Results 1 to 8 of 8
Thread: VW UP Cruise retrofit successful
    Tartu, Estonia
    This 2018 ecoUP didn't have cruise from factory.
    I helped a guy out and installed it. All new wiring done from scratch. Also added wire for later MFSW.
    VCDS is missing out a ton of information. Like Coding table for BCM and ECU.
    Luckily it is like Polo BCM so cruise bit was same, ECU info I got luckily from another scan.
    I'm still unaware of coding for MFSW and trip buttons to uncode.
    Engine - Byte 5 Bit 5 Cruise installed
    BCM - Byte 17 bit 7 Cruise Installed
    He also had issues with G85 sensor. Seems like VCDS isn't able to calibrate these things anymore as it requires switching to EOL-mode to perform calibration. From ODIS log I can see something about Seed Key login before adaption is carried out.
    Experienced similar thing with newer VW Caddy and Transporter ABS also.
    Saturday,19,October,2019,02:56:44:10298
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
    Dealer/Shop Name: LeVWFreaks.eu
    VIN: WVWZZZAAZJD   License Plate: TÕRUKESE SÕBRA UP VEAVABA
    Mileage: 19870km-12346mi   Repair Order:
    Chassis Type: AA-VW12 (1S0)
    Scan: 01 03 09 10 15 17 19 25 44 5F 61
    VIN: WVWZZZAAZJD   Mileage: 19870km-12346miles
    Address 01: Engine (------CPGA)       Labels: None
       Part No SW: 04C 906 020 EE    HW: 04C 907 309 AF
       Component: R3 1.0l CPI   H12 3828
       Revision: U5H12---
       Coding: 00110030002401000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM10CPI01104C906020EE 001004
       ROD: EV_ECM10CPI01104C906020EE.rod
       VCID: 629D5738C4CD32B7BF3-8036
    Readiness: 0110 0001
    Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
       Part No SW: 1S0 614 517 P    HW: 1S0 614 517 P
       Component: EBC 460 ESP   H17 0030
       Serial number: A01R5TR
       Coding: 12BF247129B602F748FE24F994AD40505F0100
       ASAM Dataset: EV_Brake1ESPEBC460TRW 002107
       ROD: EV_Brake1ESPEBC460TRW_002_VW25.rod
       VCID: 3C21C94006E92447D5F-8068
       Part No SW: 1S0 937 090 H    HW: 1S0 937 090 H
       Component: BCM PQ25 1MX4 H82 0752
       Revision: BW082001    Serial number: 5000 103180756
       Coding: 62B8290000010000080001D06CABACD079C0706D60CF2D602101000B0800
       VCID: 3829D55032510867317-806C
       Subsystem 1 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.405  H04 0005
       Serial number: 0000FST001ZIC5Z00000
       Coding: 181000
    Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
       Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
       Component: PARKHILFE 3K  H03 0013
       Revision: --------    Serial number: 32931809606569
       Coding: 108004
       ASAM Dataset: EV_EPHVA14VW1200000 001009
       ROD: EV_EPHVA14VW1200000.rod
       VCID: 392FD05409DB116FCE9-806C
       Part No SW: 1S0 959 655 C    HW: 1S0 959 655 C
       Component: VW10Airbag02W H03 0007
       Revision: --------    Serial number: 003UB00666EX
       Coding: 000000000000000000000000000000003257
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
       VCID: 3E25C34810F53657FBB-806A
       Serial number: 3575HRB400U5DPT679OC
       Serial number: 3585HRB401G5DNAKFH1T
       Serial number: 3557BRB40535ALPUM8B+
    Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
       Part No SW: 1S0 920 870 B    HW: 1S0 920 870 B
       Component: KOMBI         H05 0010
       Revision: X0005001    Serial number: 00000000000000
       Coding: 114A010000
       ASAM Dataset: EV_KombiUDSMM9RM10 A05808
       ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
       VCID: 3039ED70DAA1D027797-8064
       Part No SW: 1S0 909 901     HW: 1S0 937 090 H
       Component: GW-K-CAN TP20 H82 0752
       Revision: BW082001
       Coding: 001000
       VCID: 70B92D701AA19027397-8024
       Part No SW: 5K0 953 234     HW: 1S0 920 870 B
       Component: IMMO          H05 0010
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       VCID: 6A8D3F183CFD6AF7773-803E
    Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
       Part No SW: 6R1 909 144 AN    HW: 6R1 909 144 E
       Component: EPS_TRW_ALow  313 3150
       Serial number: CI4G0601
       Coding: 000700
       Shop #: WSC 63672 002 1048576
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 035372BC3B979BBFD45-8056
       Part No SW: 1S0 035 867     HW: 1S0 035 867
       Component: MU-E--EU      069 7358
       Serial number: 20031800020627
       Coding: 02210000280000004011000101000200000004C40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       VCID: 71BF2874112B992F369-8024
       Part No SW: 1S0 907 534     HW: 1S0 937 090 H
       Component: Batt.regelung H82 0752
       Coding: 032B7864
       Subsystem 1 - Part No SW: 1S0 915 181 C    HW: 1S0 915 181 C
       Component: J367-BDM  H08 0270
       Serial number: 55086C07015861933171
    End----------(Elapsed Time: 00:46, VBatt start/end: 13.2V/13.2V)-----------
    The world is my oyster...
    A ton, maybe kilo's
    Just ask.
    I have to check later if there should be more items.
    I would think it should be possible.
  3. Likes Dana, dnoermann liked this post
    Tartu, Estonia
    I've sent adpmaps to support@.... .
    I'll also leave this here. It was good to know, that this car had BCM-high due to sunroof. Honestly, I didn't check this beforehand.
    https://www.upownersclub.co.uk/forum...e-control.html
    Also, What was intresting for me, that MVB 004.2 - CCS Cancel switch was always ACTIVE, when You pushed it in Cancel position, it became not operated.
    Thanks Niels, once the guy gets MFSW installed I'll do coding.
    PS! This car will also get AC retrofitted, luckily not by me.
  5. Likes Dana liked this post
    United States
    Thanks Magnus,
    I replied to your maps with ABS EOL suggestions in the event that you have time to test that when the MFSW is installed.
    Next, as far as that momentary (or inverted) CCS position goes we still have some discrepancies in that area:
    https://forums.ross-tech.com/showthr...679#post157679
    I believe there is either difference between CCS via Stalk -and- MFSW ... or there is a difference between steering wheel types (MK6 versus Mk7 button arrangements and LIN type). The 2017 Jetta S (with factory Mk7 wheel) showed Cancel Not Oper. when released and Operated only when pressed momentarily.
    Hopefully we sort out the details so all of the PQ25 family BCM labels are correct in the future.
  7. Likes Uwe liked this post
  8. #5
    Aug 2016
    The Hague, NL
    Does it have a start/stop system (bluemotion/bluemotion tech)? If so, you'll have the BCM Max 090x for that reason.
  9. Likes Uwe liked this post
  10. #6
    Tartu, Estonia
    Indeed it does.
  11. #7
    Mar 2019
    Croatia
    i wrote in other topic regarding MFSW for vw UP tried on 2 vw Up
    one is 2017 and has BCM - 1S0 937 090 F not possible to code MFSW
    and other is 2019 - 1S0 937 090 J - i can code MFSW but tested not working
    i bought original Wheel from Vw Up 2019 and installation for Vw Up 2019
    and still have this error
    Saturday,12,October,2019,17:01:49:36287
    VIN: WVWZZZAAZKD160355   License Plate:
                    Address 09: Cent. Elect.       Labels: Redir Fail!
    Control Module Part Number: 1S0 937 090 J    HW: 1S0 937 090 J
      Component and/or Version: BCM PQ25 1MX4 H82 0762
               Software Coding: 7FB829002001000000080FC06CABBCD079C0706D60CF2D602101000B0900
                Work Shop Code: WSC 31414 790 00001
                          VCID: 3A2CC714FC574227C4D-806E
    01326 - Control Module for Multi-Function Steering Wheel (J453)
                        Reset counter: 18
                        Mileage: 802 km
                        Date: 2006.14.03
                        Time: 23:40:26
    this is complete coding from Vw Up GTI with MFSW
    can someone source wire diagram for 2019 MF ?
    i have only until 2015
    tnx
  12. #8
    Mar 2019
    Croatia
    So to add some info on this,
    MFSW in UP 2019 is working !
    coding is Ok, but there is no wires to Slip ring, you need to connect one wire from BCM and one +.
  13. Likes Uwe, Dana liked this post
