Exhaust Pressure Sensors 2014 4G 2.0 TDI
A6Jim
Scotland
C?ID=353853
I was getting the P2002 error with EML on so I've replaced both DPF sensor and Exhaust manifold sensor, (both same part 03L906 051B).
I replaced both sensors, cleared the fault and EML hasn't come back on which is great but do I need to adapt both sensors to the car via vcds?
Excuse my daftness but I'm quite new to vcds not sure how to do this or if I need to do it so the car knows I've replaced both sensors.
Would be much appreciated if someone could give me some guidance on this :)
PetrolDave
Westbury, UK
C?ID=1423
Please post a full unedited VCDS Auto-Scan some can see how your car is equipped and advise the correct procedure.
*Edit* posted at the same time as Mike@Gendan ;)
A6Jim
Scotland
C?ID=353853
The first thing to do would be to post a full Auto-Scan so we can see how the car is configured.
Hope this is suitable, had to copy and paste it as using diffPC & laptop for scans :rolleyes:
Tuesday,15,October,2019,12:59:25:23338
VIN: WAUZZZ4GXEN170558   License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
          72 AC
VIN: WAUZZZ4GXEN170558   Mileage: 61441km-38177miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FE    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8243
   Revision: 85H23---
   Coding: 0A194012242401080000
   Shop #: WSC 56319 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
   ROD: EV_ECM20TDI01104L906021FE_002.rod
   VCID: 6D87CBF47D144CCF121-8038
   Coding: 06A09F016005F9809B00
   VCID: 3A2D30A87CDA2B77C73-806E
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0551
   Coding: 03B83046000000000000
   VCID: 7AADF0A83CDAEB77873-802E
   Serial number: 0214000101172006
   Part No SW: 4G0 820 043 BB    HW: 4G0 820 043 BB
   Component: KLIMA 2 ZONEN H14 0096
   Serial number: 30051400111498
   Coding: 3421090821
   ASAM Dataset: EV_AirCondiBasisUDS 004002
   ROD: EV_AirCondiBasisUDS_004.rod
   VCID: 6099A2C0BAC611A7A97-8034
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001545955
   Coding: 2600201141349F600481008300001D0C0F9D830827090201000004606100
   VCID: 6E85CCF87092B7D72BB-803A
   Component: WWS57X 140430  H37 0080
   Serial number:         140508161043
   Coding: 0045F7
   Serial number: 22702280
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 04 06 2014  00001107
   Serial number: 04D80D27000000000001
   Revision: 11001001    Serial number: 61061415500839
   Coding: 08C206
   VCID: 71BFD784612CA82F369-8024
   Revision: --------    Serial number: 003JG00J55BZ
   Coding: 3032343631324E303235554A305234473053
   VCID: 3635249848C2CF1723B-8062
   Serial number: 3575HRB405R2B5M69HCN
   Serial number: 3585HRB405N2LFGM7HG9
   Serial number: 3515JRB400652KI8B9UC
   Serial number: 3525JRB40612OSGCF0LT
   Serial number: 3554VRB400252K8MGQ1K
   Serial number: 3564VRB400M52JN0T1H.
   Revision: 00000000    Serial number: 20140527000350
   Coding: 000014
   VCID: 30391280AA26E127797-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
   Component: MDieGb        H43 0411
   Revision: 27450259    Serial number: 658220514592066
   Coding: 33A50A000B412600010000
   ASAM Dataset: EV_RBC7KMID 004048
   ROD: EV_RBC7KMID.rod
   VCID: 3FDB41BC67F80E5FF0D-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001410198
   Coding: 00CD074400
   VCID: 72BDD888642A9337CF3-8026
   Serial number: 8598803403
   Voltage stabilizer:
   Serial number: 14031000000000000401
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA720AB9KA
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331D8C5BB0DA3F045-8066
   Coding: 011C16004001620002080002
   VCID: 47CB595C3FA8469F48D-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0022613549
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1888A4AAD3370F3-8066
   Revision: 00002001    Serial number: 0337063119
   Coding: 011F062280B900408320080400010E470000000000000000000000000000
   Revision: CJ007001    Serial number: 00000000110009
   VCID: 1D67DB34CDB47C4FC21-8048
   Coding: 011C16004401620002080002
   VCID: 46D5545838A25F97B3B-8012
   Revision: --------    Serial number: 00000001081278
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070BF4BD948CCF521-8078
   Serial number: 140602-0002-025
   Coding: 112196101000A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
   Component: RMC Nav Plus  H55 0801
   Coding: 0101000101415B47082B060301020100000000
   VCID: 270BF9DC9FE8A69FA8D-8072
   Subsystem 1 - Part No: 8X0 919 884 G
   Component: P24-50-13.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464EY0E2663603
   Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
   Serial number: 90349NER000TD
   VCID: 49CF5F6429BCB0EF5E9-801C
   Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0010
   Revision: 00000000    Serial number: 141190685
   ROD: EV_RDCMA00100_008.rod
   VCID: 2B0305EC838082FF4C5-807E
End------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.1V, udsna)--------
At a guess, these Basic Settings:
IDE05936 -- Low-pressure EGR differential pressure sensor adaptation
IDE01772 -- Adaptation of diff. pressure sensor particulate filter
A6Jim
Scotland
C?ID=353853
Thanks very much Uwe, I'll have a look tomorrow.
Sorry meant to post this too. Below is the first scan I done before clearing the codes.
P.s. Ignore the other faults, I've fixed them. It's the engine one I'm concerned with.
Thursday,03,October,2019,14:56:11:23338
VIN: WAUZZZ4GXEN170558   License Plate: Jim
          72 AC
VIN: WAUZZZ4GXEN170558   Mileage: 59887km-37212miles
   Revision: 85H23---
19226 - Particulate Trap Bank 1
          P2002 00 [236] - Efficiency Below Threshold
                    Fault Frequency: 17
                    Mileage: 59387 km
                    Date: 2019.09.27
                    Time: 12:46:54
                    Engine speed: 1264.00 /min
                    Normed load value: 56.1 %
                    Vehicle speed: 46 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 14.580 V
                    Exhaust mass flow of low-pressure EGR: calculated: 3.012
                    Differential pressure ratio: low-pressure EGR: 24.8 kg/h
                    Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 24.4 hPa
                    Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 23.5 hPa
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 84.11 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 46.34 %
                    Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 21.8 hPa
Readiness: 1 1 0 0 0
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 94
                    Mileage: 59477 km
                    Date: 2019.09.28
                    Time: 15:58:56
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: AC
0692 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_EPB_Spannkraft_Error]
                    Reset counter: 94
                    Mileage: 59477 km
                    Date: 2019.09.28
                    Time: 15:58:56
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 06
                    Uz: AC
   Coding: 3421090821
   Coding: 0045F7
   Coding: 02006D
   Coding: 08C206
   Coding: 000014
   Coding: 00CD074400
   Voltage stabilizer:
   ROD: EV_SARA2.rod
03279 - Clutch Pedal Switch for Engine Start (F194)
                    Reset counter: 87
                    Mileage: 59361 km
                    Date: 2019.09.26
                    Time: 16:01:29
71680 - Right Parking Brake Motor Voltage Supply
          C100E 12 [008] - Electrical Malfunction
                    Reset counter: 94
                    Mileage: 59477 km
                    Date: 2019.09.28
                    Time: 15:58:56
                    Voltage terminal 30: 13.5 V
                    Internal Fault ID: 29
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
End----------(Elapsed Time: 01:42, VBatt start/end: 12.1V/12.0V)-----------
Moved to Car Repair section and gave thread a more descriptive title.
A6Jim
Scotland
C?ID=353853
Thanks Uwe, spot on with this and took me 5 mins to do it :)
A6Jim
Scotland
C?ID=353853
UPDATE... Just a bit of info. These sensors seem to be a common problem, if your getting this same fault code then I'd look at these first.
I'm sure it was just the one sensor that was faulty but I replaced both just to save any hassle in future.
(Not saying this is going to be the cause on all occasions but it's certainly the cheaper option)
I got both genuine VAG sensors for £65 online compared with Audi who wanted £72 each.
Also managed to get the adaption done in VCDS by going in to Engine then Basic Settings and there's a drop down menu in there.
Hope this helps anyone with same problem.
