Results 1 to 2 of 2
Thread: 2015 e-Golf - scheduled charging - EV battery life
    trying to see if a few things are possible to check/change on VCDS.
    (1) on MY2015 scheduled charging is only accessible via the CarNet App. (2016+ this is accessible on the headunit) My CarNet subscription expired so i can no longer change the scheduled charging. Can this be changed on VCDS?
    (2) can you check battery life/degradation? When my car was new i could easily get 100+ miles of range with conservative driving. Now its down about 80. Would like to see if i can check the battery life.
    Sunday,20,October,2019,12:00:08:29944
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWPP7AU2FW9   License Plate:
    Chassis Type: AU-VW37 (5QE)
    Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
              BD C0 C5 C6
    VIN: WVWPP7AU2FW9   Mileage: 81801km-50828miles
    23-Brake Booster -- Status: Malfunction 0010
    BD-Hi Volt. Batt. Charg. -- Status: Malfunction 0010
    C5-Therm. mgt. -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
       Part No SW: 0EA 906 016 C    HW: 0EA 907 309 A
       Component: E-Vehicle     H23 8073
       Revision: WMH23---
       Coding: 000D0016002400007000
       ASAM Dataset: EV_VCU00XXX0110EA906016C 002005
       ROD: EV_VCU00XXX0110EA906016C_002.rod
       VCID: 2F6DACB77669B4370E-807A
    17154 - Acceleration Monitoring
              P150B 00 [032] - Value Above Upper Control Limit
    23599 - Active Radiator Shutter 1
              P05A0 00 [032] - Stuck Open
    25439 - Implausible Data Received from Battery Energy Control Module 2
              U0413 00 [032] - -
    18939 - Implausible Data Received from ABS Control Module
              U0415 00 [032] - -
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AE    HW: 5Q0 907 379 H
       Component: ESC           H31 0808
       Revision: 00000000    Serial number: 61155000000246
       Coding: 01FA40A12C21316D017F020081C3298002348C80408194B202810058C242
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
       VCID: 7F0DBCF7E68984B7DE-802A
    16401 - Tire Pressure Warning
              C102D 00 [032] - -
    32832 - Switch for Electric Parking Brake
              C100C 07 [032] - Mechanical Failure
       Revision: 00021000    Serial number: 0366775678
       Coding: 030C0C
       VCID: 3A7B8DE3BD2B619FA9-806E
       Part No SW: 5GE 907 044 AD    HW: 5GE 907 044 AD
       Component: Climatronic   H02 1105
       Revision: 00001K07
       Coding: 00022200200100000005000200111801
       ASAM Dataset: EV_ACClimaBHBVW37X 005132
       ROD: EV_ACClimaBHBVW37X_005_VW37.rod
       VCID: 7EF341F3E1838DBFD5-802A
    328196 - Motor for Right Temperature Flap
              B108D 71 [008] - Actuator stuck
                        Reset counter: 1
                        Mileage: 81108 km
                        Date: 2019.10.10
                        Time: 18:55:16
                        Voltage terminal 30: 14.4 V
                        Outside air temperature: 16.0 °C
                        Interior temperature: 20.8 °C
                        Right temperature flap: actual value: 78
                        Right temperature flap: actual value: 25.0 %
                        Right temperature flap: specified value: 22
    328199 - Position Sensor for Right Temperature Flap Motor
              B1095 15 [008] - Open or Short to Plus
                        Fault Frequency: 7
                        Reset counter: 25
                        Mileage: 80739 km
                        Date: 2019.10.04
                        Time: 10:25:41
                        Voltage terminal 30: 14.9 V
                        Outside air temperature: 19.0 °C
                        Interior temperature: 25.7 °C
                        Right temperature flap: actual value: 237
                        Right temperature flap: actual value: 100.0 %
                        Right temperature flap: specified value: 236
       Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
       Component: BCM MQBAB MNA H18 0137
       Serial number: 01011511000308
       Coding: 00011A66434182E169E44000001407201C00000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 79F952EFF8ADAA87E0-802C
       Component: WWS    150413  043 0551
       Serial number:         150416135942
       Component: RLHS  037 0059
       Serial number: S2Y15M04D28H09M35S15
       Coding: 90A8DD
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391511800713
       Coding: 2031151011
       VCID: 3D7186FFAC0556A78C-8068
       Serial number: 003GCR01RSG1
       Coding: 8CCCFC00002000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479DE417FED90C7726-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J150002O9JJ0F
       Coding: 303139
       Subsystem 2 - Part No SW: -----------    HW: 480 002 704 15
       Serial number: 35700000000279BC031H
       Subsystem 3 - Part No SW: -----------    HW: 480 002 704 15
       Serial number: 358000000005C26D231H
       Subsystem 4 - Part No SW: -----------    HW: 480 401 704 15
       Serial number: 3510002B51A91E76112-
       Subsystem 5 - Part No SW: -----------    HW: 480 401 704 15
       Serial number: 3520002B51A91E7532C6
       Subsystem 6 - Part No SW: -----------    HW: 480 401 704 15
       Serial number: 3550002C51A91E71F39G
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 704 15
       Serial number: 3560002C11A91E715270
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 16041504221261
       Coding: 0410
       ROD: EV_SMLSKLOMQB_010_VW37.rod
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 5GE 920 855     HW: 5GE 920 855
       Component: KOMBI         301 4311
       Coding: 0B35181A2B80CF05020868001700030000000000
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 C    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3203
       Revision: --------    Serial number: 21041510800756
       Coding: 0201001746F81000EF001200081E00000001050100030000000000000000
       ASAM Dataset: EV_GatewEVConti 011020
       ROD: EV_GatewEVConti_011.rod
       VCID: 4683E913F9D3157FDD-8012
       Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0101
       Serial number: 29150000669780035164
       Coding: 30FFFF
       Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
       Serial number: 9915866403
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
       Component: EBKV          H12 0160
       Serial number:   085430010693
       Coding: 01720100321A02030002000500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
       ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
       VCID: 4C97DB3BE7BFEF2F0B-8018
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0140
       Serial number: 05802861150415233159
    194560 - Indicator Lamp for Brake System
              C121A 00 [032] - Defective
    239616 - Implausible Data Received from Engine Control Module
              U0401 00 [040] - -
                        Fault Frequency: 73
                        Mileage: 64746 km
                        Date: 2018.11.13
                        Time: 07:35:01
       Revision: 00000000    Serial number: 15000101935002
       Coding: 7900000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3467A3DB9F4F97EF73-8060
       Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
       Serial number: 130415BDC02558
       Coding: 003013208000040000000000
       VCID: 408FFF0BDBF73B4FE7-8014
       Serial number: 00000000000005967303
       Coding: 111000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: C102
       VCID: 4385F007CAE12057FA-8016
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5QE 907 080 C    HW: 5QE 907 080 C
       Component: VW370E2615010 H06 2461
       Revision: 00H06000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM09550115QE907080C 001020
       ROD: EV_DMCM09550115QE907080C.rod
    25304 - Inverter Idle Mode  not possible
              P32B5 00 [096] - -
       Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
       Serial number: 030415BD21389A
       Coding: 003013208C00040000000000
       VCID: 3F8DFCF7A60944B79E-806A
       Serial number: 00000000000005992801
       Coding: 091000
       Coding: 051A000101000000
       VCID: 75E15EDFD4B5CEE784-8020
       Part No SW: 5G0 035 876     HW: 5G0 035 876
       Component: MU-S-NS-US    014 R025
       Serial number: V7B00904151860
       Coding: 02737002FF00000021220001001800001F0100140100010544
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 69D902AF880D1A0710-803C
       Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
       Component: ABT_Std_Nav  H60 0030
       Serial number: VWZ8Z9RS600P8X
       Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
       Component:  NAR 2015  --- 0022
       Component: OCULowMQBUS   007 0564
       Coding: 02737002C2829A017FFE06000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
       Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
       Component: K8C           H13 0722
       Serial number: VWADFDU01L
       ASAM Dataset: EV_BECM08820215QE915227M 003016
       ROD: EV_BECM08820215QE915227H.rod
       VCID: 52ABC543059BB9DF41-8006
    Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022.clb
       Part No SW: 5QE 915 022 G    HW: 12E 915 022 C
       Component: LMSG          H08 1075
       Serial number: 00920051320496
       Coding: 4A4904
       ASAM Dataset: EV_HVChargManagVWMQB 001001
       ROD: EV_HVChargManagVWMQB_001.rod
       VCID: 4581EE1FC4D51E67D4-8010
    2098176 - DC Quick-Charge; Charging Station Initialization Error
              P33E5 00 [008] - -
                        Reset counter: 35
                        Mileage: 81760 km
                        Date: 2019.10.20
                        Time: 17:28:38
                        Chademo version-Vehicle: 0
                        Chademo version-Chg. statn.: 0
                        DC charging PLC-Malfunction status: 0
                        DC charging PLC-Current: actual value: 0.0 A
                        DC charging PLC-Connection status: Not Present
                        DC charging PLC-Minimum voltage: 0.0 V
                        DC charging PLC-Maximum voltage: 0.0 V
                        DC charging PLC-Minimum current: 0.0 A
                        DC charging PLC-Maximum current: 0.0 A
                        DC charging PLC-Actual Voltage: 0.0 V
                        Status of actuator test: not active
    Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
       Part No SW: 5QE 035 335 H    HW: 5QE 035 335 H
       Component: E_SOUND_SG    H07 0198
       Serial number: EN151602840000
       Coding: 04
       ASAM Dataset: EV_ENoiseS1NNVW3707 005012
       ROD: EV_ENoiseS1NNVW3707_005.rod
    Address C5: Therm. mgt. (J1024)       Labels: None
       Part No SW: 5GE 907 458     HW: 5GE 907 458
       Component: TME-Min       H03 0108
       Serial number: 0006384
       ASAM Dataset: EV_ThermContrVISAU49X 001009
       ROD: EV_ThermContrVISAU49X_VW37.rod
       VCID: 020B3503957BE95FB1-8056
       Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G395 pT-Sens1  H61 0006
       Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
       Component: J848 HV-PTC  H09 0206
       Serial number:  T151143003807000140
       Subsystem 3 - Part No SW: 5QE 820 803 A    HW: 5QE 820 803 A
       Component: J842 eKK  H03 0007
       Geber für Kältemitteldruck/Kältemitteltemperatur 2:
       Subsystem 4 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G826 pT-Sens2  H61 0006
       Geber für Kältemitteldruck/Kältemitteltemperatur 3:
       Subsystem 5 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G827 pT-Sens3  H61 0006
       Geber für Kältemitteldruck/Kältemitteltemperatur 4:
       Subsystem 6 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G828 pT-Sens4  H61 0006
       Geber für Kältemitteldruck/Kältemitteltemperatur 5:
       Subsystem 7 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G829 pT-Sens5  H61 0006
       Refrigerant Expansion Valve 1:
       Subsystem 8 - Part No SW: 4M0 816 682     HW: 4M0 816 682
       Component: N636 EV1_KaMi  H09 0102
       Serial number: 00000000000020042355
       Refrigerant Expansion Valve 2:
       Subsystem 9 - Part No SW: 4M0 816 682     HW: 4M0 816 682
       Component: N637 EV2_KaMi  H09 0102
       Serial number: 00000000000020042351
       Refrigerant Expansion Valve 3:
       Subsystem 10 - Part No SW: 4M0 816 682     HW: 4M0 816 682
       Component: N638 EV3_KaMi  H09 0102
       Serial number: 00000000000020044484
       Refrigerant Shut Off Valve 1:
       Subsystem 11 - Part No SW: 4M0 816 703     HW: 4M0 816 703
       Component: V424 AV1_KaMi  H09 0102
       Serial number: 00000000000040045127
       Refrigerant Shut Off Valve 4:
       Subsystem 12 - Part No SW: 4M0 816 703     HW: 4M0 816 703
       Component: N642 AV4_KaMi  H09 0102
       Serial number: 00000000000040044403
       Refrigerant Shut Off Valve 5:
       Subsystem 13 - Part No SW: 4M0 816 703     HW: 4M0 816 703
       Component: N643 AV5_KaMi  H09 0102
       Serial number: 00000000000040036796
    8 Faults Found:
    32837 - HV Electronics Coolant Pump Control
              P0CEB 00 [040] - Short to GND
                        Mileage: 8878 km
                        Date: 2016.03.23
                        Time: 16:11:44
    37000 - Implausible Data Received From Electric A/C Compressor
              U046C 00 [032] - -
    37016 - Refrigerant Pressure/Temperature Sensor 2
              P1C5D 00 [032] - No Signal
    37025 - Refrigerant Pressure/Temperature Sensor 3
              P1C60 00 [032] - No Signal
    37033 - Implausible Data Received From Electric A/C Compressor
              U046C 00 [032] - -
    37096 - Automatic addressing Sub Bus 1
              B1484 21 [032] - Signal Amplitude Too Low
    37126 - Automatic addressing Sub Bus 2
              B1485 21 [032] - Signal Amplitude Too Low
    59002 - A/C Compressor; High Voltage Power Suppy
              B1453 F0 [032] - Malfunction
    Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
       Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
       Component: OBC Delta-ES  H52 1550
       ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
       ROD: EV_OBCTwoPhaseDT2VW3707.rod
       VCID: 4B95D827E2B1E81702-801E
    End-------------------------(Elapsed Time: 05:35)--------------------------
    1) I don't think so.
    2) Have a look at this thread.
