Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
Thread: Can the patient be saved ? FOD identification help please B8 A4 2.0 TFSI
    Quote Originally Posted by BigJetTech View Post
    These engines aren't my forte. Give me a Pratt, Rolls or GE !! something with a 90 plus inch fan preferred
    A 90" fan would be hard to fit, but...
  2. #12
    Nov 2017
    Bay Area, CA
    The screen blowing out on the bridge is a stupid common failure. And if that check valve and spring have come out, definitely need a whole new bridge.
    Audi says it's actually OK, if not recommended, to remove the screen on an otherwise check ball still intact cam bridge. And seeing as how frequently the screen comes apart on these, I would say it's not a bad idea to remove it from even a brand new bridge just to prevent further issue.
    For what it's worth, the adjuster that's part of the intake cam might also be damaged from this incident. Since it's easy enough to just replace the spool valve and bridge, sure, do that first. Then there's a basic setting to test the intake cam adjuster, I forget exactly how it's worded on these UDS cars (Uwe will probably come up with the answer).
    The test will require you to hold the brake pedal (enough to trip the brake switch, anyway) and press the throttle to the floor and hold it there while the basic setting test is running. It will give you a result of pass or fail, you can also select live data of intake cam position before the test starts so you can see in realtime what's happening. The timing should start around 28 degrees and eventually retard all the way to around -33 to -35, feel like the engine is misfiring for a moment before it starts to advance the cam timing back up to its start position of 28 degrees and smooths right back out. Just keep holding the pedals until the test completes.
    If the test fails and the cam timing doesn't change adequately, it will set a code immediately and then you'll also need to replace the intake cam itself to fix it. But hey, worth a shot to try just the bridge and spool valve first then re-evaluate. Would save a lot of money and work if it does end up being OK.
  3. Likes Uwe, Jack@European_Parts liked this post
  4. #13
    Quote Originally Posted by dieseldub View Post
    Without seeing a scan so I can look up at the data for his particular ECU, I would at best be guessing.
  5. #14
    Mike
    Be forewarned if timing is out mechanically and there is FOD modified programming, it is indeed possible to xylophone a motor by running a full sweep timing basic settings operation in VCDS & because some schmuck deletes the diagnostic stack!
  6. #15
    New User
    Aug 2019
    NJ, USA
    Uwe, lol, yes, Regrettably I have found that to be true as well.
    Jack, No fuel smell in the oil. Oil pressure has not been checked .. yet.. debating whether or not to drop the pan, there was no metal on the magnetic plug or sparkling oil.
    Sam, Thank you. ... I know better, 40 yrs of maintenance experience and my gut instinct thought it would be best. I deferred to a shop that is supposed to "know" the product. They are "specialists" with a very good reputation. So it was just the tensioner ....
    Now, not having pulled the bridge myself, and just seeing pictures of the back side of the bridge, would one not see that the screen, spring and check ball are missing ?
    I will be retrieving the vehicle early this next week and plan on changing the cam bridge, and control valve. I can not see doing the recommended repairs - intake cam, bridge, control valve, potentially a new head, (depending on journal condition) and timing chains to prolong the life of the vehicle. That is the minimum recommendation, this shop would actually prefer to replace the engine as the amount of metal it made - if any - is unknown. The parts and labor involved would exceed the retail value of the vehicle.
    I will report back once I have done the bridge and control valve. I want to inspect the scoring on the cam myself.
    THANK YOU to ALL who provided input and advise. These engines aren't my forte. Give me a Pratt, Rolls or GE !! something with a 90 plus inch fan preferred
    Mike
    I was just simply putting it out there. There are many other brands with chain motors that yes, happen to almost never need chain service, or only at a much higher mileage. I understand your side to the T, but the shops side, and im not pointing fingers or talking down to/on anyone. But solely because these engines i'm sure many would agree on, are anything but "durable" and specifically have a spot light on "chain concerns", along with reimbursement from OEM , other than you requesting to not change it, seeing the car is in great shape and a daily, a new updated chain would have been a smart move. Point being, you deserve a beer for making it 160k miles on original chain and tensioner ha. Secondly, fixing these things everyday, I've seen a 60k mile A4's come in for a tensioner update with correlation codes because of chain stretch. Best on was a oxygen sensor replacement that returned on a flat bed 5 minutes later because the spool valve popped. If you truly enjoy your daily, say 30 minutes added labor for a new chain, and or guides id jump on it. I completely understand when funds come into play, because either way its expensive to pay for. I just really hate seeing someone spend a lot of money on a new tensioner, to only have a chain break after, and really be put in a position of fixing their car or scrapping it because its not worth it on an otherwise perfect car.
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #16
    North Central, WI USA
    Results so far ... first and foremost ... I really do appreciate the input and help. It's been great.
    I removed the solenoid and upper cover, I immediately saw the button on the control valve popped. https://imgur.com/gallery/mDEAldL
    I removed the bridge next and what I found made me fume a bit, and swore not to use the shop I had just been to EVER again for anything. The guy put the bridge back on - LEAVING - FOD in the oil passage of the bridge. The ring sitting on the bridge oil galley face literally fell out as I pulled the bridge off. WTF - https://imgur.com/a/fB5bFqh
    I searched for any other bits in the bores, via endoscope, and magnet. None found. ....
    the vehicle now starts and runs normally. I ran out of time last night to put the VCDS on, gather and clear the current DTC's, which I will post the before and after scans. ...
    the caveat here ... the only part I have yet to recover is the check ball from the bridge, everything else of consequence has been recovered.
  9. #17
    As promised the scans. I don't feel they really show the picture of the actual happenings due to the previous shop(s) resetting the codes.
    A simple recap for future troubleshooting purposes and information that just may "save" someone some real grief.
    When the problem started, it was simple cam position sensor codes. The vehicle also started to crank longer before starting, and as mentioned above an occasional noise my missus could here from outside the vehicle during morning starts - i couldn't hear them from inside the vehicle, until i rolled own the window every morning prior to start.
    The code progressed to "unresolved cam position" and "a failure to fully retard" for starting. I retrieved those via my phone and if I could figure out where they got saved to i would be willing to share. I was trying to get ahead of what ever it was ... and not having the knowledge that SHOULD have been provided to me by AUDI.
    I have been the registered owner of this vehicle since 2013. It's not a "robust design", these items chain, guides, control valve, and bridge all need to be "life limited" parts and not "on condition". It could have the other way for me, catastrophic failure. The maintenance schedule for the cam system needs to be adjusted, and published. From VAG's recent behavior they have certainly tarnished the "brand"
    the before scan ...
    Saturday,26,October,2019,15:49:19:58603
    Dealer/Shop Name: Sch
    VIN: WAUDFAFL0AN020550   License Plate:
    Mileage: 262090km-162855mi   Repair Order: 10-26-19-2
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 72 77
    VIN: WAUDFAFL0AN020550   Mileage: 262090km-162855miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Component: 2.0l R4/4V TF H15 0001
       Revision: E1H15---
       Coding: 0104010A180F0160
       Shop #: WSC 02301 444 105041
       VCID: 79BA2A2AF83DB987E0-802C
    7 Faults Found:
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [096] - Implausible Signal
                        Mileage: 262092 km
                        Date: 2019.10.22
                        Time: 16:47:17
                        Engine speed: 733.50 /min
                        Normed load value: 9.8 %
                        Coolant temperature: 93 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 13.805 V
    4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
              P0016 00 [236] - Incorrect Correlation
                        Mileage: 262077 km
                        Date: 2019.10.15
                        Time: 09:16:28
                        Engine speed: 821.50 /min
                        Normed load value: 10.6 %
                        Coolant temperature: 42 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 13.617 V
    4054 - Cylinder 1
              P0301 00 [232] - Misfire Detected
                        Mileage: 262077 km
                        Date: 2019.10.15
                        Time: 09:14:21
                        Engine speed: 860.50 /min
                        Normed load value: 13.3 %
                        Coolant temperature: 33 °C
                        Intake air temperature: 19 °C
                        Voltage terminal 30: 13.923 V
    4060 - Cylinder 3
              P0303 00 [232] - Misfire Detected
                        Mileage: 262077 km
                        Date: 2019.10.15
                        Time: 09:14:21
    4063 - Cylinder 4
              P0304 00 [232] - Misfire Detected
                        Mileage: 262077 km
                        Date: 2019.10.15
                        Time: 09:14:21
    4057 - Cylinder 2
              P0302 00 [232] - Misfire Detected
                        Mileage: 262077 km
                        Date: 2019.10.15
                        Time: 09:14:21
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [232] - -
                        Mileage: 262077 km
                        Date: 2019.10.15
                        Time: 09:14:21
    Readiness: 1110 0101
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
       Component: ESP8 quattro  H04 0010
       Coding: 070D10
       Shop #: WSC 02391 823 56573
       VCID: 7AB83526F53BB29FE9-802E
       Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
       Component: BCM2 1.1      H02 0324
       Coding: 0B0100
       Shop #: WSC 02399 823 56573
       VCID: 77BE2C12C629AFF796-8022
       Serial number: 0509000048231016
       Serial number: 0209000060798003
       Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serial number: 01060820090247
       Coding: 64002000
       VCID: 7DB23E3AE41585A7CC-8028
    01271 - Positioning Motor for Temperature Flap (V68)
                001 - Upper Limit Exceeded
                        Fault Status: 01100001
                        Fault Frequency: 6
                        Reset counter: 112
                        Mileage: 250221 km
                        Date: 2019.05.12
                        Time: 20:47:42
                        Voltage: 12.80 V
                        Temperature: 17.0°C
                        Temperature: 15.0°C
                        Count: 11178
                        Count: 11778
                        Bin. Bits: 01000000
                        Bin. Bits: 00000111
                        Time: 7.00 s
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000323491
       Coding: 690000B1063C00010000080300007F5F0F14120800000021000000
       VCID: 3C34F33EBF8F4CAFBB-8068
       Component: WWS 280809  H06 0070
       Serial number: SWF09080280276
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000508090039
       Subsystem 3 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
                        Fault Status: 01101100
                        Reset counter: 253
                        Mileage: 242148 km
                        Date: 2019.02.07
                        Time: 15:14:00
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EGD0505V1
       Shop #: WSC 02145 785 00200
       VCID: 42C88DC6D56B3A5FF1-8016
       Serial number: 5810000R090000095W
       Serial number: 6334MSME4B062C1AJ
       Serial number: 6344MSME49160936C
       Serial number: 6352QSME373A4408G
       Serial number: 6362QSME2E38321CN
       Serial number: 63732SME02362226M
       Serial number: 63832SME04351C10Q
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304II4000CK
       Coding: 000014
       VCID: 3D32FE3AA49545A78C-8068
       Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
       Component: KOMBIINSTR.   H19 0253
       Revision: 00300000    Serial number: BWX348Z79
       Coding: 8B1009000300D705020000
       VCID: 312AD20A68CDB1C718-8064
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0105
       Revision: GB600050    Serial number: 5000G098278212
       Coding: 00C303
       VCID: 50ECB78E0307D8CF77-8004
       Component: J367-BDM  H06 0170
       Serial number: 1908CCB6310809
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0280
       Revision: 00000000
       Coding: 020302
       VCID: 393AEA2AB0BD7987A0-806C
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009255939
       Coding: 011C03204000410001
       VCID: 45C296DACC450D67D4-8010
       Revision: 00002001    Serial number: 0121249030
       Coding: 0106023A007A404400B0010000000000
       Component: GTO BF  H06 0050
       Serial number: 00000000000000162718
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
    02616 - Fuel Tank Cap; Unlock
                        Fault Status: 00101001
                        Reset counter: 189
                        Mileage: 261202 km
                        Date: 2019.09.23
                        Time: 15:20:45
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74A41B1ED75FC4EFB3-8020
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009187408
       VCID: 44C48BDEC77F346FC3-8010
       Component: EPB Audi B8   H09 0090
       Revision: 00000003    Serial number: 10000000296871
       VCID: 3424DB1E97DF84EF73-8060
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H04 0351
       Revision: 00000006    Serial number: AUZ5Z6I1262916
       Coding: 04020002010185004119070800
       VCID: 46C091D6F143067FDD-8012
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                        Reset counter: 62
                        Mileage: 220495 km
                        Date: 2018.04.28
                        Time: 18:41:22
                        Reset counter: 190
                        Mileage: 261936 km
                        Date: 2019.09.30
                        Time: 17:45:41
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000101791907
       Coding: 010C03204000210001
       VCID: 42C88DC6DD6B3A5FF1-8016
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000101791910
       Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
       Component: FSE_256x BT     H37 0600
       Revision: 00000000    Serial number: 00000005049230
       Coding: 0010370
       Shop #: WSC 02156 785 00200
       VCID: 3C34F33E7F8F4CAFBB-8068
    End----------(Elapsed Time: 01:38, VBatt start/end: 12.1V/12.1V)-----------
    the after scan ...
    Saturday,26,October,2019,18:43:27:58603
    VIN: WAUDFAFL0AN020550   License Plate: AGA8807
    Mileage: 262200km-162923mi   Repair Order: 10-26-19 final
    VIN: WAUDFAFL0AN020550   Mileage: 262200km-162923miles
       Revision: E1H15---
    Readiness: 0000 0101
       Coding: 070D10
       Coding: 0B0100
       Coding: 64002000
                        Fault Frequency: 6
                        Reset counter: 112
                        Mileage: 250221 km
                        Date: 2019.05.12
                        Time: 20:47:42
                        Voltage: 12.80 V
                        Temperature: 17.0°C
                        Temperature: 15.0°C
                        Count: 11178
                        Count: 11778
                        Bin. Bits: 01000000
                        Bin. Bits: 00000111
                        Time: 7.00 s
       Coding: 00FD11
                        Reset counter: 253
                        Mileage: 242148 km
                        Date: 2019.02.07
                        Time: 15:14:00
       Coding: 000014
       Coding: 00C303
       Revision: 00000000
       Coding: 020302
                        Reset counter: 189
                        Mileage: 261202 km
                        Date: 2019.09.23
                        Time: 15:20:45
       Revision: S2200000
       Coding: 0203010102
       Component: Display
                        Reset counter: 62
                        Mileage: 220495 km
                        Date: 2018.04.28
                        Time: 18:41:22
                        Reset counter: 190
                        Mileage: 261936 km
                        Date: 2019.09.30
                        Time: 17:45:41
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Coding: 0010370
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.6V/12.6V)-----------
    Address 09: DTCs cleared
    Address 08: DTCs cleared
    Address 46: DTCs cleared
    Address 56: DTCs cleared
       Revision: E1H15---
       Coding: 070D10
       Coding: 0B0100
       Coding: 64002000
       Coding: 00FD11
       Coding: 000014
       Coding: 00C303
       Revision: 00000000
       Coding: 020302
       Revision: S2200000
       Coding: 0203010102
       Component: Display
                        Reset counter: 151
                        Mileage: 262208 km
                        Date: 2019.10.26
                        Time: 18:50:21
       Coding: 0010370
    End----------(Elapsed Time: 01:33, VBatt start/end: 12.4V/12.4V)-----------
    Yes, the right fog lamp is out
    I do have the log file of the vehicle running and driving to to get the readiness code set. the adaptation is running at -4.02. base timing is at 28.00 and does go to the -33 area the scheduled and actual run right together while being graphed and the -4.02 is rock steady.
    All seems to be happy and running normally... and I have virtually eliminated 2 shops I trust. My problems could have all been avoided had I stuck to my guns. I don't appreciate people telling me how to do my job, and I dislike doing it to others, these people i won't have an issue with vocalizing my wishes in the future - IF - I ever use them again ...
    UWE, if you can let me know how to post the advanced measuring blocks I recorded or if you think the "collective" could benefit from them I would be more than willing ...
    AGAIN ... Thank you to ALL !!
    Mike
  10. Likes Uwe, Jack@European_Parts liked this post
  11. #18
    I'm not sure how you recorded them. If you used [Log] or [Save] in VCDS, the files are just plain text. Open them with Notepad and paste the contents here, preferably between CODE tags. If you recorded them some other way, I'll need more details before I can advise.
  12. #19
    Thinking out loud here: I wonder if part of the problem is the very light-weight oils, and/or combined with the very long (10,000 miles!) oil change intervals that VW specifies these days?
    A reciprocating piston engine is not a sewing machine, yet they call for ever-thinner oils. I had the oil changed on a 2018 Tiguan at the dealer about a month ago and they used 0w20! I believe the primary reason they do this is so they can get incrementally better fuel economy numbers out of the EPA tests.
  13. Likes PetrolDave, Jack@European_Parts liked this post
  14. #20
    Uwe, Thanks for correcting my post. The advanced measuring blocks were logged via VCDS log function, and is an excel file, I will do my best to put them between the code tags, when I get home.
    Your comments on oil may bring in a whole "barrage" of comments. I do agree however that manufactures calling for 0wxx spec oils seems a bit crazy. My A4 calls for the 0w40. These engines are known for oil usage, I changed from the factory / dealer "brand" oil to another brand, that I have used since synthetics came out.
    This simple change in "brands" took the oil usage in this engine from a quart every 2500-3000 miles to 1 in 5000 or so. I also then change oil and filter at that time, rather than add a quart and go another 5000 miles. I will only run full synthetic oil.
    Mike
  15. Likes Uwe liked this post
