Results 1 to 5 of 5
Thread: Audi Q3 F3 Rear sensor graphic on MMI
    Sep 2019
    Italy
    Hi all,
    Hope you can help me, I have stock rear distance sensor and I would like to code the graphic visualization on MMI.
    Actually I'm trying the old code for 8U and even I can now see the graphics on MMI (when I chose reverse gear), I dont' see the typical "Waves" for distance detection.
    This is what I did:
    5F-Infotainment and go to coding.
    Go to Byte 6 and enable Bit 1,
    Change adaptation change on 10-Park assist to OPS DISPLAY: This is the point!, I have found similar option using long coding and I know see (as stated before) the graphic but still non "waves".
    Any idea about?
    Many thanks for your help
    Sep 2019
    Croatia
    There should be curve option display on byte 0 or 1 on 10 park assist module
    Jun 2017
    From what I know, since Audi MY16 this is not possible anymore.
    It could be the case that is works again for this new MIB3 unit..
    Sep 2019
    Italy
    Quote Originally Posted by ib97 View Post
    I can't see any option like that, I will post some screenshot if you want
    Sep 2019
    Croatia
    Quote Originally Posted by mdk11 View Post
    then that is only a thing for mk7.
