Aleksandernils1
New Member
Hey. Just picked up an A7 3.0 TDi 2012 last night and drove it home(a few hours of driving) and I've been driving it to and from work with no issues at all.
Then, when I'm looking for an open parking spot, going around 10 km/h, I get these errors: Start/Stop, ACC&Brake Guard unavailable.
I went to my garage and did an Auto Scan with VCDS, but I'm not sure what the problem is.
Any help at all would be very welcome!
Aleksander
Aleksander
Thursday,17,October,2019,17:58:51:63589
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Dealer/Shop Name: AutoGo
VIN: WAUZZZ4G5CN122690 License Plate: ALEKSANDER A7
Mileage: 136553km-84850mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 3B 42 44 46 52 53
55 56 5F 62 69 6C 6D 72 85 8B 8E 8F 90
VIN: WAUZZZ4G5CN122690 Mileage: 136553km-84850miles
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0005
Revision: 53H37---
Coding: 1A254012057601020000
ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2616FC3268688B67C41-8072
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
[Lost Communication WithCruise Control Front Distance Range Sensor]
Fault Frequency: 37
Mileage: 135612 km
Date: 2019.09.18
Time: 14:43:16
Engine speed: 1468.00 /min
Normed load value: 56.5 %
Vehicle speed: 45 km/h
Coolant temperature: 89 °C
Intake air temperature: 22 °C
Voltage terminal 30: 14.620 V
Cruise Control System (CCS): status-Bits 0-7: 55
selected gear-Bits 0-7: 0
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Mileage: 134769 km
Date: 2019.06.27
Time: 12:04:36
Engine speed: 745.50 /min
Coolant temperature: 62 °C
Intake air temperature: 25 °C
Voltage terminal 30: 11.660 V
Unlearning counter according OBD: 5
Immobilizer snapshot A-Sia Error Snap A: 42 36 21
Immobilizer snapshot B-Sia Error Snap B: 1A 00 00
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G2 927 156 M HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H06 0004
Revision: --H06--- Serial number: 0000000681
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 001026
ROD: EV_TCMDL501021.rod
VCID: 382A224AB2DC0D9766D-806C
7971 - Transmission Control Unit
P1701 00 [040] - Locked
Reset counter: 2
Mileage: 134769 km
Date: 2019.06.27
Time: 12:04:36
Engine speed: 753 /min
Transmission input speed: 753 /min
Transmission output speed: 0 /min
Engine torque: 0 Nm
Transmission fluid temperature: 38 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 27A6C703E465E3C0FB00
0040 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_ACC_05_Timeout]
Fault Frequency: 7
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:37
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: 9E
Uz: 8D
0042 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ComScl_PDU_ACC_10_Timeout]
Fault Frequency: 7
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:37
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: A4
Uz: 8D
0484 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SCL_ACC_Status_ACC_Invalid]
Reset counter: 22
Mileage: 135597 km
Date: 2019.09.18
Time: 14:00:31
VzRef: 00
Bit Info 1: 80
Bit Info 2: 0F
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: A1
Uz: 87
Part No SW: 4H0 907 064 FP HW: 4H0 907 064 BP
Component: BCM2 2.0 H31 0560
Coding: 05AA2F06000000000000
Shop #: WSC 12676 003 1048576
VCID: 7CA2FE5AC6E4E1B7C25-8028
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 55
Mileage: 135777 km
Date: 2019.09.20
Time: 08:44:30
Fault Status: 00101101
Reset counter: 48
Mileage: 135777 km
Date: 2019.09.20
Time: 08:45:29
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H12 0064
Serial number: 28011200040100
Coding: 3603007824
VCID: 2708F1366F62926FFF7-8072
0378 - Coolant Circulation Pump
B10D0 04 [008] - Internal System Fault
Reset counter: 30
Mileage: 134833 km
Date: 2019.07.01
Time: 21:39:13
Voltage terminal 30: 14.17 V
Outside air temperature: 20.0 °C
Interior temperature: 25.07 °C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BN HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0111
Revision: 20012002 Serial number: 00000001204381
Coding: 0200E01050B49FE2C981008300001908CF9CE3082E080101000008402101
VCID: 75B4EB7EE5CEB0FFBDB-8020
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 111218 H35 0051
Serial number: 120109174547
Coding: 0045F7
Component: RLS H04 0003
Serial number: 20040763
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 23 01 2012 00000072
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 54080B06000000000001
Fault Frequency: 10
Reset counter: 22
Mileage: 135612 km
Date: 2019.09.18
Time: 14:43:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901202300621
Coding: 290B03
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B203D4683EA268F8BF-806E
Address 13: Auto Dist. Reg
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG006FASB
Coding: 30314530323130303038554A304C34473853
VCID: 36362C72B8C8FBE7741-8062
Serial number: 3575HRB4063124B28G25
Serial number: 3585HRB404T11PNAGP65
Serial number: 3515JRB405N0VIFMKGEO
Serial number: 3525JRB405T0TGJKB8CA
Serial number: 3554VRB40590V8BOA96V
Serial number: 3564VRB404V0V8BOEHM
1050368 - Databus
[CAN: 0x323 PCF_01 Timeout]
Fault Frequency: 18
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:42
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LAN000HN
Coding: 00001C
VCID: 37282176BF4202EF6F7-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Serial number: 23 11 2011 11194184
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 931 R HW: 4G8 920 931 R
Component: TDieRdwAcc H79 0416
Revision: 28460177 Serial number: 658190112596029
Coding: 138600021F030008010100
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K.rod
VCID: 3D24335E9DFE28BFB5B-8068
16776960 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_02_FR keine Kommunikation]
Fault Frequency: 57
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:41
16776961 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_04_FR keine Kommunikation]
Fault Frequency: 40
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:41
Part No SW: 4G0 907 468 G HW: 4G0 907 468 A
Component: J533--Gateway H08 0214
Revision: -------- Serial number: 00000000370747
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 3432167AAEB4E9F74A5-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790741752
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 12018001354021200181
4365 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
Fault Frequency: 37
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:37
Voltage terminal 30: 10.9 V
Voltage terminal 15: 10.9 V
Control Module temperature: 11 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: On
Datenfeld: 0
6654 - Automatic distance regulation 2
U1071 00 [009] - No communication
Fault Frequency: 17
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:39
Voltage terminal 30: 11.3 V
Voltage terminal 15: 11.3 V
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 41
Mileage: 135517 km
Date: 2019.07.28
Time: 19:55:39
Voltage terminal 30: 11.9 V
Voltage terminal 15: 0.0 V
Control Module temperature: 27 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 0
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0064
Serial number: 22011200041318
Coding: 00
VCID: 2F3819164792CA2F377-807A
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 E HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0781
Coding: 008003
ROD: EV_AirSuspe_VW51.rod
VCID: 2D04031E4D9EB83F05B-8078
0002 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 29
Reset counter: 22
Time: 00:00:00
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0009
Revision: -------- Serial number: EJ1BPA4203J33S0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F56224000628002080403
VCID: 41DC4FAEE1864C5FD13-8014
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0012308831
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323E106254A0E7C7589-8066
Revision: 00002001 Serial number: 0168571944
Coding: 013A0E2020B9B40183200A042C0302000000000000000000000000000000
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0028
Serial number: WA102902000000869062
Subsystem 4 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84198711
Fault Frequency: 24
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:41
Fault Frequency: 28
Reset counter: 62
Mileage: 135596 km
Date: 2019.09.18
Time: 13:58:52
00532 - Supply Voltage B+
Reset counter: 62
Mileage: 135777 km
Date: 2019.09.20
Time: 08:45:29
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F56224000628002080402
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000238714
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0E08027C70AF07E09-807E
327936 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FC_ACC_05_MESSAGE_TIMEOUT]
Fault Frequency: 37
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:37
Voltage terminal 30: 11.0 V
Internal Fault ID: 86
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Auto Adjust: not active
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 120124-0004-049
Coding: 11236F33F91AEB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
VCID: 303A1A6A5AACD5D72ED-8064
H01 0031
Coding: 3A0000
H01 0031
Coding: 3A0000
Part No SW: 4G0 035 061 E HW: 4G0 035 061
Component: Radio U DAB H60 0099
Revision: AB001007 Serial number: 109AP0C7546013
Coding: 010103020100000001
VCID: 1F18E9D637B25AAF877-804A
Part No SW: 4G0 035 666 G HW: 4G0 035 666 A
Component: H-BN-EU H48 0484
Revision: -------- Serial number: 426AM0C7634011
Coding: 090100040003F9EF2510AB3E00000003E00001020000000000
VCID: 2C020E1A7604B137125-8078
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB9400JVVL
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LAP000JK
Component: CD-Database 3638
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 41
Mileage: 135517 km
Date: 2019.07.28
Time: 19:48:55
Voltage: 11.90 V
Reset counter: 22
Mileage: 136540 km
Date: 2019.10.17
Time: 17:26:07
Bin. Bits: 00000000 00100000
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14224000628002080002
VCID: 44D246BAFE945977FA5-8010
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000168815195
Coding: 0109080000000000
VCID: 71BCDF6E91A69CDF613-8024
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0111
Revision: 11001001 Serial number: 82330JF0026587
Coding: 0205000001010100010102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
VCID: 2B000D06738AB60F1BF-807E
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 N HW: 4G8 959 107 F
Component: HDSG-Modul H13 0039
Revision: 11013001 Serial number: 014200785
Coding: 0A3305C003
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
VCID: 40DA4AAAEA0C4557DED-8014
Component: TSG HR H04 0212
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H25 0036
Revision: -------- Serial number: 262130025421000
Coding: EE040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 6594BB3E55EE407F0DB-8030
0724 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_timeout]
Fault Frequency: 37
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:40
Outside air temperature: -43.5 °C
Voltage terminal 15: 11.0 V
Control Module temperature: 13.0 °C
Address 8B: Adaptive Cruise 2
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000052401127
Coding: 0380AA1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0046 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ACC_timeout]
Fault Frequency: 41
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:37
Outside air temperature: 14.0 °C
Control Module temperature: 0.0 °C
Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
Component: RGS-VL H13 0080
Coding: 00660600031F037E000308014248D2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313C1F6E51A6DCDF213-8064
12583680 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 35
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:42
12583693 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Frequency: 48
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:42
12583937 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Fault Frequency: 41
Reset counter: 62
Mileage: 135590 km
Date: 2019.09.17
Time: 16:38:58
12583970 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Reset counter: 62
Mileage: 135733 km
Date: 2019.09.19
Time: 15:44:06
Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
U1111 00 [009] - -
Fault Frequency: 35
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:42
U1111 00 [009] - -
Fault Frequency: 48
Reset counter: 22
Mileage: 135590 km
Date: 2019.09.18
Time: 13:45:42
U1112 00 [008] - -
Fault Frequency: 41
Reset counter: 62
Mileage: 135590 km
Date: 2019.09.17
Time: 16:38:58
U1112 00 [008] - -
Reset counter: 62
Mileage: 135733 km
Date: 2019.09.19
Time: 15:44:06
End----(Elapsed Time: 02:21, VBatt start/end: 11.7V/11.8V. VIgn 11.7V)-----
