VW Treg 2010 7P Retrofit Hella Bixenon LED Headlights Help Required
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Hi Guys,
I am from Kenya and proud owner of my 2nd Treg which is 2010 7P imported from the UK around March 2017. I needed some assistance as tried to check on several forums threads but without success as did retrofit of Hella Bixenon LED Headlights 1ZS 010 328-061 & 1ZS 010 328-051/VW OEM 7P1941751/7P1941752which bought from the UK and replaced the factory fitted halogen and took a while with my local mechanic to have them operational but not full functional as the cornering lights function doesn't work at all and also at night they seem very weak and not well lit and range seems off as dipped facing down the road almost two metres from the car.What could be the issue with the cornering function and range and brightness? Is there coding to be done to resolve all the mentioned issues ie. cornering function when steer and brightness and also range? Also what would be the coding required once installed the Bixenon LED headlights so everything works fine, DRL,indicator,beam,full etc? According to Kufatec the current BCM1 should be compatible with Xenon headlights as they advised but seems something is amiss as when autoscan was done cannot locate address 55 which pertains to headlight range and adjustment etc.
Can someone save me as spent some good cash getting the headlights and also sent for BCM1 highline just in case is required.All this should not go down in vain! I need a miracle!
Thanks to advise and share feedback and below is last autoscan.
Removed.   Data from a clone/pirate copy of VCDS is not welcome here.
Viking
C?ID=151455
If you're determined to get this working then I'd suggest updating your VCDS first off.
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Thanks Viking, to which version would you suggest so can kick start to try and salvage the situation?:)
langers2k
C?ID=224085
The latest as always, can be found here: https://www.ross-tech.com/vcds/download/current.php
Currently that's 19.6.2.
That being said, my guess is you (or your mechanic) haven't fitted the AFS master/range controller so you should buy one and wire it up as per the factory wiring diagrams...
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Hi langers2k,
Thanks, my mechanic has confirmed has latest 19.6.2 Regards to the AFS master/range controller confirm if that is part number 7P6 907 357 C as this is what have with me in case need to buy that share the part number and possible factory wiring diagrams as sourced this from supplier who didn't share the wiring diagram unfortunately:(
Viking
C?ID=151455
Please post an autoscan using the latest VCDS version.
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
will share autoscan using latest VCDS version on Friday
So who owns the clone/pirate copy you posted the first scan from?
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
am afraid that was mine which bought from supplier few weeks ago..:rolleyes: need to get latest version with cable asap..
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
can anyone share link for wiring instructions for the Complete kit Bi-xenon headlights with cornering light for VW Touareg 7P Kufatec kit which includes the AFS master/range controller, thanks.
Viking
C?ID=151455
Really need to see a complete autoscan from your latest VCDS version. Given that support is reserved for genuine Ross Tech customers (not for pirated or cloned versions of their product) this is a real important step for you to take. The fact that you've posted a scan from a pirated version isn't helping your cause much, so I'd be inclined to try improving your forum status before asking for much further assistance.
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Hi Guys,
We managed to install both level sensors on front and back and also AFS master/range controller and BCM 1 highline which now parking lights work but the AFS not visible on address 55 on VCDS. I have attached below latest scan done few minutes ago. Can issue be related to hardware for the AFS unit 7P6 907 357 C, should this be different version to be able to pick in VCDS? Anyone can assist and troubleshoot as would appreciate.
Tuesday,05,November,2019,20:10:55:38498
VIN: WVGZZZ7PZBD010957   License Plate: KCK577Z 5TH NOV 2019
Mileage: 221892km-137877mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 42 46 52 53 56 5F 62
          6C 6D 72
VIN: WVGZZZ7PZBD010957   Mileage: 221892km-137877miles
0E-Media Player 1 -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Cannot be reached 0100
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H15 0005
   Revision: 51H15---
   Coding: 292A4012232601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401 002007
   ROD: EV_ECM30TDI0117P0907401.rod
   VCID: 6C81C3F2E602914705F-8038
   Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
   Component: AL1000 AISIN  001 1714
   Coding: 001568
   Shop #: WSC 99999 999 83333
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 313F128601A03CAF769-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 G    HW: 7P0 907 379 A
   Component: MK25A         H33 0421
   Revision: --------    Serial number: 417800010EC010
   Coding: 5B6B13C349252553DAFDC89892D9A4507700
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 41DF4246B100AC2F869-8014
   Part No SW: 4H0 907 064 AM    HW: 4H0 907 064 J
   Component: BCM2 2.0      H13 0208
   Coding: 01B60000000000000000
   VCID: 74B1DB92BEB24987DDF-8020
   Subsystem 1 - Part No SW: 7P6 959 754 L    HW: 7P6 959 754 L
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0510000035589007
   Serial number: 0210000079781011
                    Fault Status: 00101101
                    Reset counter: 146
                    Mileage: 220737 km
                    Date: 2019.09.29
                    Time: 15:15:25
   Part No SW: 7P6 907 040 AA    HW: 7P6 907 040 AA
   Component: Klima 2 Zonen H18 0511
   Coding: B626000890
   VCID: 73B3D88EBB3C4EBFC45-8026
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H11 0083
   Revision: 15011002    Serial number: 00000000719156
   Coding: 26001011C1345D010005000300001D0D431D470807000241000000000000
   VCID: 290FFAE629F0446FBE9-807C
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 955 120
   Component: WWS    100621  31  0020
   Serial number: 90243401100622045945
   Coding: 004DBD
   Component: RLFS  H09 0011
   Serial number: 10034527
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
   Component: E1 - LDS  H04 0031
   Serial number: 00000000002503100271
01757 - Headlight Washer Pump (V11)
                    Reset counter: 102
                    Mileage: 221809 km
                    Date: 2019.11.03
                    Time: 03:24:00
01771 - Control Module for Headlight Range (J431)
                    Reset counter: 98
                    Mileage: 221719 km
                    Date: 2019.10.29
                    Time: 12:09:00
Address 0E: Media Player 1
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 38941016801832
   Coding: 508501
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 55F786165588308FCA1-8000
Address 13: Auto Dist. Reg
   Part No SW: 7P0 959 655 A    HW: 7P0 959 655 A
   Component: VW10Airbag07K H05 0020
   Revision: --------    Serial number: 003FH000MC0Q
   Coding: 00000000000000000000000000000000374B
   VCID: 3FDB44BEC7F4DADFF0D-806A
   Serial number: 3575LRB405T0IRE2D9G1
   Serial number: 3585LRB405J6U4L27P9/
   Serial number: 3515RRB405L6T8MI59NE
   Serial number: 3525RRB405F6T8MI60L%
   Serial number: 3555NRB405F6NG4ENP87
   Serial number: 3565NRB40536P1I8L076
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JG70000O
   Coding: 000015
   VCID: 313F128601203CAF769-8064
   Serial number: 0017990
   Part No SW: 7P6 920 980 G    HW: 7P6 920 980 G
   Component: Kombi         H09 0114
   Revision: 08140052    Serial number: 658120710593027
   Coding: 2727310022002600010004
   ASAM Dataset: EV_KombiUDSRBVW526 001011
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 40D94742BA0AA527897-8014
   Part No SW: 7P6 907 530 A    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5179
   Revision: --------    Serial number: 00000000024384
   Coding: 0001035600
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_GatewVW526UDS 001005
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3635219AE8CE1B9723B-8062
   Serial number: 00000000005659148853
5807 - Rear View Camera System Control Module
          U104C 00 [009] - No communication
                    Reset counter: 98
                    Mileage: 221719 km
                    Date: 2019.10.29
                    Time: 12:08:37
                    Voltage terminal 30: 13.7 V
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 37 �C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
                    Reset counter: 142
                    Mileage: 221814 km
                    Date: 2019.11.03
                    Time: 11:29:44
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 38 �C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 98
                    Mileage: 221719 km
                    Date: 2019.10.29
                    Time: 12:21:24
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
0276 - FlexRay Databus
          U1032 00 [009] - Initialization Failed
                    Reset counter: 98
                    Mileage: 221719 km
                    Date: 2019.10.29
                    Time: 12:08:37
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000105978296
   Coding: 011D0620D001451005080002
   VCID: 3C2133B2D662C1C7D5F-8068
   Revision: 00002001    Serial number: 0132336216
   Coding: 011B162228B9108083200624000000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
                    Reset counter: 146
                    Mileage: 220737 km
                    Date: 2019.09.29
                    Time: 15:15:25
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000105673203
   Coding: 011D0620D001451005080000
   VCID: 3B2330AED36CC6FFDC5-806E
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Component: EPB           H51 1000
   Revision: 00000000    Serial number: A10627001DE
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 34311B92FEB209871DF-8060
   Slave 3:
Address 56: Radio
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000106248638
   Coding: 011C06200001251005080000
   VCID: 3A2D35AADC56FFF7C73-806E
Address 6C: Back-up Cam.
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 169500763
   Coding: 0523310002
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
0004 - No Basic Setting
          B2010 00 [137] - -
          [Steuerger�t nicht kalibriert]
                    Reset counter: 98
                    Mileage: 221719 km
                    Date: 2019.10.29
                    Time: 12:08:37
                    Voltage terminal 30: 13.71 V
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000106248443
End----------(Elapsed Time: 01:35, VBatt start/end: 12.0V/12.0V)-----------
OP is now Verified. Moving to Retrofits.
Dana
Western PA, USA
Although 7P6 907 357 was likely the original 55 module for this model year vehicle it supers to 7P6 907 357 C so that should be compatible. It isn't communicating so that will need to be addressed but I would add 55 using the [Installation List] function in VCDS in the meanwhile:
https://www.ross-tech.com/vcds/tour/installation-list.php
This car was born with 8T1 Cruise control system (CCS) (i.e. conventional CCS) so your installation list should NOT have 13-Auto Dist. Reg -- Status: Cannot be reached 0100. Likewise, I don't believe 0E-Media Player 1 -- Status: Cannot be reached 0100 would be installed in this vehicle either so removing those when you add 55 isn't a bad idea.
If you need assistance with the wiring of 55 please let us know which current flow wiring diagram number you are using.
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Hello Dana,
Let me try and see if address 55 will be visible on the installation list function in VCDS to be able to check/tick the box and see what happens, will revert with feedback tomorrow, thanks.
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Hello Dana,
I checked on the installation list and can confirm address 55 already shows as ticked, also removed the two 13 & 0E as you advised. I am still wondering why the unit isn't communicating, will check wiring diagram from vendor and share for the instal. Below is latest scan done.
Saturday,14,December,2019,13:08:53:38498
VIN:    License Plate: KCK577Z 14_12_2019
Chassis Type: 7P6
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          6D 72
01-Engine -- Status: Cannot be reached 0100
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
04-Steering Angle -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Malfunction 0110
08-Auto HVAC -- Status: Cannot be reached 0100
09-Cent. Elect. -- Status: Malfunction 0110
10-Park/Steer Assist -- Status: Cannot be reached 0100
15-Airbags -- Status: Cannot be reached 0100
16-Steering wheel -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: Cannot be reached 0100
46-Central Conv. -- Status: Malfunction 0110
52-Door Elect, Pass. -- Status: Malfunction 0110
53-Parking Brake -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Cannot be reached 0100
62-Door, Rear Left -- Status: Cannot be reached 0100
6D-Trunk Elect. -- Status: Malfunction 0110
72-Door, Rear Right -- Status: Cannot be reached 0100
Address 01: Engine
Address 15: Airbags
   Coding: 0001035600
5013 - Headlight Range Control Module
          U101E 00 [009] - No Communication
                    Reset counter: 157
                    Mileage: 222634 km
                    Date: 2019.12.06
                    Time: 13:03:35
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 41 �C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 157
                    Mileage: 222634 km
                    Date: 2019.12.06
                    Time: 13:03:36
                    Voltage terminal 30: 14.4 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0259 - Extended CAN Bus (SAE Bus C)
          U0047 00 [009] - Performance
          [Vehicle Communication Bus C Bus Performance]
                    Reset counter: 157
                    Mileage: 222634 km
                    Date: 2019.12.06
                    Time: 13:03:35
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
Address 55: Headlight Range
   Part No SW: 4F0 035 061 H    HW: 4F0 035 061
   Component: Radio U DAB   H46 0048
   Revision: AB001007    Serial number: 006DN0A7506216
   Coding: 010105020000000001
   VCID: 211FE2C651C08C2FE69-8074
   Part No SW: 7P6 035 666     HW: 7P6 035 666
   Component: H-BN-EU       H43 0203
   Revision: --------    Serial number: 446GZ0A7508432
   Coding: 010101050040E94F01000B0E00000003F0000101
   Shop #: WSC 00771 210 91785
   VCID: 77ABEC9EAFC4229FF8D-8022
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H23 0045
   Serial number: VWZ8Z9K280010V
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 191
                    Mileage: 222595 km
                    Date: 2019.12.02
                    Time: 12:03:47
                    Voltage: 12.10 V
                    Reset counter: 147
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 12:56:05
                    Bin. Bits: 00001000 10100000
                    Bin. Bits: 00000000 00000000
02169 - Front Right Microphone (R141)
                    Reset counter: 147
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 12:55:59
                    Voltage: 14.30 V
End----(Elapsed Time: 00:42, VBatt start/end: 12.6V/12.6V. VIgn 0.0V)------
The scan would be more useful/informative if it were done with the ignition on. ;)
wesiroyo
Verified VCDS-User
Kenya
C?ID=384594
Hi Uwe,
Yes indeed..my bad... please find scan below.
Saturday,14,December,2019,19:01:58:38498
VIN: WVGZZZ7PZBD010957   License Plate: KCK577Z 1902HRS
Mileage: 222642km-138343mi   Repair Order:
          6D 72
VIN: WVGZZZ7PZBD010957   Mileage: 222642km-138343miles
   Revision: 51H15---
   Coding: 001568
                    Fault Frequency: 98
                    Reset counter: 199
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 13:01:55
   Coding: B626000890
   Component: BCM1 2.0      H09 0083
   Revision: 15009001    Serial number: 00000000398205
   Coding: 26001011D1345F010805000300005D0C431D470807010241000000020000
   Coding: 004DBD
   Coding: 035223
                    Reset counter: 154
                    Mileage: 222611 km
                    Date: 2019.12.03
                    Time: 22:51:00
                    Reset counter: 151
                    Mileage: 222595 km
                    Date: 2019.12.02
                    Time: 15:03:00
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 151
                    Mileage: 222595 km
                    Date: 2019.12.02
                    Time: 15:03:00
   Coding: 508501
   Coding: 000015
   Coding: 0001035600
                    Reset counter: 157
                    Mileage: 222634 km
                    Date: 2019.12.06
                    Time: 13:03:35
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 157
                    Mileage: 222634 km
                    Date: 2019.12.06
                    Time: 13:03:36
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 157
                    Mileage: 222634 km
                    Date: 2019.12.06
                    Time: 13:03:35
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Fault Frequency: 97
                    Reset counter: 199
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 13:01:55
                    Reset counter: 191
                    Mileage: 222595 km
                    Date: 2019.12.02
                    Time: 12:03:47
                    Reset counter: 191
                    Reset counter: 191
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   Slave 3:
                    Reset counter: 191
                    Mileage: 222595 km
                    Date: 2019.12.02
                    Time: 12:03:47
                    Voltage: 12.10 V
                    Reset counter: 147
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 12:56:05
                    Reset counter: 147
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 12:55:59
                    Voltage: 14.30 V
   Coding: 0523310002
          B2010 00 [137] - -
                    Reset counter: 147
                    Mileage: 222539 km
                    Date: 2019.11.29
                    Time: 12:55:54
                    Voltage terminal 30: 14.25 V
End----------(Elapsed Time: 01:49, VBatt start/end: 14.1V/14.3V)-----------
OK, so neither the CAN gateway nor VCDS can talk to 55-Headlight Range.
Possibilities are: A wiring or power problem, or a bad Headlight Range module.
