Results 1 to 9 of 9
Thread: 2017 GTI ACC Screwed Up
    Jul 2018
    Just found this thread whilst trying to resolve a problem with the distance sensor on a 2017 golf GTi.
    Error message on dashboard says front assist unavailable. Here is the coding I found:
    Work Shop Code: WSC 01357 011 00200
    ASAM Dataset: EV_ACCBOSCHVW416 002005 (VW37)
    VCID: 3C21379876E1AAE7D5F-8068
    0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
    C1103 00 [009] - -
    [FAULT_MISALIGNMENT_VERTICAL]
    Reset counter: 46
    Mileage: 2699 km
    Date: 2019.10.19
    Time: 11:15:20
    Control Module temperature: 23 °C
    Voltage terminal 15: 11.7 V
    The front of the car has been apart but no accident damage, when it was put back together it was fine, but then a few days later this error occurred.
    So is this a dealer only re calibration?
    Thanks.
    Jul 2018
    Here is the full Autoscan... (distance sensor was unplugged)
    Saturday,19,October,2019,11:36:44:41168
    VIN: WVWZZZAUZHW382157   License Plate:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6 D7
    VIN: WVWZZZAUZHW382157   Mileage: 2699km-1677miles
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       Coding: 091900122444050B2000
       ROD: EV_ECM20TFS0205G0906259C.rod
       VCID: 2E050DD0B09D48776BB-807A
    22008 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:37
                        Engine speed: 745.75 /min
                        Normed load value: 10.2 %
                        Coolant temperature: 36 °C
                        Intake air temperature: 15 °C
                        Voltage terminal 30: 13.066 V
                        Engine: operating status: IS
                        ECU_STATE: SYN_ENG_IGK_ON
                        Engine oil temperature: 12.0 °C
                        Time since engine start: 70.5 s
                        T_ES: 0 min
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
    Readiness: 1110 0001
       Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
       Component: ESC           H25 0413
       Revision: 00000000    Serial number: 51107000001206
       Coding: 01FA93A13428216E47780605C0CAA980C92C84E26003957734405078C009430000000012121212B835351919323200
       VCID: 76B5E5B0084D30B7E3B-8022
    8196 - Databus
              [FCAN : ACC_10 message is not received]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:36
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0012000420011001100500000010102A
       VCID: 6D87CADC7D1BF36F121-8038
       Serial number: 02001711104482
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA5FD90207D78F7BBB-802A
       Component: WWS    170328  042 0551
       Serial number:         170419121454
       Component: RLHS  042 0105
       Serial number: S8Y17M05D03H10M23S41
       Coding: 00A8DD
       Serial number: 000000000ZY171021408
       Serial number: 00000000000068946239
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617123
       Coding: 0471051001
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       VCID: 4ACD61402C350457573-801E
    Address 13: Auto Dist. Reg
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0318
       Serial number: 003TDR2XA8B7
       Coding: 98CCC000000000005C0000CF008800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B3280AE97E87597-8044
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E04051751477
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E28041751083
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 205 17
       Serial number: 35700000000228F0C32G
       Subsystem 4 - Part No SW: -----------    HW: 480 000 205 17
       Serial number: 35800000000C7C15A32P
       Subsystem 5 - Part No SW: -----------    HW: 480 402 404 17
       Serial number: 3510001B1254CB1446C/
       Subsystem 6 - Part No SW: -----------    HW: 480 402 404 17
       Serial number: 3520001BB24E983154C9
       Subsystem 7 - Part No SW: -----------    HW: 480 400 305 17
       Serial number: 3550001C325A69A4262%
       Part No SW: 5Q0 953 507 FT    HW: 5Q0 953 549 F
       Revision: --------    Serial number: 25041704220178
       Coding: 0400
       VCID: 0D47AA5C1DDB536FB21-8058
       Part No SW: 5G1 920 791     HW: 5G1 920 791
       Component: KOMBI         409 2180
       Coding: 27AD11002F80060001886B011400000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 698FBECC49F3EF4F7E9-803C
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_AWV_0x1B keine Kommunikation]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:39
    16776960 - Databus
              [ACC_02 keine Kommunikation]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:35
    16776961 - Databus
              [ACC_04 keine Kommunikation]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:35
       Component: GW MQB High   418 4286
       Revision: --------    Serial number: 0006250262
       Coding: 030100047F085900FB00027E080F00010001050000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 2F3B10D4B797417F60D-807A
       Serial number: 29170000806220087165
       Coding: 2CFFFF
       Serial number: 3567433804
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
              [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:35
                        Supply voltage: Terminal 30: 12.7 V
                        Terminal 15: On
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       VCID: 47CB58743F27F93F48D-8012
       Serial number: 180417EDI13664
       Coding: 003F0220D001048000001000
       VCID: 43D34C640B1FD51F945-8016
       Serial number: 00000000000014436723
       Coding: 0D0000
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D31807CD594D7C73-806E
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Component: FCM MQB Low   001 0285
       Serial number: 21041710803211
       Coding: 000000050100164E01100F01020000000000000000000000000000000000
       VCID: 72BDD9A064252C97CF3-8026
       Serial number: 110217EBA13347
       Coding: 003F0020DE01048000801000
       VCID: 42DD49601405DC179F3-8016
       Serial number: 00000000000014407222
       Coding: 150000
       Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
       Component: MU-S-ND-ER    840 0753
       Coding: 02731001FF00000051110101008808001F0503E601200000CF
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 313F16ACA1A3578F769-8064
       Component: ABT_Std-2_Nav  H41 8084
       Serial number: VWZ6ZHT1170850
       Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
       Component: ECE1 2017/18  --- 0820
              U1111 00 [009] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:38
                        Voltage terminal 30: 13.2 V
                        BAP-BAP_Function_ID: 02
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 46
                        Mileage: 2699 km
                        Date: 2019.10.19
                        Time: 11:34:39
       Serial number: 170330200177
       VCID: 6B83C4C4430FFD5F0C5-803E
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392F2E8C79D39FCFCE9-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxRKEBODVW481.rod
    End----------(Elapsed Time: 01:41, VBatt start/end: 13.4V/13.6V)-----------
    May 2017
    Check that the sensor is firmly seated to it’s holder, then try reset misalignment angle basic setting and go for a drive.
    Jul 2018
    I have removed the grille and checked everything is located correctly, if I try to erase the fault code it just comes back straight away. Is there a separate setting to reset the misalignment?
    May 2017
    In basic settings.
    What exactly did you remove? Front bumber? Did you need to remove the crash bar where the radar is attached? If you’ve only removed the sensor, check again that it’s firmly in place. The legs need to be in their sockets completely. Otherwise you’ll have this error again even you do the reset.
    Jul 2018
    This is a later model golf, the sensor is behind the VW badge on the front grille, it's definitely located correctly.
  7. #7
    Quote Originally Posted by invernesspl View Post
    Right, but a 2017 GTI is nothing like a 2015 Touareg, so I've split this into its own thread.
  8. #8
    May 2017
    Ah yes newer models also don’t have the reset misalignment basic setting. Search the forum, there was quite nice guide how to make basic settings for these newer radars.
  9. #9
    Jul 2018
    Sorry Uwe, arrived at the thread via Google search and didn't realise it was Toureg specific
  10. Likes Uwe liked this post
