Results 1 to 5 of 5
Thread: MY18 VW Golf drivers seat not moving
    Verified VCDS User sasha's Avatar
    Oct 2016
    Australia
    Question MY18 VW Golf drivers seat not moving
    Hi all,
    Repairing a Golf after a front impact accident, and for some reason the drivers seat is stuck in most forward / top position. It's an electronically adjusted memory seat (just on drivers side) and doesn't move at all using adjustment buttons on the side of the seat.
    Based on attached scan of the car, any ideas? Have anyone had this before?
    Tuesday,15,October,2019,16:55:49:25557
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
    VCDS Version 19.6.2.0  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZAUZJP504752   License Plate:
    Mileage: 19950km-12396mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 4B 52 5F
              A5 D6 D7
    VIN: WVWZZZAUZJP504752   Mileage: 19950km-12396miles
    36-Seat Mem. Drvr -- Status: Cannot be reached 0100
    4B-Multifunc. Module -- Status: Malfunction 0010
    A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
    D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
    D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
       Component: R4 1.4l TFS   H26 3742
       Revision: R7H26---
       Coding: 0125003224641D083000
       Shop #: WSC 00028 028 00078
       ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
       ROD: EV_ECM14TFS01104E906027HD.rod
       VCID: 6D87C9D89D17C33F121-8039
       CAN Converter 01:
    8 Faults Found:
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [047] - Electrical Malfunction
                        Mileage: 19950 km
                        Date: 2019.09.26
                        Time: 04:06:51
                        Coolant temperature: 23 ∞C
                        Intake air temperature: 25 ∞C
                        Voltage terminal 30: 12.203 V
                        Outside air temperature: 215 ∞C
                        Absolute intake pressure: 101 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 0.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Overrun cut-off-Bits 0-7: 0
    17156 - Databus
              U1123 00 [096] - Received Error Message
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
                        Engine speed: 1019.00 /min
                        Normed load value: 16.5 %
                        Vehicle speed: 23 km/h
                        Coolant temperature: 98 ∞C
                        Intake air temperature: 39 ∞C
                        Voltage terminal 30: 13.853 V
                        Acceleration: -7.800 m/s≤
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 8
                        Drivetrain coordinator: brake fault status-Bits 0-7: 0
    17158 - Databus
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:39
                        Engine speed: 1239.00 /min
                        Normed load value: 13.3 %
                        Coolant temperature: 11 ∞C
                        Intake air temperature: 12 ∞C
                        Voltage terminal 30: 11.638 V
                        Acceleration: 0.000 m/s≤
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 130
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 136
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
    20360 - Power Supply Terminal 15
              P3325 00 [032] - Implausible
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:42
                        Coolant temperature: 24 ∞C
                        Voltage terminal 30: 11.779 V
                        Outside air temperature: 24 ∞C
                        Fuel level: 48.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 15.9998
              U0428 00 [032] - -
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:39
                        Engine speed: 1190.50 /min
                        Normed load value: 13.7 %
                        Voltage terminal 30: 11.614 V
                        Outside air temperature: 11 ∞C
                        Absolute intake pressure: 30 kPa abs
                        Engine torque: 10.3 Nm
                        Fuel level: 44.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 0.9541
    5595 - Crash Shut-Down Activated
              P1609 00 [032] - -
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
    4787 - Crash Shut-Down Activated
              P1609 00 [032] - -
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [047] - -
              [Lost Communication WithCruise Control Front Distance Range Sensor]
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:40
                        Fuel level: 48.00 l
                        Oxygen sensor bank 1 sensor 1: specified value: 15.2834
       Part No SW: 0CW 300 041 B    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1006
       Revision: 00005026    Serial number: CU501705237527
       Shop #: WSC 00028 028 00069
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 34311CBCBEBD52F71DF-8061
    21193 - No Communication with Cruise Control Module
              U0104 00 [047] - -
                        Fault Frequency: 11
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:41
                        Engine speed: 3.25 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 72 km/h
                        Control Module temperature: -37 ∞C
                        CURRENT pressure: -10.0 bar
                        selected gear: GANG_6
                        Driving position: N
                        Accelerator position: 0.0 %
                        DTC memory status: 45568
       Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0743
       Revision: 00000000    Serial number: 61367000001925
       Coding: 04FA8AA124202170477E060540C52920512484E26002947338225038C2A2430000000012121212B835351919323200
       VCID: 79AFED88D95F6F9F8E9-802D
    0297 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:38
    8192 - Databus
              [FCAN: ACC_07 message is not received]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:41
    8196 - Databus
              [FCAN : ACC_10 message is not received]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:41
    8382 - Databus
              [FCAN: HCA_01 not received]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:46
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0442580081
       Coding: 032C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C21349C96ED9AB7D5F-8069
       Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
       Revision: 00001K08
       Coding: 0212002420010000110500001210142A
       Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
    459015 - Databus
              [Feuchtesensor innen - kein Signal/Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:47
    459024 - Databus
              [Frontsensorik - kein Signal/Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 02:09:11
                        Outside air temperature: 12.0 ∞C
                        Engine speed: 800 /min
                        Temperature after evaporator: 12.3 ∞C
                        System run time-Engine running time: 5 s
                        System run time-Terminal 15 on: 5 s
              B10CD 00 [008] - -
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.13
                        Time: 06:33:54
                        Voltage terminal 30: 10.8 V
    1048839 - Function limitation due to crash signal
              B1397 00 [009] - -
                        Reset counter: 141
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:46
       Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
       Component: BCM PQ37BOSCH 034 0242
       Revision: --------    Serial number: 865827051701S5
       ROD: EV_BCMBOSCH_018.rod
       VCID: 05579178A5A71B7FFA1-8051
       Component: WWS    170502  042 0551
       Serial number:         170515145335
       Roof Blind:
       Subsystem 2 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS22.409  H03 0004
       Serial number: 0000FST001MDTXQ00000
       Coding: 191900
    10 Faults Found:
    569092 - Databus
              [LCM links - LCM_Feh_LM_L_alt aktiv]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    576516 - Databus
              [LCM rechts - LCM_Feh_LM_R_alt aktiv]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    567062 - Databus
              [LCM links - Tagfahrlicht defekt]
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.13
                        Time: 06:20:33
    568086 - Databus
              [LCM links - Blinker defekt]
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.13
                        Time: 02:41:08
    568342 - Databus
              [LCM rechts - Blinker defekt]
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:44
    13762560 - Component protection
              U1114 00 [008] - GFA key
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:53:31
    934148 - No Communications with Rain/Light Sensor
              U10F6 00 [009] - -
              [Sensor f¸r Regen- und Lichterkennung->kein Signal/ Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:41
    939524 - No Communications with Humidity Sensor
              U10F5 00 [009] - -
              [Sensor f¸r Feuchteerkennung->kein Signal/ Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 02:05:56
    204290 - Remote key 1
              B1479 18 [008] - Current Too Low
    204546 - Remote key 2
                        Reset counter: 0
                        Mileage: 17202 km
                        Date: 2019.05.09
                        Time: 07:26:12
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417617145
       Coding: 0371167851
       Shop #: WSC 00028 028 00075
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50F9702C2A650ED7197-8005
    10 Faults Found:
    1111572 - Side Front Left Parking Aid Sensor
              B10F6 14 [009] - Open or Short to Ground
                        Fault Frequency: 9
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    1111828 - Front Left Parking Aid Sensor
              B10F7 14 [009] - Open or Short to Ground
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    1112084 - Front Left Center Parking Aid Sensor
              B10F8 14 [009] - Open or Short to Ground
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:29
    1112340 - Front Right Center Parking Aid Sensor
              B10F9 14 [009] - Open or Short to Ground
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    1112596 - Front Right Parking Aid Sensor
              B10FA 14 [009] - Open or Short to Ground
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    1112852 - Side Front Right Parking Aid Sensor
              B10FB 14 [009] - Open or Short to Ground
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    12727553 - Databus
              [Steuerger‰t f¸r Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
                        Fault Frequency: 10
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:42
    13637426 - Databus
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:39
    13679386 - Databus
              [Steuerger‰t f¸r Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:38
    12727554 - Databus
              [Steuerger‰t f¸r Heading-Control - Gateway_79.LDW_02_alt - kein Signal/keine Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:42
    Address 13: Auto Dist. Reg
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWR2ZYBTW
       Coding: 98CCC000000000005C000000008800000065
       Shop #: WSC 00028 028 00065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 094F9D4889BF7F1F9E9-805D
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169677E31051750273
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169676E24051751148
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 003 005 17
       Serial number: 357000000006F9B8052S
       Subsystem 4 - Part No SW: -----------    HW: 480 003 005 17
       Serial number: 35800000000EFA41C42Z
       Subsystem 5 - Part No SW: -----------    HW: 480 400 106 17
       Serial number: 3510001BD25975E48529
       Subsystem 6 - Part No SW: -----------    HW: 480 400 106 17
       Serial number: 3520001BD25975E4565B
       Subsystem 7 - Part No SW: -----------    HW: 480 401 905 17
       Serial number: 3550001A725A698253A5
    13 Faults Found:
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
    9437723 - Igniter for Passenger's Airbag
              B1002 1B [137] - Resistance Too High
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
              B1007 1B [137] - Resistance Too High
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
    9438491 - Igniter for Driver head airbag
              B1005 1B [137] - Resistance Too High
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
    9438235 - Igniter for Front passenger's Head Curtain Airbag
              B1004 1B [137] - Resistance Too High
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
    9440283 - Driver side knee airbag igniter
              B100C 1B [137] - Resistance Too High
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:32
    9466352 - Crash Data from Belt Tensioner Stored
              B1071 F0 [137] - Unknown Error Elaboration
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
    9447424 - Front crash data stored
              B1028 00 [137] - -
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
    1049093 - Databus
              [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                        Reset counter: 181
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:40
    1054464 - Databus
              [NWD: 0x117 ACC_10 Timeout]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
    1049094 - Databus
              [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                        Reset counter: 181
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 17:28:26
       Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20170523201200
       Coding: 0C10
       ASAM Dataset: EV_SMLSVALEOMQB 001016
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 73B3DFA0FB3315CFC45-8027
       Part No SW: 5G1 920 750 C    HW: 5G1 920 750 C
       Component: KOMBI         302 0310
       Coding: 27A421186F88000801886B0B5401000000000000
       VCID: 270BFBF07F6B296FA8D-8073
    7 Faults Found:
    16777010 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_LDW_0x19 keine Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:46
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_AWV_0x1B keine Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:46
    13697024 - Component Protection
              U1100 00 [008] - No Basic Setting
              [Komponentenschutz keine oder falsche Grundeinstellung bzw. Adaption]
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:53:05
    16776960 - Databus
              [ACC_02 keine Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:40
    16776961 - Databus
              [ACC_04 keine Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:40
    16776969 - Databus
              [LDW_02 keine Kommunikation]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:41
    9456681 - Key
              B104C 29 [008] - Implausible Signal
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:39:50
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 24051710520307
       Coding: 030100347F085700FB00025C1C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 33331FA0BBB355CF045-8067
       Serial number: 39170001343100047204
       Coding: 2DFFFF
       Serial number: 3049234104
    131660 - Seat/Mirror Postion Control Module - Driver
              U0208 00 [009] - No Communications
              [Timeout Knoten 0x4C / 36 - Steuerger‰t f¸r Sitz-/Spiegelpos. Fahrerseite]
                        Fault Frequency: 10
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 00:00:41
                        Supply voltage: Terminal 30: 12.5 V
                        Terminal 15: On
    131663 - No Communications with Front Sensor Package for Driver Assist. Systems
              U10E0 00 [009] - -
              [Timeout Knoten 0x4F / A5 - Frontsensorik f¸r Fahrerassistenzsysteme]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
                        Supply voltage: Terminal 30: 11.6 V
                        Terminal 15: On
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
              [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:43
                        Terminal 15: On
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:52:36
                        Supply voltage: Terminal 30: 11.8 V
                        Terminal 15: On
    8526361 - LV Energy Management
              B1802 F1 [008] - Warning Triggered
                        Reset counter: 180
                        Mileage: 19950 km
                        Date: 2019.07.13
                        Time: 07:02:01
                        Supply voltage: Terminal 30: 11.3 V
                        Terminal 15: On
       Revision: 00000000    Serial number: 17000142683004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       Serial number: Y0006QCG20282
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       Component: HRE_Master    H12 0080
       Serial number: 0443098291
       Coding: 02011203
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D2739988DF793BFE21-8069
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0440466756
       Coding: 020112
       Serial number: 0000259589629
       Coding: 003B1320D201028000001000
       VCID: 47CB5B70DF2BC96F48D-8013
       Serial number: 00000000000005889327
       Coding: 0D0000
       Coding: 9307
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D32849CD9A487C73-806F
    16272 - Steering Angle Sensor
                        Reset counter: 145
                        Time: 00:00:00
                        Motor status: 00
                        System status: Reset
                        Supply voltage: 12.25 V
                        Temperature: 11.0 ∞C
                        KFC: 3F
                        KFA: 00 90
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.41 V
                        uAdSensI_SwitchedKl30_xdu16: 12.41 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 00 C0
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: activated
                        RP_CNTERR: activated
    21760 - Databus
              [HCA_01 Botschaft - CAN-Timeout]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:45
                        Motor status: 00
                        Supply voltage: 11.50 V
                        Temperature: 33.0 ∞C
                        KFC: 55
                        KFA: 00 00
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 11.66 V
                        uAdSensI_SwitchedKl30_xdu16: 11.64 V
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: not activated
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Serial number: 23051710520878
       Coding: 000000070100194E01000101020000000000000000000000000000000000
       VCID: 72BDDAA484291CC7CF3-8027
    13705478 - Databus
              [RLS_01 data bus missing message]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:42
    131080 - Databus Front Lights
              U1504 00 [137] - No Communications
              [Databus AFS no communication]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 05:50:40
       Serial number: 0000260270008
       Coding: 003B1120DE01028000801000
       VCID: 46D55674D821D067B3B-8013
       Serial number: 00000000000005614390
       Coding: 050000
       Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
       Component: MU-S-N-ER     H41 0475
       Serial number: VWZAZ2W0348130
       Coding: 02731208FF00000051510001000808001F0506D601200102CF
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 303910AC4AA56ED7797-8065
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZJT1540787
       Subsystem 2 - Part No SW: 3G0 919 866 BF    HW: -----------
       Component: MRM2 2017/18  --- 0821
              U1111 00 [009] - -
              [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 06:08:27
                        Voltage terminal 30: 13.5 V
                        BAP-BAP_Function_ID: 02
    7184 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Seat adjustment/seat memory (0x10) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.07.09
                        Time: 02:09:31
                        Voltage terminal 30: 12.5 V
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 140
                        Mileage: 19950 km
                        Date: 2019.10.13
                        Time: 06:08:25
                        Voltage terminal 30: 13.4 V
    Address A5: Frt Sens. Drv. Assist
    Address D6: Light Ctrl Left 2
    Address D7: Light Ctrl Right 2
    End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    So the gateway doesn't think your seat memory module is alive. The seat memory control module owns all the adjustment buttons and drives all the motors, so it's got to be alive and working for the buttons to do anything.
    But here it is, talking to VCDS just fine. That means it's got power and it's talking on CAN. But your gateway disagrees. That's extremely odd.
    PartsLink24 shows this car should have left the factory with seat memory module 5Q0 959 760 C and you have B. I have a Golf seat memory retrofit project on my workbench, and if memory serves, that part changed between the Mk7 and Mk7.5 facelift.
    Looking at the airbag module, I see the car popped the forward AND side curtain airbags on both the driver and passenger side. If I were to make a wild guess, I'd say the side airbags in the seat also went off, and you fixed that by swapping in salvage yard seats as a complete assembly, and that got you a seat memory control module that's older than what the car expects. If you still have the original seats, grab the control module off the bottom and trade.
    If that's not it, then we're going to need a lot more detail about what repairs you've been doing, either replacements or rewiring. The gateway and BCM part numbers look legitimate, but they're also complaining about Component Protection, which is an indicator there may have been more salvage-yard part-swapping or rewiring projects going on.
    Silence gives consent.
  3. Likes PetrolDave, Uwe, DV52 liked this post
    Oct 2016
    Australia
    @jyoung8607 wow mate thanks for the writeup! i'll try to list all i know about the car to date.
    no parts were swapped / changed / replaced on the car yet as the seat being stuck in the top forward position makes it difficult to work on the car. all airbags blew up except for the ones in seats. car arrived without a key. a new genuine key was ordered and once arrived got taken to the dealership (with the car on a tow truck) to get it coded in (probably why the component protection comes up)...
    i tried moving the seat using basic settings when in module 36 however it fails with a 'refused' error.
    i'm kinda stuck with it not knowing where to from here. i guess i could disassemble the seat while its bolted to the car however leaving this as plan b.
    is there anything on the CAN gateway i can do to make the 'Seat Mem. Drvr' module recognisable? or there is a better route with this?
    Oct 2016
    Australia
    would a battery disconnect for a day and reconnect make the car to 'rethink' everything, or not that easy?
    Oct 2016
    Australia
    hi guys, would anyone else have any ideas with this one? i'm stuck
