Results 1 to 9 of 9
Thread: VW 1.5 tdi crdi polo not starting once heated
    Sep 2019
    IN
    hello you fantastic people.
    i have a polo 1.5 tdi crdi with a peculiar problem the car starts finevwhen cold but once the coolant temp reaches 90 degrees and if i turn off the ignition then the car fails to start it just keeps cranking and starts only when the coolant temp reaces below 90 deg. or starts if i unplug the coolant sensor. there are no fault codes. i tried changing the coolant temp sensor but didnt help.
    am attaching a scan too. please help i tried changing the starter and battery also.
     Thursday,17,October,2019,13:14:34:02918
    VIN: MEXE16604GT088189   License Plate: POLO HEAT
    Mileage: 38750km-24078mi   Repair Order:
    Chassis Type: 60-VW25 (6RU)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: MEXE16604GT088189   Mileage: 38750km-24078miles
    Address 01: Engine (J623-CWXA)       Labels: None
       Part No SW: 03L 906 023 SL    HW: 03L 907 425 B
       Component: R4 1.5l TDI   H33 9977
       Revision: --H33---    Serial number:
       Coding: 00110116032500080000
       Shop #: WSC 01234 785 00200
       ASAM Dataset: EV_ECM15TDI02103L906023SL 001001
       ROD: EV_ECM15TDI02103L906023QT.rod
       VCID: 02489DD89504775FB1-8056
       Part No SW: 6R0 907 379 BP    HW: 6R0 907 379 AQ
       Component: ABS9.0 front  H01 0003
       Serial number: --------------
       Coding: 60DD2763412B18C80615E471825A18020000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_Brake1ABS90BOSCH 003017
       ROD: EV_Brake1ABS90BOSCH_VW25.rod
       VCID: 0D52BEE4DC5A3827DC-8058
    0903 - Please Check Fault Codes in Engine Control Module
              U101F 00 [008] - -
              [Scl_EngineTrq_Invalid]
                        Fault Frequency: 17
                        Reset counter: 52
                        Mileage: 38419 km
                        Date: 2017.03.31
                        Time: 00:27:07
    Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
       Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
       Component: Climatronic   H12 0615
       Revision: V0000000
       VCID: 41CA52D4D882AC47E8-8014
                        Fault Status: 00101101
                        Reset counter: 52
                        Mileage: 38419 km
                        Date: 2017.03.31
                        Time: 01:39:12
       Part No SW: 6RU 937 086 M    HW: 6RU 937 086
       Component: BCM IM M+4    H40 0432
       Revision: BY040001    Serial number: 0200 122160778
       Coding: 3AB02BFF08B30000013800006C2B06900080414F608C0000200000000000
       Shop #: WSC 124697 483 00190
       VCID: 6B96D07C8A8E961762-803E
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 040316 03  37  0059
       Coding: 036800
       Subsystem 2 - Part No SW: 6R0 959 802 EF    HW: 6R0 959 802 EF  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  020 2551
       Serial number: 13102848160114104301
       Subsystem 3 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  023 2551
       Serial number: 13202849160223130053
       Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
       Serial number: 0471608365801042AB2B
       Coding: 240000
       Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
       Component: J388__TSG_HL  022 1552
       Serial number: 13102728160209153222
       Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
       Component: J389__TSG_HR  022 1552
       Serial number: 13202729160301134756
       Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
       Component: VW10AirbagU06 H10 0020
       Revision: --------    Serial number: 003GW01423DV
       Coding: 003036
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 49DA4AF4E8B2640730-801C
       Part No SW: 6RF 920 862 A    HW: 6RF 920 862 A
       Component: KOMBI         H01 0215
       Coding: 1208000000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
       VCID: 4AD875F8EDB46F1F39-801E
       Part No SW: 6RU 909 901     HW: 6RU 937 086
       Component: GW-K-CAN TP20 H40 0432
       Revision: BY040001
       Coding: 002300
       VCID: 197ADAB41092D48740-804C
       Component: IMMO          H01 0215
       VCID: 6A98D5788D748F1F19-803E
    Address 44: Steering Assist (J500)       Labels:| 1Sx-909-144-44.clb
       Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
       Component: EPS_ECU       H61 1702
       Coding: 0001000000000000
       ASAM Dataset: EV_SteerAssisNSK 014008
       ROD: EV_SteerAssisNSK_014.rod
       VCID: 41CA52D4D082AC47E8-8014
    Address 56: Radio
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)-----------
    Last edited by Wmwizkid; 10-19-2019 at 02:05 PM. Reason: Wrong auto scan wad uploaded earlier
    HQ
    We have your email, but we'd rather do this on the forum so other people can chime in and also for the next person that has this issue can possibly find answers. Please post your Auto-Scan here.
    Regards.
    Jef
  3. Likes Uwe liked this post
    Sep 2019
    IN
    Have added the scan please help
    Oct 2017
    Northwest UK
    Check the wires are not fused together. I had a similar problem on a Touran about 3 years ago and there was 2 wires that had fused together. Took me best part of 5 days testing and testing and testing.
    Quote Originally Posted by Wmwizkid View Post
     Monday,07,October,2019,20:17:44:02918
    VIN: TMBBBH3T8BA302768   License Plate: SUP
    Mileage: 108200km-67232mi   Repair Order:
    Chassis Type: 3T-SK46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 62 72
              77
    VIN: TMBBBH3T8BA302768   Mileage: 108200km-67232miles
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 3T0 907 115 G    HW: 1Z0 907 115 F
       Component: 1.8l R4/4V TFSI     0040
       Revision: AAH18---    Serial number:
       Coding: 0203000C24070160
       Shop #: WSC 62987 001 1048576
       VCID: 352236045C4A10E744-8060
    000290 - Throttle Position Sensor (G69)
                   P0122 - 000 - Signal too Low - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Load: 0.0 %
                        Temperature: 98.0°C
                        Temperature: 45.0°C
                        Absolute Pres.: 940.0 mbar
                        Voltage: 12.319 V
    000546 - Angle Sensor 2 for Throttle (G188)
                   P0222 - 000 - Signal Too Low - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Load: 0.0 %
                        Temperature: 98.0°C
                        Temperature: 45.0°C
                        Voltage: 12.319 V
    Readiness: 0110 0101
       Part No SW: 0AM 300 054 B    HW: 0AM 927 769 D
       Component: GSG DSG AG7     441 3640
       Revision: 00044014    Serial number: CU501708105505
       Shop #: WSC 04940 001 00001
       VCID: 2C1413608F00512F2B-8078
       Revision: 00H31001
       Coding: 863D6016092200FC611206EA90210081350000
       Shop #: WSC 33361 790 00074
       VCID: 7BB6E03CFAEE0697F2-802E
                        Reset counter: 132
                        Mileage: 108201 km
                        Date: 2014.02.27
                        Time: 00:25:60
                        Count: 14
                        Count: 12544
                        Count: 8193
                        Count: 41728
                        Count: 65280
                        Count: 65026
       Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
       Component: Climatronic   H18 0506
       Revision: 00001007
       Coding: 0000001002
       ROD: EV_ClimaAutoBasis_SK46.rod
       VCID: 7CB4E320F7E001AFFB-8028
    9480465 - Control Circuit for A/C Compressor
              B10A9 11 [009] - Short to Ground
                        Reset counter: 132
                        Mileage: 108203 km
                        Date: 2019.10.07
                        Time: 00:19:18
       Part No SW: 1K0 937 087 AB    HW: 1K0 937 087 AB
       Component: BCM PQ35  H+  110 0651
       Revision: 00110 AC
       Coding: 48990ABBE85BF1C040080080310089E4417000AE732089605C8040000040
       VCID: 71AAC214A8A27CC758-8024
       Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 25061  26  0602
       Coding: 00D7B7
       Component: RLS 080711 05  54  0403
       Coding: 0730ED
       Subsystem 4 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
    01134 - Alarm Horn (H12)
                        Reset counter: 172
                        Mileage: 108201 km
                        Date: 2014.02.27
                        Time: 00:17:39
                            Term 15 Off
                        Voltage: 12.25 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 44
                        Reset counter: 132
                        Mileage: 108201 km
                        Date: 2014.02.27
                        Time: 00:17:50
                            Term 15 On
                        Voltage: 13.45 V
                            Term 50 Off
    03396 - Supply voltage terminal 30 for central locking
                        Fault Status: 00101011
                        Reset counter: 172
                        Mileage: 108203 km
                        Date: 2014.02.27
                        Time: 00:06:17
                            Term 15 On
                        Voltage: 12.25 V
                            Term 50 Off
                        Fault Status: 00101010
                        Reset counter: 172
                        Mileage: 108203 km
                        Date: 2014.02.27
                        Time: 00:11:14
                            Term 15 On
                        Voltage: 13.85 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
       Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0005
       Revision: --H06---    Serial number: 28291115773397
       Coding: 108104
       ASAM Dataset: EV_EPHVA18SKxxx0000 001001
       ROD: EV_EPHVA18SKxxx0000_001.rod
       VCID: 43C658DCCA9EBE57FA-8016
       Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
       Component: J234__LAQ VW10 HI   1918
       Revision: 20014000    Serial number: 003K2PBCZQ05
       Coding: 0016721
       VCID: 41CA52D41882AC47E8-8014
       Subsystem 1 - Serial number: 6332MTS682541691
       Subsystem 2 - Serial number: 6342MTS666841691
       Subsystem 3 - Serial number: 6351HTS6Q6ROT9KJ
       Subsystem 4 - Serial number: 6361HTS686MI5AKR
       Subsystem 5 - Serial number: 63727TS6JT3JS9KJ
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110709301460
       Coding: 089A140000
       Shop #: WSC 33361 790 00999
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76A0F108C9CC5BFF8D-8022
       Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO  H07 0012
       Coding: 830000
       Part No SW: 3T2 920 841 J    HW: 3T2 920 841 J
       Component: KOMBI         H04 0617
       Coding: 110F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       VCID: 3B36203CB26EC697B2-806E
    9453330 - Outside temperature sensor
              B103F 1B [008] - Resistance Too High
                        Reset counter: 172
                        Mileage: 108203 km
                        Date: 2019.10.07
                        Time: 00:26:26
       Part No SW: 7N0 907 530 H    HW: 1K0 907 951
       Component: J533  Gateway H42 1620
       Revision:   H42       Serial number: 020711F2001827
       Coding: 353303
       VCID: 352236049C4A10E744-8060
       Component: IMMO          H04 0617
       Part No SW: 3C8 959 760 C    HW: 3C8 959 760 A
       Component: Sitzmemory    H05 2901
       Revision: 00H05000
       Coding: 00003B
       Shop #: WSC 12336 024 394758
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
       Component: TSG FA        H09 0410
       Coding: 011D0220DE01001000
       VCID: 4FEE64EC1ED64A376E-801A
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 195    3201
       Revision: 00H20000
       VCID: 34240B00573009EF73-8060
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.6 V
                            PD
                        Temperature: 35.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Count: 1
                            SteerAng n.Init
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
       Component: TSG BF        H09 0410
       VCID: 4ED079E819DC433F65-801A
                        Fault Status: 01101100
                        Reset counter: 132
                        Mileage: 108201 km
       Coding: 1377095
       Component: AFS-Lst.-Modul l    0005
       Coding: 00000021
       Coding: 00000021
       Part No SW: 3T0 035 156 F    HW: 3T0 035 156 F
       Component: BOLERO        001 0008
       Revision: -----08S    Serial number: SKZ4Z3L1140439
       Coding: 0D0004000004
       VCID: 312A021468223CC718-8064
       Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
       Component: TSG HL        H06 0409
       Coding: 010C00200001001000
       Component: TSG HR        H06 0409
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H09 2730
       Revision: 1B001001    Serial number: 00007660377881
       Coding: 0200000000010110
       ASAM Dataset: EV_UHVNA A01015
       ROD: UHVNA.rod
       VCID: 35223604944A10E744-8060
    End----------(Elapsed Time: 01:20, VBatt start/end: 13.7V/13.8V)-----------
    Address 08: DTCs cleared
    Polo diesel in the text and Superb petrol from the scan.
    Which car is it?
  7. Likes Uwe liked this post
    Sep 2016
    Riga, Latvia
    Fix the throttle issue first.
    But... Is this the correct scan of a car You are asking about??? Title is about Polo TDI but scan is from some 1,8 TFSI Skoda Octavia???
  9. Likes Uwe liked this post
  10. #7
    Sep 2019
    IN
    Oops i goofed up will post the proper scan
  11. #8
    Sep 2019
    IN
    The correct scan
              U101F 00 [008] - -
                        Fault Frequency: 17
                        Reset counter: 52
                        Mileage: 38419 km
                        Date: 2017.03.31
                        Time: 00:27:07
       Revision: V0000000
                        Reset counter: 52
                        Mileage: 38419 km
                        Date: 2017.03.31
                        Time: 01:39:12
       Coding: 036800
       Coding: 240000
       Coding: 003036
       Coding: 1208000000
       Revision: BY040001
       Coding: 002300
    Address 56: Radio
  12. #9
    I would check crank/cam and also fuel pressure when not starting.
  13. Likes MartinsX liked this post
