Caddy Flashing Immo Light
GXCars
C?ID=248011
Hi
Hopefully someone may have seen this before but I'm a little perplexed by this one as it doesnt make sense
Picked up a 2006 caddy last week as a fixer upper, starts and runs OK when I got it the guy said there was a wiring fault with the cluster and it didnt work, went through the wiring and it was just a blown 5a fuse. Put in a new fuse cluster comes on and everything works fine - BUT the immo light is flashing and a message immobiliser adjustment failure in the display.
VCDS says there is no key signal 01176 so that being the case the van should not run but it does, its had a new key at some point and I only have 1 key so cant test with another.
Logic says put a new key reader on the ignition barrel but I'm then woriied the immo will kick in
Does anyone have any thoughts or has seen this before? any wisdom apopreciataed
Scan attached
Thanks in advance
Ian
Address 44: DTCs clearedSunday,13,October,2019,18:17:55:17347
VCDS Version: 19.6.2.0 (x64)
VIN: WV1ZZZ2KZ7X015100   License Plate: GP06XAK
Mileage: 309930km-192581mi   Repair Order:
Chassis Type: 2K (1K0)
VIN: WV1ZZZ2KZ7X015100   Mileage: 309930km-192581miles
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 AQ    HW: 028 101 239 0
   Component: R4 1,9l EDC  000SG  7872
   Revision: --H02---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000071
   Shop #: WSC 35110 377 00157
   VCID: 6ED46F2679D4C63F45-803A
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017106
   VCID: 3F8AE2626E3E7FB79E-806A
   Part No: 1K0 820 047 FH
   Component: Climatic PQ35   120 0606
   VCID: 6FEA72227EDECF374E-803A
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000005847999
   Coding: 00884F030004100000000000000000000009FB075C
   Shop #: WSC 35110 377 08192
   VCID: 2A5CA33685BCEA1FD9-807E
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 130606 020  0501
   Coding: 00038805
   Shop #: WSC 35110
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 2Q AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR06LDT6
   Coding: 0012881
   Shop #: WSC 35110 377 00158
   VCID: 7DF6586A24B2ADA7CC-8028
   Part No SW: 1K0 953 549 BC    HW: 1K0 953 549 BC
   Component: Lenksäulenmodul 636 0070
   Coding: 0000012
   VCID: 74E07D4E17F8ECEFB3-8020
   Part No SW: 1T0 920 963 A    HW: 1T0 920 963 A
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0F7012010
   Coding: 0017401
   Shop #: WSC 00041 067 57207
   VCID: 3362BE525276ABD76A-8066
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H04 0010
   Revision:   H04 02    Serial number: 22050602000624
   Coding: 3D0F034007007401
   VCID: 2C50A52E8F48F42F2B-8078
                    Reset counter: 200
                    Mileage: 309934 km
                    Time: 23:32:34
   Component: IMMO            VDD 1610
   Shop #: WSC 00137 211 56823
01176 - Key
                    Reset counter: 200
                    Mileage: 309934 km
                    Time: 23:33:40
   Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
   Component: Tuer-SG         005 0930
   Coding: 0000560
   VCID: 3878897E4B10488F5F-806C
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.140 H07 1806
   Shop #: WSC 35110 666 38454
   VCID: 3566804A5C02B5E744-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 008A0C087F2D8405485A010010C0
   Shop #: WSC 08224 211 56823
   VCID: 79FE4C7A309A9187E0-802C
   Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
   Coding: 0000560
   VCID: 397E8C7A701A5187A0-806C
Address 56: Radio
End-------------------------(Elapsed Time: 01:21)--------------------------
GXCars
C?ID=248011
that is a possibility but how can u tell from the scan if thats the case and how can I then disable the light on the cluster as I cant see how to code it out, at this stage I just want the light out
MartinsX
Riga, Latvia
C?ID=268515
This is not the VCDS related job.
GXCars
C?ID=248011
Ill get a couple of new immo chips and take it to someone who has Geko then and get them to reload everything properly, I dont suppose you can disable the immo in the can gateway to stop the light - the flashing annoys the hell out of me and I want the immo working in any case
golfi_vend
Tartu, Estonia
C?ID=195131
Get the system fixed.
You need someone with knowledge to re-enable immobiliser in ecu and match it cluster + add keys.
What does ECU say in 0x01-10-091 VCDS value from r immobilizer status?
We need to determine if flash or eeprom related in ECU because GeKo won't do anything if it is being ignored.
You could however stick a key around the D2 key coil with transponder to see if observed in VCDS blocks.
MartinsX
Riga, Latvia
C?ID=268515
Don't need a scan to tell. Can be deduced from the fact that it ran with a dead cluster and the fact that it runs with the Immo light on.
Exactly ;)
Plus:
   Coding: 0000071
Just marry a key and MIL for key or message should vacate, who cares right it's running a defeated immo and when the light comes on again later and the car runs anyway, you can point your middle finger like I do to my TDI saying I got you bitch, the engine is still running & I'm not stuck today?
GXCars
C?ID=248011
They key has a transponder in it but there’s no way I can tell if it’s been previously used, the issue I have now is that I can’t pull the SKC because I don’t have a “working” key which is required to get the SKC.
VW dealer said they don’t really want to touch it which is fair enough so I may have to either get a second hand set of ECU key and clocks or try and map out the DTC to stop the light and that’s assuming I can pull the map from the ECU 👿
Not true.
Send me the cluster and we can default it to like new or virgin state & so you can marry or we can pre marry a transponder set or we can defeat immobilizer in cluster and just shut it off.
Just pay for transponders, freight and donation you feel is fair plus provide credentials.
Not like you can't use until so ....
GXCars
C?ID=248011
I'd love to send it to you Jack but I tink the cost would be prohibitive even though I work in the airfreight business part time here in the UK!
I'm confident there are people in the UK who can do that.
Sorry about your location OP, I tried. :rolleyes:
Since you are in the freight business how is it the Chinese can ship their stuff here and represent it as here but get it here for pennies in 1-2 days and or free freight than ship to forwarding agent for free too?
GXCars
C?ID=248011
So in answer to that question here in Europe its a bit of a scam, what happens is stuff is shipped from China as a bulk consignment full of thousands of orders usually shipments are 7-8000 kgs each !
They do one customs entry to transfer the freight into the domestic mail, each piece which may be only the size of a letter has been prepaid with the local postage and electronically declared at a low value usually less than £15 and it therefore doesnt require a customs entry and is duty free.
Using this method you get delivery from china in around 10 days at little more than the cost of the domestic postage and it doesnt even attract any customs formalities because the Chinese undervalue stuff to avoid the customs formalities which drive the cost right up.
To send the cluster to you and for you to send it back to me would probably end up costing about £100 becuase its a one piece shipment so you get hit with charges both ways, I could get it to you relatively cheaply but unless you have a special arrangement with somone in the US it can be expensive to send it back.
Up until recently we ran one of the Global Shipping Lanes from ebay into Australia and that works in a similar way.
There are ways around it but you really you need to send multiple orders from one country to another in order to keep the costs down and if you need any logistical help here in the UK just PM me :)
GXCars
C?ID=248011
So as everyone suspected the car has had an immo bypass done on the ECU, the key is not matched to the cluster and try as I might with 3 different tools I can’t seem to retrieve the SKC I think is because I need a working key.
The dealer will only code for me if a pay them a ridiculous amount of money for a new key and won’t code up new transponders plus they don’t know if the ECU can be returned to its stock state.
If I buy a couple of new transponders and a second hand ECU that hasn’t been messed with does anyone know if it can be coded if connected to the factory as I really don’t want something that has no immobiliser
My only other option seems to be a second hand matching cluster ECU and key but then I’m not entirely sure how to write the vin into the new ECU and cluster
If I could just get the SKC I could sort it in about 30 minutes but I can’t seem to read the eeprom either
Any ideas anyone?
Thanks in advance
Buy a used ECU set and send me the equipment with credentials or send me the existing stuff and buy some new transponders.
Offer still stands............
