Results 1 to 10 of 10
Thread: 2017 Audi A4 Allroad 2.0L Petrol (UK). Fault after service which will not clear.
    Verified VCDS User Klaus Ludwig's Avatar
    Oct 2014
    Would be very grateful for any advice on the following:
    I have a 2017 Audi A4 Allroad (UK). I have very recently had a routine oil change service carried out by an independent garage which has a good reputation and has some auto technician staff who previously worked at VAG. Before taking the car in I carried out an autoscan before and after clearing DTC's. The car went in for it's service with zero DTC's. After the service it has one fault that I have never seen before and which will not clear. In case they are of any help, I have previously also taken "VCDS MAPS" though really don't have much idea what they are or what to do with them.
    The fault that will not clear is on 17 (INSTRUMENTS).
    I have attached the before service and after service auto scans:
    BEFORE SERVICE (AFTER DTC CLEAR):
    Wednesday,16,October,2019,02:08:14:27553
    VIN: WAUZZZF47HA152503   License Plate:
    Mileage: 16403km-10192mi   Repair Order:
    Chassis Type: F4-AU49 (4M2)
    Scan: 01 02 03 08 09 13 15 16 17 19 22 29 2B 39 42 44 46 47 52 5F
              69 6C 6D 74 81 8B A5 BB BC CA D6 D7
    VIN: WAUZZZF47HA152503   Mileage: 16403km-10192miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CYRB)       Labels:. 06L-907-115-V1.clb
       Part No SW: 8W0 906 259 D    HW: 06L 907 425
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 326500322376050B34180000000000000000000000000000
       ASAM Dataset: EV_ECM20TFS0208W0906259D 001004
       ROD: EV_ECM20TFS0208W0906259D.rod
       VCID: 42DE43B2E4096B079F3-8016
    Readiness: 1110 0001
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 80A 927 155 G    HW: 0CJ 927 156
       Component: 0CJ 20TFSIRdW H03 0003
       Revision: --H03---    Serial number: 0000002276
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002024
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 2D04000E4D97847F521-8078
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  002 0572
       Serial number: 75117071170056001135
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
       Part No SW: 8W0 907 379 H    HW: 8W0 907 379 D
       Component: ESP9 Premium  H09 0719
       Coding: 14AA409928A72A9891A34891208052A2E6A592280214548912044A4567A549
       Shop #: WSC 06334 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 001001
       ROD: EV_ESP9BOSCHCMP_001.rod
       VCID: 4ACE6B92DC39B347573-801E
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
       Component: Klima Zone 3  H32 0090
       Coding: 240808095544440D02000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 37282266BFCB3EAF38D-8062
       Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
       Component: J216 FLuftV  H08 0003
       Serial number: 00000000000001365114
       Serial number: D0788B9880PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07501143C13900CD051587155B3F00B9130B31080000000000000000600016810A4502AB22B60A
       VCID: 025E83B2A489AB07DF3-8056
       Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 170120  043 0813
       Serial number: 89425300301702003822
       Coding: 5BC7F7
       Serial number: 20314225X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 05 07 2016  00728608
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE111011723310757
       Coding: 230000
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 AT    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B00298144
       Subsystem 6 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2616000199543002
       Part No SW: 8W0 907 561 B    HW: 8W0 907 561
       Component: LRR4          H10 0220
       Coding: 3473FFEB58FFEC0A949880A0
       ASAM Dataset: EV_ACCBOSCHAU49X 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 3D24304E9DF714FFE21-8068
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
       Component: Airbag10.44   H03 0106
       Serial number: 003UP003D6JD
       Coding: AACCF0C00C800000985400F3D0CC00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006015
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 4CC26D8AD64DAD7765F-8018
       Subsystem 1 - Part No SW: -----------    HW: 442 060 903 17
       Serial number: 3577Y00C721922F351E0
       Subsystem 2 - Part No SW: -----------    HW: 442 060 903 17
       Serial number: 3587Y00C721922F4635$
       Subsystem 3 - Part No SW: -----------    HW: 442 0B2 302 17
       Serial number: 35177000C2A58D2A878M
       Subsystem 4 - Part No SW: -----------    HW: 442 0B2 302 17
       Serial number: 3527700022A55168376-
       Subsystem 5 - Part No SW: -----------    HW: 442 0C0 803 17
       Serial number: 3557500BD21FBF14A1AX
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C0 803 17
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500BD21FBF1531AS
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C1 203 17
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500A521FBF13041%
       Subsystem 8 - Part No SW: -----------    HW: 442 431 003 17
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M00B91FD7521E1BW
       Subsystem 9 - Part No SW: -----------    HW: 442 431 003 17
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M00B91FD7523051F
       Part No SW: 4M0 907 129 HL    HW: 4M0 907 129 HL
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 015C8CBEA18FB01FC69-8054
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 790 C    HW: 8W5 920 790 C
       Component: FBenRDW       H17 0313
       Coding: 248481D2FC90060001A3E9601000600000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       Part No SW: 4M2 907 468 D    HW: 4M2 907 468 A
       Component: Gateway       H16 0108
       Revision: 4W020004    Serial number: 0444W031017303
       Coding: 0301000100008640290700000059003258B20007100000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU49.rod
       VCID: 392C245E89DF28DFCE9-806C
       Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
       Component: J453 MFL  H06 0002
       Serial number: 20170306092341 01094
       Serial number: 7667883204
    Address 22: AWD (J492)       Labels:* None
       Part No SW: 8W9 927 755     HW: 0CJ 927 749
       Component: B9_DL3_H_SD5  H01 0004
       Serial number: 1627218093
       Coding: 11040000
       ASAM Dataset: EV_AWDCQUOD31 001048
       ROD: EV_AWDCQUOD31.rod
       VCID: 0B40AE9693C3EA4FAC5-805E
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AD    HW: 4M0 907 397 D
       Component: LCM_MLBevoH05 0024
       VCID: 79ACE45EC95FE8DF8E9-802C
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 17000057571014
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 323E137254A9DB870F3-8066
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       Part No SW: 8W0 959 593 E    HW: 8W0 959 593
       Component: TSG FS        005 0057
       Serial number: 0000246992342
       Coding: 005F9A215001000000001082
       Part No SW: 8W0 909 144 G    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0409
       Coding: 0D888380008080
       ASAM Dataset: EV_EPSZFAU49X 003018
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 41DC4CBEE10F701F869-8014
       Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
       Component: BCM2 MLBevo   018 0344
       Coding: 013500006F110040630980006E00480033004010004702502F0400000504803F001F0001000000
       ASAM Dataset: EV_BCM2HellaAU736 012013
       ROD: EV_BCM2HellaAU736_012_AU49.rod
       VCID: 7F580A46D77BC6EFB0D-802A
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY170523FQR
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000068824057
       Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
       Component: GEB.F.Heckoef  H16 0904
       Serial number: >1057819
       Part No SW: 8W0 035 465     HW: 8W0 035 465
       Component: MIB2_amp_P_B9 H11 0420
       Revision: 00000001    Serial number: AUZ8ZAHJA01DJYQ
       Coding: 0194420800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       VCID: 76B6EF62F84187A7E3B-8022
       Part No SW: 8W0 959 592 E    HW: 8W0 959 592
       Component: TSG BFS       005 0057
       Serial number: 0000247202345
       Coding: 005F9A215C01000000001080
       VCID: 4BC06E96D343AA4F6C5-801E
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 035     HW: 8W5 035 035
       Component: MU-P-LND-EU   033 0917
       Serial number: A829C0HB015766
       Coding: 019442010000000013111102000A00332F0003E7017001009E
       VCID: 74B2D56AEE3D95B7DDF-8020
       Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
       Component: ECE 2018  --- 0166
       Subsystem 2 - Part No SW: 8W2 919 605     HW: 8W2 919 605
       Component: AU49x_DU_HIGH  H40 0008
       Serial number: AUZ8Z9GBK00ERZ
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK111021700040012
       Component: Gracenote2  --- 1015
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anheanger     H21 0203
       Serial number: 00006789,)-''.
       Coding: 0100000202000000
       VCID: 3B203E5683E31ACFDC5-806E
       Part No SW: 4M0 907 428 E    HW: 4M0 907 428
       Component: Areaview 2    H13 0315
       Serial number: C854607JG014213
       Coding: 02940201BF0FA10008404080
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
       ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
       VCID: 3432156AAEBDD5B71DF-8060
       Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: 31246258600000
       Coding: 0570
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 8W0 907 777 H    HW: 8W0 907 777 C
       Component: Fahrwerk-SG   H35 1214
       Serial number: 1603170515
       Coding: 9051486158
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W2 713 041 L    HW: 8W2 713 041 J
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20170313001402
       ROD: EV_GSMWaehlZFAU736.rod
    Address 8B: Adaptive Cruise 2 (J850)       Labels: None
       Part No SW: 8W0 907 541 B    HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W0 907 217 B    HW: 8W0 907 217
       Component: BVS           H15 0042
       Coding: 0404090200000402024023A5CD0000FCB0F0C020E280
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       Part No SW: 8W0 959 595 E    HW: 8W0 959 595
       Component: TSG HFS       005 0057
       Serial number: 0000247086289
       Coding: 000F98200001000000001080
       VCID: 4EC6678220519F670BB-801A
       Component: TSG HBFS      005 0057
       Serial number: 0000247421983
       Part No SW: 4M0 907 594     HW: 4M0 907 594
       Component: SAD_STG_1     012 0003
       Coding: 508000049202
       ASAM Dataset: EV_SunRoofCONTIAU736 004008
       ROD: EV_SunRoofCONTIAU736_004.rod
       VCID: 73B0D676EB33928FC45-8026
       Part No SW: 7PP 941 571 BC    HW: 7PP 941 571 B
       Component: LED1L         H09 0008
       VCID: 1768C2E6DF0B1EAF18D-8042
       Component: LED1R         H09 0008
    End----(Elapsed Time: 02:09, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    AFTER SERVICE (AND AFTER AN ADDITIONAL POST SERVICE DTC CLEAR):
    Wednesday,16,October,2019,20:28:13:27553
    Mileage: 16484km-10242mi   Repair Order:
    VIN: WAUZZZF47HA152503   Mileage: 16484km-10242miles
       Revision: --H13---
       Coding: 000001
       Coding: 5BC7F7
       Coding: 02005D
       Light switch:
       Coding: 230000
    1048578 - Incorrect Basic Setting
              B2011 00 [009] - -
              [ECU no or wrong basic setting]
                        Reset counter: 143
                        Mileage: 16484 km
                        Date: 2019.10.16
                        Time: 20:22:40
       Coding: 11040000
       Coding: 0570
       Coding: 9051486158
    End----------(Elapsed Time: 02:09, VBatt start/end: 12.2V/12.2V)-----------
    I have also attached a copy of ADMAP17 (INSTRUMENTS) which I recorded some time ago - well before this current issue:
    ;SW:8W5-920-790-C   HW:8W5-920-790-C ---  Instruments
    ;Component:FBenRDW       H17 0313, Coding:248481D2FC90060001A3E9601000600000000000
    ;EV_DashBoardAU736,001022,EV_DashBoardAU736.rod
    ;Friday,27,October,2017,20:03:51:27553
    ;VCDS Version: Release 17.8.0 (x64)  Data version: 20170721 DS276.2
    ;VCID: 42DE43B2E4096B070DE-8016
    IDE00001-Production mode,not active ,3
    IDE00301-Distance,6125 km,3
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,English ,1
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,20 H,1
    IDE00501-Minute,3 min,1
    IDE00502-Year,2017 yr,2
    IDE00503-Month,10 mon,1
    IDE00504-Day,27 d,1
    IDE00510-ESI: distance driven from inspection,6100 km,3
    IDE00511-ESI: time from inspection,185 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,14500 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,good oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,14400 km,2
    IDE00819-Day counter,208 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,14500 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 1 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,0.00 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-1.20 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,0.00 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.70 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.70 l,5
    IDE03329-Driving profiled for range remaining,7.30 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,miles ,3
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,∞C ,3
    IDE03346-MAS02957-Units adjusted-Time,24h ,3
    IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (UK) ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03348-MAS01456-Speed warning-Speed,0 ,2
    IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
    IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,30578 km,3
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,6100 km,3
    IDE03352-FIX: Time since last time-dependent inspection,185 d,2
    IDE03372-Source for synchronization of time,GPS ,1
    IDE03867-Deactivate seat belt warning,No ,1
    IDE04169-Display correction of consumption and operating range: gas,100 %,1
    IDE05930-Service notification in days,30 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,1095 d,2
    IDE06588-Ignition active message: actuator,Driver door ,1
    IDE06922-No-voltage display,No display ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE07221-Cylinder shut-off,No display ,1
    IDE07579-MAS05872-Driving profile for operating range consump.with electric drive-Operating range average voltage,10.00 A,8
    IDE07579-MAS05875-Driving profile for operating range consump.with electric drive-Average consumption: electric drive,25 ,8
    IDE07579-MAS05876-Driving profile for operating range consump.with electric drive-Average consumption: low voltage auxiliary consumer,0.20 ,8
    IDE07579-MAS05877-Driving profile for operating range consump.with electric drive-Average consumption: high voltage auxiliary consumer,0.50 ,8
    IDE07600-ENG114653-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_0,25.00 ,14
    IDE07600-ENG114654-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_1,25.00 ,14
    IDE07600-ENG114655-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_2,25.00 ,14
    IDE07600-ENG114656-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_3,25.00 ,14
    IDE07600-ENG114657-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_4,25.00 ,14
    IDE07600-ENG114658-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_5,25.00 ,14
    IDE07600-ENG114659-Drive profile for road-specif. remain.oper.range for el. drive-s_erw_rwdv_antrieb_high_class_6,25.00 ,14
    IDE08140-Driving profiled for range remaining CNG,0.00 kg/100 km,2
    IDE08247-Driving profile for range remaining LPG,0.00 l/100km,2
    IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
    IDE10693-Initialize sensor for fuel level,No ,1
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.60 ,14
    IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 ,14
    IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 ,14
    IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 ,14
    IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 ,14
    IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 ,14
    IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 ,14
    IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
    IDE11472-MAS12789-Configuration of displayable contents-Display: engine running required,No display ,4
    IDE12050-Acoustic: drive position R,active ,1
    MAS03555-Lap counter,No display ,1
    MAS03685-Digital speedometer,Display ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,21
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,21
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,21
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,21
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,21
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,21
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,21
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,21
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,21
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,21
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,21
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,21
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,21
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,21
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,21
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,21
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,21
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,21
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,21
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,21
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,21
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,21
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,21
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,21
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,21
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,21
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,21
    ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,21
    ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,21
    ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,21
    ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,21
    ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,21
    ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,21
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,21
    ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,21
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,21
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,21
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,21
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,21
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,50ms ,21
    ENG128731-MAS01129-designvariant_activation-Version 1,not active ,2
    ENG128731-MAS01130-designvariant_activation-Version 2,not active ,2
    ENG128731-MAS01131-designvariant_activation-Version 3,not active ,2
    ENG128731-MAS03101-designvariant_activation-Version 4,not active ,2
    ENG128731-MAS03102-designvariant_activation-Version 5,not active ,2
    ENG128731-MAS03103-designvariant_activation-Version 6,not active ,2
    ENG128731-MAS03104-designvariant_activation-Version 7,not active ,2
    ENG128731-MAS03105-designvariant_activation-Version 8,not active ,2
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A ,12
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC ,12
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06 ,12
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A ,12
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,50 ,12
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,02 ,12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,02 ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,0E ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,1E ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
    ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,14 ,12
    ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,1E ,12
    ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,32 ,12
    ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,46 ,12
    ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,64 ,12
    ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,00 ,12
    ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,14 ,12
    ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,1E ,12
    ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,32 ,12
    ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,46 ,12
    ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
    ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
    ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC ,12
    ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,02 ,12
    ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,02 ,12
    ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,06 ,12
    ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,0A ,12
    ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,50 ,12
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 96 ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 32 ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 64 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8 ,20
    ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
    ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
    ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
    ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02 ,12
    ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02 ,12
    ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
    ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
    ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,50 ,12
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xs_bus ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,lds ,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 ∞C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 ∞C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 ∞C,16
    ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.00 km,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.00 ∞C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.00 ,16
    ENG135292-phev_stat_intervall-,5.00 ,3
    ENG135292-phev_stat_intervall-,100 m,3
    ENG135292-phev_stat_intervall-,0 min,3
    ENG109340-tank_validation,validation_deactivated ,1
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.50 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,1.40 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,active ,4
    Elapsed Time: 00:24
    ;Saturday,28,October,2017,16:31:14:27553
    IDE00301-Distance,6142 km,3
    IDE00500-Hour,16 H,1
    IDE00501-Minute,31 min,1
    IDE00504-Day,28 d,1
    IDE00511-ESI: time from inspection,186 d,2
    IDE00518-ESI: thermal load,14500 km,2
    IDE00819-Day counter,209 d,2
    IDE03329-Driving profiled for range remaining,7.40 l/100km,2
    IDE03352-FIX: Time since last time-dependent inspection,186 d,2
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.90 ,14
    ENG99320-Developers_menu,not active ,1
    ENG126284-parameter_animations,41 43 56 03 05 FF 23 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,1000
    ENG126283-parameter_hmi,41 43 56 03 05 FF 23 03 00 01 00 FA 02 00 FF 00 00 FF FF 00 00 F3 00 00 FF 00 24 00 FF 43 14 28 00 00 5A 00 E1 00 19 FF B4 00 1E 8C AA 64 AA 00 BF 4B 68 A2 91 6D 6D 97 A2 73 9B 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,100
    Elapsed Time: 00:26
  2. Likes Dana liked this post
  3. #2
    HQ
    Some wonky SRI was most likely done. This thread is relevant:
    https://forums.ross-tech.com/showthr...-Basic-Setting
    Thing get interesting around post #17 in there.
    Jef
  4. Likes Uwe, Dana, Jack@European_Parts liked this post
  5. #3
    Post the Adpmap after service.
  6. Likes Dana, Jack@European_Parts liked this post
  7. #4
    Jan 2018
    Cheshire UK
    'Incorrect basic setting' is the norm fault display when the SRI has been done incorrectly as mentioned above.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #5
    Oct 2014
    Latest Adpmap
    Please see attached current (after service) Adpmap :
    ;EV_DashBoardAU736,001022,EV_DashBoardAU736_AU49.rod
    ;Thursday,17,October,2019,18:05:36:27553
    ;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
    ;VCID: 42DE43B2E4096B079F3-8016
    IDE00301-Distance,16484 km,3
    IDE00500-Hour,18 H,1
    IDE00501-Minute,5 min,1
    IDE00502-Year,2019 yr,2
    IDE00504-Day,17 d,1
    IDE00510-ESI: distance driven from inspection,0 km,3
    IDE00511-ESI: time from inspection,1 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,30000 km,2
    IDE00518-ESI: thermal load,200 km,2
    IDE00819-Day counter,928 d,2
    IDE00827-ESI: minimum value of time between inspections,730 d,2
    IDE03329-Driving profiled for range remaining,7.50 l/100km,2
    IDE03348-MAS01456-Speed warning-Speed,85 ,2
    IDE03348-Speed warning-,active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,3
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,3
    IDE03352-FIX: Time since last time-dependent inspection,1 d,2
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.50 l/100km,14
    IDE10694-ENG126303-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_1,10.00 l/100km,14
    IDE10694-ENG126304-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_2,10.00 l/100km,14
    IDE10694-ENG126305-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_3,10.00 l/100km,14
    IDE10694-ENG126306-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_4,10.00 l/100km,14
    IDE10694-ENG126307-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_5,10.00 l/100km,14
    IDE10694-ENG126308-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_6,10.00 l/100km,14
    IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
    IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
    IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
    IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
    Elapsed Time: 00:25
  10. Likes Dana, Jack@European_Parts liked this post
  11. #6
    United States
    Thanks for posting the new map. Per a Compare It! of your maps the service related discrepancies appear to be.
    • Old/Original condition
    • Current condition
      I would set all 3 of those values back to the original condition (or round to even 15,000 km / 30,000 km if you prefer) followed by a VCDS [SRI Reset] > Reset FIX&ESI / INSP - North America or Rest of World second service and later > [Perform SRI] and key cycle to see if that allows you to clear the DTC.
  12. #7
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    YES!
    Dana has it,
    IDE00512-ESI: minimum value km-driving distance/inspection,30000 km,2 set to 15000
    IDE00827-ESI: minimum value of time between inspections,730 d,2 set to 365
    that are the Basics
    -Wolfgang
    Drive more talk less
  13. Likes Dana, Uwe, Jack@European_Parts liked this post
  14. #8
    Oct 2014
    • Current condition
    Will try it this weekend!
  15. #9
    • Current condition
    Depending what work the shop did and what work is due, for 30.000 km mileage-related inspection, I would also change IDE03349 to this:
    IDE03349-FIX: Max. distance until next mileage-related inspection,13500 km
    But if you have the same drive pattern in the future, you will hit the next time-dependent inspection anyway.
    You have driven 10359 km in the last 720 days.
  16. Likes Uwe liked this post
  17. #10
    Oct 2014
    Hi all,
    Many thanks
    Not 100% sure, but hope I have got it right now?
    The garage changed the oil using Castrol Edge 5W-30 LL advanced Fully Synthetic Oil (suitable for variable service intervals). They also changed the oil filter and pollen filter and carrried out all other checks that were due after the first two 2 years of the cars life.
    I now have been able to clear the fault.
    The updated adpmap is attached below:
    ;Friday,25,October,2019,16:09:30:27553
    IDE00301-Distance,16558 km,3
    IDE00342-ESI: Resetting ESI,Reset ,1
    IDE00501-Minute,9 min,1
    IDE00504-Day,25 d,1
    IDE00511-ESI: time from inspection,0 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
    IDE00518-ESI: thermal load,0 km,2
    IDE00819-Day counter,936 d,2
    IDE03352-FIX: Time since last time-dependent inspection,0 d,2
    IDE10694-ENG126302-Driving profile for road-related range remaining-s_vkmrw_rwdv_high_class_0,7.60 l/100km,14
    Elapsed Time: 00:25
  18. Likes Uwe liked this post
