Results 1 to 10 of 13
Thread: 09 Central Elects, the coding shows 00000000000000000000000000
    Oct 2019
    Currently do not have forum permission to post a thread in VCDS Support section.
    Just carried out a scan with the new upgrade HEX-V2 cable and latest version of VCDS software.
    My question is, under : 09 Central Elects, the coding shows 00000000000000000000000000
    Why is this?
    A window popped up asking if I was agreeing to using a VIN number token to do an adaption. I entered the last 3 digits in the pop up window believing it was the vin number for the car. Was this the correct vin to enter or should it have been the vin at the top of the scan?
    Tuesday,15,October,2019,11:01:51:33763
    VIN: WVGZZZ5NZHW827920   License Plate: FL66NYW
    Mileage: 54456km-33837mi   Repair Order:
    Chassis Type: 5N-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 52 55 5F 6C
              6D A5 BB BC CA D6 D7
    VIN: WVGZZZ5NZHW827920   Mileage: 54456km-33837miles
    CA-Sunroof -- Status: Malfunction 0010
    D6-Light Ctrl Left 2 -- Status: Malfunction 0010
    D7-Light Ctrl Right 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H24 3030
       Revision: B4H24---
       Coding: 0125003203661D082000
       ASAM Dataset: EV_ECM20TDI01104L906026HT 004002
       ROD: EV_ECM20TDI01104L906026GP_004.rod
       VCID: 035388274B9D262FD45-8056
    12002 - Diesel Particle Filter; Differential Pressure Sensor
              P2453 00 [237] - Implausible Signal
                        Mileage: 54225 km
                        Date: 2019.10.10
                        Time: 12:38:55
                        Coolant temperature: 86 ∞C
                        Intake air temperature: 57 ∞C
                        Voltage terminal 30: 13.180 V
                        Particle filter: air pressure sensor 1 bank 1: raw value: 579 hPa
                        Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 379 hPa
                        Par.fil: diff.pr.sens.1 bank 1: offset: 134 hPa
                        Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 200 hPa
                        Extern.temp.sens.1 bank 1: raw value: 14.0 ∞C
                        Particle filter: soot mass measured: 13.45 g
                        Particle filter: soot mass calculated: 12.95 g
    31489 - Differential Pressure Sensor for DPF
              P154B 00 [175] - Faulty
                        Fault Frequency: 9
                        Mileage: 54123 km
                        Date: 2019.10.06
                        Time: 18:56:45
                        Coolant temperature: 20 ∞C
                        Intake air temperature: 22 ∞C
                        Voltage terminal 30: 12.520 V
                        Engine status: COENG_STANDBY
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
    31490 - Differential Pressure Sensor for DPF
                        Fault Frequency: 9
                        Mileage: 54123 km
                        Date: 2019.10.06
                        Time: 18:56:45
    9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
              P2209 00 [096] - Implausible Signal
                        Mileage: 54379 km
                        Date: 2019.10.13
                        Time: 18:02:44
                        Engine speed: 1464.00 /min
                        Normed load value: 73.3 %
                        Vehicle speed: 84 km/h
                        Coolant temperature: 65 ∞C
                        Intake air temperature: 63 ∞C
                        Voltage terminal 30: 14.400 V
                        NOx sensor before SCR cat conv: NOx concentration: 79 ppm
                        NOx sensor before SCR catalytic converter: supply voltage: 14080 mV
                        Extern.temp.sens.1 bank 1: raw value: 12.0 ∞C
                        Mean injection quantity: 18.90 mg/stroke
    Readiness: 1 3 0 0 0
       Part No SW: 0DL 300 011 A    HW: 0DE 927 711
       Component: GSG DQ500     H12 1412
       Revision: 00H12V32
       VCID: 2615F1B3986F330793B-8072
       Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
       Component: ESC           H25 0507
       Revision: 00000000    Serial number: 62316000000777
       Coding: 0AEE929A34220B734780670262C34950492CD0E2E646927D38625078C22A02
       VCID: 78A9EFCB025B75F7F17-802C
    8352 - Databus
              [FCAN: TSG_FT_02 is not received]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
       Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
       Component: AC Automat    H35 4003
       Revision: 20K08000    Serial number: 00000B00213997
       Coding: 0012012420211001110510000010112A
       ASAM Dataset: EV_ACClimaPrehVW37X 002014
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 47CB5C373F25CA0F48D-8012
       Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number: 00000000000000000000
    459021 - Databus
              [T¸rsteuerger‰t Fahrerseite - kein Signal/Kommunikation]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
       Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H34 0236
       Serial number: 02001623903987
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7F5B04D7277542CFB0D-802A
       Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
       Component: 326 RL 160728  033 0372
       Serial number: 00000001607250306391
       Component: RLHS  042 0105
       Serial number: S5Y16M08D31H12M56S12
       Coding: 06A8DD
       Serial number: 000000000ZY161960H5R
       Serial number: 00000000000066838942
    549909 - Databus
              [TSG_FT_01 Datenbus fehlende Botschaft]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:31
    551445 - Databus
              [TSG_HFS_01 Datenbus fehlende Botschaft]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:31
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H10 0021
       Serial number: 001808167478092
       Coding: 0331563851
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: 3B2330C773ED9EEFDC5-806E
    13679388 - Databus
              [Lenkhilfe - LH_EPS_01.EPS_PLA_Status - Fehlerspeicher auslesen]
                        Reset counter: 180
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 15:31:45
    1080304 - Parking Sensor(s); Rear
              B107B F0 [008] - Function Limitation due to External Factors
                        Reset counter: 169
                        Mileage: 53663 km
                        Date: 2019.09.24
                        Time: 10:36:58
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H01 0233
       Coding: 320067C358FF8728749C8145304087
       VCID: 3E2539D360FF8BC7FBB-806A
    1086 - Databus
              [FAULT_TIMEOUT_TSG_FT_02]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 44 ∞C
                        Longitudinal_acceleration_vehicle_reference: 0.28 m/s≤
    0836 - Databus
              [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                        Fault Frequency: 17
                        Reset counter: 170
                        Mileage: 52542 km
                        Date: 2019.09.15
                        Time: 10:32:09
                        Voltage terminal 15: 13.9 V
                        Control Module temperature: 36 ∞C
                        Longitudinal_acceleration_vehicle_reference: 0.03 m/s≤
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0315
       Serial number: 003TDR228A3B
       Coding: 98CCC0C00C0000005C5400CF008800000065
       VCID: 1079B76B0AEB4DB7597-FFFE
       Component: BeltPretRevFL  106 1032
       Serial number: 5NC857705C0237Q01617
       Coding: 80000D
       Component: BeltPretRevFR  106 1032
       Serial number: 5NC857706C0236Q00996
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 608 16
       Serial number: 357000000008D215CD1R
       Subsystem 4 - Part No SW: -----------    HW: 480 002 508 16
       Serial number: 358000000005EB399D1
       Subsystem 5 - Part No SW: -----------    HW: 480 402 908 16
       Serial number: 3510001A72216EE1F2FD
       Subsystem 6 - Part No SW: -----------    HW: 480 400 109 16
       Serial number: 3520001BD22707F19585
       Subsystem 7 - Part No SW: -----------    HW: 480 402 808 16
       Serial number: 3550001AB2216EE3F50B
       Subsystem 8 - Part No SW: -----------    HW: 480 402 608 16
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001A52216EE364D7
       Subsystem 9 - Part No SW: -----------    HW: 480 402 608 16
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001AD2216EE1C3EK
       Subsystem 10 - Part No SW: -----------    HW: 480 402 608 16
       Component: PedP_Sensor_C  000 6149
       Serial number: 2300001A52216EE632A
       Subsystem 11 - Part No SW: -----------    HW: 480 002 308 16
       Serial number: I0M000000004C37DDD1K
       Subsystem 12 - Part No SW: -----------    HW: 480 002 308 16
       Serial number: I0N00000000494BC0E1A
    1054464 - Databus
              [NWD: 0x117 ACC_10 Timeout]
       Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160824400233
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 41DF422F1101F43F869-8014
       Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
       Component: KOMBI         405 2153
       Coding: 27A400086F84260001886B031401000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
    16776994 - Databus
              [TSG_FT_02 keine Kommunikation]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
       Revision: --------    Serial number: 0005238889
       Coding: 030500041F087300FB07225E1E0F00010001050000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 7CA1F3DB366359D795F-8028
       Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
       Serial number: 2231623360302477AS2B
       Coding: 2D0000
    131658 - Door Control Module - Driver's Door
              U0199 00 [008] - No Communications
              [Timeout Knoten 0x4A / 42 - T¸rsteuerger‰t Fahrerseite]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:34
                        Supply voltage: Terminal 30: 12.0 V
                        Terminal 15: On
    197175 - Control unit for battery monitoring
              U1050 00 [009] - No Communication
              [BDM (LIN#1) Timeout]
                        Reset counter: 114
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 10:03:31
                        Terminal 15: On
       Serial number: HA1-00019.07.16
       Coding: 0101
       VCID: 4ACD65032C373767573-801E
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH07 0014
       VCID: 45D7563F0529D81FBA1-8010
       Serial number: 060416ED313449
       Coding: 003F0A20D001048000001000
       VCID: 43D348270B1DE62F945-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 9307
       ROD: EV_SteerAssisMQB_013.rod
       Serial number: 150816EHE01951
       Coding: 003F0020DE01048000001000
       VCID: 42DD4D231407EF279F3-8016
    65570 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [T¸relektronik Fahrer (J386)]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
    65572 - Local Data Bus
              U10BA 00 [008] - No Communication
              [T¸relektronik Fahrerseite hinten (J388)]
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0051
       Coding: 08AE00104B200201
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
       Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
       Component: MU-S-ND-ER    840 0757
       Coding: 02730601FF00000051110101008808001F0100E6012000008F
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 313F12EFA1A164BF769-8064
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL038HB
       Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H09 0170
       Coding: 0123060122002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
       VCID: 77ABECF70F457A8FF8D-8022
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30871625900000
       Coding: 0A00
       ASAM Dataset: EV_DeckLidCONTIAU736 001012
       VCID: 3FDB44D767F582CFF0D-806A
    0056 - Databus
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:35
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 17081611K10276
       Coding: 000307060000040100021344C050A10094000E200040
       VCID: 3A2D35C37CD7A7E7C73-806E
    1135140 - Databus
              [APS_03_US_Fehler_HS]
                        Reset counter: 169
                        Mileage: 53663 km
                        Date: 2019.09.24
                        Time: 10:36:58
                        Control Module temperature: 42 ∞C
                        Outside air temperature: 16.0 ∞C
                        Vehicle speed: 73.22 km/h
                        System run time: 13170.3 s
                        Voltage terminal 15: 14.0 V
                        mid: 02 65
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 0
                        Software_Info_3: 2
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 290716EGS03559
       Coding: 002A00200100048000001000
       Serial number: 290716EGS0325A
       Component: SAD_STG_1     013 0005
       Coding: 308040732602
       VCID: 3D273EDF6DF990DFE21-8068
    0304 - Databus
                        Reset counter: 155
                        Mileage: 52512 km
                        Date: 2019.09.14
                        Time: 11:50:32
       VCID: 1675C173280FA38703B-8042
    0774 - Light Bulb for Low Beam
              C1198 29 [008] - Signal Implausible
                        Reset counter: 190
                        Mileage: 52944 km
                        Date: 2019.09.21
                        Time: 12:45:15
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
                        Reset counter: 190
                        Mileage: 52944 km
                        Date: 2019.09.21
                        Time: 12:45:15
    End----------(Elapsed Time: 02:10, VBatt start/end: 12.0V/12.2V)-----------
    On 2019 models many modules no longer use long coding, all settings are done using adaptation channels.
    Quote Originally Posted by mrlapou View Post
    Fixed/Verified.
    My question is, under : 09 Central Elects, the coding shows 00000000000000000000000000[/code]
    Why is this?
    Because you have an MK7.5 style BCM and VW has moved everything that could previously be changed in Coding to various Adaptation channels.
    Making you type the last three digits of the VIN in order to register the VIN is a means of ensuring that people don't whine at us that they registered a VIN "by accident".
  4. Likes Mike@Gendan liked this post
    It's primarily BCMs. Just about every other module in his car still has a non-zero coding string.
  6. Likes PetrolDave liked this post
    Oct 2019
    Thanks to all, for the brill replies.
    Now need to find a site / list that translates the German terms in adaption selections to English.
    ^^^^ good way to complete that particular task IMO - is to make an adaptation channel map of your BCM in CSV format - then you will have a database file that can be read by higher order application like MS Excel/MS access etc. After that, and depending on your level of conviction, it's just a matter of copy-and-paste and Mr Google's handy-dandy translator (and dedication)!!
    PS: Interesting DTC s - you might start by translating the errors (perhaps)
    I might be able to help with that:
    TSG = Tür Steuer Gerät = Door Control Module.
    FT_01 = Fahrer Tür = Driver's Door; not sure what the 01 is about.
    HFS_01 = Hinten Fahrer Seite = Rear Driver's Side
    Datenbus fehlende Botschaft = Databus Missing Message
    Is it possible someone was checking fuses and unpluged one on 2019.09.14?
    If it were mine, I would clear those faults and not worry about them unless they come back.
    But I would also be more concerned with the Engine faults than anything else. Those have a high probability of leading to a plugged up DPF...
  10. #8
    Oct 2019
    Spot on. Some faults codes were caused by unplugging a live fuse.
    The differential DPF pressure sensor was changed, which cleared the engine management light and all codes.
    However after about 350 miles later, scan now shows return of P2209 NOx sensor 1 bank 1 implausible signal. At the same time the supplementarity / quick cabin heater function has stopped working. On the colder days, it takes about 3 miles to feel heat from vents and about 9 miles / 15mins for the cabin temp to come up to about 22c.
    The heater fan also does not seem to regulate speed settings.
    The Auto supplementary heater setting is on in the climate control 'menu' screen on the headunit.
    Here is the latest scan.. The Central Elects fault code
    is caused by unplugging the two pin connector on the battery terminal to deactivate the stop/start. I did this on my previous Mk7 TDi with came engine and gearbox as my current Mk3 MY66 Tiguan with no issue.
    Thursday,31,October,2019,10:13:49:33763
    Mileage: 55045km-34203mi   Repair Order:
    VIN: WVGZZZ5NZHW827920   Mileage: 55045km-34203miles
    CA-Sunroof -- Status: OK 0000
       Revision: B4H24---
              P2209 00 [101] - Implausible Signal
                        Mileage: 54489 km
                        Date: 2019.10.17
                        Time: 12:21:08
                        Engine speed: 1485.50 /min
                        Normed load value: 73.7 %
                        Vehicle speed: 85 km/h
                        Coolant temperature: 62 ∞C
                        Intake air temperature: 55 ∞C
                        Voltage terminal 30: 14.580 V
                        NOx sensor before SCR cat conv: NOx concentration: 60 ppm
                        Extern.temp.sens.1 bank 1: raw value: 7.0 ∞C
                        Mean injection quantity: 15.21 mg/stroke
    28991 - No Communications with NOX Sensor 1
              U029D 00 [036] - -
                        Mileage: 55018 km
                        Time: 00:00:00
                        Coolant temperature: 15 ∞C
                        Intake air temperature: 15 ∞C
                        Voltage terminal 30: 11.440 V
                        Cruise Control System (CCS): status-Bits 0-7: 6
                        CAN status - brake control module 1-Bits 0-7: 8
                        selected gear-Bits 0-7: 0
       Revision: 00H12V32
       Coding: 0E45DD
       Coding: 06A8DD
       Coding: 0331563851
    13679388 - Databus
                        Reset counter: 204
                        Mileage: 54575 km
                        Date: 2019.10.19
                        Time: 18:28:29
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 1079B76B0AEB4DB7597-8044
       Belt Pretensioner left:
       Coding: 80000D
       Belt Pretensioner right:
       Coding: 80000D
       Pedestrian Protection Driver:
       Pedestrian Protection Center:
       Coding: 0C10
       Coding: 2D0000
                        Reset counter: 154
                        Mileage: 54473 km
                        Date: 2019.10.16
                        Time: 10:35:54
                        Supply voltage: Terminal 30: 11.6 V
                        Terminal 15: On
    66565 - Diagnostic Databus
              U1202 00 [008] - Malfunction
              [Bus defekt CAN-Diagnose]
                        Reset counter: 194
                        Mileage: 54473 km
                        Date: 2019.10.16
                        Time: 16:49:16
                        Supply voltage: Terminal 30: 11.5 V
                        Terminal 15: On
       Coding: 0101
       Coding: 9307
       Coding: 0A00
    End----------(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V)-----------
  11. #9
    You mean the fault in the Gateway?
    I would plug it back in for a while as a test. If the Gateway doesn't know the battery's State-of-Charge, it may not allow the auxiliary electric heater to function.
  12. #10
    Oct 2019
    Thank you.....Sounds like a good plan which I'll implement...
