Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Retrofit AID in Golf 7 GTD 2014 Error only in display! No Autoscan
    Oct 2019
    Italy
    Hi
    I have retrofitted in my golf 7 gtd 2014 the AID, not have error in AUTO SCAN;
    but in display have this error:
    ERROR IN THE CALCULATION OF AUTONOMY
    Please post a complete Auto-Scan for context.
    Oct 2019
    Italy
    Hi
    Not have error in autoscan......only in the display
    ^^^ djthema: hi - VCDS autoscan reports can be useful in all sorts of ways: yes, they are useful in identifying errors (DTC s) on the vehicle, but they also have the advantage of telling forum colleagues what sort of equipment is fitted to the car - plus, autoscan reports also tell us how the long code string on each module is set,
    So- notwithstanding that "not have error in AUTO SCAN" , please post-up a copy (unedited and in English)
    EDIT: oops - great minds think alike (and fools seldom......)!!
  5. Likes Uwe, myounus liked this post
    Jan 2015
    Bosnia and Herzegovina
    you AID thinks that the car is hybrid, scan and adaptations from 17 might help
  7. Likes Uwe, myounus liked this post
    Dec 2016
    Amsterdam
    Again, autoscan please
    Current:
  9. Likes Uwe liked this post
  10. #7
    Oct 2019
    Italy
    Friday,18,October,2019,19:28:28:36623
    VIN: WVWZZZAUZEW169209   License Plate:
    Mileage: 30341km-18853mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F A9
    VIN: WVWZZZAUZEW169209   Mileage: 30341km-18853miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EQ    HW: 04L 907 309 A
       Component: R4 2,0L EDC   H22 6284
       Revision: 81H22---
       Coding: 011D0032032405082000
       ASAM Dataset: EV_ECM20TDI01104L906021EQ 002006
       ROD: EV_ECM20TDI01104L906021ER.rod
       VCID: 78A81321825BBB37F17-802C
       Part No SW: 0D9 300 040 J    HW: 02E 927 770 AN
       Component: DQ250-6F MQB  H52 4027
       Revision: 05652104    Serial number: TFK01309271755
       ROD: EV_TCMDQ250021.rod
       VCID: 1E6425B9403F2507DBB-804A
              P1734 00 [002] - -
       Revision: 00000000    Serial number: 628330000010CC
       Coding: 01FA62A1342609750379060041CC2980462C90C0608294F50062507AC109
       VCID: 7BA20C2DB36D902F9C5-802E
       Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00020114202100011005000000101000
       VCID: 66944D59D8EF3DC753B-8032
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011329104429
       Coding: 00141A46C24122FB4BE44000001C0728100A000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 77AA101D8F45B44FF8D-8022
       Component: WWS    131012  042 0551
       Serial number:         131014133932
       Component: RLFS  024 0042
       Serial number: Y13M10D09H11M38S49S1
       Coding: 00A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.013  H02 0007
       Serial number:     WOO24736938
       Coding: 181801
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Component: PARKHILFE PLA 011 0029
       Revision: --------    Serial number: 61131328801038
       Coding: 0031251051
       ASAM Dataset: EV_EPHVA2CAU3700000 003014
       ROD: EV_EPHVA2CAU3700000_003.rod
       VCID: 3D26C235EDF95E1FE21-8068
       Component: AirbagVW20    014 0385
       Serial number: 003F6R01TFR.
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41DEBEC591013AFF869-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 210 13
       Serial number: 3576700000050379DD0Z
       Subsystem 2 - Part No SW: -----------    HW: 480 000 210 13
       Serial number: 3586700000010379DD0W
       Subsystem 3 - Part No SW: -----------    HW: 480 401 710 13
       Serial number: 3516502A71230BB4F077
       Subsystem 4 - Part No SW: -----------    HW: 480 401 710 13
       Serial number: 3526502AF11FBEA2213M
       Subsystem 5 - Part No SW: -----------    HW: 480 401 510 13
       Serial number: 3556502991142C85E106
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Component: Lenks.Modul   075 0085
       Revision: FF026026    Serial number: 20131011400219
       Coding: 0400
       ASAM Dataset: EV_SMLSVALEOMQB 001011
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDAB83DE7F54C0FF0D-806A
       Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
       Component: KOMBI         408 3195
       Coding: 03AD41082B90000800086A000400000000000000
       Shop #: WSC 00046 123 12345
       VCID: 2A0CF9690C77D9A7B73-807E
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0001165062
       Coding: 030100040B087300FF00066A1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       VCID: 3B22CC2DF3ED502FDC5-806E
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H06 0101
       Serial number: 27130001506960073376
       Coding: 29FFFF
       Serial number: 5199551503
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 08101301101316
       Coding: 003F0320D000040000001000
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003086053
       Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
       Component: EPS_MQB_ZFLS  502 5011
       Coding: 8301
       ASAM Dataset: EV_SteerAssisMQB 009026
       ROD: EV_SteerAssisMQB_009_VW37.rod
       VCID: 3332E40DDBBD986F045-8066
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 12101301101476
       Coding: 003F0120DE00040000801000
       VCID: 3E24C539E0FF4507FBB-806A
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003102712
       Coding: 090000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Coding: 029A01000B000200
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
       Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
       Component: MU-S-N-ER     851 0842
       Coding: 02731001FF00000011510000000A00001F0602F4012000004E
       Shop #: WSC 00046 000 00000
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 313EEE0521A1AA7F769-8064
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZHV0750013
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Component: SAS-GEN 2     H06 0011
       Serial number: 130918201213
       VCID: 6B823C6DC30D00AF0C5-803E
    End----------(Elapsed Time: 01:10, VBatt start/end: 12.9V/12.6V)-----------
  11. #8
    Oct 2019
    Italy
    long ago I installed the drive select mode in vw (original kit)...........is possible that the problem is solved by refresh the fecs in gataway
  12. #9
    May 2017
    Is your drive select working? If yes then the FeCs are ok.
  13. #10
    Quote Originally Posted by m87a View Post
    your AID thinks that the car is hybrid, scan and adaptations from 17 might help
    m87a: perhaps Byte 2 on the hex17 module? Current value from auto-scan for Byte 2 = hex41 -which means that Bits 3-7 value=hex40 - which means that instrument module is set-up for Vehicle variant, derivative 9. I have no idea what "derivative 9 " is, but it's unusual!
  14. Likes PetrolDave, Uwe liked this post
