Results 1 to 6 of 6
Thread: Security code not prompted
    Sep 2019
    IN
    Hello guys.
    I had a skoda octavia 1z the other day for scanning and coding.
    I was not prompted the security code for many modules and so i was unable to code the vehicle.
    I tried the 12233 code but it didnt work.i even tried uninstalling and reinstalling vcds but all in vain.
    Security codes are module-specific. It's not possible to address this without seeing a scan of the vehicle and more information such as what you were trying to code into which module.
    Sep 2019
    IN
    The vehile is a vw polo 1.5
    Here is the scan
     Thursday,17,October,2019,13:14:34:02918
    VIN: MEXE16604GT088189   License Plate: POLO HEAT
    Mileage: 38750km-24078mi   Repair Order:
    Chassis Type: 60-VW25 (6RU)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: MEXE16604GT088189   Mileage: 38750km-24078miles
    Address 01: Engine (J623-CWXA)       Labels: None
       Part No SW: 03L 906 023 SL    HW: 03L 907 425 B
       Component: R4 1.5l TDI   H33 9977
       Revision: --H33---    Serial number:
       Coding: 00110116032500080000
       Shop #: WSC 01234 785 00200
       ASAM Dataset: EV_ECM15TDI02103L906023SL 001001
       ROD: EV_ECM15TDI02103L906023QT.rod
       VCID: 02489DD89504775FB1-8056
       Part No SW: 6R0 907 379 BP    HW: 6R0 907 379 AQ
       Component: ABS9.0 front  H01 0003
       Serial number: --------------
       Coding: 60DD2763412B18C80615E471825A18020000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_Brake1ABS90BOSCH 003017
       ROD: EV_Brake1ABS90BOSCH_VW25.rod
       VCID: 0D52BEE4DC5A3827DC-8058
    0903 - Please Check Fault Codes in Engine Control Module
              U101F 00 [008] - -
              [Scl_EngineTrq_Invalid]
                        Fault Frequency: 17
                        Reset counter: 52
                        Mileage: 38419 km
                        Date: 2017.03.31
                        Time: 00:27:07
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
       Component: Climatronic   H12 0615
       Revision: V0000000
       VCID: 41CA52D4D882AC47E8-8014
                        Fault Status: 00101101
                        Reset counter: 52
                        Mileage: 38419 km
                        Date: 2017.03.31
                        Time: 01:39:12
       Part No SW: 6RU 937 086 M    HW: 6RU 937 086
       Component: BCM IM M+4    H40 0432
       Revision: BY040001    Serial number: 0200 122160778
       Coding: 3AB02BFF08B30000013800006C2B06900080414F608C0000200000000000
       Shop #: WSC 124697 483 00190
       VCID: 6B96D07C8A8E961762-803E
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 040316 03  37  0059
       Coding: 036800
       Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  020 2551
       Serial number: 13102848160114104301
       Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  023 2551
       Serial number: 13202849160223130053
       Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
       Serial number: 0471608365801042AB2B
       Coding: 240000
       Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
       Component: J388__TSG_HL  022 1552
       Serial number: 13102728160209153222
       Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
       Component: J389__TSG_HR  022 1552
       Serial number: 13202729160301134756
       Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
       Component: VW10AirbagU06 H10 0020
       Revision: --------    Serial number: 003GW01423DV
       Coding: 003036
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 49DA4AF4E8B2640730-801C
       Part No SW: 6RF 920 862 A    HW: 6RF 920 862 A
       Component: KOMBI         H01 0215
       Coding: 1208000000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
       VCID: 4AD875F8EDB46F1F39-801E
       Part No SW: 6RU 909 901     HW: 6RU 937 086
       Component: GW-K-CAN TP20 H40 0432
       Revision: BY040001
       Coding: 002300
       VCID: 197ADAB41092D48740-804C
       Component: IMMO          H01 0215
       VCID: 6A98D5788D748F1F19-803E
    Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
       Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
       Component: EPS_ECU       H61 1702
       Coding: 0001000000000000
       ASAM Dataset: EV_SteerAssisNSK 014008
       ROD: EV_SteerAssisNSK_014.rod
       VCID: 41CA52D4D082AC47E8-8014
    Address 56: Radio
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
    I want to do injector coding and for that i need to put the security code for engine control module.
    Quote Originally Posted by Wmwizkid View Post
    What was the return message after you tried this ?
    Try: Ignition ON > Ignition OFF > Wait 10 sec. > Ignition ON > Test 27971
    Else do that again with 12233.
  5. Likes Uwe liked this post
    Which car are you requesting help with ???
  7. Likes Uwe liked this post
    Sep 2019
    IN
    Both cars have same issue code not suggested
