VW 1.5 tdi crdi polo not starting once heated
Wmwizkid
India
C?ID=374582
hello you fantastic people.
i have a polo 1.5 tdi crdi with a peculiar problem the car starts finevwhen cold but once the coolant temp reaches 90 degrees and if i turn off the ignition then the car fails to start it just keeps cranking and starts only when the coolant temp reaces below 90 deg. or starts if i unplug the coolant sensor. there are no fault codes. i tried changing the coolant temp sensor but didnt help.
am attaching a scan too. please help i tried changing the starter and battery also.
 Thursday,17,October,2019,13:14:34:02918
VIN: MEXE16604GT088189   License Plate: POLO HEAT
Mileage: 38750km-24078mi   Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: MEXE16604GT088189   Mileage: 38750km-24078miles
Address 01: Engine (J623-CWXA)       Labels: None
   Part No SW: 03L 906 023 SL    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110116032500080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM15TDI02103L906023SL 001001
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 02489DD89504775FB1-8056
   Part No SW: 6R0 907 379 BP    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Serial number: --------------
   Coding: 60DD2763412B18C80615E471825A18020000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0D52BEE4DC5A3827DC-8058
0903 - Please Check Fault Codes in Engine Control Module
          U101F 00 [008] - -
          [Scl_EngineTrq_Invalid]
                    Fault Frequency: 17
                    Reset counter: 52
                    Mileage: 38419 km
                    Date: 2017.03.31
                    Time: 00:27:07
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41CA52D4D882AC47E8-8014
                    Fault Status: 00101101
                    Reset counter: 52
                    Mileage: 38419 km
                    Date: 2017.03.31
                    Time: 01:39:12
   Part No SW: 6RU 937 086 M    HW: 6RU 937 086
   Component: BCM IM M+4    H40 0432
   Revision: BY040001    Serial number: 0200 122160778
   Coding: 3AB02BFF08B30000013800006C2B06900080414F608C0000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 6B96D07C8A8E961762-803E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 040316 03  37  0059
   Coding: 036800
   Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  020 2551
   Serial number: 13102848160114104301
   Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13202849160223130053
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 0471608365801042AB2B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13102728160209153222
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13202729160301134756
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Component: VW10AirbagU06 H10 0020
   Revision: --------    Serial number: 003GW01423DV
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49DA4AF4E8B2640730-801C
   Part No SW: 6RF 920 862 A    HW: 6RF 920 862 A
   Component: KOMBI         H01 0215
   Coding: 1208000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4AD875F8EDB46F1F39-801E
   Part No SW: 6RU 909 901     HW: 6RU 937 086
   Component: GW-K-CAN TP20 H40 0432
   Revision: BY040001
   Coding: 002300
   VCID: 197ADAB41092D48740-804C
   Component: IMMO          H01 0215
   VCID: 6A98D5788D748F1F19-803E
Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ASAM Dataset: EV_SteerAssisNSK 014008
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 41CA52D4D082AC47E8-8014
Address 56: Radio
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
Jef
HQ
We have your email, but we'd rather do this on the forum so other people can chime in and also for the next person that has this issue can possibly find answers. Please post your Auto-Scan here.
Regards.
Wmwizkid
India
C?ID=374582
Have added the scan please help
myounus
Northwest UK
C?ID=321059
Check the wires are not fused together. I had a similar problem on a Touran about 3 years ago and there was 2 wires that had fused together. Took me best part of 5 days testing and testing and testing.
DGMotors
C?ID=57532
 Monday,07,October,2019,20:17:44:02918
VIN: TMBBBH3T8BA302768   License Plate: SUP
Mileage: 108200km-67232mi   Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 62 72
          77
VIN: TMBBBH3T8BA302768   Mileage: 108200km-67232miles
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
   Component: 1.8l R4/4V TFSI     0040
   Revision: AAH18---    Serial number:
   Coding: 0203000C24070160
   Shop #: WSC 62987 001 1048576
   VCID: 352236045C4A10E744-8060
000290 - Throttle Position Sensor (G69)
               P0122 - 000 - Signal too Low - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 98.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 940.0 mbar
                    Voltage: 12.319 V
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 000 - Signal Too Low - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 98.0°C
                    Temperature: 45.0°C
                    Voltage: 12.319 V
Readiness: 0110 0101
   Part No SW: 0AM 300 054 B    HW: 0AM 927 769 D
   Component: GSG DSG AG7     441 3640
   Revision: 00044014    Serial number: CU501708105505
   Shop #: WSC 04940 001 00001
   VCID: 2C1413608F00512F2B-8078
   Revision: 00H31001
   Coding: 863D6016092200FC611206EA90210081350000
   Shop #: WSC 33361 790 00074
   VCID: 7BB6E03CFAEE0697F2-802E
                    Reset counter: 132
                    Mileage: 108201 km
                    Date: 2014.02.27
                    Time: 00:25:60
                    Count: 14
                    Count: 12544
                    Count: 8193
                    Count: 41728
                    Count: 65280
                    Count: 65026
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000001002
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 7CB4E320F7E001AFFB-8028
9480465 - Control Circuit for A/C Compressor
          B10A9 11 [009] - Short to Ground
                    Reset counter: 132
                    Mileage: 108203 km
                    Date: 2019.10.07
                    Time: 00:19:18
   Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
   Component: BCM PQ35  H+  110 0651
   Revision: 00110 AC
   Coding: 48990ABBE85BF1C040080080310089E4417000AE732089605C8040000040
   VCID: 71AAC214A8A27CC758-8024
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 25061  26  0602
   Coding: 00D7B7
   Component: RLS 080711 05  54  0403
   Coding: 0730ED
   Component: LIN BACKUP HO  H11 9005
01134 - Alarm Horn (H12)
                    Reset counter: 172
                    Mileage: 108201 km
                    Date: 2014.02.27
                    Time: 00:17:39
                        Term 15 Off
                    Voltage: 12.25 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 44
                    Reset counter: 132
                    Mileage: 108201 km
                    Date: 2014.02.27
                    Time: 00:17:50
                    Voltage: 13.45 V
                        Term 50 Off
03396 - Supply voltage terminal 30 for central locking
                    Fault Status: 00101011
                    Reset counter: 172
                    Mileage: 108203 km
                    Date: 2014.02.27
                    Time: 00:06:17
                    Voltage: 12.25 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 172
                    Mileage: 108203 km
                    Date: 2014.02.27
                    Time: 00:11:14
                    Voltage: 13.85 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28291115773397
   Coding: 108104
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000_001.rod
   VCID: 43C658DCCA9EBE57FA-8016
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAQ VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PBCZQ05
   Coding: 0016721
   VCID: 41CA52D41882AC47E8-8014
   Subsystem 1 - Serial number: 6332MTS682541691
   Subsystem 2 - Serial number: 6342MTS666841691
   Subsystem 3 - Serial number: 6351HTS6Q6ROT9KJ
   Subsystem 4 - Serial number: 6361HTS686MI5AKR
   Subsystem 5 - Serial number: 63727TS6JT3JS9KJ
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20110709301460
   Coding: 089A140000
   Shop #: WSC 33361 790 00999
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76A0F108C9CC5BFF8D-8022
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 830000
   Part No SW: 3T2 920 841 J    HW: 3T2 920 841 J
   Coding: 110F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3B36203CB26EC697B2-806E
9453330 - Outside temperature sensor
          B103F 1B [008] - Resistance Too High
                    Reset counter: 172
                    Mileage: 108203 km
                    Date: 2019.10.07
                    Time: 00:26:26
   Revision:   H42       Serial number: 020711F2001827
   Coding: 353303
   VCID: 352236049C4A10E744-8060
Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760 C    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2901
   Revision: 00H05000
   Coding: 00003B
   Shop #: WSC 12336 024 394758
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011D0220DE01001000
   VCID: 4FEE64EC1ED64A376E-801A
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 195    3201
   Revision: 00H20000
   VCID: 34240B00573009EF73-8060
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.6 V
                        PD
                    Temperature: 35.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4ED079E819DC433F65-801A
02123 - Door Warning Light / Entry Light
                    Reset counter: 132
                    Mileage: 108201 km
   Coding: 1377095
   Coding: 00000021
   Coding: 00000021
   Part No SW: 3T0 035 156 F    HW: 3T0 035 156 F
   Component: BOLERO        001 0008
   Revision: -----08S    Serial number: SKZ4Z3L1140439
   Coding: 0D0004000004
   VCID: 312A021468223CC718-8064
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
   Component: TSG HR        H06 0409
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660377881
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 35223604944A10E744-8060
End----------(Elapsed Time: 01:20, VBatt start/end: 13.7V/13.8V)-----------
Address 08: DTCs cleared
Polo diesel in the text and Superb petrol from the scan.
Which car is it?
MartinsX
Riga, Latvia
C?ID=268515
Fix the throttle issue first.
But... Is this the correct scan of a car You are asking about??? Title is about Polo TDI but scan is from some 1,8 TFSI Skoda Octavia???
Wmwizkid
India
C?ID=374582
Oops i goofed up will post the proper scan
Wmwizkid
India
C?ID=374582
The correct scan
          U101F 00 [008] - -
                    Fault Frequency: 17
                    Reset counter: 52
                    Mileage: 38419 km
                    Date: 2017.03.31
                    Time: 00:27:07
   Revision: V0000000
                    Reset counter: 52
                    Mileage: 38419 km
                    Date: 2017.03.31
                    Time: 01:39:12
   Coding: 036800
   Coding: 240000
   Coding: 003036
   Coding: 1208000000
   Revision: BY040001
   Coding: 002300
Address 56: Radio
DGMotors
C?ID=57532
I would check crank/cam and also fuel pressure when not starting.
