Results 1 to 7 of 7
Thread: Lost Abs long code, Golf 7 CRBC 2013
    Aug 2017
    Hi there!
    I'm wondering if there is anybody out there who can help me with the Abs long coding on a Mk 7 golf?
    CRBC engine
    2.0l Diesel
    2013
    Manual transmission/electronic handbrake/lane assist
    As you can see in the vehicle scan the abs unit has lost its coding and reverted back to 00's
    It's a 0-29 byte long code (30 total)
    I've contacted Ross-tech who said "We don't have a singe scan from a good baseline car with
    that 01-Engine and 03-ABS module combo" but advised to post here to see if anybody has a code from the same style vehicle which could help.
    Thanks in advance
    Will
    VCDS Version: 19.6.2.0
    VIN: WVWZZZAUZEP006808
    Mileage: 92819km-57675mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
    VIN: WVWZZZAUZEP006808   Mileage: 92819km-57675miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5514
       Revision: 83H22---
       Coding: 01190012034505082000
       Shop #: WSC 00028 028 00080
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: F9F3AC7778CE3E8760-80AC
    17158 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 15:08:27
                        Coolant temperature: 84 °C
                        Intake air temperature: 71 °C
                        Voltage terminal 30: 12.720 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
    4716 - No Communications with Parking Brake Control Module
              U0128 00 [039] - -
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:20
                        Engine speed: 770.50 /min
                        Normed load value: 17.3 %
                        Coolant temperature: 95 °C
                        Intake air temperature: 57 °C
                        Voltage terminal 30: 14.060 V
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        selected gear-Bits 0-7: 0
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 61493000000A8A
       VCID: 8717DA8F3E3A587766-80D2
    12 Faults Found:
    0195 - Control module not coded
              U1013 00 [137] - -
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    0295 - Steering angle sensor
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    8278 - Control Module Incorrectly Coded
              U1014 00 [137] - -
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    8290 - Coding Not Possible
              U10BC 00 [137] - -
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:29
    8306 - Databus
              U1122 00 [137] - Implausible Message
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:29
    8308 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    8314 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [009] - -
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    32848 - Control Module for Electric Parking Brake
              C10E2 F1 [137] - Switches/Motors Detected
                        Reset counter: 102
                        Date: 2019.10.02
                        Time: 14:48:24
    32951 - Control Module for Electronic Parking Brake
              C10E2 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 09:15:08
       Part No SW: 5G0 907 426 M    HW: 5G0 907 426 M
       Component: AC Manuell    H01 0705
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       Shop #: WSC 00028 028 00023
       VCID: B56B604714561AE7C4-80E0
       Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
       Component: BCM MQBAB M   H14 0112
       Serial number: 00011314402521
       Coding: 03000842C241027B0BA44080B1040328100A000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: C89519B373A4970FAF-809C
       Component: WWS    130514  042 0551
       Serial number:         130523124114
       Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
       Component: RLS  024 0042
       Serial number: Y13M05D30H08M50S35S1
       Coding: 00A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1304900FL
       Serial number: 00000000000056818215
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231315101021
       Coding: 0071051001
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       VCID: BB7F767F3272CC9732-80EE
    12658704 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:34
    13637426 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:34
       Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
       Component: ACC Bosch MQB H03 0141
       Serial number: 30051376510736
       Coding: 00000300FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001013
    1071 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
                        Control Module temperature: 41 °C
                        Voltage terminal 15: 14.0 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1058 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
    1059 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
    0261 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
    1043 - Automatic Distance Control
              B10E7 F0 [009] - Disconnected
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Serial number: 003M1R0359H1
       Shop #: WSC 00028 028 00061
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: CA9123BB6DA8651FB9-809E
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169677B29051350226
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676B31051340418
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 805 13
       Serial number: 3576700000036A010D0I
       Subsystem 4 - Part No SW: -----------    HW: 480 002 805 13
       Serial number: 35867000000022713D0E
       Subsystem 5 - Part No SW: -----------    HW: 480 403 105 13
       Serial number: 3516502B31050662610K
       Subsystem 6 - Part No SW: -----------    HW: 480 403 105 13
       Serial number: 3526502B31050660A23R
       Subsystem 7 - Part No SW: -----------    HW: 480 402 705 13
       Serial number: 3556502B9105EDD343AQ
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:26
    1049093 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
    1049094 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
    1049095 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:27
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 06061304221417
       Coding: 0D00
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: FBFFB67F72F20C9772-80AE
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
       Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
       Component: KOMBI         252 2210
       Coding: 27A419002780260001886A01000000
       VCID: A855B933D3E4770F4F-80FC
    16776967 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:29
    16776973 - Databus
                        Reset counter: 102
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:29
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2147
       Revision: --------    Serial number: 03061310800362
       Coding: 030100040B087300EF00045C080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewConti 009011
       ROD: EV_GatewConti_009.rod
       Component: E221__MFL-DC1  H14 0035
       Serial number: 27130000684510063213
       Coding: 2C0000
       Serial number: 1198930603
       Part No SW: 5Q4 959 593     HW: 5Q4 959 593
       Component: TSG FS        007 0006
       Serial number: 0000062143164
       Coding: 003B0220D001028000001000
       VCID: 8201CB9B15187D5F31-80D6
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001586615
       Coding: 0D0000
       Coding: 81
       ROD: EV_SteerAssisMQB_008.rod
       VCID: BD7B78672C66C2A70C-80E8
    19204 - Databus
                        Reset counter: 142
                        Mileage: 92819 km
                        Date: 2019.10.02
                        Time: 14:48:31
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 14.00 V
                        Temperature: 29.0 °C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 21
                        uAdSensI_U5VFiltered_xdu16: 5.04887 V
                        uioUdNotFilt_xdu16: 14.09 V
                        uAdSensI_SwitchedKl30_xdu16: 14.08 V
       Part No SW: 5Q4 959 592     HW: 5Q4 959 592
       Component: TSG BFS       007 0006
       Serial number: 0000062572776
       Coding: 003B0020DE01028000801000
       VCID: 8103C497101E664728-80D4
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001591320
       Coding: 050000
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    040 0421
       Serial number: V7F02505131975
       Coding: 02730001FF00000021111201002800001F0100060100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: E7D7FA0F1E7AB87786-80B2
       Component: ABT_Std_Nav  H44 0020
       Serial number: VWZ8Z9N3401XQC
       Subsystem 2 - Part No SW: 5G0 919 866 E    HW: -----------
       Component:  ECE 2013/14  --- 0034
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 99
                        Mileage: 92819 km
                        Date: 2019.10.01
                        Time: 20:39:02
                        Voltage terminal 30: 11.8 V
                        BAP-BAP_Function_ID: 02
    7206 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 99
                        Mileage: 92819 km
                        Date: 2019.10.01
                        Time: 20:39:02
  2. Likes Dana liked this post
  3. #2
    Oct 2014
    Loosely similar UK Golf (same ECU + coding) here: https://forums.ross-tech.com/showthr...-AC-fault-code
    At the very least, you'll need to chance the VIN specific bytes mentioned here: https://forums.ross-tech.com/showthr...100-ABS-Coding
    I've never touched a MK100 code but based on the above:
    000000000000000000000000000000000000000000000000000000000000 <-- length check
    01FA8AA1242409700378060341CC2980512490C0608294F3F4605078C002 <-- other car
    01FA8AA124--09--03--06--41--2980512490C0608294F3F4605078C002 <-- VIN bytes striped
    01FA8AA124200972037F060041CB2980512490C0608294F3F4605078C002 <-- TRY THIS
    I'd suggest you check the other bytes against the MK100 coding guide to make sure it's sane and I'm more than happy for others to correct me.
    Try it at your own risk
  4. Likes Somnus, Will, Dana liked this post
  5. #3
    Aug 2017
    Brilliant! Thats done the trick, Thank you very much!
  6. Likes Uwe, Somnus, Dana liked this post
  7. #4
    Aug 2017
    Feb 2018
    SLC
    Would you be so kind as to post an Auto-Scan now that the ABS coding is fixed?
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
  9. Likes Uwe liked this post
  10. #6
    Aug 2017
    No problem, ive posted below.
    Please note that the missing message faults in the system were there prior to the ABS coding issue, there are faults with the acc.
    We tried other codes with no luck, but this code worked straight away
    Thanks again
    VIN: WVWZZZAUZEP006808   License Plate:
    Mileage: 92828km-57680mi   Repair Order:
    VIN: WVWZZZAUZEP006808   Mileage: 92828km-57680miles
       Revision: 83H22---
       Coding: 01FA8AA124200972037F060041CB2980512490C0608294F3F4605078C002
       Shop #: WSC 37042 210 01865
    8299 - Databus
                        Reset counter: 104
                        Date: 2019.10.16
                        Time: 11:40:19
       Revision: 00001K06
       Coding: 00A8DD
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 104
                        Mileage: 92820 km
                        Date: 2019.10.16
                        Time: 12:10:17
       Coding: 0071051001
    1058 - Databus
                        Reset counter: 144
                        Mileage: 92820 km
                        Date: 2019.10.16
                        Time: 11:40:18
                        Control Module temperature: 22 °C
                        Voltage terminal 15: 11.7 V
       Coding: 333135
       Coding: 333135
       Coding: 0D00
       Coding: 2C0000
       Coding: 0D0000
       Coding: 81
       Coding: 050000
    End-------------------------(Elapsed Time: 04:05)--------------------------
  11. #7
    Feb 2018
    SLC
    If I were a betting man, I would say that ABS Missing Message's extended fault detail is [FCAN: Anhaenger_01_alt veraltet bit is set].
    Check your ABS Adaptations and see if "vehicle and trailer stabilization" is enabled.
    Disabling that channel should, in theory, clear the missing message fault
  12. Likes Uwe, Dana liked this post
