'd ask it to be with Easy Open module of 3G0 962 243 B. Index here is very important. One without "B" isn't sufficent for me at this time.
    The world is my oyster...
  6. Likes Mindfreak liked this post
    Apr 2019
    Quote Originally Posted by Mindfreak View Post
    I'm just wondering. Was your easy open module new or used?
    Mine was used and perhaps running "Output Voltage test" is enough to get it calibrated???
    https://forums.ross-tech.com/showthr...l=1#post176201
    Have you tried calibrating with ODIS since you have access to one?
    Jan 2017
    Estonia
    Well I just finished this retrofit successfully yesterday.
    I replaced the Easy Open module "3G0 962 243 C" with "3G0 962 243" and then was able to clear the error codes.
    We tried the "Output Voltage test" and calibration with ODIS for the ""3G0 962 243 C" without success. The C module was new and current one is used.
    Le VW Freaks
    Apr 2019
    Yeah I think the key is to get a used module.
