Results 1 to 3 of 3
Thread: 2015 Audi A6 Scan
    Aug 2019
    2015 Audi A6 Scan
    Does anyone know what the Tire pressure warning means, and does it indicate a tire or the whole system? I'm guessing the key fault is a low battery? I had the pcv valve and breather hose changed, didn't throw a code for 2 weeks and then came back
    Monday,14,October,2019,17:58:15:32728
    VIN: WAUHGAFC8FN028305   License Plate:
    Mileage: 172550km-107217mi   Repair Order:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 3C 42 44 46 47 52
              53 55 56 5F 62 6C 72 82 8F 90
    VIN: WAUHGAFC8FN028305   Mileage: 172550km-107217miles
    Address 01: Engine (J623-CTUA)       Labels: None
       Part No SW: 4G0 907 551 J    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0004
       Revision: --H07---
       Coding: 0A2A0034052601060000
       ASAM Dataset: EV_ECM30TFS0214G0907551J 001004
       ROD: EV_ECM30TFS0214G0907551J.rod
       VCID: 303911F60AA4AE077A9-8064
    20136 - PCV Valve Malfunction
              P052E 00 [096] - -
                        Mileage: 170852 km
                        Date: 2019.10.04
                        Time: 16:05:05
                        Engine speed: 707.00 /min
                        Normed load value: 14.5 %
                        Coolant temperature: 88 ∞C
                        Intake air temperature: 71 ∞C
                        Voltage terminal 30: 13.913 V
                        Unlearning counter according OBD: 22
                        Engine speed: actual: 672 /min
                        MAF_ENVD: 147.07058 mg/stroke
                        Coolant temperature (unfiltered): 88.50 ∞C
                        Engine: operating status: IS
                        Engine load: 14.453125 %
                        Vehicle speed: actual: 0 km/h
       Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H19 1006
       Revision: --H19---
       Coding: 000002
       VCID: 2D0708821D96C3EF51F-8078
       Coding: 44A7970122E5E9804B00
       VCID: 3A2D33DEDCD86457C4D-806E
    0629 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 204
                        Mileage: 169692 km
                        Date: 2019.09.27
                        Time: 18:35:48
                        VzRef: 67
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 30
                        Uz: B5
       Part No SW: 4H0 907 064 FR    HW: 4H0 907 064 ER
       Component: BCM2 2.0      H36 0551
       Coding: 0DA82046000000000000
       VCID: 7EA5FFCE80F08877B85-802A
       Serial number: 3214000109154003
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 172
                        Mileage: 170394 km
                        Date: 2019.10.01
                        Time: 10:36:09
       Part No SW: 4G0 820 043 AN    HW: 4G0 820 043 AN
       Component: KLIMA 4 ZONEN H14 0096
       Serial number: 10101400040430
       Coding: 6601207A59
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6B83C69AE3020DDF0FB-803E
       Revision: 11012002    Serial number: 00000001940217
       Coding: 09072091073C9FE081000884A0003800CF9CD208A60802258001085C7B00
       VCID: 6FBBD28AD79AF1FF233-803A
       Component: WWS57X 140923  H37 0080
       Serial number:         140926220152
       Coding: 0045F7
       Serial number: 23305602
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
       Component: E1 - LDS  H07 0044
       Serial number: 10 10 2014  00001012
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z009D7FB0
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0116263591
       Coding: 853000
       Serial number: 00000010101400010344
       Coding: 110000
       Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000003101400010252
       Coding: 110000
       Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA109324000009531512
       Coding: 020300
       Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 54298F47000000000001
       Revision: 11001001    Serial number: 61061428301959
       Coding: A8C306
       VCID: 71BFD4F2C12EE70F357-8024
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G0001GR3N
       Coding: 303331343131303134354A55304C34473053
       VCID: 34311DE6FEBC92271E1-8060
       Serial number: 6940000Y14000188UC0V
       Serial number: 3575HRB405D2R8PE1OI1
       Serial number: 3585HRB40592OJSO5GEB
       Serial number: 3515JRB405731BAK58N$
       Serial number: 3525JRB405P31BAKM0IJ
       Serial number: 3554VRB400S52QV49PMR
       Serial number: 3564VRB400S52QV4DHMO
       Revision: 00000000    Serial number: 20141013000558
       Coding: 000034
       VCID: 303911F60A24AE077A9-8064
       Part No SW: 4G8 920 984 K    HW: 4G8 920 984 K
       Component: TBenUsa       H58 0622
       Revision: 29460237    Serial number: 658031014596001
       Coding: 0BE609040B41D705020000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 3E253FCEC0F04877F85-806A
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001593792
       Coding: 00CD073000
       VCID: 72BDDBFEC428DC17CCD-8026
       Serial number: 4462254703
       Voltage stabilizer:
       Serial number: 140728000000000005EA
       Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
       Component: KLIMA FOND    H08 0096
       Serial number: 13101400041130
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 392F2CD2D9DE6F4FCD7-806C
       Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
       Revision: AA000000    Serial number: 00000119630086
       Coding: C0581B008F006001000001010101102030303232203232
       VCID: 382929D6E2547647329-806C
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA720CZHVC
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 33331EFAFBB2951F07B-8066
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH05 0060
       Revision: 00H05000    Serial number: 6PZ 010 287-03
       VCID: 303911F60624AE077A9-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H05 0060
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F14.10.1400H05000AMS15618ˇ
       Subsystem 4 - Serial number: S15618ˇ
       Coding: 011F17005E00628002000012
       VCID: 47CB5A2A9FAA09BF4B3-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0005061713
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0349017827
       Coding: 0106023A00FA418580B0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000248754
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO33185352
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00009671957
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93350891
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 164
                        Mileage: 169598 km
                        Date: 2019.09.27
                        Time: 15:07:35
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 164
                        Mileage: 169598 km
                        Date: 2019.09.27
                        Time: 15:09:36
       Revision: CJ007001    Serial number: 00000000144697
       Coding: 030000
       VCID: 1D67D8426DB6336FC1F-8048
       Coding: 011F17005E00628002000002
       VCID: 46D5572E98A010B7B05-8012
       Revision: --------    Serial number: 00000001224328
       ROD: EV_ParkiBrake_VW51.rod
       Serial number: 141013-0002-176
       Coding: 1221A6601002A500
       ROD: EV_HeadlRegulBasic.rod
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156JB0E8079378
       Coding: 020007010000000001
       VCID: 2411EDA64EDC02A78E1-8070
       Part No SW: 4G0 035 746 G    HW: 4G0 035 746 E
       Component: H-BNT-NA      H41 0810
       Revision: --------    Serial number: 194J40E7618542
       Coding: 050200000003E5EF55128B3E00000003100001000000000000
       VCID: 2B03069A2302CDDF4FB-807E
       Subsystem 1 - Part No: 8R0 060 884 CA
       Component: NAR 2014  1002
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDED005QKA4
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349NJD000Q3
       Component: CD-Database  5950
       VCID: 49CF5C1289BEFFCF5D7-801C
       Revision: --H08---    Serial number: 525 PA8J49GAYX
       Coding: 1080004
       VCID: 2615F7AE34E0F0B7905-8072
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
       Component: HeadUpDisplay 006 0203
       Coding: A20000
       ASAM Dataset: EV_HUDContiC7 001023
       ROD: EV_HUDContiC7.rod
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F14F201AEA70F757-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 323D1BFE04A89C170CD-8066
    End----------(Elapsed Time: 02:36, VBatt start/end: 12.3V/12.3V)-----------
    Sep 2014
    Looking at your scan, I think your car uses an in-direct TPMS - it uses the wheel speed sensors in the ABS to monitor for a deflated tyre.
    I would check all of your tyre pressures are correct and then perform the calibration. In the MMI, select the CAR menu and then 'Servicing and Checks', 'Tyre Pressure Monitoring' and there will be an option to store tyre pressures. Hopefully, this will clear the TPMS fault code.
  3. Likes PetrolDave, Uwe liked this post
    Aug 2019
    All 4 tire pressures were good, never got a warning message on the dash in months.
