Results 1 to 9 of 9
Thread: Acc not available, lane assist error, afs steering light error?
    New User
    Oct 2019
    Croatia
    Vw Tiguan original with composition media and AID 5Na920790.
    Retrofitted new AID 5na920791 and discover pro. Removed cp of aid in official dealer discover pro is cracked.
    But all time we had this error acc, line assist and afs steering light. When switch off in coding it is same??
    Put back original composition media all ok?
    Discover pro unit is from 2019 it is possible that something is changed?
    Please help any suggestion?
    Jun 2014
    Swansea, UK
    I'm not sure I understand the question, but for any answers you'll need to post a full Auto-Scan please
  3. Likes myounus, downtime, PetrolDave, Uwe liked this post
    New User
    Oct 2019
    Croatia
    Quote Originally Posted by Mike@Gendan View Post
    I wont to retrofit discover pro mib 2.5, car is originally with composition media without nav.
    After retrofit i have present acc, line assist, afs error. When put back composition media all is ok.
    Nov 2015
    So again, please run an autoscan and post the log here.
  6. Likes PetrolDave, Uwe liked this post
    New User
    Oct 2019
    Croatia
    Quote Originally Posted by Viking View Post
    Currently I am not able to do that due to i dont have discover pro unit with me.
    I know that is difficult to give some answer on this way.
    Nov 2015
    A scan with the original unit would help
  9. Likes PetrolDave liked this post
  10. #7
    Oct 2019
    Ireland
    Iím having the same issue. MIB 2.5 patched firmware
  11. #8
    Oct 2019
    Ireland
    Original composition media
    ;SW:3Q0-035-824-B   HW:3Q0-035-824-B ---  Information Electr.
    ;Component:MU-S--ER      710 0751, Coding:02730600FF00000051110001000808001F0100C60120010003
    ;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW37.rod
    ;Monday,11,November,2019,17:13:49:21692
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    ;VCID: 2C00FF58D68E7CA745F-8078
    IDE00346-Summertime-automatic,manual ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
    IDE02502-Confirmation of installation change,BB F3 ,2
    IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
    IDE10604-Menu entries for mobile online services,not activated ,1
    IDE11122-Country identification: country of sale HMI,IE ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    MAS00951-Bluetooth,On ,1
    MAS01968-Fan,normal ,1
    MAS03782-WLAN,On ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Available ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
    ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,00 ,32
    ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,00 ,32
    ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,00 ,32
    ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,00 ,32
    ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,00 ,32
    ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,00 ,32
    ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,00 ,32
    ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,00 ,32
    ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,00 ,32
    ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,00 ,32
    ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,00 ,32
    ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,00 ,32
    ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,00 ,32
    ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,00 ,32
    ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,00 ,32
    ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,00 ,32
    ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,00 ,32
    ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,00 ,32
    ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,00 ,32
    ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,00 ,32
    ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,00 ,32
    ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,00 ,32
    ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,00 ,32
    ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,00 ,32
    ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,00 ,32
    ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,00 ,32
    ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,00 ,32
    ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,00 ,32
    ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,00 ,32
    ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,00 ,32
    ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,00 ,32
    ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,00 ,32
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE ,40
    ENG117808-p_HMI_Display,13 %,1
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    Elapsed Time: 00:34
  12. #9
    Jul 2014
    Tallinn, Estonia
    Also post a full unedited autoscan and admap of the MIB2.5.
