Security code not prompted
Wmwizkid
India
C?ID=374582
Hello guys.
I had a skoda octavia 1z the other day for scanning and coding.
I was not prompted the security code for many modules and so i was unable to code the vehicle.
I tried the 12233 code but it didnt work.i even tried uninstalling and reinstalling vcds but all in vain.
Security codes are module-specific. It's not possible to address this without seeing a scan of the vehicle and more information such as what you were trying to code into which module.
Wmwizkid
India
C?ID=374582
The vehile is a vw polo 1.5
Here is the scan
 Thursday,17,October,2019,13:14:34:02918
VIN: MEXE16604GT088189   License Plate: POLO HEAT
Mileage: 38750km-24078mi   Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: MEXE16604GT088189   Mileage: 38750km-24078miles
Address 01: Engine (J623-CWXA)       Labels: None
   Part No SW: 03L 906 023 SL    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM15TDI02103L906023SL 001001
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 02489DD89504775FB1-8056
   Part No SW: 6R0 907 379 BP    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Serial number: --------------
   Coding: 60DD2763412B18C80615E471825A18020000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0D52BEE4DC5A3827DC-8058
0903 - Please Check Fault Codes in Engine Control Module
          U101F 00 [008] - -
          [Scl_EngineTrq_Invalid]
                    Fault Frequency: 17
                    Reset counter: 52
                    Mileage: 38419 km
                    Date: 2017.03.31
                    Time: 00:27:07
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CA52D4D882AC47E8-8014
                    Fault Status: 00101101
                    Reset counter: 52
                    Mileage: 38419 km
                    Date: 2017.03.31
                    Time: 01:39:12
   Part No SW: 6RU 937 086 M    HW: 6RU 937 086
   Component: BCM IM M+4    H40 0432
   Revision: BY040001    Serial number: 0200 122160778
   Coding: 3AB02BFF08B30000013800006C2B06900080414F608C0000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 6B96D07C8A8E961762-803E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 040316 03  37  0059
   Coding: 036800
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13102848160114104301
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13202849160223130053
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 0471608365801042AB2B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13102728160209153222
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13202729160301134756
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Component: VW10AirbagU06 H10 0020
   Revision: --------    Serial number: 003GW01423DV
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49DA4AF4E8B2640730-801C
   Part No SW: 6RF 920 862 A    HW: 6RF 920 862 A
   Component: KOMBI         H01 0215
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4AD875F8EDB46F1F39-801E
   Part No SW: 6RU 909 901     HW: 6RU 937 086
   Component: GW-K-CAN TP20 H40 0432
   Revision: BY040001
   Coding: 002300
   VCID: 197ADAB41092D48740-804C
   Component: IMMO          H01 0215
   VCID: 6A98D5788D748F1F19-803E
Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ASAM Dataset: EV_SteerAssisNSK 014008
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 41CA52D4D082AC47E8-8014
Address 56: Radio
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
I want to do injector coding and for that i need to put the security code for engine control module.
NEtech
C?ID=56995
What was the return message after you tried this ?
Try: Ignition ON > Ignition OFF > Wait 10 sec. > Ignition ON > Test 27971
Else do that again with 12233.
Wmwizkid
India
C?ID=374582
Both cars have same issue code not suggested
