Results 1 to 7 of 7
Thread: Aux Heater Issue
    Sep 2019
    Aux Heater Issue
    During the Auto Scan on my ’06 Jetta TDI BRM one of the issues is the Aux Heater is labeled defective by the OEM computer. But, with the VCDS I can make the Aux Heater work. Or, at least the VCDS says it’s working. I’ve attached a screen shot. (I think. First try at this).
    https://imgur.com/hWmVIfO
    OK, that didn't work. Anyway, the VCDS showed that the Aux Heater was ON, showing Voltage, Current and Output.
    So, my question is who’s right? VCDS or the OEM computer?
    Thanks for any help,
    Steve.
    Last edited by Ramp Rat; 10-21-2019 at 09:38 PM. Reason: IMG -> URL, but still no joy
    Please post the Auto-Scan from your Jetta.
  3. Likes Uwe liked this post
    Google Photos does not play nice with forums. Please see How to Post Pictures.
    He's got an Auto-Scan here:
    https://forums.ross-tech.com/showthread.php?20482
    Sep 2019
    OK, I've edited my post with a link to my image.
    [img]https://imgur.com/hWmVIfO[/img]
    See if this works????
    Steve
    Click EDIT on your own post above to see how I fixed it. To embed an image in-line, you must put the URL of an actual image file in between the IMG tags. The most common image file names end in .jpg or .png, but there are others. What you did above didn't work because it was missing the ".jpg".
    PS: 340 watts strikes me as a bit weak. It would be interesting to see what that value is on a heater that's free of faults.
  7. Likes Ramp Rat liked this post
    Nov 2014
    New Zealand
    My PTC this morning (It was 12C! outside) ran at 77Amps initially, quickly dropping to about 63 as long as I was over 2500 rpm... eventually it dropped to low 50's, then shut off once my coolant hit 75C (90C on the gauge).
    I aslo suspect thoguh, that the current draw is a calculated value, based on the PWM of the 3 separate heater elements - if one of yours is open circuit, the other may work, but the fault is still logged.
    If you google "PTC heater dry joints repair" or similar, you should find the repair procedure that helps. THIS ONE has the pictures screwed by photoshop, but there are some big/obvious resistors that get dry joints.
    Re-flow everything you can manage with a fine soldering tip and real solder (with lead in!). MAKE SURE you don't bridge anything with solder.
    Peak draw should get close to 80 Amps during the test.
    EDIT: Better Thread: https://www.audi-sport.net/xf/thread....208717/page-2
    P.S. my R32 engine is *slightly* less efficient than a TDI, so the PTC only runs for 6 to 8 minutes in the middle of winter, before the engine is up to 75C and it shuts off
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  9. Likes Uwe, Ramp Rat liked this post
  10. #7
    Sep 2019
    Thanks Uwe for the posting lesson. I am trainable. Maybe next time I'll get it right.
    AS for the cold solder joints, I'm not in a rush to pull the heater unit as yet. (I live in southeast Arizona so the nights aren't what I would call "Cold" as yet). However, this vehicle spent most of it's life back east and is suffering from some corrosion. I've noticed some of the power lead connections at the fuse box showing some corrosion. I think I'll try cleaning those points up before pulling the heater unit. It may not help but there's no harm in trying, eh?
    Thanks, everyone.
    Steve.
  11. Likes NZDubNurd, Uwe liked this post
