After retrofitting reverse cam on Q2
when image revert back to radio , my mmi hang on volume button , if car did not engage reverse cam , i have no issue , so i did tried to off the reverse cam option , after numerous of trying , the car image still appear when engaging reverse , anyway to revert back to original code ? or another one did encounter this problem before ? after reverse cam revert back to the radio MMI , the steering wheel button volume was not functioning and then the whole mmi hang , which i need to reset the whole mmi system , after reset the whole mmi , radio and steering is working well as normal till you engage the reverse camera again
so now need help on revert back the MMI without reverse camera to confirmed the camera is faulty or is any code that can help to resolve the issue
Monday,14,October,2019,15:58:58:63906
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZGA6KA082xxx License Plate:
Mileage: 1308km-812mi Repair Order:
Gateway Installation List: 3Q0 907 530 AA
Monday,14,October,2019,16:02:00:63906
Chassis Type: GA-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 29 2B 39 42 44 4B 52 5F 6D D6
D7
VIN: WAUZZZGA6KA082xxx Mileage: 1308km-812miles
Address 01: Engine (J623-CHZJ) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 026 AL HW: 04C 907 309 AL
Component: R3 1.0l TFS H26 5154
Revision: W1H26---
Coding: 0225003223241D083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM10TFS01104C906026AL 002007
ROD: EV_ECM10TFS01104C906026AL_AU37.rod
VCID: 6B96CFE6827C521762-803E
CAN Converter 01:
Readiness: 1110 0001
Part No SW: 0CW 300 043 HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1601
Revision: 00005008 Serial number: CU501905267142
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 74A4D49ADF428DEFB3-8020
Part No SW: 5Q0 614 517 EH HW: 5Q0 614 517 BR
Component: ESC H82 0107
Revision: 00000000 Serial number: 61559000001846
Coding: 34008A8D2028246E897C0E0562C6242C51042491704624F20221F004121B4A0300000633D2D21212FF35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 7BB6FFA6F21CC297F2-802E
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0519035895
Coding: 030C0C1720
VCID: 43C64746CA6C7A57FA-8016
Part No SW: 8V0 820 043 AA HW: 8V0 820 043 AA
Component: AC Automat H03 0140
Revision: 20001000 Serial number: 00000001843432
Coding: 06100003110000001000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 71AADD8EA050B8C758-8024
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 0DC011B900PAG0MUFU03
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 01001915901893
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7DB2F1BEEC08CCA7CC-8028
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 23123467X81A955555A0
Coding: 80005E
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 AQ HW: 8V0 941 531 AQ
Component: E1 - LDS MQB H06 0032
Serial number: 21 03 2019 20001677
Steering Column Switch:
Subsystem 3 - Part No SW: 82A 953 521 BF HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000030051904400338
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419319165
Coding: 0600000011
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000_009.rod
VCID: 4AD86A62ED46AB1F39-801E
Part No SW: 5Q0 959 655 BN HW: 5Q0 959 655 BN
Component: AirbagVW21 007 0403
Serial number: 003FHR5CRZT+
Coding: 88CCF0000000000058000000C0C8000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0D52A17EDCA8FC27DC-8058
Subsystem 1 - Part No SW: ----------- HW: 480 001 106 19
Serial number: 3570000000060A8CDC3-
Subsystem 2 - Part No SW: ----------- HW: 480 001 106 19
Serial number: 35800000000208E85D3Q
Subsystem 3 - Part No SW: ----------- HW: 480 401 406 19
Component: SideSensor_Dr 005 6149
Serial number: 35100019AF03BAC5795K
Subsystem 4 - Part No SW: ----------- HW: 480 401 406 19
Component: SideSensor_Pr 005 6149
Serial number: 35200019AF03BAC5833E
Subsystem 5 - Part No SW: ----------- HW: 480 400 106 19
Component: FrontSensor_D 005 6149
Serial number: 3550001A0EE9B781452D
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 400 106 19
Component: FrontSensor_P 005 6149
Serial number: 3560001A0EE9B78147FT
Part No SW: 81A 920 750 D HW: 81A 920 750 D
Component: KOMBI H21 2700
Coding: 25A5221C2A8000080100AA001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: 2502F9DE2418A467F4-8070
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: -------- Serial number: 0009675910
Coding: 030100043F0857005B00004A100B00000001010000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E90C6F2B16EA73F45-803A
Component: 1-01-02-01-04
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0004
Serial number: 20190604111625 21197
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003911905241446
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 C HW: 8S0 907 397 C
Component: LCM_MQB H07 0022
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 41CA4D4ED0706847E8-8014
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 19000140932008
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_AU37.rod
VCID: 332617869ACCCAD76A-8066
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS002 0287
Serial number: YE007SEL04157
Coding: 00121B205001000000001002
VCID: 44C4445ACF627D6FC3-8010
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000030800328
Coding: 0D0000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 811F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C343CBAB79205AFBB-8068
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 01061910800673
Coding: 000000050900116600102B00020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 3522299E94B8D4E744-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS002 0287
Serial number: YE007SEP2316E
Coding: 001213205C01000000001002
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000030881977
Coding: 150000
Part No SW: 81A 035 824 D HW: 81A 035 824 D
Component: MU-S--ER 722 0962
Coding: 01720600EF0A000011110001000A00002F002A160170010002
Shop #: WSC 19460 666 12345
ASAM Dataset: EV_MUStd6C3DELP 001013
ROD: EV_MUStd6C3DELP_AU37.rod
VCID: 2404E4DA2F225D6FE3-8070
Subsystem 1 - Part No SW: 81A 919 604 B HW: 81A 919 604 B
Component: DU Std AU216 H42 0100
Serial number: INX00104031900020241
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 81C 919 614 HW: 81C 919 614
Component: ControlUnit_B H20 0200
Serial number: APVAK127041900060112
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 130
Mileage: 1308 km
Date: 2019.10.14
Time: 15:59:23
Voltage terminal 30: 12.4 V
BAP-BAP_Function_ID: 02
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0271
Revision: -------- Serial number: A2-C737-6291-8
Coding: 1A28
VCID: 48DC506AF34A590F2F-801C
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 177EC316EE7406F776-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----------(Elapsed Time: 01:16, VBatt start/end: 12.5V/12.5V)-----------
