I'm in the process of buying a 2015 GTI that recently started having an EPC light and going into limp mode on cold starts, but once the car is restarted it runs fine. I've looked around on the forms and other people that had similar problems found it was the turbo actuator. Can anyone confirm this is the problem? Here's my VCDS results:
Thursday,10,October,2019,17:33:13:42891
VCDS Version: 19.6.2.0 (x64)
VIN: 3VW5T7AU9FM0XXXXX License Plate:
Mileage: 147314km-91536mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 20 2B 42 44 47 52 55 5F A9
VIN: 3VW5T7AU9FM0XXXXX Mileage: 147314km-91536miles
Address 01: Engine (J623-CNTA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 091900122424000F1000
Shop #: WSC 00066 790 00218
ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
ROD: EV_ECM20TFS0205G0906259A.rod
VCID: 2C57423547ACBC2F2B-8078
9 Faults Found:
15074 - Cylinder Disabling
P130A 00 [096] - -
Mileage: 147165 km
Date: 2019.10.07
Time: 15:47:44
Engine speed: 2205.25 /min
Normed load value: 10.2 %
Coolant temperature: 107 °C
Intake air temperature: 67 °C
Voltage terminal 30: 13.808 V
Unlearning counter according OBD: 36
Engine: operating status: PL
STATE_LS_SAE[1]: OL_ERR
T_AST_SAE: 6902 s
Engine oil temperature: 107.0 °C
Lambda probes actual: bank1: 0.7285
FAC_LAM_LIM[1]: -19.295 %
FUP_H_SAE: 8670.0 kPa
15125 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 147165 km
Date: 2019.10.07
Time: 15:47:24
Engine speed: 1952.00 /min
Normed load value: 6.7 %
Coolant temperature: 105 °C
Intake air temperature: 65 °C
STATE_LS_SAE[1]: CL
T_AST_SAE: 6882 s
Engine oil temperature: 106.0 °C
Lambda probes actual: bank1: 0.7266
FAC_LAM_LIM[1]: -35.001 %
FUP_H_SAE: 5390.0 kPa
15131 - Cylinder 3
P0303 00 [096] - Misfire Detected
Mileage: 147165 km
Date: 2019.10.07
Time: 15:47:24
STATE_LS_SAE[1]: CL
T_AST_SAE: 6882 s
15134 - Cylinder 4
P0304 00 [096] - Misfire Detected
Mileage: 147165 km
Date: 2019.10.07
Time: 15:47:24
STATE_LS_SAE[1]: CL
T_AST_SAE: 6882 s
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
Mileage: 147165 km
Date: 2019.10.07
Time: 15:47:24
STATE_LS_SAE[1]: CL
T_AST_SAE: 6882 s
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 147165 km
Date: 2019.10.07
Time: 15:47:24
STATE_LS_SAE[1]: CL
T_AST_SAE: 6882 s
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [104] - Implausible Signal
Fault Frequency: 10
Mileage: 146912 km
Date: 2019.09.11
Time: 00:07:49
Coolant temperature: 44 °C
Intake air temperature: 27 °C
Voltage terminal 30: 12.968 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
Charge air pressure control valve uncond voltage sensor: 2.5781 V
Charge air pressure control valve position: target value: 0.00 %
Charge air pressure control valve position: actual value: 9.10 %
Charge air pressure control valve activation pulse duty factor: -30.57 %
Charge air pressure control valve voltage: position closed: 2.8548 V
STATE_BPA[0]: AD
15029 - Fuel Trim; Bank 1
P0172 00 [096] - System Too Rich
Mileage: 147165 km
Date: 2019.10.07
Time: 15:46:44
Engine speed: 2312.00 /min
Coolant temperature: 106 °C
Voltage terminal 30: 13.769 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 6842 s
MAP_MES_SAE: 32 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.230 V
FUP_H_SAE: 5970.0 kPa
15202 - Actuator Module for Turbocharger 1
P00AF 00 [104] - Stuck
Fault Frequency: 18
Mileage: 146911 km
Date: 2019.09.07
Time: 00:57:08
Engine speed: 2169.25 /min
Vehicle speed: 72 km/h
Coolant temperature: 102 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.574 V
Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000000
Charge air pressure control valve uncond voltage sensor: 1.1572 V
Charge air pressure control valve position: target value: 80.02 %
Charge air pressure control valve position: actual value: 59.46 %
Charge air pressure control valve activation pulse duty factor: 81.81 %
STATE_BPA[0]: OPM
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 53143000000241
Coding: 01FA6BA1342009700078020781C42980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
VCID: 44870A95CF3C546FC3-8010
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 194
Mileage: 146983 km
Date: 2019.09.14
Time: 20:10:39
Revision: 00021000 Serial number: 0328644422
Coding: 030C0C
VCID: 3A7B746DBDF8129FA9-806E
Part No SW: 5G0 907 044 AD HW: 5G0 907 044 AD
Component: Climatronic H02 0805
Revision: 00001K07
Coding: 00020014200100010005000000101000
VCID: 69D9FB2188DE690710-803C
Air quality sensor:
590081 - Control Circuit for A/C Compressor
B10A9 11 [008] - Short to Ground
Reset counter: 205
Mileage: 147054 km
Date: 2019.09.17
Time: 12:16:30
Outside air temperature: 20.0 °C
Engine speed: 1100 /min
Compressor shut-off requirement: Compressor activation: malfunction in activation path
Compressor current: specified value: 0.000 A
Part No SW: 5Q0 937 087 K HW: 5Q0 937 087 K
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86580804140574
Coding: 00110B464041A2E949E44000091407201800000000000000000000000000
Shop #: WSC 00066 790 00206
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_012.rod
VCID: 43850989CA325357FA-8016
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140224 043 0581
Serial number: 140422135559
Component: RLFS 024 0042
Serial number: Y14M03D20H18M38S35S7
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO2730282+
Coding: 181801
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Fault Frequency: 7
Reset counter: 209
Mileage: 146912 km
Date: 2019.09.12
Time: 18:39:22
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM004C2$
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 51A933C1004EB1C778-8004
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. 005 0016
Serial number: IBH0000J140000MPZT09
Coding: 30325A
Subsystem 2 - Part No SW: ----------- HW: 480 002 901 14
Serial number: 35700000000F9868BE00
Subsystem 3 - Part No SW: ----------- HW: 480 003 101 14
Serial number: 35800000000D833D9E0-
Subsystem 4 - Part No SW: ----------- HW: 480 400 702 14
Serial number: 3510002B1107DB4561D+
Subsystem 5 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3520002B313013F1529N
Subsystem 6 - Part No SW: ----------- HW: 480 402 002 14
Serial number: 3550002C7107DB43C3AC
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 002 14
Serial number: 3560002C9107DB42505%
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 17031404401689
Coding: 0400
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 79F9AB61F87ED987E0-802C
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 316 2210
Coding: 0BAD09112980880902086A00000000
VCID: 6CD78235872C7C2F6B-8038
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 M
Component: GW MQB High 212 2163
Revision: -------- Serial number: 11031410000983
Coding: 0101000820085900EF00022A080F00000001000000000000000000000000
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti_010.rod
VCID: 3F8D0579A6DA37B79E-806A
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001883000043503
Coding: 28FFFF
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511 D
Component: FLA H05 0002
Revision: AA001001
Coding: 02018864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B55412942A2BB1722-807E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000063664004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34675A559F9CE4EF73-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 280414060502EA
Coding: 003E13200000040000000000
VCID: 408F0685DB24484FE7-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001873200
Coding: 011000
65604 - Door Warning Lamp
B1326 01 [009] - Electrical Failure
Reset counter: 144
Mileage: 146906 km
Date: 2019.09.03
Time: 22:56:02
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB_010.rod
VCID: 3561675194E6FDE744-8060
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H30 0042
Serial number: VWZ8Z1DC400X6XS
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst11CALPI 001005
ROD: EV_AMPMst11CALPI.rod
VCID: 63C5E9096AF23357DA-8036
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 030514060502MT
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001850904
Coding: 191000
Reset counter: 147
Mileage: 146913 km
Date: 2019.09.13
Time: 20:11:37
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 021A01010B000400
VCID: 3D717F71ACD625A78C-8068
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 013 0645
Serial number: V7B02303142210
Coding: 027300000000000021220002001800001F0203340100010002
Shop #: WSC 00066 790 07026
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 64C7EA156FFC346F23-8030
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS5001XX
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140207200026
VCID: 6BD5812982227B1762-803E
End-------------------------(Elapsed Time: 04:14)--------------------------
