Results 1 to 7 of 7
Thread: Touareg T1 - Lamp for Low Beam; Left (M29) 007 - Short to Ground
    Oct 2019
    Oklahoma, USA
    I bought the '06 v10 Touareg about a month ago. The headlights worked when I bought it, but were very dim. It had cheap bulbs in it that probably burnt the chrome (lovely).
    I replaced the hardly insulated short jumper behind trays that somehow worked, and the bulbs with Sylvania Basic D1S. Both lows worked but were still not very bright. After a week the left light fails to turn on, right at the start of a trip of course...
    I then bought a new Valeo ballast and replaced the left one thinking that was the problem. Still no left light, shows the below error in VCDS:
    Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
    Part No: 7L6 937 049 N
    Component: 3002
    Coding: 0111838
    Shop #: WSC 22188 444 89171
    VCID: 4796E2DA3580D07718-5120
    007 - Short to Ground (BUT WHERE?)
    Thinking it was the internal headlight module wiring, I bought and replaced the headlight units with new Valeo ones, swapping the low bulbs and ballasts. Still no left light! I cleared the code, turned the vehicle off. Started it up - still the same error.
    I tested the short 3-wire jumper from the ballast to the bulb, and it appears to be fine as I swapped left and rights with no change. Then I poked around in VCDS some more and realized that if I select 39 - the right headlight, it connects to the controller fine. If I select 29 - the left headlight, nothing. VCDS cannot find it! The rest of the lights work fine on that side (high, turn, marker). From what I can tell these are all driven from the "Vehicle Electrical System Central Control Unit" module under that dash.
    I'm still looking for a good wiring diagram for 2006 xenons so I can actually test voltages and find the short to ground (if that is still true, and not something that just needs to be re-coded or reset). Recommendations?
    Thanks in advance,
    Bryan
    Here is a full scan I did earlier before replacing anything:
    Monday,12,August,2019,13:43:53:11556
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVGPT77L46D063114   License Plate: TOURAG
    Mileage: 339690km-211073mi   Repair Order:
    0111838
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGPT77L46D063114   Mileage: 339690km-211073miles
       Part No SW: 070 906 016 CQ    HW: 028 101 196 2
       Component: V10 5,0L EDCG000AGMª8472
       Revision: --H02---    Serial number: VWZ3Z0F6459651
       Coding: 0060575
       Shop #: WSC 66565 257 00032
       VCID: 61C21C42BB648E47F6-5120
       Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
       Component: AL 750 6A           0856
       Revision: 00H37000    Serial number:
       Coding: 0004216
       Shop #: WSC 31414 000 00000
       VCID: 7F06BA3A2DD058B7E0-513C
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D7A8032675C8AA7B2-513C
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137 A    HW: 5WK 485 02
       Component: 29 Kessy            6700
       Revision: 67005915    Serial number: VWZ3Z0F6459651
       Coding: 0147688
       VCID: 3162AC02AB047EC726-513C
       Part No: 7L0 959 760
       Component: Sitzverstellung     0701
       VCID: 77F6521A05E060F7A8-513C
       Part No: 7L6 907 044 T
       Component: CLIMAtronic 2+2     4222
       Coding: 0021030
       VCID: 458AE8D20F8CC267EA-513C
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    00710 - Defroster Flap Positioning Motor (V107)
    02600 - Rear Right Temperature Flap Motor (V314)
       Component:                     3002
       Coding: 0111839
       VCID: 4796E2DA3580D07718-513C
    Address 11: Engine II        Labels: Redir Fail!
       Component: V10 5,0L EDCG000AGSª8472
       Coding: 0060575
       VCID: 61C21C42BB648E47F6-513C
       Part No: 3D0 909 601 H
       Component: 05 Airbag 8.4E++H01 0562
       Revision: BB38727     Serial number: 0007756?
       Coding: 0012341
       VCID: 2854416698DE3F0FF1-5120
       Subsystem 1 - Part No: 7L0 959 339 C
       Component: BF-Gewichtsens. 006 0008
       Part No: 7L6 953 549 F
       Component: Lenksaeulenmodul    3501
       Coding: 0010032
       Shop #: WSC 31414 790 00001
       VCID: 4280F3CE1EA2F55FCF-5120
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 981 R
       Component: KOMBIINSTRUMENT RB8 3211
       Coding: 0005231
       VCID: 4894E1E6389EDF0F11-513C
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 815 071 D
       Component: Standheizung E1MAC
       Coding: 0000100
       VCID: 336EA60A51184CD754-5120
       Part No: 6N0 909 901
       Coding: 0000006
       Shop #: WSC 22188 444 52556
       VCID: 70E46906608E37CF69-513C
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No: 7L6 919 879 A
       Component: JCI PathPoint       2200
       VCID: 458AE8D20F8CC267EA-5120
       Part No: 0AD 927 755 AT
       Component: TRANSFERCASE        0114
       VCID: 0D1A10F2177C7A27E2-513C
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       VCID: 36689F1E426A59FF73-513C
       Component: Sitzverstellung     0703
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 M
       Component:      Navigation     0047
       Coding: 0000101
       VCID: 50A4C986C0CE17CF49-513C
       Part No: 3D0 909 158
       Coding: 0000003
       VCID: 67D6025A5540F07738-5102
       Part No: 7L0 959 933 J
       Component:    HSG              5115
       Coding: 0000085
       VCID: 438EF6CA01B8FC57C4-4B00
       Subsystem 1 - Part No: 7L0 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    6 Faults Found:
    00927 - Terminal 30 (Right)
    01516 - Terminal 30; Left
    00926 - Terminal 30
    01134 - Alarm Horn (H12)
    00488 - Rear Right Outside Door Handle Central Locking Button (E372)
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 7L6 035 456
       Component: 08K Audioverst.     0105
       VCID: 70E46906608E37CF69-5120
       Subsystem 1 - Part No: 7L6 035 456
    No Faults Found
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 E
       Component:        Radio        0047
       Coding: 0014062
       VCID: 356A98125F6C52E77A-5120
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 K
       Component: Front Wiper         4027
       Coding: 0000341
       Shop #: WSC 31414 000 376832
       VCID: 3C7C8D367C4683AF85-513C
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       VCID: 38749126487EAF8F61-5120
       Part No SW: 7L6 907 441     HW: 7L6 907 441
       Component: J772__Rearview      0051
       Revision: 00H07000    Serial number:    PA8 J620637
       Coding: 0000101
       VCID: 72E0630E6E8205DF9F-513C
    Address 6E: Ctrl Head Roof        Labels: None
       Part No: 7L6 919 044 T
       Component: DACHDISPLAY         0539
       Revision: 00900539    Serial number: 2009289.07
       VCID: 4894E1E6389EDF0F11-5120
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 397294227374B6879E-513C
    End-------------------------(Elapsed Time: 09:50)--------------------------
    Quote Originally Posted by hallkbrdz View Post
    erWin?
    Buy a short subscription, enter your Vin and download every document relevant to your T1 - even if you don't need them now you may need them in the future
  3. Likes Uwe liked this post
    Oct 2019
    Oklahoma, USA
    Yes, I have the erWin wiring diagrams, although they are wrong in regards to the HID bulb. Pins 6 and 8 are for the halogen high beam, not the HID. That of course is from the jumper from the J567 Left Headlight Range Control Module.
    I don't see that anything is wrong ground wise that would set off that code - at least now. Is that a stored fault that I somehow need to clear? If not - where does that come from?
    Below is what I traced out, and the Volts column shows what I found at each pin with the headlights on in the high-beam mode with the headlight module disconnected.
    Pin		Black 14	        White 12	        Size Volts	Actually goes to
    1		blk			blk			0.35	     6		Ctrl - J567 Left Headlight Range Control Module - Headlight Range Adjustment Connection
    2		blk			blk			0.75	     14	Ctrl - +v J567 Left Headlight Range Control Module - Plus Connection 3
    3		orange		orange		0.5	     0.18	Blk +v - N395 Left Headlight Reflector Adjustment Solenoid
    4		li			li			0.5	     14	Blk +v - M1 Left Parking Light
    5		red			red			0.75	     0.39	Ctrl GND - J567 Left Headlight Range Control Module - From J519 Vehicle Electrical System
    6		orange		orange		1.5	     0.19	(1) Blk +v - M30 Left High Beam Headlight (passing)
    7		brn			brn			0.5	     0		Ctrl GND - J567 Left Headlight Range Control Module
    8		brn			brn			1.5	     0		(1) Brn GND - M30 Left High Beam Headlight  (passing) and N395 Left Headlight Reflector Adjustment Solenoid
    9		li			li			0.75	     0.13	Blk +v M5 Left Front Turn Signal Light
    10		brn			brn			1.0	     0		Brn GND - M5 Left Front Turn Signal Light and M1 Left Parking Light
    11		blk			blk			0.35	     9.16	Ctrl - J567 Left Headlight Range Control Module - OBD Connection 1
    12		blk			blk			0.35	     11.52	Ctrl - J567 Left Headlight Range Control Module - Headlight Range Adjustment Connection
    13		Unused		N/A
    14		Unused		N/A
    Voltage reference is to Pin 10 as ground
    (1) erWin shows J343 Left High-intensity Gas Discharge Lamp Control Module
    J343 Left High-intensity Gas Discharge Lamp Control Module connects through J567 Left Headlight Range Control Module
    Last edited by Uwe; 10-18-2019 at 07:20 PM. Reason: Trying to get the CODE section to look better
    Oct 2019
    Oklahoma, USA
    I tried swapping the right headlight into the left side - no surprise, no low beam.
    I then measured the same pins on the right side. Pin voltages side by side:
    Pin - Left / Right
    1 - 6 / 6
    2 - 14 / 14
    3 - 0.18 / 14
    4 - 14 / 14
    5 - 0.39 / 14
    6 - 0.19 / 0.05
    7 - 0 / 0 - Ground
    8 - 0 / 0 - Ground
    9 - 0.13 / 0.18
    10 - 0 / 0 - Reference ground
    11 - 9.16 / 9.12
    12 - 11.52 / 11.52
    So to activate the low beam I should have +14 on 3 and 5 where I now have what look like low float voltages - not shorts. So the J519 Vehicle Electrical System Control Module seems suspect.
    I see in erWin references to a self diagnostic. Can I do that with VCDS?
    If I do need to replace the J519, which I believe is the BCM 7L6937049(N) - where would I code that?
    Thanks in advance
    Sep 2016
    Riga, Latvia
    Maybe check fuses and wiring first
    Oct 2019
    Oklahoma, USA
    Quote Originally Posted by MartinsX View Post
    I did. The fuses are fine (verified with a VOM) and all of the wiring was replaced with new, except for the main harness. Based on the voltage values, nothing is actually shorted to ground. Before with the cracked and missing insulation - sure.
    For now I'm just going to splice in a relay in the headlight tray jumper triggered by the running lights for 3 and 5 to supply voltage for the low beam.
    Oct 2019
    Oklahoma, USA
    Resolved. It was a bad contact on the left #35 fuse. Checked good (12v both sides), but found it as I got desperate and removed and reinserted every single fuse. Figures...
    35 15A Vehicle electrical system control module – Headlamps (high/low beam)
  9. Likes Uwe liked this post
