TPMS display error Passat b8 help
ecumix
Poland
C?ID=381630
Hi can give me advice i have error about tpms display can some one help me ?
16385 - TPMS Display
C1146 F2 [137] - EEPROM Malfunction
Reset counter: 37
Mileage: 247104 km
Date: 2016.01.11
Time: 04:25:15
ecumix
Poland
C?ID=381630
Monday,21,October,2019,15:17:22:21652
VIN: WVWZZZ3CZGE002584   License Plate: TMPS ERROR PASSAT B8
Mileage: 247104km-153543mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZ3CZGE002584   Mileage: 247104km-153543miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1343
   Revision: B5H21---
   Coding: 011D003203241D083000
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
   ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
   VCID: 00598701AA864A47C97-8054
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4801
   Revision: 05853104    Serial number: TFK01504262177
   Shop #: WSC 05311 115 00086
   ROD: EV_TCMDQ250021.rod
   VCID: 1675C159D802D4F703B-8042
   Part No SW: 3Q0 907 379 K    HW: 3Q0 907 379 F
   Component: ESC           H42 0622
   Revision: 00000000    Serial number: 61225000001213
   Coding: 0EEC6A8F34200B6E077C060841C74970562CD0E0608292F13062F078C202
   VCID: 42DD4D09E40A98579F3-8016
                    Reset counter: 37
                    Mileage: 247104 km
                    Date: 2016.01.11
                    Time: 04:25:15
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0709
   Revision: 00026000    Serial number: 0369523318
   Coding: 000F0F0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   VCID: 392F2AE589DCDB8FCE9-806C
   Part No SW: 5G0 907 044 BF    HW: 5G0 907 044 BF
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 11020104202100011015500000101802
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 6C81C3B1B60EBE2705F-8038
   Part No SW: 5Q0 937 086 AH    HW: 5Q0 937 086 AH
   Revision: --------    Serial number: 86583004152335
   Coding: 00011842C2C102FF43E04004000007081880000000000000000000000000
   Shop #: WSC 05311 115 00105
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150427  042 0607
   Serial number:         150430072614
   Component: RLHS  037 0059
   Serial number: S5Y15M05D20H09M46S48
   Coding: 90A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 07 04 2015  00000345
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: ˙˙˙305183615132
   Coding: 0271161051
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D47AE35EDD4172FB21-8058
   Component: ACC BOSCH MQB H04 0192
   Coding: 3200600151FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311BD1AEBE26E71DF-8060
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2P9ARYKS
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 025D8D09A48A5857DF3-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 003 004 15
   Serial number: 3576U0000000B3C80414
   Subsystem 2 - Part No SW: -----------    HW: 454 003 004 15
   Serial number: 3586U0000005A3C80419
   Subsystem 3 - Part No SW: -----------    HW: 454 802 204 15
   Serial number: 3516RD98772060000008
   Subsystem 4 - Part No SW: -----------    HW: 454 800 405 15
   Serial number: 3526R1CF494060000008
   Subsystem 5 - Part No SW: -----------    HW: 454 800 905 15
   Serial number: 3556V2B605B060000005
   Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150510400013
   Coding: 0010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 6D87CEB58D14B72F121-8038
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4300
   Coding: 07A401182380000800886B011001000000000000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_DashBoardVDDMQBAB 009042
   VCID: 619FA28541CCE34FA69-8034
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 14051510800335
   Coding: 0B0300045F087300FB0002481C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E6D5E5447FEFEA1-8020
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29150000824360025175
   Coding: 28FFFF
   Serial number: 1690236603
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H54 0033
   Serial number: 0062493
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 15000084229018
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD2C5912C53CF369-8024
   Serial number: 280415BDR16596
   Coding: 00350B20D000020000001000
   VCID: 43D3480DFB10915F945-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001403404
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000214627
   Coding: 01010010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3B2330ED83E0E99FDC5-806E
   Serial number: 300415BDT06127
   Coding: 00350120D000020000001000
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001406395
   Coding: 090000
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0624
   Coding: 02840101FF00000051110001000808001F01008401200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6E85C9B980124C372BB-803A
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9R1410329
   Subsystem 2 - Part No SW: 3G0 919 866 H    HW: -----------
   Component: ECE 2015/16  --- 0430
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184010162002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   VCID: 77ABECDDFF480DFFF8D-8022
End----------(Elapsed Time: 01:49, VBatt start/end: 12.1V/12.0V)-----------
OP got Verified, moving to Car Repair Support.
ecumix
Poland
C?ID=381630
ok thank you " Uwe "for advice so now can someone have solution?
ecumix
Poland
C?ID=381630
Maybe someone have check coding correct abs?
