Results 1 to 7 of 7
Thread: 2009 Audi A4 2.0T Quattro B8 Misfire in Cylinder #3 and random misfire in #4 at idle
    Oct 2019
    Question 2009 Audi A4 2.0T Quattro B8 Misfire in Cylinder #3 and random misfire in #4 at idle
    I bought this car a couple months ago for $2800 the vacuum line rotted off from the vacuum pump the breaks didnt work.
    I replaced the whole line. it fixed the problem. But its been misfireing in cylinder #3 at idle and randomly will misfire in #4.
    I pulled my intake off put 4 new injectors and wallnut shelled the carbon off the intake valves. Got better gas milage.
    The person that had it before me put teflon tape on the intake bolts between 3 and 4 they are stripped out I can put a heater coil in it.
    But I dont think thats the problem. There is oil coming out the camshaft bridge seal outside for the camshaft positioning magnet seal.
    I think the cam bridge screen broke into peices and is stuck in the oil drain ports. Have not had the time to pull the front end apart yet.
    I keep getting a bost pressure code and think my waste gate actuator rod and fasteners are the cause of it.
    I need to get my car on a lift and wiggle the rod and make sure. I put a forge blow off valve on my turbo and when my car idles I can hear the air coming out of it.
    witch makes me think its the waste gate actuator. The person that had the car before me put a amp in the car and took the original amp out and said it had a fault I sill have it.
    its a rats nest of wires in my trunk from them splicing the amp into the speakers I have the Hormone Kardon sound system. I know there is shorts because of their rats nest of a Splice job.
    I have been trying to run the camshaft positioning test to see if the solenoid's on my exhaust cam are working correctly. But cant figure out how to get it to run the test.
    I have been doing the work myself but have not had the time or place to rip my front end apart and look at it. I keep getting these suspension Codes
    01769- Sensor for Viechicle Leveling Front Right (G289) 010- open or Short to Plus
    03262- Comfort Restrction 000.
    Dose anybody know where I can find Wiring Diagrams for my 2009 Audi A4 2.0T Quattro B8 looking to find the shorts from the previous owner installing the aftermarket amp.
    Wednesday,16,October,2019,16:34:06:05713
    VIN: WAUMF78K19N0XXXX   License Plate: BOOKER
    Mileage: 347690km-216044mi   Repair Order:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 07 08 09 0E 0F 10 14 15 16 17 19 1B 1E 36 37 3C
              42 46 47 52 53 55 56 62 65 67 6C 72 77
    VIN: WAUMF78K19N029678   Mileage: 347690km-216044miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0001
       Revision: E1H14---
       Coding: 0104010A190F0160
       Shop #: WSC 02301 444 04944
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: F9BA752878CF838760-80AC
    7 Faults Found:
              U1113 00 [040] - -
                        Mileage: 345999 km
                        Date: 2019.10.11
                        Time: 04:05:07
                        Engine speed: 2431.00 /min
                        Normed load value: 37.3 %
                        Vehicle speed: 120 km/h
                        Coolant temperature: 94 °C
                        Intake air temperature: 16 °C
                        Ambient air pressure: 950 mbar
                        Voltage terminal 30: 13.923 V
                        Unlearning counter according OBD: 32
              U1113 00 [040] - -
                        Mileage: 345999 km
                        Date: 2019.10.11
                        Time: 04:05:07
    10434 - Catalyst System; Bank 1
              P0420 00 [237] - Efficiency Below Threshold
                        Mileage: 346786 km
                        Date: 2019.10.11
                        Time: 23:03:25
                        Engine speed: 1549.00 /min
                        Normed load value: 16.9 %
                        Vehicle speed: 59 km/h
                        Coolant temperature: 95 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 14.041 V
    5671 - Boost Pressure Regulation
              P0299 00 [237] - Control Range Not Reached
                        Fault Frequency: 9
                        Mileage: 346469 km
                        Date: 2019.10.11
                        Time: 17:31:33
                        Engine speed: 3018.50 /min
                        Normed load value: 52.2 %
                        Vehicle speed: 63 km/h
                        Coolant temperature: 30 °C
                        Intake air temperature: 5 °C
                        Voltage terminal 30: 14.135 V
    4060 - Cylinder 3
              P0303 00 [237] - Misfire Detected
                        Fault Frequency: 9
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:50:29
                        Engine speed: 796.50 /min
                        Normed load value: 13.7 %
                        Coolant temperature: 77 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 13.216 V
    7960 - Cylinder Disabling
              P130A 00 [040] - -
                        Mileage: 346494 km
                        Date: 2019.10.11
                        Time: 18:35:44
                        Engine speed: 783.50 /min
                        Normed load value: 17.6 %
                        Vehicle speed: 3 km/h
                        Coolant temperature: 96 °C
                        Intake air temperature: 21 °C
                        Ambient air pressure: 960 mbar
                        Voltage terminal 30: 14.159 V
                        Unlearning counter according OBD: 36
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [109] - -
                        Fault Frequency: 9
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:50:23
                        Engine speed: 950.50 /min
                        Normed load value: 12.9 %
                        Coolant temperature: 78 °C
                        Intake air temperature: 53 °C
                        Voltage terminal 30: 13.334 V
    Readiness: 0000 0100
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: B620BE140951ACFFCD-80E2
       Part No SW: 8K0 907 379 AD    HW: 8K0 907 379 AD
       Component: ESP8 quattro  H04 0060
       Coding: 152500
       Shop #: WSC 02399 823 56573
       VCID: FBB66F207AF3B19772-80AE
                        Reset counter: 154
                        Mileage: 345999 km
                        Date: 2019.10.11
                        Time: 04:05:07
                        Hex Value: 0x7840
                        Hex Value: 0x4006
                        Hex Value: 0x1F07
                        Hex Value: 0x81AF
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 AG    HW: 8K0 907 064 AG
       Component: BCM2 1.1      H80 0143
       Coding: 0D0100
       VCID: F5A279185CD7E7E704-80A0
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: ELVAUDIB8  H36 0041
       Serial number: 0208000066865009
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Fault Status: 00100111
                        Reset counter: 159
                        Mileage: 347624 km
                        Date: 2019.10.14
                        Time: 13:32:01
    Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
       Part No SW: 8T0 035 729 M    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 340IR087512547
       Coding: 0000003
       VCID: C3C6D7C0828309577A-8096
       Subsystem 1 - Part No: 8T0 919 609 D
       Component: E0380 BedienteilH08 0100
       Subsystem 2 - Serial number: 00000000151568
       Subsystem 3 - Serial number: 0115.09.080000000100010014˙
       Subsystem 4 - Serial number: 010014˙
       Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
       Component: KLIMA 3 ZONEN H06 0140
       Revision: C1000000    Serial number: 0112.09.081189
       Coding: 64002000
       VCID: F2A842042DB9F0DF21-80A6
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Fault Frequency: 91
                        Reset counter: 122
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:33
                        Fault Frequency: 85
                        Reset counter: 162
                        Mileage: 345676 km
                        Date: 2019.10.10
                        Time: 13:54:19
                        Temperature: 17.0°C
                        Fault Frequency: 95
                        Reset counter: 162
                        Mileage: 345676 km
                        Date: 2019.10.10
                        Time: 13:54:21
                        Temperature: 17.0°C
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H22 0253
       Revision: 05022001    Serial number: 00000000125485
       Coding: 26001091063CAF311F00080300003D0D0F9CD24800010161000000
       VCID: B02C880CE33582CF97-80E4
       Component: WWS 160908  H06 0070
       Serial number: SWF08090165524
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10254148
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002009080933
    7 Faults Found:
                        Reset counter: 115
                        Mileage: 346756 km
                        Date: 2019.10.11
                        Time: 21:20:00
                        Fault Frequency: 83
                        Reset counter: 160
                        Mileage: 346818 km
                        Date: 2019.10.12
                        Time: 06:10:00
    03020 - Local databus 2
                        Fault Status: 00101100
                        Fault Frequency: 175
                        Reset counter: 162
                        Mileage: 345676 km
                        Date: 2019.10.10
                        Time: 13:54:00
                        Reset counter: 159
                        Mileage: 346506 km
                        Date: 2019.10.11
                        Time: 19:09:00
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 76
                        Reset counter: 122
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:00
    02258 - Door Opener Transmitter
                        Reset counter: 122
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:00
    03207 - Charisma Switch Module
                        Reset counter: 158
                        Mileage: 347613 km
                        Date: 2019.10.14
                        Time: 11:23:00
       Part No SW: 8T1 035 110 C    HW: 8T1 035 110 C
       Component: MP3-Changer     H43 0390
       Revision: 00043003    Serial number: AUZ5ZBH8601924
       VCID: AA189A6405E9F81F59-80FE
    Address 0F: Digital Radio
       Part No SW: 8K0 919 475 D    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0020
       Revision: 11001001    Serial number: 52940825301285
       Coding: 200103
       VCID: BA38AA243549489F29-80EE
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8K0 907 364     HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H08 0052
       Revision: 00000000    Serial number: 10090806130002
       Coding: 050181
       Shop #: WSC 02301 444 52373
       VCID: F0AC480C23B5C2CFD7-80A4
    01769 - Sensor for Vehicle Leveling; Front Right (G289)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 112
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:33
    03262 - Comfort Restriction
                        Fault Frequency: 58
                        Reset counter: 122
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:33
                        Error Code: 2
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD14801G
       Coding: 303836354230303030304A55304C384B3053
       VCID: C0CCD8CC5B95124F67-8094
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0800001QYG
       Serial number: 6334MSME40220455
       Serial number: 6344MSME3F346E1FZ
       Serial number: 6352QSME750B10247
       Serial number: 6362QSME260D220EH
       Serial number: 63732SME4E091228$
       Serial number: 63832SME230D341A-
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90319HH90007Q
       Coding: 000016
       VCID: BE30A634296164BF15-80EA
       Part No SW: 8K0 920 980 A    HW: 8K0 920 980 A
       Component: KOMBIINSTR.   H17 0224
       Revision: 00100000    Serial number: 9E1115K98
       Coding: 8B1609003300D705020000
       Part No SW: 8T0 907 468 L    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0094
       Revision: 4FB50047    Serial number: 4700F08907812C
       Coding: 000303
       VCID: CAD8FAE465A9D81FB9-809E
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H04 0150
       Serial number: 1804338A030908
    02230 - Digital Radio (DAB) (R147)
                        Reset counter: 112
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:43:34
                        Reset counter: 112
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:43:34
                        Reset counter: 112
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:49:08
       Part No SW: 8K0 907 144 B    HW: 8K0 907 144 B
       Component: DYNAMIKLENK.  H05 0490
       Revision: 50000003    Serial number: --------------
       Coding: 0C0000
       VCID: AE109674F901943F85-80FA
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 C
       Component: SG ext.Player H15 0850
       Revision: 00000000
       Coding: 020000
       VCID: AB169F60CA13E117A2-80FE
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00000015855579
       Coding: 00581300000000000000
       Shop #: WSC 02391 823 56573
       VCID: BB36AF203A73719732-80EE
                        Reset counter: 122
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:33
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H52 1100
       Revision: 00000000    Serial number: 341IM087515520
       Shop #: WSC 02301 444 54128
       VCID: B83CB02CCB455A8FDF-80EC
       Part No SW: 8K0 907 566 B    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0050
       Revision: 00H01000    Serial number: 6PZ 009 014-13
       VCID: B620BE14C151ACFFCD-80E2
       Subsystem 1 - Part No: 8K0 907 568 B
       Component: J0770_SWA_Slave_H01 0050
       Subsystem 2 - Serial number: 6PZ 009 014-33
       Subsystem 3 - Serial number: 5F24.09.0800H010003CD10278˙
       Subsystem 4 - Serial number: D10278˙
    02850 - Control Module 2 for Lane Change Assistance (J770)
                014 - Defective
                        Reset counter: 112
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:42:34
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000007705080
       Coding: 011C13204E00410001
       VCID: C1CADDC8589F1B4768-8094
       Revision: 00002001    Serial number: 0114589452
       Coding: 0106023A007A440500B001
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0040
       Serial number: 00000000000000072096
       Subsystem 3 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 112
                        Mileage: 345756 km
                        Date: 2019.10.10
                        Time: 14:42:00
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 112
                        Mileage: 345756 km
                        Date: 2019.10.10
                        Time: 14:44:05
    Address 47: Sound System
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000007699504
       VCID: C0CCD8CC5395124F67-8094
       Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
       Component: EPB Audi B8   H05 0060
       Revision: 00000003    Serial number: 10000000097666
       VCID: B12A8D08E83F8BC798-80E4
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000005
       VCID: B424841CD72DBEEFF3-80E0
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 N
       Revision: 00000000    Serial number: 379IS087531301
       VCID: B12A8D08283F8BC798-80E4
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100279635
       Coding: 010C13204000210001
       VCID: C4C4D4DC478D0E6F43-8090
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13140781805958
       Coding: 0CD154
    02214 - Tire Pressure Warning
                        Reset counter: 155
                        Mileage: 346807 km
                        Date: 2019.10.12
                        Time: 00:36:48
                        Bin. Bits: 00000000 00100101
                        Voltage: 13.80 V
                        Text:  04,0°C; -0,56bar;3441675374;00h;  6°C
       Component: SDS 3501 US     H46 0630
       Revision: 00000000    Serial number: 00000809120244
       Shop #: WSC 12336 024 394758
       Part No SW: 8T0 907 441 B    HW: 4L0 907 441 A
       Component: J772__Rearview      0070
       Revision: --H12---    Serial number: 525PA8-J8990UX
       Coding: 1001006
       VCID: B73EB310C65B55F7D6-80E2
       Revision:             Serial number: 0000100279613
                        Reset counter: 118
                        Mileage: 345672 km
                        Date: 2019.10.10
                        Time: 13:50:42
       Component: Handyvorb2      H20 1130
       Revision: 00000000    Serial number: 00000005061582
       Coding: 0010900
       VCID: A81C606C1BE5CA0F4F-80FC
    End----------(Elapsed Time: 02:43, VBatt start/end: 12.2V/12.0V)-----------
    Nice. 216,000 miles.
    What have you done so far to try to trouble-shoot these misfires? Plugs? Coils? How's this engine's compression? How badly are the intake valves carboned up?
  3. Likes DrPeter liked this post
    16.4905° S, 151.7375° W
    The ECM may not run the Basic Settings when there are fault codes. You can run the Output Tests to hear/feel if the N205-Camshaft Adjustment Valve clicks on/off, do this with the key on, engine off.
    Also when everything is fixed and the only codes you have left are the misfire faults, try clearing the fault codes three times in a row, in 30 seconds or less to Reset Misfire Adaptions.
    - See the Ross-Tech wiki page for the P0300- Random/Multiple Cylinder Misfire Detected
    Have you looked here: Official Factory Repair Information
    drpeter
  5. Likes Uwe liked this post
  6. #4
    Oct 2019
    I’ve changed the coils and plugs, just did a compression test 1,2,4 165 right at start 3 at start Is 100 but go’s up to 150 after a little bit. The intake valves where pretty carboned up they are clean now. I keep getting oil on top of my valve cover and I don’t know where it’s coming from. I think the cam bridges screen broke and is plugging up the ports for the oil to drain down. I just don’t understand how It can be on top of my valve cover. And when I put new oil in it turns black after a couple 100 miles. And I don’t think it’s from carbon. I bought the VVT bolt on my intake cam that holds my cam bridge in I was going to replace it and put a new Cambridge and timing chain kit and tensioner in it when I take my front end apart. Because of the high miles. I had Audi look at it they charged me $165 HR and said there is scratching and scoring on my cylinder #3 walls. Saying that the repairs going to cost $20,000 for a new block. I said all you did was pull my spark plug out and put I camera down it. And charged me $165 I could have done that. I was pissed. And if they are right I’ll just bore it out when I pull my front end apart. But I looked with a camera and didn’t see anything. Haven’t done a leak down test on It yet. I’ll run the N205 test and see if it clicks. When I shut my car off right after something clicks close to the front right side of the engine. Any body have any idea what that could be?
    Car is run out, call LKQ and get a drop out for a couple hundred to thousand, no?
    Oct 2019
    What’s LKQ? Sorry I’m new to this Forum.
    Sunday,20,October,2019,12:04:13:05713
    VIN: WAUMF78K19N0XXXXX   License Plate: BOOKER
    Mileage: 348180km-216349mi   Repair Order:
    VIN: WAUMF78K19N0XXXXX   Mileage: 348180km-216349miles
       Revision: E1H14---
                        Mileage: 347706 km
                        Date: 2019.10.17
                        Time: 06:24:37
                        Engine speed: 2949.00 /min
                        Normed load value: 72.5 %
                        Vehicle speed: 113 km/h
                        Intake air temperature: 6 °C
                        Voltage terminal 30: 13.570 V
    4060 - Cylinder 3
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:42:40
                        Engine speed: 761.50 /min
                        Normed load value: 13.3 %
                        Coolant temperature: 69 °C
                        Intake air temperature: 42 °C
              P0300 00 [109] - -
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:42:33
                        Engine speed: 940.50 /min
                        Coolant temperature: 70 °C
                        Voltage terminal 30: 13.428 V
    Readiness: 0100 0101
       Revision: --H04---
       Coding: 001002
       Coding: 152500
       Coding: 0D0100
       Coding: 0000003
       Coding: 64002000
                        Fault Frequency: 41
                        Reset counter: 132
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:45
                        Fault Frequency: 64
                        Reset counter: 171
                        Mileage: 347729 km
                        Date: 2019.10.17
                        Time: 17:40:17
                        Temperature: 13.0°C
                        Fault Frequency: 74
                        Reset counter: 171
                        Mileage: 347729 km
                        Date: 2019.10.17
                        Time: 17:40:19
                        Temperature: 13.0°C
       Coding: 00FD11
       Coding: 025028
    7 Faults Found:
                        Fault Frequency: 126
                        Reset counter: 168
                        Mileage: 347731 km
                        Date: 2019.10.17
                        Time: 19:34:00
                        Fault Frequency: 152
                        Reset counter: 171
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 20:52:00
                        Reset counter: 166
                        Mileage: 347768 km
                        Date: 2019.10.18
                        Time: 19:33:00
                        Reset counter: 167
                        Mileage: 347777 km
                        Date: 2019.10.18
                        Time: 19:52:00
                014 - Defective
                        Fault Frequency: 34
                        Reset counter: 132
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:00
                        Fault Frequency: 216
                        Reset counter: 132
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:00
                        Reset counter: 167
                        Mileage: 347803 km
                        Date: 2019.10.18
                        Time: 20:17:00
       Coding: 200103
       Coding: 050181
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:45
                        Fault Frequency: 30
                        Reset counter: 132
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:45
                        Error Code: 2
       Coding: 000016
       Coding: 000303
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:40:45
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:40:45
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:42:46
       Coding: 0C0000
       Revision: 00000000
       Coding: 020000
                        Reset counter: 132
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:45
                014 - Defective
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:39:45
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:51:35
                        Reset counter: 122
                        Mileage: 347696 km
                        Date: 2019.10.17
                        Time: 06:16:15
       Coding: 0000005
       Coding: 0CD154
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 130
                        Mileage: 348171 km
                        Date: 2019.10.20
                        Time: 10:15:11
                        Bin. Bits: 00001000 00100011
                        Voltage: 14.10 V
                        Text:  11,5°C; -0,64bar;3441675374;00h;  7°C
       Coding: 1001006
                        Reset counter: 131
                        Mileage: 347696 km
                        Date: 2019.10.16
                        Time: 18:51:35
       Coding: 0010900
    End----------(Elapsed Time: 02:33, VBatt start/end: 12.3V/12.2V)-----------
