2017 a3 etron headlight drl activation
Chuck.Dee
Palmton, Ca
C?ID=10180
Is there a way to activate the hadlight drl on a 2017 a3 etron? The fogs are already set as drl but would like to disable those and set the headlight as drl like my s3.
siLc
Tallinn, Estonia
C?ID=330192
Not only autoscan but also admap of module 09.
Chuck.Dee
Palmton, Ca
C?ID=10180
Monday,14,October,2019,21:17:09:18420
VCDS Version: 19.6.2.0 (x64)
VIN: WAUTPBFFXHA042906 License Plate:
Chassis Type FF-AU37 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 3C 42 44 47 51 52
55 5F 6C 75 8C BB BC C0 C6 CF
VIN: WAUTPBFFXHA042906 Mileage: 42941km-26682miles
C6-Batt. Chrg. -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CXUA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 023 AN HW: 04E 907 309 F
Component: R4 1.4l TFS H22 3695
Revision: X3H22---
Coding: 021D0012632401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906023AN 008005
ROD: EV_ECM14TFS01104E906023AN_008.rod
VCID: 6CDD983C87CC032F6B-8038
Readiness: 1110 1101
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DD 300 046 A HW: 0DD 927 770 C
Component: GSG DQ400E H32 1602
Revision: 00032056 Serial number: TFK01607280044
Shop #: WSC 00099 780 00200
ASAM Dataset: EV_TCMDQ400021 001001
ROD: EV_TCMDQ400021_VW41.rod
VCID: 2649AA1459A0F97FFD-8072
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 BL HW: 5Q0 614 517 AH
Component: ESC H62 0855
Revision: 00000000 Serial number: 62216000000995
Coding: 12FF40923824226E89800A0081C92948021C44915081947212A10054828802
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
VCID: 7CFDA87CF7AC93AFFB-8028
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0414876571
Coding: 030C0C
VCID: 3B7F6B60B2225497B2-806E
Part No SW: 8V0 820 043 S HW: 8V0 820 043 S
Component: AC Automat H03 0610
Revision: 20001000 Serial number: 00000001022948
Coding: 0300001001000000080000000000140001000000
ASAM Dataset: EV_AirCondiFrontNARAU37X 001019
ROD: EV_AirCondiFrontNARAU37X.rod
VCID: 42811684D5C8255FF1-8016
Subsystem 1 - Part No SW: 4M0 959 603 HW: 4M0 959 603
Component: G395 pT-Sens1 H61 0006
Subsystem 2 - Part No SW: 3Q0 963 231 D HW: 3Q0 963 231 D
Component: J848 HV-PTC 200 0204
Serial number: -00103.2T.3B20340198
Subsystem 3 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: B848444800PAG0MUFU02
Subsystem 4 - Part No SW: 5QE 816 803 C HW: 5QE 816 803 C
Component: J842 eKK H02 0006
Serial number: IABB00000K000000013B
Part No SW: 5Q0 937 085 BF HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H34 0236
Serial number: 02001620400690
ROD: EV_BCMBOSCH_017.rod
VCID: 7EF9A274E1B081BFD5-802A
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160808 043 0580
Serial number: 160815043323
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62163726
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H05 0032
Serial number: 27 06 2016 00001009
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000066832181
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST00151FQC00000
Coding: 101F00
Part No SW: 5QA 919 294 HW: 5QA 919 294
Component: PDC 8 KanalH07 0031
Serial number: 000308418616230
Coding: 0430155011
ASAM Dataset: EV_EPHVA18AU3700000 009027
VCID: 0913C1A8A87EB607F0-805C
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: D500008218F78428949C8055000024
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
Component: AirbagVW20 010 0830
Serial number: 003GCR05S1EK
Coding: 9DFCFCC0002000009000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47970790FEEA007726-8012
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34230167A25081640366
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34230168A25081650063
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001J2Z5
Coding: 303334
Subsystem 4 - Part No SW: ----------- HW: 480 002 608 16
Serial number: 35700000000588956D1R
Subsystem 5 - Part No SW: ----------- HW: 480 002 608 16
Serial number: 35800000000388956D1Q
Subsystem 6 - Part No SW: ----------- HW: 480 402 608 16
Serial number: 3510001A12216EE1A4D2
Subsystem 7 - Part No SW: ----------- HW: 480 402 608 16
Serial number: 3520001A12216EE3766/
Subsystem 8 - Part No SW: ----------- HW: 480 402 507 16
Serial number: 3550002AB211FA3443B4
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 507 16
Serial number: 3560002AB211FA32C298
Part No SW: 8V0 953 521 JR HW: 5Q0 953 549 E
Revision: -------- Serial number: 17081604400209
Coding: A418
VCID: 132FE3C0FA327CD70A-8046
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 894 HW: 8V0 920 894
Component: FBenUSA H13 0045
Coding: 00640C512B98CF050283FE101B00000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
Address 19: CAN Gateway (J533) Labels:* Redir Fail!
Part No SW: 5QE 907 530 F HW: 5QE 907 530 A
Component: GW MQB EV 312 3265
Revision: -------- Serial number: 10081610520328
Coding: 0201001726F200005B00120C58100000000101010001000000 0300000000
ASAM Dataset: EV_GatewEVConti 013020
ROD: EV_GatewEVConti_013.rod
VCID: 499301A8E8FEF60730-801C
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20160818143945 20765
Subsystem 2 - Part No SW: 5QE 915 181 A HW: 5QE 915 181 A
Serial number: 3478810604
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 5QE 909 059 E HW: 5QE 909 059 B
Component: EBKV H14 0200
Serial number: 085430010782
Coding: 03720100331A00030002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
VCID: 50A52CCC0BA4C7CF77-8004
Brake Assistance Sub:
Subsystem 1 - Part No SW: 5QE 909 057 C HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0152
Serial number: 05802861020816083946
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000146449006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346D405C9F7C9BEF73-8060
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 D HW: 3Q0 907 566
Component: MRR1Rear H16 0410
Revision: --------
Coding: 040002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
VCID: 39737168B81E6687A0-806C
Component: TSG FS 020 0041
Serial number: 310516EEV05449
Coding: 005D1F204000048000000002
VCID: 438F1380CAD22C57FA-8016
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: C106
ROD: EV_SteerAssisMQB_013.rod
VCID: 458B0D98C4E61267D4-8010
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0100
Revision: 00000001 Serial number: AUZ8ZAGHX007Y0K
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 62C1F6047508455FD1-8036
Address 51: Electric Drive (J841) Labels: None
Part No SW: 5G0 907 080 E HW: 5G0 907 080 E
Component: LE Gen 3.3H11 1032
Revision: 00H11000
Coding: 40020000000000000000
ASAM Dataset: EV_DMCM08530115G0907080E 001008
ROD: EV_DMCM08530115G0907080E.rod
VCID: 2953A12848BED607D0-807C
Component: TSG BFS 020 0041
Serial number: 060816EH505328
Coding: 005D17204000048000000002
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Coding: 0E5A001123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
VCID: 3E796274A13041BF95-806A
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 880 HW: 8V1 035 880
Component: MU-P-LNS-US 052 0694
Serial number: A702H0G7511094
Coding: 017393020000000011220002041A00102F0029E5017001047E
VCID: 77F7B750CE8AB0F796-8022
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY2071HU
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL118081600010143
Component: Gracenote2--- --- 3009
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273100102002001400040
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 017393011080BA0100F800000000
ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 5Q0 915 182 E HW: 5Q0 915 182 C
Component: BECM H05 1101
Serial number: U2220052
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006042
ROD: EV_BECM09620115Q0915182.rod
VCID: 356B7D58940682E744-8060
Battery Junction Box:
Subsystem 1 - Part No SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Component: BJB H28 0240
Cell module: control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D1 H14 0481
Serial number: V013C1630830547
Cell module: control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D2 H14 0481
Serial number: V013C1630830548
Cell module: control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D3 H14 0481
Serial number: V013C1630830545
Cell module: control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D4 H14 0481
Serial number: V013C1630830602
Cell module: control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D5 H14 0481
Serial number: V013C1630830533
Cell module: control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D6 H14 0481
Serial number: V013C1630830515
Cell module: control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D7 H14 0481
Serial number: V013C1630830585
Cell module: control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 E HW: 5QE 915 591 E
Component: 6D8 H14 0481
Serial number: V013C1630830546
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 150816BHD0810A
Coding: 000C17204000048000000002
Component: TSG HBFS 020 0041
Serial number: 150816BHD08101
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 L HW: 5QE 035 335 B
Component: E_SOUND_SG H09 0212
Serial number: EN163119290000
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 006013
ROD: EV_ENoiseS1NNVW3707_006.rod
VCID: 4A913EA4EDF8FD1F39-801E
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 AP HW: 5QE 915 682 AG
Component: OBC KOSTAL H31 4114
Revision: -------- Serial number: 0508160GT000T4
Coding: 105168023000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P.rod
VCID: 1B3F8BE012E2349752-804E
Address CF: Lane Chge Asst 2
Interface not compatible.
End-------------------------(Elapsed Time: 06:10)----------------------
Chuck.Dee
Palmton, Ca
C?ID=10180
Don't know how to get the adaption map of moulde 09, any pointers?
[Applications]
[Controller Channel Map]
- Single Controller Address = 09
- Login or Secruity Access: leave blank
- Function: set to Adaptation
- Output: set to CSV file
[Go]
See also:
https://www.ross-tech.com/vcds/tour/controller-channels-map.php
And PLEASE do not split data into multiple messages. Put one scan, or one map, into one message. Use CODE tags.
Chuck.Dee
Palmton, Ca
C?ID=10180
;SW:5Q0-937-085-BF   HW:5Q0-937-085-BF ---  Cent. Elect.
;Component:BCM MQBAB MNA H34 0236	 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB	17001	EV_BCMBOSCH_017.rod
;Sunday	20	October	2019	14:53:48:18420
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 7EF9A274E1B081BFD5-802A
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Exterior lighting	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01550-Service position	133.197670 °	2
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal 	10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	not active 	10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active 	10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	300 ms	10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	300 ms	10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	300 ms	10
IDE02332-Deactivate production mode	0	3
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	3 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	1 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	5 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	5 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	not active 	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	1000 ms	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-0.3 °	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	OFF 	16
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	90 °	16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	30 °	16
IDE03638-ENG116676-static AFS light-Upper speed threshold	32.0 km/h	16
IDE03638-ENG116674-static AFS light-Vorschrift	OFF 	16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
IDE03787-Activate left/right hand drive switch-over	not active 	1
IDE04927-IDE01446-Window heater-Running time of heated front window	600 s	11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
IDE04927-ENG126845-Window heater-FSH Automatik	not active 	11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s	11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	not active 	11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	8
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active 	8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham 	8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Sounder_verbaut 	8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	installed 	8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
IDE04928-ENG142249-Anti-theft device-OBD Alarm	activ 	8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	Yes 	8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
IDE05144-Read parameter address	00 00 00 	3
IDE05145-Light configuration	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 04 45 00 1E 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 	224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	28.00 °C	30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	27.50 °C	30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	28.00 °C	30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	27.50 °C	30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	41.00 °C	30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	40.50 °C	30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	41.00 °C	30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	40.50 °C	30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	63.00 °C	30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	62.50 °C	30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	63.00 °C	30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	62.50 °C	30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
IDE06425-Roller test bench mode: functional	not active 	1
IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop 	8
IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED not installed 	8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
IDE07356-Position during interval mode	21.197781 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit 	6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	not active 	6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	active 	9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.00 s	19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	0	19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	0	19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	0	19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	0%	19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	0%	19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	0%	19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	0%	19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	0%	19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active 	19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active 	19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	active 	19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	not active 	19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	active 	19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	not installed 	19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	installed 	5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	active 	5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	installed 	5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	not installed 	17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
IDE10298-Alternating park position 1	18.197784 °	2
IDE10299-Alternating park position 2	21.197781 °	2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	1	256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	1	256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	100%	256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	100%	256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	100%	256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	100%	256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	100%	256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	100%	256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	100%	256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	100%	256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	100%	256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	100%	256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	100%	256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	100%	256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	100%	256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	100%	256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	0.0 s	256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s	256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	225	30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	225	30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	225	30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	225	30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	225	30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	225	30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	225	30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	225	30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	225	30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	225	30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	225	30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	225	30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	225	30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	225	30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	225	30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	225	30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	225	30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	225	30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	225	30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	225	30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	225	30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	225	30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	225	30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	225	30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	225	30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	225	30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	225	30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	225	30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	225	30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	225	30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	installed 	3
IDE11944-ENG141948-Keyless access and start authorization-Kessy	installed 	3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	active 	3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	active 	3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
MAS01490-ENG141978-Energy management-Recuperation	active 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS05055-lower turn position	26.197776 °	2
MAS05056-upper turn position	166.197637 °	2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	1000 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 50 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	6000 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	0	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	0	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	0	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	0	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	0	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	0	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	0	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	0	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	0	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	0	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	0	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	0	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	0	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	0	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	0	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	NOT-DEFINED 	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	NOT-DEFINED 	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	NOT-DEFINED 	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	NOT-DEFINED 	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	NOT-DEFINED 	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	NOT-DEFINED 	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	NOT-DEFINED 	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	NOT-DEFINED 	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	NOT-DEFINED 	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	NOT-DEFINED 	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	NOT-DEFINED 	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	NOT-DEFINED 	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	NOT-DEFINED 	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	NOT-DEFINED 	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	NOT-DEFINED 	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	active 	10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	active 	10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	active 	10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	active 	10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	active 	10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	active 	10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	active 	10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	active 	10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	active 	10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	active 	10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	4 km/h	9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	not active 	9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	active 	9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	active 	9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	installed 	9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active 	9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active 	9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active 	9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	active 	9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen 	9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No 	5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	60 km/h	5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	active 	5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	installed 	18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	abschaltbar über Energiemanagement 	18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	abschaltbar über Energiemanagement 	18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	Hinweis_in_LDS-Stellung_Null_und_SL 	18
ENG141656-ENG133382-Außenlicht_uebergreifend-Faktor fuer Verfügbarkeitstimer	Faktor fuer x1 Stunden 	18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	6400 lx	18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	separate 	18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	false 	18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	Yes 	18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	LIN 	18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	installed 	18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung aktivieren 	18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	20 seconds 	18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	60 seconds 	18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	active 	18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	8 s	18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
ENG122934-erase_error_table	55 00 00 	3
ENG122933-error_mask	0 bit	2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	AFS: Fernlicht ueber AFS 	6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	active 	6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	Not Present 	6
ENG141685-Front_wash_function	10	2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	active 	6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	500 ms	6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	not active 	6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	2000 ms	6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	active 	6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
ENG99457-ENG117394-Head area heater-blower_speed	0	2
ENG99457-ENG98971-Head area heater-Temperature	-3	2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	installed 	8
ENG141645-ENG142026-HW_Verbau-Druckklappe	installed 	8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	installed 	8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	not active 	8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	active 	8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	0.00%	30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	-0.10%	30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	-0.60%	30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	-1.10%	30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	-1.60%	30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	-2.10%	30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	-2.60%	30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	-3.1	30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	-3.60%	30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	-4.10%	30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	100.00%	30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	89.50%	30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	83.00%	30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	75.50%	30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	68.00%	30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	61.00%	30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	56.50%	30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	47.00%	30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	40.00%	30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	33.00%	30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	0	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	0	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	0	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	not active 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	not active 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E 	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	45	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	4 - LED Tagfahrlichtmodul Signal 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Versorgungsbedarf der LCM Module 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	127	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	5D 	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	36	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	6 - LED Lichtmodul 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Coming Home oder Leaving Home aktiv 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	127	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	5E 	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	40	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	6 - LED Lichtmodul 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Coming Home oder Leaving Home aktiv 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	85	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	35	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0A 	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	Coming Home oder Leaving Home aktiv 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	85	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	36	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	1A 	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	Coming Home oder Leaving Home aktiv 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	minimize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	minimize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	127	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	127	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	3F 	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	38 - LED Blinkleuchten 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Brake light 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	Blinken links aktiv (beide Phasen) 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	Blinken links Hellphase 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	Blinken links Dunkelphase 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	minimize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	minimize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	127	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	127	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	40	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	38 - LED Blinkleuchten 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Brake light 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	Blinken rechts aktiv (beide Phasen) 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	Blinken rechts Hellphase 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	Blinken rechts Dunkelphase 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	4	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	0	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	46 - LED Kleinleistung 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Ambientelicht 2 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	minimize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	0	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	127	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	127	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	35 - kombinierte LED Blink-Bremsleuchten 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	not active 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Brake light 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Blinken links Hellphase 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	Blinken links Dunkelphase 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	minimize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	0	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	127	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	127	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	35 - kombinierte LED Blink-Bremsleuchten 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	not active 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Brake light 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Blinken rechts Hellphase 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	Blinken rechts Dunkelphase 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	80	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	50	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Coming Home oder Leaving Home aktiv 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	80	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	50	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Coming Home oder Leaving Home aktiv 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Parking light right 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	127	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	Coming Home oder Leaving Home aktiv 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	beidseitiges Dauerparklicht 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	minimize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E 	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0C 	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	37 - allgemeine LED bis 12W 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	Left high beam 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	minimize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	100	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F 	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	1C 	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	37 - allgemeine LED bis 12W 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	Right high beam 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	37 - allgemeine LED bis 12W 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	37 - allgemeine LED bis 12W 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	127	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	61	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	36 - LED Kleinleistung 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Unknown (73)	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	46 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	100	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	100	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 2 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	100	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 3 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	100	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 4 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	127	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	62	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	36 - LED Kleinleistung 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Unknown (74)	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	0	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	0	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	0	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	not active 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	not active 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	0	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	0	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	0	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	not active 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	not active 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	127	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	6 - LED Lichtmodul 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	Coming Home oder Leaving Home aktiv 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	127	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	6 - LED Lichtmodul 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	Coming Home oder Leaving Home aktiv 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	127	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	4B 	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	44	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	6 - LED Lichtmodul 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Versorgungsbedarf der LCM Module 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	Parking light right 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	127	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	49	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3A 	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	6 - LED Lichtmodul 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Versorgungsbedarf der LCM Module 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	26 08 00 3F 18 00 7F 1A 06 80 02 00 7F 03 00 80 26 18 00 40 18 00 7F 1A 07 80 04 00 7F 05 00 80 23 13 00 3D 00 00 00 18 00 7F 02 00 7F 03 00 80 23 23 00 3E 00 00 00 18 00 7F 04 00 7F 05 00 80 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 1E 50 09 00 32 00 00 00 00 00 00 2B 1A 00 2A 08 1E 50 0A 00 32 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 3A 00 7F 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 0D 00 80 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 0E 00 80 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
ENG141662-Leuchtenkonfiguration_Sonstiges	2B 0A 00 35 08 1E 55 00 00 00 00 00 00 00 00 00 2B 1A 00 36 08 1E 55 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	2650 mm	62
ENG141658-ENG142218-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_H4	4.50 mm/%	62
ENG141658-ENG142217-Leuchtweitenregulierung-Achssensor_PWM_Wert_Einfederung_Sensor_vorn	3.30 mm/%	62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	active 	62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	84.00%	62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	20.00%	62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	4.10 mm/%	62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	4.70 mm/%	62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	3.30 mm/%	62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	3.30 mm/%	62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Mehrlenkerhinterachse Frontantrieb 	62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	70.00%	62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.10 Hz	62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	1	62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	10 mm	62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	10 mm	62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	10 mm	62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	10 mm	62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	550 mm	62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	680 mm	62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	5.00%	62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	5 km/h	62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	10.00 Hz	62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	not active 	62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	60.00%	62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	active 	62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	5.0 %/s	62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	20.00%	62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	0.00 s	62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	0.00%	20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-0.55%	20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-1.10%	20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-2.40%	20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-2.80%	20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	0.3	20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	0.2	20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	0.8	20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-4.6	20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-0.2	20
ENG122979-ENG141954-Networking-A/C electronics	installed 	8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
ENG122979-ENG99457-Networking-Head area heater	not installed 	8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
ENG122979-ENG141969-Networking-UGDO	not installed 	8
ENG124714-ENG142044-OCU-DWA_push	not active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
ENG124714-OCU-	not installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	0 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	0	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	0 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	0.0 ms	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	0	16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	not active 	16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_inactive 	16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG142030-Personalization-Profil_Variante	Schluessel 	16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	not active 	16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	not active 	16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
ENG141646-MAS01065-Querschnitts_funktionen-Brand	Audi 	5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin 31 	5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	installed 	5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
ENG122927-RLS_close_glazing	2.0 s	1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s	3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s	3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h	3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h	3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx	2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12	2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6	2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s	2
ENG122929-RLS_LIN_Communication	4 s	1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	100 lx	1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	200 lx	1
ENG122930-RLS_tunel_gateway_recognize	5 s	1
ENG122935-RLS_Washer_Front	15 s	1
ENG122926-RLS_wiper_position_parking	15 s	1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	8	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active 	10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	1000 ms	10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	1200 ms	10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	1000 ms	10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	1000 ms	10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	1200 ms	10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	SMLS 	4
ENG116588-Sonderfunktionen-	not enabled 	4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by look command via remote control key 	5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	active 	5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	not active 	5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG142236-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xs PWM	0.00 s	21
ENG141663-ENG142238-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xt PWM	0.00 s	21
ENG141663-ENG142239-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG142237-Suchbeleuchtung_allgemein-Daempfung Aufdimmen KL 58xt PWM	0.00 s	21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	0.0 s	21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	0.0 s	21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	active 	21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	5	21
ENG141663-ENG142235-Suchbeleuchtung_allgemein-PWM Daempfung Aufdimmen KL58xs PWM	0.00 s	21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	50%	21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.248	21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	1.00%	21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	100	12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	150	12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	6.00%	12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	6.00%	12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	16.00%	12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	30.00%	12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	60.00%	12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	200 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	400 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	600 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	84	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	166	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	250	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	370	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	active 	4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	active 	4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	installed 	4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	active 	9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active 	9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active 	9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active 	9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	active 	9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	nur wenn freigegeben 	9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active 	9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active 	9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active 	9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	42	3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	62	3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30	3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active 	7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	not active 	7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
ENG141651-ENG141958-ZV allgemein-Tankschloss	unidirectional 	7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	active 	4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	active 	4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active 	7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	via_CAN 	7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active 	7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	not active 	7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Pulse control 	7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	active 	7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	not active 	8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active 	8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	active 	8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	active 	8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	Tuersteuergeraet im Fond verbaut oder keine Fondtuer 	5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
Elapsed Time: 02:27
Nice. Someone who understands the Leuchte (Lighting) channels better than I do will almost surely be along to help you with this.
DV52
C?ID=194404
^^^ Chuck (what a magnificent Yankee name!): Hi and thanks for posting the admap - very interesting!
hmm....... not sure that I comply with Uwe's qualifications to respond, and my familiarity with an e-tron (as distinct from the more normal A3 8V - which I drive) is not good- but with these caveats, consider the following:
Setting Headlights as DRLs
Try this:
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 > Daytime running lights (not active)
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 > Daytime running lights (not active)
note: when you select the allowable settings for the channels above, VCDS presents 2 x "Daytime running light" options as shown in the first screen below. Select the first of these options (i.e. 1A)
...... And, if the above suggestion isn't successful add the following amendment (i.e. choose the 2nd option of "Daytime running light" for ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag - 2B)
Deactivating DRL from Front Fog-lights:
Without intending any offense, your observation that the fog-lights are set as DRLs isn't strictly correct - although it's understandable why you might believe this to be the case. In fact, my suspicion is that the lamps aren't viewed by the e-tron designers as fog- lights at all (but I could be mistaken). Does your e-tron have an LDS (rotary-light-switch) with a front fog light position?
Apart from the coming/leaving home function, the active leuchte-command from your admap on the left and right side Leuchte-sets for the front fogs is Klemme 15 mit Nachlauf bis Fahrzeugstillstand - which instructs the front fogs to Illuminate when the ignition is switched-on, or if the vehicle rolls. So, it would indeed seem that the front fogs act as DRLs - but importantly (and unlike the normal DRL function), these 2 x lamps also, and always stay illuminated whenever the low-beams are switched-on - I suspect!
Try this:
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C > Daytime running lights (not active)
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C > Daytime running lights (not active)
When you implement these changes - the default settings for the allied Dimmwert CD channel (i.e. zero) and Dimming Direction CD channel (i.e. maximize) should switch-off the lamps ONLY during daylight conditions - I hope!
Please report your observations
Chuck.Dee
Palmton, Ca
C?ID=10180
Lol my yankee name. No worries Im not offended 1 bit. Thanks for the help.
Coding works but turns on the low beam along with the out portion of the headlights. I just want the outter portion to work as the drl, and without the winking turn signal. Is there a way to do that?
DV52
C?ID=194404
.........Coding works but turns on the low beam along with the out portion of the headlights. I just want the outter portion to work as the drl, and without the winking turn signal. Is there a way to do that?
Chuck/Charles/Charley/Chaas/Chip: Thank you for your feedback.
It's most likely the fact that we Aussies have bastardized the form of English that our colonial masters gave to us that causes my confusion. Or maybe it's the American accent (it's great to hear, but it's difficult to understand -entirely my fault).
The lamp(s) that your are now calling "the outer portion" of the headlights is I assume what Audi identifies as the all-weather-lights and which I'm guessing (because of my unfamiliarity with NAR e-tron) is what we have been referring to the "front fog lights" in our initial chat.
From your first post (see below) I had understood that you wanted the front-fogs/all-weather lights to NOT function as DRLs
..............The fogs are already set as drl but would like to disable those and set the headlight as drl....
I had omitted the changes below in my first response. So - if you want the front-fogs/all-weather lights to NOT function as DRLs, add these mods.:
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 > minimize
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 > minimize
Now - again because of our local version of English, I have no understanding of what "and without the winking turn signal" means - alas.
There is a function associated with DRLs which is euphemistically called DRL-wink - which dims/switches-off the DRL on the side of the car of the turn signal, when activated. From your admap, I notice that a form of DRL-wink happens on the tail-lights on your car - but I don't believe that DRL-Wink happens on the headlights.
Andy
Sector 7G
HC424490
I have a 2018 A3 e-tron and I remember looking into this shortly after I got the car in December, 2017. I was able to turn on the upper DRL along with the lower one but it also put the rear lights on all the time as well:
From my notes at the time:
"I did a SA with 31347 and changed this:
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
to Active and it achieved the desired results. I now have the lower L shaped LEDs on as DRLs plus the outlines of the headlights.
As a side effect, this also causes the tail lamps to come on when DRLs are on. That's not the case in the factory setting. I'm leaving this back to factory setting for now.
Chuck.Dee
Palmton, Ca
C?ID=10180
Dv52, what andy posted above os what aim looking for. Thats the outter rim of the headlight i want as drl. His coding worked but cuts the rears on also, that I don't want.
Andy, thanks for posting. Glad im not the only one thats looking into things for the etron
DV52
C?ID=194404
^^^ Andy: that's the tweak for "Scandanavian DRLs"
Chuck: OK
Chuck.Dee
Palmton, Ca
C?ID=10180
DV52 any luck finding which feature needs to be turned on?
DV52
C?ID=194404
Chuck: Hi again. My personal credo is "a problem shared is a problem abrogated"!! :D. So - let me tell you my problem
As I understand your situation, you have implemented "Scandinavian DRLs" as per Andy's instructions which has enabled what you call the "out portion of the headlights" - is this correct? I'm not sure of the current status of the front fog-lights on your car - they should stay illuminated ALL the time with the factory Leuchte programming on your car (irrespective of the Scandinavian DRLs). Please advise what now happens with your front fogs.
Further, Scandanavian DRLs also "cuts the rears on" -as you say. You don't want this. It is possible to separately force program each rear lamp with the Leuchte DRL command -but with zero illumination. This will (should?) have the impact of countermanding the Scandinavian DRL function on each tail light. BUT (and there is always a "but"), each of the rear lamps must have sufficient spare channels to accommodate the extra commands - and some of the Leuchte-sets in your BCM admap are very full. Plus - this approach of implementing Scandinavian DRLs and then countermanding some aspects of the tweak is now getting fairly complicated!!
If you agree-I think we need another approach (a simpler way to get your wants)
DV52
C?ID=194404
Chuck: Another problem to share! ;)
One of the peculiarities (for me at least) of MQB platform vehicles is the way that Leuchte-sets (the channels in the BCM that control the car's exterior lighting) are allocated to individual lamps: the allocation of Leuchte-set to lamp position on the car varies across models, across different equipment options within models and across vehicles in different countries.
So, the first task in tweaking lighting activity on MQB platform cars is to identify which Leuchte-set belongs to the lamp in question. Fortunately (for me) I have a reasonable database of BCM admaps from around the world to help - but this is only a guide where some models are concerned, like your A3-etron.
I suspect a better approach (no offense intended to Andy for his suggestion) to achieving your wants is to identify the 2 x Leuchte-sets for the "out portion of the headlights" and tweak these - rather than using Scandinavian DRLs and then countermanding some features. To this end, I've had a look @ my database and @ your BCM admap and my guess (emphasize, "guess") is that perhaps the candidate Leuchte-sets for these lamps are:
Leuchte3SL VRB21 (right-side)
Leuchte2SL VLB10 (left-side)
Now comes the problem: If I look @ your BCM admap, I see that both these Leuchte-sets are active on your car and they both only have one lighting function programed (so, good start) - but VCDS reports that single light function as follows:
In desperation and in the hope that your BCM results are an isolated aberration, I sought solace in Andy's BCM admap HERE and I found this:
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 - missing
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Unknown (73),16
This is not good in confirming, or not- my guess about the correct Leuchte-set for the "out portion of the headlights"
@Andy - can you explain why VCDS is reporting these Leuchte-channels in this manner-please. And do you have any additional intelligence about my guess above?
Chuck.Dee
Palmton, Ca
C?ID=10180
Scanned my buddies 8v RS3 today, hopfully this provides the correct information to get my lights to work like his.
;SW:5Q0-937-085-BN   HW:5Q0-937-085-BF ---  Cent. Elect.
;Component:BCM MQBAB MNA H36 0253	 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB	18001	EV_BCMBOSCH_018.rod
;Saturday	18	July	2020	16:49:06:18420
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 0609CA94B960D9B631-8052
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Exterior lighting	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01550-Service position	133.296571 °	2
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal 	10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active 	10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	not active 	10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active 	10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	300 ms	10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	300 ms	10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	300 ms	10
IDE02332-Deactivate production mode	0	3
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	not installed 	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	3 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	1 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	5 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	5 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	not active 	8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	1000 ms	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-0.3 °	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	OFF 	16
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	90 °	16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	30 °	16
IDE03638-ENG116676-static AFS light-Upper speed threshold	32.0 km/h	16
IDE03638-ENG116674-static AFS light-Vorschrift	OFF 	16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
IDE03787-Activate left/right hand drive switch-over	No_Menue 	1
IDE04927-IDE01446-Window heater-Running time of heated front window	600 s	11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
IDE04927-ENG126845-Window heater-FSH Automatik	not active 	11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s	11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	not active 	11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	8
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active 	8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	not_active 	8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham 	8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Sounder_verbaut 	8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
IDE04928-ENG142249-Anti-theft device-OBD Alarm	activ 	8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	not_active 	8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	Yes 	8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm 	8
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
IDE05144-Read parameter address	00 00 00 	3
IDE05145-Light configuration	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 24 00 00 61 49 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 62 4A 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 1A 0B 00 7F 1E 00 7F 00 00 00 00 00 00 06 40 00 1B 0C 00 7F 1E 00 7F 00 00 00 00 00 00 06 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 06 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 36 00 5D 28 1E 7F 00 00 00 00 00 00 00 00 00 06 40 00 5E 28 1E 7F 00 00 00 00 00 00 00 00 00 	224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	28.00 °C	30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	27.50 °C	30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	28.00 °C	30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	27.50 °C	30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	41.00 °C	30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	40.50 °C	30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	41.00 °C	30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	40.50 °C	30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	63.00 °C	30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	62.50 °C	30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	63.00 °C	30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	62.50 °C	30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Sollspannungsanforderung 14.7 	30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.7 V	30
IDE06425-Roller test bench mode: functional	not active 	1
IDE06507-MAS13125-Button in center console-Function of button 1	not coded/not installed 	8
IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
IDE06507-MAS13132-Button in center console-Function of button 3	Driving program 	8
IDE06507-MAS13135-Button in center console-Function of button 4	not coded/not installed 	8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED not installed 	8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	not installed 	8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
IDE07356-Position during interval mode	21.692286 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit 	6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	not active 	6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	active 	9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	not installed 	9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	2	19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	not active 	19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.00 s	19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	0	19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	0	19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	0	19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	0%	19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0	19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	0%	19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	0%	19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	0%	19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	0%	19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active 	19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active 	19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	active 	19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	not active 	19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	active 	19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	not installed 	19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	0	5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	installed 	5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	active 	5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	installed 	5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%	17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%	17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%	17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%	17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%	17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%	17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%	17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%	17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%	17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	not installed 	17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
IDE10298-Alternating park position 1	18.692289 °	2
IDE10299-Alternating park position 2	21.692286 °	2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	1	256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1	256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	1	256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	100%	256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%	256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	100%	256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	100%	256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%	256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	100%	256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	100%	256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	100%	256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	100%	256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%	256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	100%	256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%	256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%	256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	100%	256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%	256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	100%	256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	100%	256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%	256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	100%	256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	100%	256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%	256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	100%	256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	100%	256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%	256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	100%	256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	100%	256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%	256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	100%	256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	0.0 s	256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s	256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	installed 	3
IDE11944-ENG141948-Keyless access and start authorization-Kessy	installed 	3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	active 	3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	active 	3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
MAS01490-ENG141978-Energy management-Recuperation	not active 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS05055-lower turn position	27.692280 °	2
MAS05056-upper turn position	166.296538 °	2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	1000 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 50 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	4000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	4500 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	6000 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	2000 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active 	4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active 	4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	0	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	0	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	0	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	0	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	0	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	0	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	0	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	0	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	0	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	0	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	0	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	0	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	0	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	0	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	0	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	NOT-DEFINED 	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	NOT-DEFINED 	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	NOT-DEFINED 	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	NOT-DEFINED 	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	NOT-DEFINED 	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	NOT-DEFINED 	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	NOT-DEFINED 	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	NOT-DEFINED 	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	NOT-DEFINED 	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	NOT-DEFINED 	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	NOT-DEFINED 	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	NOT-DEFINED 	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	NOT-DEFINED 	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	NOT-DEFINED 	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	NOT-DEFINED 	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Sollspannungsanforderung 13.5 	23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	active 	10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	active 	10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	active 	10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	3	10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	active 	10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	active 	10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	active 	10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	active 	10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	active 	10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	active 	10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	active 	10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	active 	10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	active 	10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	active 	10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	active 	10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	4 km/h	9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	not active 	9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	active 	9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	active 	9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active 	9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active 	9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active 	9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	active 	9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen 	9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No 	5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	60 km/h	5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	active 	5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	installed 	18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	abschaltbar über Energiemanagement 	18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	abschaltbar über Energiemanagement 	18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	bewusste Aktivierung Fahrer Dauerhaft 	18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Low beam 	18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	Hinweis_in_LDS-Stellung_Null_und_SL 	18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x1 Stunden 	18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Keine_Spannungsanforderung 	18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Keine_Spannungsanforderung 	18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	6400 lx	18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	separate 	18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	false 	18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	Yes 	18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	LIN 	18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	installed 	18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Keine_Spannungsanforderung 	18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung aktivieren 	18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	20 seconds 	18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	60 seconds 	18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	active 	18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	8 s	18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Keine_Spannungsanforderung 	18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
ENG122934-erase_error_table	55 00 00 	3
ENG122933-error_mask	0 bit	2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	AFS: Fernlicht ueber AFS 	6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	active 	6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	Not Present 	6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	Not Present 	6
ENG141685-Front_wash_function	10	2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	active 	6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	500 ms	6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	not active 	6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Keine_Spannungsanforderung 	6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
ENG141682-ENG141966-Front_wiper-Frontwischertyp	LIN 	6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	2000 ms	6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	active 	6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
ENG99457-ENG117394-Head area heater-blower_speed	0	2
ENG99457-ENG98971-Head area heater-Temperature	-3	2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	installed 	8
ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	not active 	8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	0.00%	30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	-0.10%	30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	-0.60%	30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	-1.10%	30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	-1.60%	30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	-2.10%	30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	-2.60%	30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	-3.1	30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	-3.60%	30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	-4.10%	30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	100.00%	30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	89.50%	30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	83.00%	30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	75.50%	30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	68.00%	30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	61.00%	30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	56.50%	30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	47.00%	30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	40.00%	30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	33.00%	30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	0	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	0	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	0	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	not active 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	not active 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Unknown (76)	16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	127	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	5D 	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	36	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	6 - LED Lichtmodul 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Coming Home oder Leaving Home aktiv 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	127	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	5E 	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	40	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	6 - LED Lichtmodul 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Klemme 15 mit Nachlauf bis Fahrzeugstillstand 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Coming Home oder Leaving Home aktiv 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	minimize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	minimize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	127	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	127	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	3F 	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	38 - LED Blinkleuchten 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Brake light 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	Blinken links aktiv (beide Phasen) 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	Blinken links Hellphase 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	Blinken links Dunkelphase 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	minimize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	minimize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	127	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	127	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	40	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	38 - LED Blinkleuchten 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Brake light 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	Blinken rechts aktiv (beide Phasen) 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	Blinken rechts Hellphase 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	Blinken rechts Dunkelphase 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	4	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	0	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	46 - LED Kleinleistung 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Ambientelicht 2 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	minimize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	0	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	127	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	127	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D 	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	13	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	35 - kombinierte LED Blink-Bremsleuchten 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	not active 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Brake light 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	Blinken links Hellphase 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	Blinken links Dunkelphase 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	minimize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	0	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	127	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	127	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E 	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	23	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	35 - kombinierte LED Blink-Bremsleuchten 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	not active 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Brake light 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	Blinken rechts Hellphase 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	Blinken rechts Dunkelphase 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	127	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	127	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	37 - allgemeine LED bis 12W 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Coming Home oder Leaving Home aktiv 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	127	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	127	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A 	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	37 - allgemeine LED bis 12W 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Coming Home oder Leaving Home aktiv 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Parking light right 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	127	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	Coming Home oder Leaving Home aktiv 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	beidseitiges Dauerparklicht 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	minimize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2E 	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0C 	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	37 - allgemeine LED bis 12W 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	Left high beam 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	minimize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	100	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	2F 	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	1C 	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	37 - allgemeine LED bis 12W 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Nebelschlusslicht wenn kein Anhaenger gesteckt 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	Right high beam 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	127	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	37 - allgemeine LED bis 12W 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	127	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	37 - allgemeine LED bis 12W 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	127	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	61	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	36 - LED Kleinleistung 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Unknown (73)	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	46 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	100	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	3	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	Ambientelicht 1 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	100	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	4	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	Ambientelicht 2 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	100	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	5	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	Ambientelicht 3 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	100	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	6	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	Ambientelicht 4 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	127	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	62	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	36 - LED Kleinleistung 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Unknown (74)	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	0	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	0	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	0	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	not active 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	not active 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	0	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	0	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	0	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	not active 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	not active 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	127	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	6 - LED Lichtmodul 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	not active 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	Coming Home oder Leaving Home aktiv 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	127	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	6 - LED Lichtmodul 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	not active 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	Coming Home oder Leaving Home aktiv 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	127	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	4B 	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	44	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	6 - LED Lichtmodul 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Versorgungsbedarf der LCM Module 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	Parking light right 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	127	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	49	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3A 	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	6 - LED Lichtmodul 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Versorgungsbedarf der LCM Module 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	26 08 00 3F 18 00 7F 1A 06 80 02 00 7F 03 00 80 26 18 00 40 18 00 7F 1A 07 80 04 00 7F 05 00 80 23 13 00 3D 00 00 00 18 00 7F 02 00 7F 03 00 80 23 23 00 3E 00 00 00 18 00 7F 04 00 7F 05 00 80 2A 29 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 25 0A 00 29 08 1E 7F 09 00 7F 00 00 00 00 00 00 25 1A 00 2A 08 1E 7F 0A 00 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 3A 00 7F 00 00 00 00 00 00 25 0C 00 2E 1A 00 64 0D 00 80 00 00 00 00 00 00 25 1C 00 2F 1A 00 64 0E 00 80 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 	192
ENG141662-Leuchtenkonfiguration_Sonstiges	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 03 2D 00 64 00 00 00 00 00 00 00 00 00 00 00 00 04 2E 00 64 00 00 00 00 00 00 00 00 00 00 00 00 05 2F 00 64 00 00 00 00 00 00 00 00 00 00 00 00 06 30 00 64 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	2650 mm	62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	active 	62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	84.00%	62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	20.00%	62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-127.0 ms	62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	4.10 mm/%	62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	4.70 mm/%	62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	4.50 mm/%	62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	3.30 mm/%	62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	3.30 mm/%	62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	3.30 mm/%	62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_3 	62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	70.00%	62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.10 Hz	62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	Inverted 	62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	10 mm	62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	10 mm	62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	10 mm	62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	10 mm	62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	550 mm	62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	680 mm	62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	5.00%	62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	5 km/h	62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	10.00 Hz	62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	Rear 	62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	not active 	62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	60.00%	62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	active 	62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	5.0 %/s	62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	20.00%	62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	0.00 s	62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	0.00%	20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-0.30%	20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-0.80%	20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-1.80%	20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-2.10%	20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	0.3	20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	0	20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	0.62	20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	0.8	20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-0.7	20
ENG122979-ENG141954-Networking-A/C electronics	installed 	8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	not installed 	8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
ENG122979-ENG99457-Networking-Head area heater	not installed 	8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
ENG122979-ENG141969-Networking-UGDO	not installed 	8
ENG124714-ENG142044-OCU-DWA_push	not active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	not active 	8
ENG124714-OCU-	not installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	0 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	0 Hz	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	0 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	0 ms	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	not_active 	8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	0	16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	not active 	16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_inactive 	16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	not active 	16
ENG98831-ENG142030-Personalization-Profil_Variante	Schluessel 	16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	not active 	16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	not active 	16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	not active 	16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
ENG141646-MAS01065-Querschnitts_funktionen-Brand	Audi 	5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	not active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	installed 	5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
ENG122927-RLS_close_glazing	2.0 s	1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s	3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s	3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h	3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h	3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx	2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12	2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6	2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s	2
ENG122929-RLS_LIN_Communication	4 s	1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	100 lx	1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	200 lx	1
ENG122930-RLS_tunel_gateway_recognize	5 s	1
ENG122935-RLS_Washer_Front	15 s	1
ENG122926-RLS_wiper_position_parking	15 s	1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	8	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	installed 	10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active 	10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	1000 ms	10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	1200 ms	10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	1000 ms	10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	1000 ms	10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	1200 ms	10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Sollspannungsanforderung 13.5 	10
ENG141684-SFT271873-Slave_systems_identification-Control Unit For Wiper Motor	Not available 	6
ENG141684-SFT271874-Slave_systems_identification-Rain Light Recognition Sensor	Not available 	6
ENG141684-SFT271875-Slave_systems_identification-Light switch	Not available 	6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module	Not available 	6
ENG141684-SFT271877-Slave_systems_identification-Garage Door Opener Operating Unit	Not available 	6
ENG141684-SFT271894-Slave_systems_identification-Sensor For Anti Theft Alarm System	Not available 	6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn	Not available 	6
ENG141684-SFT271904-Slave_systems_identification-Sun Roof	Not available 	6
ENG141684-SFT271910-Slave_systems_identification-Ceiling Light Module	Not available 	6
ENG141684-SFT271928-Slave_systems_identification-Roof Blind	Not available 	6
ENG141684-SFT271947-Slave_systems_identification-Relative Air Humidity Interior Sender	Not available 	6
ENG141684-SFT271966-Slave_systems_identification-Neck Heating Left	Not available 	6
ENG141684-SFT271967-Slave_systems_identification-Neck Heating Right	Not available 	6
ENG141684-SFT272065-Slave_systems_identification-Seat Backrest Fan 1 Front Left	Not available 	6
ENG141684-SFT272067-Slave_systems_identification-Seat Cushion Fan 1 Front Left	Not available 	6
ENG141684-SFT272069-Slave_systems_identification-Seat Backrest Fan 1 Front Right	Not available 	6
ENG141684-SFT272071-Slave_systems_identification-Seat Cushion Fan 1 Front Right	Not available 	6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	SMLS 	4
ENG116588-Sonderfunktionen-	not enabled 	4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by look command via remote control key 	5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	active 	5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	active 	5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	not active 	5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	active 	5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250	10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	CAN 	10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	10.0 min	10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	Potentiometer 	21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	0.0 s	21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	0.0 s	21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	active 	21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	5	21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	50%	21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.248	21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	1.00%	21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	500 lx	8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	8 lx	10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	6	10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	100	10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	100	10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	100	10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	100	12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	150	12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	6.00%	12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	6.00%	12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	16.00%	12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	30.00%	12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	60.00%	12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	200 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	400 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	600 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	84	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	166	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	250	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	370	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	active 	4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	active 	4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	installed 	4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	not installed 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	LIN 	4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	not active 	9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	active 	9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active 	9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active 	9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active 	9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	active 	9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	not active 	9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	Always 	9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	nur wenn freigegeben 	9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	not installed 	9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	not active 	9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	not active 	9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active 	9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	not active 	9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active 	9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active 	9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	not active 	9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba	not active 	9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	not installed 	9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	42	3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	62	3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30	3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active 	7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	not active 	7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	not active 	7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	Freigabe_Softtouch 	7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	adjustable 	3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	active 	4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	active 	4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active 	7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	via_CAN 	7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active 	7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	active 	7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	No 	7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Pulse control 	7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	active 	7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	not active 	8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active 	8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	not active 	8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	active 	8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	active 	8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	Tuersteuergeraet im Fond verbaut oder keine Fondtuer 	5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
DV52
C?ID=194404
^^^^^^Chuck: Hi - it's been a while!!
The BCM in the RS3 is a tad different to your e-tron and in any event I'm not sure that it's helpful
However, I've had another look at the admap in your car and I'm guessing that what you are calling "the outer portion" of the headlights (i.e. the lamps that you want to operate as DRLs), currently work as parking lights and as single side parking lights.
If my guess is correct, then try this (the settings in brackets are the current values in your admap):
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 > Daytime running lights (not active)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 > Daytime running lights (not active)
Please note that the particular version of "Daytime running lights" in my suggestion above is what I have labeled 1A in the picture in my post #9
Chuck.Dee
Palmton, Ca
C?ID=10180
Hello, yeah I have been wanting for my rs3 bumper to hit the states. Now that it's here I want to get this going again...
Tried the coding you suggested and still the same, fogs are on and outer portion of light is still off.
