Results 1 to 10 of 16
Thread: 2006 Audi S4 Avant Manual missfire issues
    Oct 2019
    Hello.First time Audi owner and Just purchased Ross Tech scannder per Forum members suggestion.
    I have 2006 S4 Manual. 87000 miles
    car seem fine at idle but when I drive it hesitates and drives very sluggish.
    when RPM is raised to 2500 or over CEL flashes and sometimes CEL goes away soon as I slow down.
    But sometimes it stays on solid.
    CEL Code
    P0300, P0301, P0302,P0305,P0307,P0308
    P0174,P0172
    so far repair shop replaced all the spark plugs, Coils packs, Injectors, fuel filters, Vapor Canister Purge Solenoid.
    Car ran fine for for about 4000 miles then another CEL
    P0300,P0301,P0302, P0303, and same condition as before..
    errors appear under load not at idle.
    At idle engine does not shake it is very smooth. It is very quite even at cold start.
    Also Passenger side exhaust out put is very weak compare to the Drivers side.
    Please Help.
    Friday,18,October,2019,12:36:53:62900
    VIN: WAUUL78E26A135028   License Plate:
    Mileage: 140840km-87513mi   Repair Order:
              67 69 75 76 77
    VIN: WAUUL78E26A135028   Mileage: 140840km-87513miles
    Address 01: Engine        Labels: 079-910-560-BBK.lbl
       Part No SW: 8E2 910 560     HW: 8E2 907 560
       Component: 4.2L V8/5V      G   0030
       Revision: --H01---    Serial number:
       Coding: 0007711
       Shop #: WSC 26147 444 51445
       VCID: 6491AC2C0254E4674DF-8030
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
       Component: ESP8 quattro    H05 0120
       Coding: 0004901
       Shop #: WSC 06325 000 00000
       VCID: 290FFD1825F6790FBE9-807C
    18265 - Load Signal
                P1857 - 000 - Error Message from ECU - Intermittent
                        Reset counter: 38
                        Hex Value: 0x0000
                        Hex Value: 0x6222
                        Hex Value: 0x0028
                        Hex Value: 0x018C
                        Hex Value: 0x0001
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2832
       Coding: 00000
       VCID: 6D87C908D48EA52F121-50D0
                80-00 - Single-Wire Operation
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  USA 0504
       Coding: 11023
       Shop #: WSC 65536
       VCID: 3B233750DA7AFB9FDC5-4AA4
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW:
       Component: SDAR XM
       Revision:             Serial number: AUZ4Z7E8036892
       VCID: 2B0307102F2A6B1F4C5-513C
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H11 3540
       Revision: 91H1135    Serial number: 0036N0011GCJ
       Coding: 0032607
       VCID: 3C21344CDA64FCA7D5F-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 002 0070
       Subsystem 2 - Serial number: 35NRL
       Subsystem 3 - Serial number: 0001.01.000000200000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB4022A932EP˙†63
       Subsystem 5 - Serial number: A932EP˙†6342DRB4025189A4N˙†63
       Subsystem 6 - Serial number: 189A4N˙†6352ARB400B524DCT˙†63
       Subsystem 7 - Serial number: 524DCT˙†6362ARB400B3CE80V˙†63
       Subsystem 8 - Serial number: 3CE80V˙†63729RB400C58452J˙†63
       Subsystem 9 - Serial number: 58452J˙†63829RB400C58462L˙
       Subsystem 10 - Serial number: 58462L˙
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 04042
       Shop #: WSC 06325
       VCID: 41DF45B8B896914F869-4AA4
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 982 C    HW: 8E0 920 982 C
       Component: KOMBI+WFS 4     H12 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0023261
       Shop #: WSC 26147 444 58994
       VCID: 2E050E041C081E376BB-50F4
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0023261
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71BFD578C88641CF369-4B1E
       Part No: 8E0 959 433 BT
       Component: Komfortgerát T7B    3332
       Coding: 12092
       Shop #: WSC 06325
       VCID: 04518CACE7044467EDF-4AA4
       Component: Tőrsteuer.FS BRM 0506
       Component: Tőrsteuer.BF BRM 0205
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
    9 Faults Found:
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
       Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
       Component: AFS 1           H01 0010
       Coding: 0000019
       VCID: 2809F81C3EFC4007A17-807C
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H03 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH03 0020
    02769 - Headlight Swivel Module; Left
                        Fault Status: 00100011
                        Reset counter: 15
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 F    HW: 8E0 035 192 F
       Component: RNS-E US3       H70 0110
       Revision:      01S    Serial number: AUZBZ7E2002903
       Coding: 0309637
       Shop #: WSC 06431 176 52258
       VCID: 270BFB2033C24F7FA8D-513C
    7 Faults Found:
    00532 - Supply Voltage B+
                        Fault Frequency: 10
                        Reset counter: 79
                        Date: 2006.01.21
                        Time: 04:40:38
                        Voltage: 11.80 V
                        Fault Frequency: 13
                        Reset counter: 79
                        Date: 2006.01.21
                        Time: 04:39:45
                        Voltage: 11.80 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
    02261 - Data Medium
                        Fault Status: 00101110
                        Reset counter: 60
                        Date: 2005.03.13
                        Time: 21:37:25
                        Mileage: 655350 km
                        Count: 604
                        Clock: 15:37
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 60
                        Date: 2005.02.10
                        Time: 00:00:57
                        Mileage: 655350 km
                        Count: 1002
                        Clock: 02:53
                        Reset counter: 79
                        Date: 2005.02.10
                        Time: 00:02:43
                        Mileage: 655350 km
                        Count: 2607
                        Clock: 22:55
    00857 - CD Changer Unit (R41)
                        Fault Frequency: 22
                        Reset counter: 64
                        Date: 2007.04.09
                        Time: 17:46:05
                        Fault Frequency: 34
                        Reset counter: 79
                        Date: 2006.04.30
                        Time: 08:29:48
                        Bin. Bits:     0000
                        Mileage: 655350 km
                        Count: 610
                        Clock: 11:55
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273     HW: 8E0 907 273
       Component: Reifendruck 3   H03 0110
       Coding: 0063022
       Shop #: WSC 06435 000 00000
       VCID: 698FBD18E556B90F7E9-513C
       Part No SW: 8P0 862 335 G    HW: 8P0 862 335 G
       Component: FSE_255x BT     H21 0190
       Revision: 00000001    Serial number: 00000000331627
       Coding: 0011877
       VCID: 3A2D3254D040C297C73-50D0
    End----(Elapsed Time: 04:55, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
                    Address 01: Engine  (8E2 910 560 )
    12:53:37 Group 001: General
      760 /min  Engine Speed (G28)
      41.0°C  Coolant Temperature (G62)
      5.5 %  Lambda Control Bank 1
      6.3 %  Lambda Control Bank 2
      1.6 %  Lambda Control Bank 1
      10.2 %  Lambda Control Bank 2
    12:53:37 Group 002: General
      18.0 %  Engine Load
      3.28 ms  Injection Timing
      6.39 g/s  Mass Air Flow Sensor (G70)
    12:53:39 Group 001: General
      2.3 %  Lambda Control Bank 1
      10.9 %  Lambda Control Bank 2
    12:53:39 Group 002: General
      18.0 %  Engine Load
      6.28 g/s  Mass Air Flow Sensor (G70)
    Readiness Status: 0110 0101
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Failed or Incomplete
    Oxygen Sensor(s): Failed or Incomplete
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Failed or Incomplete
    Catalyst Heating: Passed
    Catalytic Converter(s): Failed or Incomplete
  2. Likes Uwe liked this post
  3. #2
    What do the fuel trims look like? Any significant difference between the banks?
    Oct 2019
    They are different.
    I do not know how to post pictures so this is best I can do
    Adaptation(Idle) Adaptation(Partial)
    Bank 1 Sensor 1 Bank 1 Sensor 1 Bank 1 Sensor 1 Bank 2 sensor 2
    Group 032 0.4% 0.0% 1.5% 0.0% Value stays same
    Group 033 -1.6% to 2.3% 1.520v to1.540v 0.8% to -2.3%, -3.1% 1520v to 1.540V Value changes
    Oct 2019
    I removed passenger side oxygen sensor before pre cat and sensor is tan color not black as I see the pictures of used oxygen sensor.
    Is it normal ?
    Quote Originally Posted by cdsjklee View Post
    They are different.
    I would not call that difference significant. Moreover, those long-term numbers are all at idle, and IIRC, your problems come under load. Since you cleared fault codes recently, you're going to have to drive the car some before the "Partial Load" values will budge from zero.
    Oct 2019
    Are these failed or incomplete meaning these failed or Incomplete parts need to be replaced?
    No, it means the routines that monitor/test those systems have not had a chance to run (have not seen the correct conditions) since the last time you cleared fault codes.
  9. #8
    Oct 2019
    Just drove the S4 for about 14 miles it started ok for few miles then on the freeway RPM does not go over 3000 very sluggish.
    then CEL flashes as I was try to go little faster but soon as I let go the gas CEL goes away...
    At lower speed when I raise the RPM pass 3000 I hear some kind of knocking sound.
    Temp guage is set at about middle but engine bay seems very hot.
    and Yellow Flat tire looking symbol has appeared on center screen.
    These are the result of Log.
    Sunday,20,October,2019,09:05:52:62900
    09:05:30 Group 031: Lambda Control (Lambda Sensor Voltages)
      1.991  Lambda Control Bank 1 (actual)
      1.000  Lambda Control Bank 1 (specified)
      1.991  Lambda Control Bank 2 (actual)
      1.000  Lambda Control Bank 2 (specified)
    09:05:30 Group 032: Lambda Control (Mixture Adaptation)
      0.4 %  Adaptation (Idle) Bank 1 Sensor 1
      -9.4 %  Adaptation (Partial) Bank 1 Sensor 1
      -2.4 %  Adaptation (Idle) Bank 2 Sensor 1
      11.7 %  Adaptation (Partial) Bank 2 Sensor 1
    09:05:30 Group 033: Lambda Control
      0.0 %  Lambda Control Bank 1 Sensor 1
      3.780 V  Sensor Voltage Bank 1 Sensor 1
      0.0 %  Lambda Control Bank 2 Sensor 1
      3.960 V  Sensor Voltage Bank 2 Sensor 1
    09:20:58 Group 031: Lambda Control (Lambda Sensor Voltages)
      1.000  Lambda Control Bank 1 (actual)
      1.000  Lambda Control Bank 2 (actual)
    09:20:58 Group 032: Lambda Control (Mixture Adaptation)
      0.8 %  Adaptation (Idle) Bank 1 Sensor 1
      -13.3 %  Adaptation (Partial) Bank 1 Sensor 1
      -3.4 %  Adaptation (Idle) Bank 2 Sensor 1
      20.3 %  Adaptation (Partial) Bank 2 Sensor 1
    09:20:58 Group 033: Lambda Control
      2.3 %  Lambda Control Bank 1 Sensor 1
      1.540 V  Sensor Voltage Bank 1 Sensor 1
      2.3 %  Lambda Control Bank 2 Sensor 1
      1.520 V  Sensor Voltage Bank 2 Sensor 1
    09:21:09 Group 031: Lambda Control (Lambda Sensor Voltages)
    09:21:09 Group 032: Lambda Control (Mixture Adaptation)
    09:21:09 Group 033: Lambda Control
      3.9 %  Lambda Control Bank 1 Sensor 1
      1.520 V  Sensor Voltage Bank 1 Sensor 1
      -2.3 %  Lambda Control Bank 2 Sensor 1
                    Address 01: Engine       Labels: 079-910-560-BBK.LBL
    Control Module Part Number: 8E2 910 560     HW: 8E2 907 560
      Component and/or Version: 4.2L V8/5V      G   0030
               Software Coding: 0007711
                Work Shop Code: WSC 26147 444 51445
    17538 - Fuel Trim; Bank 2 (Mult)
                P1130 - 001 - System too Lean
                        Fault Status: 01100001
                        Mileage: 140864 km
                        RPM: 2931 /min
                        Load: 40.4 %
                        Speed: 111.0 km/h
                        Temperature: 90.0°C
                        Temperature: 38.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.843 V
                P0300 - 001 -
                        Mileage: 140868 km
                        RPM: 3286 /min
                        Load: 71.7 %
                        Speed: 47.0 km/h
                        Temperature: 96.0°C
                        Temperature: 37.0°C
                        Voltage: 13.716 V
    16686 - Cylinder 2
                P0302 - 001 - Misfire Detected
                        Mileage: 140868 km
                        RPM: 3286 /min
                        Load: 71.7 %
                        Speed: 47.0 km/h
                        Temperature: 96.0°C
                        Temperature: 37.0°C
                        Voltage: 13.716 V
    16685 - Cylinder 1
                P0301 - 001 - Misfire Detected
                        Mileage: 140869 km
                        RPM: 3424 /min
                        Load: 71.7 %
                        Speed: 68.0 km/h
                        Temperature: 99.0°C
                        Temperature: 35.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.843 V
    16687 - Cylinder 3
                P0303 - 001 - Misfire Detected
                        Mileage: 140869 km
                        RPM: 2855 /min
                        Load: 74.9 %
                        Speed: 40.0 km/h
                        Temperature: 102.0°C
                        Temperature: 40.0°C
                        Voltage: 13.716 V
    Readiness: 0000 0101
    Readiness Status: 0000 0101
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Passed
  10. #9
    Wow, there's quite a difference now in fuel trims. Bank one went rich while bank 2 went lean.
    I am not sure what would cause this, but hopeflly someone will have some ideas.
  11. #10
    Oct 2019
    someone told me my S4 may have clogged cat. but I do not have any CEL for Clogged cat or oxygen sensor. what do you guys think?
    it gets worse as temp goes up.
