I have a problem with my ACC on Skoda Superb L&K 2016 and I would like to reset the misalignement, unfortunately the option isn't available in basic settings and I think I need to go to put in a code first. I haven't got a clue what the security code is, can you please help?
here are the logs
Thank you & Regards
here are the logs
Thursday,17,October,2019,17:32:49:20409
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBBH7NP5H7028??? License Plate:
Mileage: 43984km-27330mi Repair Order:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 47 52 55
5F 6D A5 BB BC
VIN: TMBBH7NP5H7028363 Mileage: 43984km-27330miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ES HW: 04L 907 309 R
Component: R4 2.0l TDI H23 1989
Revision: B5H23---
Coding: 01190032034501087000
Shop #: WSC 33361 790 00123
ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
ROD: EV_ECM20TDI01104L906026ES_002_SK48.rod
VCID: 7F5B032A2779876FB0D-802A
Part No SW: 5Q0 614 517 CC HW: 5Q0 614 517 AG
Component: ESC H62 0637
Revision: 00000000 Serial number: 62196000001262
Coding: 1D07929C34220B74477A060641C649B8492CD0E2608292753460F0F8C0A202
ROD: EV_Brake1UDSContiMK100IPB_035_SK48.rod
VCID: 74B1DC061E3FD437DDF-8020
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0413912747
Coding: 032C0C0E03
VCID: 3C21342676EF5C77D5F-8068
Subsystem 1 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84418625
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 BE HW: 3V0 907 044 BE
Component: AC Automat H34 4003
Revision: 20K06000 Serial number: 00000B00207790
Coding: 1111010400241001100510010010110A
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_ACClimaPrehVW37X 002014
ROD: EV_ACClimaPrehVW37X.rod
VCID: 78A9E8360257B057F17-802C
Subsystem 1 - Part No SW: 3V0 907 049 C HW: 3V0 907 049 C
Component: E265KlimaHeck H02 0101
Serial number: 00000000000000000000
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001623900847
ROD: EV_BCMBOSCH_017.rod
Subsystem 1 - Part No SW: 010 5 HW: 3V1 955 119
Component: 48x RL 160708 032 0121
Serial number: 00000001607050300816
Coding: 165DDD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M08D29H05M22S13
Coding: 0088DF
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY162040Y5H
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000036183546
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 99
Mileage: 43818 km
Date: 2019.10.08
Time: 17:38:18
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616231
Coding: 0371067841
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000.rod
VCID: 0D47A9E21DD5A5FFB21-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 2A0060C351FFC428949C8045
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311C065EBF94371DF-8060
0791 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MISALIGNMENT_VERTICAL]
Reset counter: 120
Mileage: 43984 km
Date: 2019.10.17
Time: 16:24:48
Control Module temperature: 40 °C
Voltage terminal 15: 11.7 V
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 20081641350214
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3829283642D77057317-806C
Part No SW: 5Q0 959 655 AK HW: 5Q0 959 655 AK
Component: AirbagVW21 005 0130
Serial number: 003Q5R22856+
Coding: 98CCC0C0000000005C5400CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 094F9DF269BDB9DF9E9-805C
Subsystem 1 - Part No SW: ----------- HW: 480 001 908 16
Serial number: 3570000000074260FD1K
Subsystem 2 - Part No SW: ----------- HW: 480 001 908 16
Serial number: 358000000008F46D4D1.
Subsystem 3 - Part No SW: ----------- HW: 480 400 608 16
Serial number: 3510002C5215E1C1E06+
Subsystem 4 - Part No SW: ----------- HW: 480 400 608 16
Serial number: 3520002C7215E1C4D164
Subsystem 5 - Part No SW: ----------- HW: 480 400 408 16
Serial number: 3550002B121FBE8331ED
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 EF HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20160827501348
Coding: 6400
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3V0 920 911 A HW: 3V0 920 911 A
Component: KOMBI 304 8311
Coding: 27A501127F80A600018B6B0B5001000000000000
Shop #: WSC 73430 031 00123
ROD: EV_DashBoardVDDMQBAB_SK48.rod
VCID: 30391016AAA7A817797-8064
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 22081610520505
Coding: 030100045F087300EB00025A880F00010001070000000000000000000000
Shop #: WSC 33361 790 00114
ROD: EV_GatewConti_013.rod
VCID: 7CA1F426366F9C7795F-8028
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B1107180816
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 4263861104
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000184752005
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD512612DE11F369-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PHO10508
Coding: 0014000000000500018280808080000000008181000000D400
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0414778795
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0414371994
Coding: 020112
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000215587773
Coding: 001D0820DE01040000001100
VCID: 47CB5BCA3F290FAF48D-8012
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D751C205251DBFBA1-8010
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1GJE0080DP
Coding: 0384010000AA002FAA0000000000
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 59EF8DB2999D895FEE9-800C
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000215371705
Coding: 001D0220DE01040000001100
VCID: 46D556CE382316A7B3B-8012
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 06D602003F010000
VCID: 40D940D61A073897897-8014
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0006
Coding: B20000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0006
Coding: B20000
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 3V0 035 020 C HW: 3V0 035 020
Component: MU-H-ND-EU H50 0702
Serial number: A676H0G7512791
Coding: 038401010000000051111202008808002F0103E601200100DE
VCID: 2615F64E9863F6A793B-8072
Subsystem 1 - Part No SW: 3V0 919 606 HW: 3V0 919 606
Component: ABT_High-2 H47 1031
Serial number: SKZ8Z9SLU00BJC
Subsystem 2 - Part No SW: V03 959 801 JP HW: -----------
Component: ECE 2018 --- 0166
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30888255000000
Coding: 1008
ASAM Dataset: EV_DeckLidCONTIAU736 001012
ROD: EV_DeckLidCONTIAU736_AU73.rod
VCID: 3FDB432A67F9476FF0D-806A
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 24081612P10945
Coding: 020408010000040100062354C050A10084000E100000
VCID: 3A2D323E7CDB6247C73-806E
Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B
Component: TSG HFS 011 0031
Serial number: 0000214894785
Coding: 001C00208001040000001100
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
Component: TSG HBFS 011 0031
Serial number: 0000214894784
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End----(Elapsed Time: 01:42, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Thank you & Regards
