Results 11 to 20 of 21
Thread: VW Treg 2010 7P Retrofit Hella Bixenon LED Headlights Help Required
    Nov 2015
    Really need to see a complete autoscan from your latest VCDS version. Given that support is reserved for genuine Ross Tech customers (not for pirated or cloned versions of their product) this is a real important step for you to take. The fact that you've posted a scan from a pirated version isn't helping your cause much, so I'd be inclined to try improving your forum status before asking for much further assistance.
  2. Likes PetrolDave, Uwe, Dana liked this post
  3. #12
    Quote Originally Posted by wesiroyo View Post
    can anyone share link for wiring instructions for the Complete kit Bi-xenon headlights with cornering light for VW Touareg 7P Kufatec kit which includes the AFS master/range controller, thanks.
    If you need a wiring diagram for a Kufatec kit, I suggest contacting Kufatec.
    If you need a factory wiring diagram, please see: Where do I get a Wiring-Diagram?.
  4. Likes Dana liked this post
  5. #13
    Verified VCDS-User
    Oct 2019
    Kenya
    Hi Guys,
    We managed to install both level sensors on front and back and also AFS master/range controller and BCM 1 highline which now parking lights work but the AFS not visible on address 55 on VCDS. I have attached below latest scan done few minutes ago. Can issue be related to hardware for the AFS unit 7P6 907 357 C, should this be different version to be able to pick in VCDS? Anyone can assist and troubleshoot as would appreciate.
    Tuesday,05,November,2019,20:10:55:38498
    VIN: WVGZZZ7PZBD010957   License Plate: KCK577Z 5TH NOV 2019
    Mileage: 221892km-137877mi   Repair Order:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 42 46 52 53 56 5F 62
              6C 6D 72
    VIN: WVGZZZ7PZBD010957   Mileage: 221892km-137877miles
    0E-Media Player 1 -- Status: Cannot be reached 0100
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    17-Instruments -- Status: Cannot be reached 0100
    56-Radio -- Status: Cannot be reached 0100
    5F-Information Electr. -- Status: Cannot be reached 0100
    6C-Back-up Cam. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
       Part No SW: 7P0 907 401     HW: 7P0 907 401
       Component: 3.0TDI EDC17  H15 0005
       Revision: 51H15---
       Coding: 292A4012232601020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0117P0907401 002007
       ROD: EV_ECM30TDI0117P0907401.rod
       VCID: 6C81C3F2E602914705F-8038
       Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
       Component: AL1000 AISIN  001 1714
       Coding: 001568
       Shop #: WSC 99999 999 83333
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031_001_VW52.rod
       VCID: 313F128601A03CAF769-8064
    Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
       Part No SW: 7P0 907 379 G    HW: 7P0 907 379 A
       Component: MK25A         H33 0421
       Revision: --------    Serial number: 417800010EC010
       Coding: 5B6B13C349252553DAFDC89892D9A4507700
       ASAM Dataset: EV_MK25AXT 007001
       ROD: EV_ESPMK25A00700.rod
       VCID: 41DF4246B100AC2F869-8014
       Part No SW: 4H0 907 064 AM    HW: 4H0 907 064 J
       Component: BCM2 2.0      H13 0208
       Coding: 01B60000000000000000
       VCID: 74B1DB92BEB24987DDF-8020
       Subsystem 1 - Part No SW: 7P6 959 754 L    HW: 7P6 959 754 L
       Component: FBSTOUAREGIDG  H05 0051
       Serial number: 0510000035589007
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
       Serial number: 0210000079781011
                        Fault Status: 00101101
                        Reset counter: 146
                        Mileage: 220737 km
                        Date: 2019.09.29
                        Time: 15:15:25
       Part No SW: 7P6 907 040 AA    HW: 7P6 907 040 AA
       Component: Klima 2 Zonen H18 0511
       Coding: B626000890
       VCID: 73B3D88EBB3C4EBFC45-8026
       Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
       Component: BCM1 2.0      H11 0083
       Revision: 15011002    Serial number: 00000000719156
       Coding: 26001011C1345D010005000300001D0D431D470807000241000000000000
       VCID: 290FFAE629F0446FBE9-807C
       Subsystem 1 - Part No SW: 7P0 955 120     HW: 955 120
       Component: WWS    100621  31  0020
       Serial number: 90243401100622045945
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
       Component: RLFS  H09 0011
       Serial number: 10034527
       Coding: 035223
       Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
       Component: E1 - LDS  H04 0031
       Serial number: 00000000002503100271
    01757 - Headlight Washer Pump (V11)
                        Fault Status: 01101100
                        Reset counter: 102
                        Mileage: 221809 km
                        Date: 2019.11.03
                        Time: 03:24:00
                        Reset counter: 98
                        Mileage: 221719 km
                        Date: 2019.10.29
                        Time: 12:09:00
    Address 0E: Media Player 1
    Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
       Part No SW: 7P6 919 475     HW: 7P6 919 475
       Component: PARKHILFE 8K  H03 0016
       Revision: --------    Serial number: 38941016801832
       Coding: 508501
       ASAM Dataset: EV_VW526ParkiAssis2 001008
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 55F786165588308FCA1-8000
    Address 13: Auto Dist. Reg
       Part No SW: 7P0 959 655 A    HW: 7P0 959 655 A
       Component: VW10Airbag07K H05 0020
       Revision: --------    Serial number: 003FH000MC0Q
       Coding: 00000000000000000000000000000000374B
       ROD: EV_AirbaVW10BPAVW526_001.rod
       VCID: 3FDB44BEC7F4DADFF0D-806A
       Serial number: 3575LRB405T0IRE2D9G1
       Serial number: 3585LRB405J6U4L27P9/
       Serial number: 3515RRB405L6T8MI59NE
       Serial number: 3525RRB405F6T8MI60L%
       Serial number: 3555NRB405F6NG4ENP87
       Serial number: 3565NRB40536P1I8L076
       Part No SW: 4H0 953 568 A    HW: 7P6 953 507
       Component: Lenks.Modul   H07 0007
       Revision: --------    Serial number: 90815JG70000O
       Coding: 000015
       VCID: 313F128601203CAF769-8064
       Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
       Component: E221__MFL-TAS  H03 0027
       Serial number: 0017990
    Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
       Part No SW: 7P6 920 980 G    HW: 7P6 920 980 G
       Component: Kombi         H09 0114
       Revision: 08140052    Serial number: 658120710593027
       Coding: 2727310022002600010004
       ASAM Dataset: EV_KombiUDSRBVW526 001011
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 40D94742BA0AA527897-8014
       Part No SW: 7P6 907 530 A    HW: 7P6 907 530 A
       Component: GW-CAN-L-MOST H08 5179
       Revision: --------    Serial number: 00000000024384
       Coding: 0001035600
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_GatewVW526UDS 001005
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3635219AE8CE1B9723B-8062
       Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0140
       Serial number: 00000000005659148853
    5807 - Rear View Camera System Control Module
              U104C 00 [009] - No communication
                        Reset counter: 98
                        Mileage: 221719 km
                        Date: 2019.10.29
                        Time: 12:08:37
                        Voltage terminal 30: 13.7 V
                        Voltage terminal 15: 13.7 V
                        Control Module temperature: 37 �C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    4224 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
                        Reset counter: 142
                        Mileage: 221814 km
                        Date: 2019.11.03
                        Time: 11:29:44
                        Voltage terminal 30: 12.2 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 38 �C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
    0267 - Optical data bus
              U1049 00 [009] - Open circuit
                        Reset counter: 98
                        Mileage: 221719 km
                        Date: 2019.10.29
                        Time: 12:21:24
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 0
    0276 - FlexRay Databus
              U1032 00 [009] - Initialization Failed
                        Reset counter: 98
                        Mileage: 221719 km
                        Date: 2019.10.29
                        Time: 12:08:37
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
       Component: TSG FA        H07 0162
       Revision: --------    Serial number: 0000105978296
       Coding: 011D0620D001451005080002
       VCID: 3C2133B2D662C1C7D5F-8068
       Revision: 00002001    Serial number: 0132336216
       Coding: 011B162228B9108083200624000000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
    01316 - ABS Control Module
                        Reset counter: 146
                        Mileage: 220737 km
                        Date: 2019.09.29
                        Time: 15:15:25
       Component: TSG BF        H07 0162
       Revision: --------    Serial number: 0000105673203
       Coding: 011D0620D001451005080000
       VCID: 3B2330AED36CC6FFDC5-806E
       Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
       Component: EPB           H51 1000
       Revision: 00000000    Serial number: A10627001DE
       Coding: 01040000
       ROD: EV_ParkbA7.rod
       VCID: 34311B92FEB209871DF-8060
       Slave 3:
    Address 56: Radio
       Component: TSG HL        H09 0162
       Revision: --------    Serial number: 0000106248638
       Coding: 011C06200001251005080000
       VCID: 3A2D35AADC56FFF7C73-806E
    Address 6C: Back-up Cam.
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 169500763
       Coding: 0523310002
       ROD: EV_HeckkTouar.rod
    0004 - No Basic Setting
              B2010 00 [137] - -
              [Steuerger�t nicht kalibriert]
                        Reset counter: 98
                        Mileage: 221719 km
                        Date: 2019.10.29
                        Time: 12:08:37
                        Voltage terminal 30: 13.71 V
       Component: TSG HR        H09 0162
       Revision: --------    Serial number: 0000106248443
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.0V/12.0V)-----------
  6. Likes Uwe liked this post
  7. #14
    OP is now Verified. Moving to Retrofits.
  8. Likes Dana liked this post
  9. #15
    United States
    Although 7P6 907 357 was likely the original 55 module for this model year vehicle it supers to 7P6 907 357 C so that should be compatible. It isn't communicating so that will need to be addressed but I would add 55 using the [Installation List] function in VCDS in the meanwhile:
    https://www.ross-tech.com/vcds/tour/...ation-list.php
    This car was born with 8T1 Cruise control system (CCS) (i.e. conventional CCS) so your installation list should NOT have 13-Auto Dist. Reg -- Status: Cannot be reached 0100. Likewise, I don't believe 0E-Media Player 1 -- Status: Cannot be reached 0100 would be installed in this vehicle either so removing those when you add 55 isn't a bad idea.
    If you need assistance with the wiring of 55 please let us know which current flow wiring diagram number you are using.
  10. Likes Uwe liked this post
  11. #16
    Verified VCDS-User
    Oct 2019
    Kenya
    Hello Dana,
    Let me try and see if address 55 will be visible on the installation list function in VCDS to be able to check/tick the box and see what happens, will revert with feedback tomorrow, thanks.
  12. Likes Dana liked this post
  13. #17
    Verified VCDS-User
    Oct 2019
    Kenya
    Hello Dana,
    I checked on the installation list and can confirm address 55 already shows as ticked, also removed the two 13 & 0E as you advised. I am still wondering why the unit isn't communicating, will check wiring diagram from vendor and share for the instal. Below is latest scan done.
    Saturday,14,December,2019,13:08:53:38498
    VIN:    License Plate: KCK577Z 14_12_2019
    Chassis Type: 7P6
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
              6D 72
    01-Engine -- Status: Cannot be reached 0100
    02-Auto Trans -- Status: Cannot be reached 0100
    03-ABS Brakes -- Status: Cannot be reached 0100
    04-Steering Angle -- Status: Cannot be reached 0100
    05-Acc/Start Auth. -- Status: Malfunction 0110
    08-Auto HVAC -- Status: Cannot be reached 0100
    09-Cent. Elect. -- Status: Malfunction 0110
    10-Park/Steer Assist -- Status: Cannot be reached 0100
    15-Airbags -- Status: Cannot be reached 0100
    16-Steering wheel -- Status: Cannot be reached 0100
    42-Door Elect, Driver -- Status: Cannot be reached 0100
    46-Central Conv. -- Status: Malfunction 0110
    52-Door Elect, Pass. -- Status: Malfunction 0110
    53-Parking Brake -- Status: Cannot be reached 0100
    55-Headlight Range -- Status: Cannot be reached 0100
    62-Door, Rear Left -- Status: Cannot be reached 0100
    6D-Trunk Elect. -- Status: Malfunction 0110
    72-Door, Rear Right -- Status: Cannot be reached 0100
    Address 01: Engine
    Unable to communicate with address 09. Are you sure the doors are unlocked?
    Address 15: Airbags
       Coding: 0001035600
    5013 - Headlight Range Control Module
              U101E 00 [009] - No Communication
                        Reset counter: 157
                        Mileage: 222634 km
                        Date: 2019.12.06
                        Time: 13:03:35
                        Voltage terminal 30: 14.5 V
                        Voltage terminal 15: 14.4 V
                        Control Module temperature: 41 �C
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
                        Reset counter: 157
                        Mileage: 222634 km
                        Date: 2019.12.06
                        Time: 13:03:36
                        Voltage terminal 30: 14.4 V
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    0259 - Extended CAN Bus (SAE Bus C)
              U0047 00 [009] - Performance
              [Vehicle Communication Bus C Bus Performance]
                        Reset counter: 157
                        Mileage: 222634 km
                        Date: 2019.12.06
                        Time: 13:03:35
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 55: Headlight Range
       Part No SW: 4F0 035 061 H    HW: 4F0 035 061
       Component: Radio U DAB   H46 0048
       Revision: AB001007    Serial number: 006DN0A7506216
       Coding: 010105020000000001
       VCID: 211FE2C651C08C2FE69-8074
       Part No SW: 7P6 035 666     HW: 7P6 035 666
       Component: H-BN-EU       H43 0203
       Revision: --------    Serial number: 446GZ0A7508432
       Coding: 010101050040E94F01000B0E00000003F0000101
       Shop #: WSC 00771 210 91785
       VCID: 77ABEC9EAFC4229FF8D-8022
       Subsystem 1 - Part No: 8R0 060 884 R
       Component: EUR 2010  1106
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H23 0045
       Serial number: VWZ8Z9K280010V
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: CD-Database  1886
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 191
                        Mileage: 222595 km
                        Date: 2019.12.02
                        Time: 12:03:47
                        Voltage: 12.10 V
                        Reset counter: 147
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 12:56:05
                        Bin. Bits: 00001000 10100000
                        Bin. Bits: 00000000 00000000
    02169 - Front Right Microphone (R141)
                        Fault Status: 01101011
                        Reset counter: 147
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 12:55:59
                        Voltage: 14.30 V
    End----(Elapsed Time: 00:42, VBatt start/end: 12.6V/12.6V. VIgn 0.0V)------
  14. #18
    The scan would be more useful/informative if it were done with the ignition on.
  15. Likes PetrolDave liked this post
  16. #19
    Verified VCDS-User
    Oct 2019
    Kenya
    Hi Uwe,
    Yes indeed..my bad... please find scan below.
    Saturday,14,December,2019,19:01:58:38498
    VIN: WVGZZZ7PZBD010957   License Plate: KCK577Z 1902HRS
    Mileage: 222642km-138343mi   Repair Order:
              6D 72
    VIN: WVGZZZ7PZBD010957   Mileage: 222642km-138343miles
       Revision: 51H15---
       Coding: 001568
                        Fault Frequency: 98
                        Reset counter: 199
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 13:01:55
       Coding: B626000890
       Component: BCM1 2.0      H09 0083
       Revision: 15009001    Serial number: 00000000398205
       Coding: 26001011D1345F010805000300005D0C431D470807010241000000020000
       Shop #: WSC 02391 785 00200
       Coding: 004DBD
       Coding: 035223
                        Reset counter: 154
                        Mileage: 222611 km
                        Date: 2019.12.03
                        Time: 22:51:00
                        Reset counter: 151
                        Mileage: 222595 km
                        Date: 2019.12.02
                        Time: 15:03:00
    00471 - Control Module for Elect. Regulated Dampers (J250)
                        Reset counter: 151
                        Mileage: 222595 km
                        Date: 2019.12.02
                        Time: 15:03:00
       Coding: 508501
       Coding: 000015
       Coding: 0001035600
                        Reset counter: 157
                        Mileage: 222634 km
                        Date: 2019.12.06
                        Time: 13:03:35
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
                        Reset counter: 157
                        Mileage: 222634 km
                        Date: 2019.12.06
                        Time: 13:03:36
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
                        Reset counter: 157
                        Mileage: 222634 km
                        Date: 2019.12.06
                        Time: 13:03:35
                        Engine running: On
                        IN ZAS_Te_X: On
                        Datenfeld: 0
                        Fault Frequency: 97
                        Reset counter: 199
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 13:01:55
                        Reset counter: 191
                        Mileage: 222595 km
                        Date: 2019.12.02
                        Time: 12:03:47
                        Reset counter: 191
                        Reset counter: 191
       Coding: 01040000
       ROD: EV_ParkbA7.rod
       Slave 3:
                        Reset counter: 191
                        Mileage: 222595 km
                        Date: 2019.12.02
                        Time: 12:03:47
                        Voltage: 12.10 V
                        Reset counter: 147
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 12:56:05
                        Reset counter: 147
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 12:55:59
                        Voltage: 14.30 V
       Coding: 0523310002
              B2010 00 [137] - -
                        Reset counter: 147
                        Mileage: 222539 km
                        Date: 2019.11.29
                        Time: 12:55:54
                        Voltage terminal 30: 14.25 V
    End----------(Elapsed Time: 01:49, VBatt start/end: 14.1V/14.3V)-----------
  17. #20
    OK, so neither the CAN gateway nor VCDS can talk to 55-Headlight Range.
    Possibilities are: A wiring or power problem, or a bad Headlight Range module.
