Results 11 to 20 of 33
Thread: Retrofit AID in Golf 7 GTD 2014 Error only in display! No Autoscan
    Oct 2019
    Italy
    my old analogic cluster:
    System description KOMBI
    SoftwareVersion 2210
    HardwareVersion 314
    VW/Audi part number 5G6920870A
    Hardware part number 5G6920870A
    Coding 07AD09082B90000800086A00000000
    ASAM/ODX file identification EV_DashBoardVDDMQBAB
    ASAM/ODX file version 008031
    i try 09 but have the error
  2. #12
    May 2016
    Flash gateway to newer version.
  3. Likes m87a liked this post
  4. #13
    Aug 2019
    Manchester, UK
    In 17 instrument long code u need to change the tank version to your car will go away.
  5. #14
    May 2014
    ^^^ hmm........ here's the compare table for both hex17 modules:
    Name	Old module		AID Module
    Byte	Hex	 Binary	        Hex	Binary
    0	07	00000111	03	00000011
    1	AD	10101101	AD	10101101
    2	09	00001001	41	01000001
    3	08	00001000	08	00001000
    4	2B	00101011	2B	00101011
    5	90	10010000	90	10010000
    6	00	00000000	00	00000000
    7	08	00001000	08	00001000
    8	00	00000000	00	00000000
    9	08	00001000	08	00001000
    10	6A	01101010	6A	01101010
    11	00	00000000	00	00000000
    12	00	00000000	04	00000100
    13	00	00000000	00	00000000
    14	00	00000000	00	00000000
    15		00000000	00	00000000
    16		00000000	00	00000000
    17		00000000	00	00000000
    18		00000000	00	00000000
    19		00000000	00	00000000
    Tank version is set by Byte 2, Bit 0-2. Both are set to Tank characteristic curve, Version 2.
    I'm not sure what Byte 12, Bit 2 does on AID module (Radio station listings?) - perhaps someone else can advise?
  6. #15
    Looks to be dimming. Terminal 58xt vs. Terminal 58xd. But don't ask me what the difference is.
    Byte 5, bit 6 should be "Powertrain hybrid", but that's not set.
  7. #16
    Jan 2015
    Bosnia and Herzegovina
    m87a: perhaps Byte 2 on the hex17 module? Current value from auto-scan for Byte 2 = hex41 -which means that Bits 3-7 value=hex40 - which means that instrument module is set-up for Vehicle variant, derivative 9. I have no idea what "derivative 9 " is, but it's unusual!
    not really sure since on a lot of modules on mqb first 3 bytes are vehicle coding and some options (derivatives) so worth a try, also you can put a GTI or GTD AID in diesel or gas car and it will display correct RPM's probably info from ECU but a lot of other stuff is coding and adaptations channels
    Quote Originally Posted by vastechnics View Post
    maybe with update it will help
  8. #17
    May 2016
    This is coding from GTD facelift with OEM AID:
    Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
    Component: KOMBI 407 3193
    Coding: 07AD11182F80000801886B011401000000000000
    VCID: 2A0CF40DAC758817B4D-807E
    Believe me update firmware off gateway and problem solved.
  9. Likes m87a liked this post
  10. #18
    Jan 2015
    talked to a colleague and he confirmed for range error when retrofitting AID flash gateway to fix it
  11. #19
    May 2016
    Flash to AJ 1244
  12. #20
    Oct 2019
    Italy
    thanks i try to flash gataway
