Results 1 to 4 of 4
Thread: VW Touareg 7P facelift bixenon retrofit
    Feb 2018
    Lithuania
    Hello members!
    I have 2014 VW Touareg, that has been in an accident (front collision) and owner decided to put facelift Bi-xenons with LED Drl. Seems like everything works, except DRL dim ( as parking light). I have wiring diagrams for 2014 bi-xenons, but don't have for 2016, so don't know if these headlamps work the same. By the way new headlights has 1 pin less than original ones. So could someone share wiring diagrams for verification?
    autoscan here:
    Chassis Type: BP-VW52 (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
              69 6C 6D 72
    VIN: WVGEP9BP3ED011134   Mileage: 141019km-87625miles
    Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
       Component: 3.0TDI FSA    H21 0011
       Revision: 56H21---
       Coding: 292A4012233600050000
       Shop #: WSC 01313 444 00000
       ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
       ROD: EV_ECM30TDI0117P0907401K.rod
       VCID: 377D59878E9E5EF756-8062
    Readiness: 0 0 0 1 1
       Part No SW: 0C8 927 750 CF    HW: 0C8 927 750 CF
       Component: AL1000 AISIN  002 3376
       Coding: 001368
       Shop #: WSC 63971 001 1048576
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_002.rod
       VCID: 72EBA893A57CFBDFA1-8026
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
       Component: MK25A         H36 0446
       Revision: --------    Serial number: 406340010EC818
       Coding: 5B7613C349252554DAF5C89692D6A4407300
       Shop #: WSC 31414 790 00001
       ROD: EV_ESPMK25A00800.rod
       VCID: 4A9B1073ED6CD31F39-801E
       Part No SW: 4H0 907 064 EK    HW: 4H0 907 064 EK
       Component: BCM2 2.0      H36 0521
       Coding: 0D860016000000000000
       VCID: 76E39483C114E7FF8D-8022
       Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Serial number: 0214000038407011
       Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
       Component: Klima 2 Zonen H21 1306
       Coding: B606200A80
       VCID: 0501E34F84F2FC6794-8050
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [008] - Signal Amplitude Too Low
                        Reset counter: 20
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 13:54:08
       Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
       Revision: 15012002    Serial number: 00000001527396
       Coding: 26001096973C5D010021180300005D0C431C660882010261000000020000
       Shop #: WSC 00334 121 02345
       VCID: 6CD7B6EB8F582D2F6B-8038
       Component: WWS    140308  033 0021
       Serial number: 90243400140312140855
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Serial number: 20275997
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
       Component: E1 - LDS  H04 0031
       Serial number: 00000000001303140522
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555RAA4C03
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Fault Status: 01101100
                        Reset counter: 235
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 12:30:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 235
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 12:30:00
                        Reset counter: 235
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 13:54:00
                        Reset counter: 235
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 13:54:00
    03280 - Switch Position of Light-Switch Knob
                        Fault Frequency: 11
                        Reset counter: 20
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 12:37:00
       Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
       Component: VW10Airbag06X H06 0026
       Revision: --------    Serial number: 003L5004TAE0
       Coding: 000000000000000000000000000000003658
       ROD: EV_AirbaVW10BPAVW526_001.rod
       VCID: 428B3853D55C0B5FF1-8016
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R13C190HSCW
       Serial number: 3575LRB40672B8KK7181
       Serial number: 3585LRB405H150GU40LB
       Serial number: 3515RRB401A50UUEP0Q9
       Serial number: 352  RB400000000000%
       Serial number: 3555NRB400U50TIMQ0VT
       Serial number: 3565NRB401250T8CD1C
    9443603 - Rear Side Airbag Crash Sensor (on front passenger's side)
              B1019 13 [137] - Open Circuit
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:28
    9442074 - Driver's Belt Force Limiter Igniter
              B1013 1A [137] - Resistance Too Low
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:29
    9442587 - Igniter for battery interrupt
              B1015 1B [137] - Resistance Too High
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:29
    9442330 - Passenger's Belt Force Limiter Igniter
              B1014 1A [137] - Resistance Too Low
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:29
    9444883 - Driver's seat position sensor
              B101E 13 [137] - Open Circuit
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:27
       Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
       Revision: --------    Serial number: 01335NCH000GR
       Coding: 000015
       VCID: 366354838194A7FF4D-8062
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H05 0028
       Serial number: 0000716 TRW 20140213
                        Fault Status: 00101101
                        Reset counter: 19
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 09:54:18
    Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
       Part No SW: 7P6 920 982 L    HW: 7P6 920 982 L
       Component: Kombi         H13 0419
       Revision: 13240270    Serial number: 658170314592046
       Coding: 8B7733022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001020
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 479D2947FE7E2E7726-8012
       Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6032
       Revision: --------    Serial number: 00000001311602
       Coding: 000103AD00
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3F8D31A7A6AE66B79E-806A
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 31065051055701866256
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000091415627
       Coding: 00581B0000004001000001010101202020202121202020
       VCID: 34676E8B97E8B5EF73-8060
    03777 - Sensor for Lumbar Support Adjustment
                        Fault Status: 01100101
                        Reset counter: 235
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:23
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000095461241
       Coding: 011D17205E00453005080000
       VCID: 7AFB80B3F50C839FE9-802E
       Revision: 00002001    Serial number: 0329018965
       Coding: 0186123A68B9509580A00620210A08000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Serial number: 0581422444
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Serial number:     WOO26074867
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Serial number:     WOO2760332/
       Coding: 191100
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93173778
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000095562778
       VCID: 489F2A7BFB60210F2F-801C
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1430200002
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 366354838994A7FF4D-8062
       Slave 3:
    Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
       Coding: 010A00000F000400
       VCID: 7CF786ABF738BDAFFB-8028
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0003
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0003
       Coding: 130000
    5276209 - Power Output Module for Right Headlamp
              C1082 31 [008] - No Signal
                        Reset counter: 20
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 14:18:14
       Revision: AB001007    Serial number: 156C%0E7980454
       Coding: 020007020100000001
       VCID: 24479ECB2708256FE3-8070
    02983 - Connection between Impedance Converter 1 and Window Antenna
                        Fault Status: 01101011
                        Reset counter: 235
                        Mileage: 141019 km
                        Date: 2019.02.22
                        Time: 15:36:33
                        Voltage: 11.50 V
       Part No SW: 7P6 035 664 E    HW: 7P6 035 664 A
       Component: H-BN-NA       H40 0783
       Revision: --------    Serial number: 273CU0E7510840
       Coding: 010200050040E1EE41022B0C00000003F00001030000000000
       VCID: 3A7B40B3B58C439FA9-806E
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Serial number: VWZ8Z9PA3005LP
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  5571
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000095579945
       Coding: 011817200000253005080000
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 10000000128693
       ROD: EV_RDKBERU25_VW52.rod
    8389633 - Radio Frequency Interference
              C105C 00 [008] - -
                        Fault Frequency: 8
                        Reset counter: 20
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 09:42:36
    8389636 - Radio Frequency Interference
              C105C 00 [008] - -
                        Fault Frequency: 8
                        Reset counter: 20
                        Mileage: 141019 km
                        Date: 2019.02.23
                        Time: 09:42:36
    8397570 - Rear Left TPMS Sensor
              C1052 31 [009] - No Signal
                        Reset counter: 227
                        Mileage: 140986 km
                        Date: 2019.01.17
                        Time: 03:05:17
                        Vehicle speed: 52 km/h
                        Outside air temperature: 21.5 °C
                        Reception level antenna 1: 660 mV
                        Offset level antenna 1: 610 mV
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H11 0110
       Revision: 5A001001    Serial number: 00008200183887
       Coding: 020D000000000000
       VCID: 3B7545B7BAB67A97B2-806E
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H08000    Serial number: 525 PA8J430129
       Coding: 0110001
       VCID: 377D5987469E5EF756-8062
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 055400695
       Coding: 0533314003
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000095580082
    End-------------------------(Elapsed Time: 05:29)--------------------------
    any help will be much appreciated!
  3. Likes Dana liked this post
    United States
    That looks like a NAR market T'reg so the (old) factory condition scan from my husband's 2017 NAR (7P) may be useful in regards to a handful of 09 and 55 coding bits in addition to the VIN to pull up diagrams in erWin VW:
    Monday,19,March,2018,17:16:17:04045
    VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4421.4
    Data version: 20180316 DS287.1
    VIN: WVGRF7BP0HD004431   License Plate: TOUAREG
    Mileage: 13505km-8391mi   Repair Order:
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3C 42 46 52 53 55 56 5F
              62 65 69 6C 6D 72 85 8B 8E
    VIN: WVGRF7BP0HD004431   Mileage: 13505km-8391miles
    Address 01: Engine (J623-CGRA)       Labels:. 03H-907-309-V1.clb
       Part No SW: 03H 906 023 DD    HW: 03H 907 309 E
       Component: VR6 3.6l FSI  H17 3178
       Revision: M7H17---
       Coding: 002A0012437600000000
       ASAM Dataset: EV_ECM36FSI01103H906023DD 002001
       ROD: EV_ECM36FSI01103H906023DD_002.rod
       VCID: 6788B1F50FED28EFD32-8032
    Readiness: 0000 0101
    Address 02: Auto Trans (J217)       Labels:. 0C8-927-755.clb
       Part No SW: 0C8 927 755 F    HW: 0C8 927 755
       Component: 94304G0I.MOT  130 3067
       Coding: 010200000C008400000000000000000000000000
       ASAM Dataset: EV_TCMAL991031 003118
       ROD: EV_TCMAL991031_003.rod
       VCID: 343216B90EBB9377A60-8060
    Address 03: ABS Brakes (J104)       Labels:| 7P0-907-379.clb
       Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
       Component: MK25A         H37 0521
       Revision: --------    Serial number: 42656444096442
       Coding: 5B7613C349246F57DAF8C89692D3F660F701
       ASAM Dataset: EV_MK25AXT 010001
       ROD: EV_ESPMK25A01000.rod
       VCID: 4CC26E59764BEBB7DE0-8018
       Part No SW: 4H0 907 064 JK    HW: 4H0 907 064 JK
       Component: BCM2 2.0      H44 0582
       VCID: 7BA0FD8563E59C0F27A-802E
       Serial number: 3216000291283002
       Part No SW: 7P6 907 040 DA    HW: 7P6 907 040 DA
       Component: Klima 2 Zonen H23 1608
       Coding: 4686200880
       VCID: 76B6ECB15847C167584-8022
       Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
       Revision: 22020001    Serial number: 00001538544201
       Coding: 26000096963C5D010020480000005D4C431C6608A2014267000000008040110000000000000000
       VCID: 6A8EC8C11C7F1587CCC-803E
       Component: WWS    161118  033 0021
       Serial number: 90243400161205141359
       Coding: 004DBD
       Serial number: 80959290
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
       Component: E1 - LDS  H02 0040
       Serial number: 00000000002311160072
       Serial number: 00000000095Z027E461D
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0230236760
       Coding: 952F00
       Subsystem 6 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Serial number:           0230238467
       Coding: 952F00
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475 D    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0030
       Revision: --------    Serial number: 28261632601121
       Coding: 310D04
       ASAM Dataset: EV_VW526ParkiAssis2 001013
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 44D246795E1B23F7160-8010
       Part No SW: 7P6 907 561 C    HW: 7P6 907 561
       Component: ACC3          H21 0400
       Coding: 3701010101
       ASAM Dataset: EV_AdaptCruisContrVW526 002012
       ROD: EV_AdaptCruisContrVW526_002.rod
       VCID: 3C223E9926EB5B376E0-8068
       Part No SW: 7P0 959 655 G    HW: 7P0 959 655 G
       Component: VW10Airbag035 H11 0048
       Revision: --------    Serial number: 003TU001E8ZY
       Coding: 000000000000000000000000000000003335
       ASAM Dataset: EV_AirbaVW10BPAVW526 002001
       ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
       VCID: 45D45B7D55211AFF01E-8010
       Serial number: 5850000R169090UAXA
       Serial number: 3575LRB405L4A2MI499F
       Serial number: 3585LRB405L4A2MIF1DN
       Serial number: 3517ARB40534738I6H4E
       Serial number: 3527ARB405N47TV0CPJ9
       Serial number: 3557BRB404P460NCAO9I
       Serial number: 3567BRB404P460NCIO3L
       Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
       Component: Lenks.Modul   H06 0010
       Revision: --------    Serial number: 01374PL3000PK
       Coding: 000CDD
       VCID: 3D24339D3D71523F59E-8068
       Component: E221__MFL-TAS  H04 0028
       Serial number: 0145310 TRW 20160310
       Part No SW: 7P6 920 983 M    HW: 7P6 920 983 M
       Component: Kombi         H15 0607
       Revision: 15240314    Serial number: 658081216592024
       Coding: 8B4732026F08CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001030
       VCID: 49CC574D7939FE9FE56-801C
       Part No SW: 7P6 907 530 R    HW: 7P6 907 530 G
       Component: GW-CAN-L-FR-M H15 6051
       Revision: --------    Serial number: 00000002465346
       Coding: 0021035600
       ASAM Dataset: EV_GatewVW526UDS 001008
       VCID: 47C851756F2D08EFF32-8012
       Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
       Component: Batt_Sensor  H07 0270
       Serial number: 33335J28465811991450
       Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
       Component: SWA Master    H08 0030
       Serial number: 0423724645
       Coding: 030221
       VCID: 3FD8499537FD402F4B2-806A
       Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0030
       Serial number: 0424551825
       Coding: 030221
       Component: TSG FA        H03 0306
       Revision: --------    Serial number: 0000232712279
       Coding: 011D17200000453005080001
       VCID: 7AAEF8816CDFA5073CC-802E
       Revision: 00002001    Serial number: 0425900145
       Coding: 0187123A68B9501580B00620210A18000000000000000000000000000000
       Serial number: 3241624941
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS30.408  H03 0004
       Serial number: 0000FST001CB61V00000
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
       Component: J394 PS30.408  H03 0004
       Serial number: 0000FST001CFPEV00000
       Coding: 191100
       Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
       Component: GEB.F.Heckoef  H16 0813
       Serial number: 65068906
       Component: TSG BF        H03 0306
       Revision: --------    Serial number: 0000232121022
       Coding: 011D17200000453005080000
       VCID: 48CA524962B30797FA8-801C
       Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
       Revision: 00000000    Serial number: C16B0700514
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 372821B51FCD786F832-8062
       Slave 3:
       Component: AFS-ECU       H01 0120
       Coding: 012A02010B000400
       ROD: EV_HeadlRegulAFSMQBMLB_VW51.rod
       Component: LeiMo links  H01 0006
       Coding: B00000
       Component: LeiMo rechts  H01 0006
       Coding: B00000
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H66 0138
       Revision: AB001007    Serial number: 156L-0G2750150
       VCID: 2514FBFDB5E1FAFF21E-8070
       Part No SW: 7P6 035 664 N    HW: 7P6 035 664 A
       Component: H-BN-NA       H42 1048
       Revision: --------    Serial number: 606L-0G5000069
       Coding: 010200050040E9EF39022B0E00000003F00001030000000000
       VCID: 43D045655B9524CF2FA-8016
       Subsystem 1 - Part No: 7P6 060 884 H
       Component: NAR 2017  1502
       Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: DU8 SV Touch  H56 0046
       Serial number: VWZ8Z9SGG00DZM
       Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
       Component: CD-Database  9040
       Component: TSG HL        H04 0306
       Revision: --------    Serial number: 0000231707877
       Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 30000000056520
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
       Component: Anhaenger     H20 0160
       Revision: 7C001003    Serial number: 0425122862
       Coding: 0200000200000000
       ROD: EV_TrailFunctGener2Hella_VW52.rod
    Address 6C: Back-up Cam. (J772)       Labels:* None
       Part No SW: 7P6 980 556     HW: 7P6 980 556
       Component: RVC Compact   H08 0160
       Coding: 0125060123002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAVW526 001001
       ROD: EV_CamSysRVRVCPANAVW526.rod
       VCID: 7EA6F49170778927004-802A
       Revision: 22010001    Serial number: 335600005
       Coding: 0533314003
       Component: TSG HR        H04 0306
       Revision: --------    Serial number: 0000231707601
       Part No SW: 7P6 907 217 B    HW: 7P6 907 217
       Component: DPC-SG        H27 0035
       Coding: 69020000
       ASAM Dataset: EV_OnBoardCamerDTR 001001
       ROD: EV_OnBoardCamerDTR.rod
       VCID: 392C278D29D96E1F756-806C
       Slave 1:
       Subsystem 1 - Part No: 7P6 907 658
       Component: NICKRATENSENS  H02 0001
       Serial number: 000000007069212_3053
       Part No SW: 7P6 907 541 C    HW: 7P6 907 541
       Coding: 3701010101
       ASAM Dataset: EV_AdaptCruisContr2VW526 002011
       ROD: EV_AdaptCruisContr2VW526_002.rod
       VCID: 3A2E38812CDF65077CC-806E
    Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
       Part No SW: 7P6 907 107 B    HW: 7P6 907 107
       Component: BV-SG         H34 0035
       Serial number: 005002473011167
       Coding: 0AA118040000
       ASAM Dataset: EV_BTR 002001
       ROD: EV_BTR_002.rod
    End----------(Elapsed Time: 02:20, VBatt start/end: 12.4V/12.4V)-----------
    Current versions of VCDS would load a 4H0-907-063-V2 label for the facelift (longer coding) 09 module.
  5. Likes Uwe liked this post
    Feb 2018
    Lithuania
    Thank you! Does your drl dim when you turn low beams on?
