Results 1 to 10 of 12
Thread: Passat b5 tdi 4 motion -99 lock problem
    New User
    Oct 2019
    Sweden
    Hello
    now is the first time i write on a forum for help.
    is not good in english so have to use google translate to write better
    have been stuck in ideas of what the error in my car might be.
    the car unlocks itself and opens all 4 windows.
    I have no wrong codes on the lock. has also replaced the driver and passenger side lock boxes. Replace cables in the driver's door and have no cable break. the comfort controller is 2 years old bought brand new. have been looking under the carpet for bad cables and cable breakage. have also seen that the lamp under the door does not go out when the door is closed
    Even though there are no fault codes please post a full unedited VCDS Auto-Scan, this will show how your car is equipped and make it easier to make good suggestions.
  3. Likes Uwe liked this post
    New User
    Oct 2019
    Sweden
    now i have a swedish version of vcds. how do i do an autoscan in english
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    This is not a problem.
    Download the current 19.6.2 on the page https://www.ross-tech.com/vcds/download/current.php
    Both versions are running on your computer
    -Wolfgang
    Drive more talk less
  6. Likes Uwe liked this post
    New User
    Oct 2019
    Sweden
    now I think I got an autoscan
    Friday,18,October,2019,11:55:13:00080
    VCDS Version: 19.6.2.0 (x64)
    Chassis Type: 3B - VW Passat B5 (1997 > 2005)
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
       Mileage: 239910km-149073miles
       Part No: 038 906 018 P
       Component:  1,9l R4 EDC  G00SG  1623
       Coding: 00003
       Shop #: WSC 05314
       VCID: 237DAF2CB1D5A8579A-FFFE
    00626 - Glow Plug Indicator Light (K29)
                31-10 - Open or Short to Ground - Intermittent
                P1570 - 35-00 -
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 8E0-614-111-EDS.lbl
       Part No: 8E0 614 111 A
       Component: ABS/EDS 5.3 QUATTRO D00
       Shop #: BB 24334
       VCID: 1C0F94D08CAB97AF5B-FFFE
                35-00 - -
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 A
       Component: CLIMATRONIC       S 9.0
       Coding: 00000
       VCID: 1F75A3DC9DBD8CB7BE-FFFE
                30-00 - Open or Short to Plus
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 607 A
       Component: AIRBAG VW3 S        V04
       Coding: 00065
       Shop #: WSC 05311
       VCID: 2B6D470CD905601722-FFFE
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 3B0-919-xxx-17.lbl
       Part No: 3B0 919 881 N
       Component: B5-KOMBIINSTR. VDO V30
       Coding: 04140
       Shop #: WSC 35161
       VCID: 37456B7C154DD4F756-FFFE
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0W0518891
       IMMO-IDENTNR: VWZ7Z0W0518891
    00667 - Ambient Temperature Signal
                29-10 - Short to Ground - Intermittent
    00771 - Fuel Level Sensor (G)
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 J
       Component: 0E Zentral-SG Komf.0002
       Coding: 04097
       Shop #: WSC 05311
       VCID: 45B911B45FA1B667D4-FFFE
       Subsystem 1 - Part No: 1J1959801D
       Component: 3C Tőrsteuerger. FS0001
       Subsystem 2 - Part No: 1J1959802E
       Component: 0E Tőrsteuerger. BF0001
       Subsystem 3 - Part No: 1J4959811D
       Component: 0E Tőrsteuerger. HL0001
       Subsystem 4 - Part No: 1J4959812D
       Component: 0E Tőrsteuerger. HR0001
    01389 - Tailgate Open Switch (F124)
                35-00 - -
    End-------------------------(Elapsed Time: 07:54)--------------------------
    Sep 2014
    Hello and thank you
    There is something wrong with the Central Locking,Key Switch in Driver or Passenger Door.
    I prefer checking the measurement in "46" channel 003,1,Central Locking,Key Switch Drv.,Range: open/closed/not operated/implausible
    and 006,1,Central Locking,Key Switch Pass.,Range: open/closed/not operated/implausible.
    Maybe defektive micro switches or water inside
    -Wolfgang
  9. Likes Uwe liked this post
  10. #7
    New User
    Oct 2019
    Sweden
    these are brand new. mounted these yesterday when I believed in this error. during the day i have been wondering if my comfort controllers can be wrong even if this is now quite new. can there be poor soldering?
  11. Likes PetrolDave liked this post
  12. #8
    Quote Originally Posted by Trucker_v8 View Post
    Have you cleared the fault codes since you fitted the new locks? Fault codes do not always clear automatically.
  13. #9
    New User
    Oct 2019
    Sweden
    yes then they are gone. another disappeared today when I changed the glass in the rear view mirror. I have a code that comes o goes which is for the tailgate. the cable to be in the lock in the tailgate is completely green and does not find a good tool for removing the cables or spray to dissolve the oxide. but I have a hard time believing this to work on the locks beyond
  14. #10
    New User
    Oct 2019
    Sweden
    Hello again . now i have been looking o looking but not coming to anything. has a theory about another problem. the car draws thief current 0.36A. the interior lighting is lit up and related several times. the lamp under the right door is constantly lit. the car unlocks, the window goes down. even when i removed the fuse, the lamp shines under the door but then dim. now this thief current can give the comfort controller wrong signals. have been looking for this all day but no one is going anywhere. has taken out o put in the comfort of the harness several times but this draws no current. all the cables from the driver's door I took table o then the current went down to 0.27A
