- Joined
- Mar 20, 2019
- Messages
- 58
- Reaction score
- 16
- Location
- South Africa
- VCDS Serial number
- C?ID=357723
hi there all members. customer fitted a new abs control unit. we have managed to get a very similar vehicle with similar long coding. we have edit the 5 last digits of vin into new coding. abs controller keeps rejecting coding. batt very strong. had car idle while try to enter long coding. keeps rejecting it. this is the long coding. please try and assist. thanks you.
163B600D892200FE681006E8911E0082B000
Wednesday,16,October,2019,18:44:14:62451
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: AAVZZZ1KZ9U004545 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: AAVZZZ1KZ9U004545 Mileage: 161330km-100245miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H63NM8DW
Coding: 0403001018070160
Shop #: WSC 78899 280 403206
VCID: 3536D5A7494E499F7DB-8060
Readiness: 0110 0101
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
VCID: 7EA40A8B30F84AC7EC1-802A
Reset counter: 116
Mileage: 161335 km
Count: 7
Count: 2
Count: 12800
Count: 195
Count: 50176
00003 - Control Module
Fault Status: 01100101
Reset counter: 116
Mileage: 161335 km
Count: 7
Count: 2
Count: 12800
Count: 143
Count: 50176
Reset counter: 116
Mileage: 161335 km
Count: 7
Count: 2
Count: 12800
Count: 295
Count: 50176
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6D863DC7619EC15F45B-8038
Revision: 00H54000 Serial number: 00000008484804
Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
Shop #: WSC 00046 412 00000
VCID: 3332EBBF473A57AF53F-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 050808 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 040708 046 0204
Coding: 00208933
Shop #: WSC 00046
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD22L390
Coding: 0013121
VCID: 3D26CD87717E91DFB5B-8068
Subsystem 1 - Serial number: 6332MSME29330F0EH
Subsystem 2 - Serial number: 6342MSME293276337
Subsystem 3 - Serial number: 6352QSME666235218
Subsystem 4 - Serial number: 6362QSME682F7845X
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 752 0101
Coding: 0002022
VCID: 015E71774D06353F913-8054
Component: E0221 002 0010
Part No SW: 1K6 920 874 HW: 1K6 920 874
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0002000 Serial number: VWX7Z0H63NM8DW
Coding: 0004103
Shop #: WSC 04297 996 10963
VCID: 70B824B376AC2CB76ED-8024
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 020608F1001038
Coding: E9817F060002020003
Component: IMMO VDD 2416
Shop #: WSC 12222 000 00000
014 - Defective
Fault Status: 01101110
Mileage: 69518 km
Time: 18:36:49
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 3828DC935E5CB4F766D-806C
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 3634D2AB54484287741-8062
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 199002005103087F2D040F0F70085FC690FC00
VCID: 03527B7F571A272F83F-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
01134 - Alarm Horn (H12)
Reset counter: 116
Mileage: 161335 km
Time: 00:43:46
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 392ED9976556ADFF993-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B028A302B410978A5-8020
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio 553 0555
Revision: R0553007 Serial number: VWZ5Z1N0808986
Coding: 0500040002
Shop #: WSC 00000 000 31414
VCID: 2A0CF6DB9CF01667E09-807E
Reset counter: 116
Mileage: 161335 km
Time: 00:43:30
Reset counter: 116
Mileage: 161335 km
Time: 00:43:30
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1301
Coding: 0000144
Shop #: WSC 00046 412 1012544
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Shop #: WSC 00046 000 1012544
End----------(Elapsed Time: 01:36, VBatt start/end: 12.6V/12.5V)-----------
