Results 1 to 7 of 7
Thread: Replace comfort control module
    Oct 2019
    Irwin, PA, USA
    HI All,
    Have a 2008 A4 cab to the dealer and they said the control module was bad.
    I order the module and the Ross-Tech tool.
    Did the auto scan and came up with other faults? Are they part of what the module does.
    To reprogram the new module, i look but could not find what i thought i needed.
    Thanks for the help.
    I am new to the forum.
    Rich
    Hope i did this right.
    Sunday,13,October,2019,12:44:27:03103
    Dealer/Shop Name: RDP
    VIN: WAUDF48H18K013841   License Plate:
    Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
              63 65 67 73 75 76 77
    VIN: WAUDF48H18K013841   Mileage: 54500km-33864miles
       Part No SW: 8E1 910 115 G    HW: 8E0 907 115 D
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5EH15---    Serial number:
       Coding: 011C010A190F0120
       Shop #: WSC 00672 785 00200
       VCID: 2615F62084E7CCC793B-8072
    049412 - No Communication with Cruise Control Module
                   U0104 - 008 -  - Intermittent
                        Fault Frequency: 197
                        Mileage: 53553 km
                        RPM: 1155 /min
                        Load: 23.1 %
                        Temperature: 85.0°C
                        Temperature: 73.0°C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 12.446 V
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 008 -  - Intermittent
                        Fault Frequency: 50
                        Mileage: 53553 km
                        RPM: 1198 /min
                        Load: 19.6 %
                        Temperature: 84.0°C
                        Temperature: 66.0°C
                        Voltage: 11.811 V
       Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
       Component: AG6 09L 2,0TFSI USA 0080
       Revision: --H01---    Serial number:        4428893
       VCID: 2F3B1304AB1D8D8F60D-807A
    049682 - Steering Column Control Module
                   U0212 - 000 - No Communications - Intermittent
                        Fault Frequency: 218
                        RPM: 832 /min
                        RPM: 640 /min
                        (no units): 30.0
                        (no units): 33.0
                        Temperature: 69.0°C
                        T.B. Angle: 0.0°
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004528
       VCID: 2E050E00AC1784876BB-807A
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   3233
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6D87C90C64813F9F121-50F4
                49-00 - No Communications
    Address 15: Airbags        Labels: 8H0-959-655-94.lbl
       Part No SW: 8H0 959 655 H    HW: 8H0 959 655 H
       Component:    Airbag 9.42  H01 1830
       Revision: 92H01183    Serial number: 003D00004K2%
       Coding: 0132105
       VCID: 3FDB43447B7D7D0FF0D-806A
       Subsystem 1 - Part No: 8H0 910 339 B
       Component: BF-Gewichtsens. H02 0020
       Subsystem 2 - Serial number: 0272P
       Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
       Subsystem 4 - Serial number: 000000ÿ†6332BRB403877890Nÿ†63
       Subsystem 5 - Serial number: 77890Nÿ†6342BRB403876FA8$ÿ†63
       Subsystem 6 - Serial number: 76FA8$ÿ†63729RB403A0DA1FZÿ†63
       Subsystem 7 - Serial number: 0DA1FZÿ†63829RB403A111E3Hÿ
       Subsystem 8 - Serial number: 111E3Hÿ
       Part No SW: 8H0 920 982 B    HW: 8H0 920 982 B
       Component: KOMBI+WFS 4     H10 0200
       Revision: 0200        Serial number: 00000000000000
       Coding: 0007261
       Shop #: WSC 06442 444 57235
       VCID: 30391078B6339277797-50F4
       Coding: 0007261
    Address 26: Auto Roof        Labels: 8H0-959-255.lbl
       Part No: 8H0 959 255 B
       Component:  VSG  B6 CABRIO     7195
       VCID: 3537216C4951B75F2A1-50F4
    00532 - Supply Voltage B+
    02023 - Terminal 87
       Part No SW: 8H0 035 192 H    HW: 8H0 035 192 H
       Component: RNS-E US        H74 0260
       Revision:      04S    Serial number: AUZBZ7H2500226
       Coding: 0413617
       VCID: 2C0104089A2BF69745F-5160
                        Reset counter: 245
                        Date: 2009.08.16
                        Time: 11:45:26
                        Voltage: 10.10 V
                        Reset counter: 245
                        Date: 2009.08.16
                        Time: 10:59:08
                        Voltage: 10.50 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
       Part No SW: 4L0 910 357     HW: 4L0 907 357
       Component: AFS 1           H01 0040
       Coding: 0000019
       VCID: 698FBD1C557923BF7E9-803C
       Component: AFS-Modul links H05 0030
       Component: AFS-Modul rechtsH05 0030
       Coding: 0413617
                        Reset counter: 245
                        Date: 2009.08.16
                        Time: 11:45:26
                        Voltage: 10.10 V
                        Reset counter: 245
                        Date: 2009.08.16
                        Time: 10:59:08
                        Voltage: 10.50 V
                        Mileage: 655350 km
                        Count: 65535
                        Clock: 255:255
    Address 63: Entry Assist,D        Labels: None
       Part No: 8H0 959 760 A
       Component: EasyEntry F   H13   0010
       Coding: 00005
       Shop #: WSC 00065
       VCID: 3537216C4C61B75F2A1-4B3C
    Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
       Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
       Component: Reifendruck 3   H04 0130
       Coding: 0062121
       VCID: 2A0D021090DFE8A7B73-5160
    Address 73: Entry Assist, P        Labels: None
       Component: EasyEntry BF  H13   0010
       Coding: 00005
       Shop #: WSC 00065
    8 Faults Found:
                37-10 - Faulty - Intermittent
                80-10 - Single-Wire Operation - Intermittent
    02010 - Left Entry Assistance Control Module (J572)
       Part No SW: 8P0 862 335 R    HW: 8P0 862 335 R
       Component: FSE_255x BT     H26 0350
       Revision: 00000000    Serial number: 00000005069288
       Coding: 0011807
       VCID: 45D751AC19B127DFBA1-50D0
    End----------(Elapsed Time: 05:16, VBatt start/end: 14.4V/14.2V)-----------
    Where is 0x09 have you checked fuses and what was old part number and new one you installed?
    Oct 2019
    Irwin, PA, USA
    Hi Jack,
    The old part# 8h0959433l the new part is the same number it will be deliver tomorrow (Monday) I did not see a bad fuse.
    I will replace it but I was told it needed reprogramed that is why i bought the Ross tech. I do not know what 0x09 is.
    Rich
    Vehicle Identification No. WAUDF48H18K013841
    Model audi a4 cabrio. 2.0
    quattro
    AA4C
    Date of production 17.03.2008
    Model year 2008
    Sales type 8HE5EL
    Engine Code BWT
    Transmission Code HYH
    Emission standard 7GB Emission standard ULEV 2
    So you're missing 0x09 & 0x46 so most likely 0x46 based on that part number but what happened to 0x09 too?
    Should it be this than?
    Examples.........that seem to be missing to me
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 N
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 L
    09, 16, and 46 are all conspicuously absent.
    Sep 2016
    Riga, Latvia
    Water ingress. Very common fault A4 B6/B7. Flooded 0x09 and 0x46.
  8. Likes Uwe, Jack@European_Parts liked this post
    Oct 2019
    Irwin, PA, USA
    Hi All,
    Installed the new comfort control module today,
    Things are much better.
    Trying to install the new auto scan but am having a problem.
    I will work on this and post it as soon as i can
    Water ingress was the problem glass to top seal.
    Had some corrosion on one connection clean several times will reclean it in the morning.
    Thanks for all the help.
    Rich
  10. Likes Jack@European_Parts, Uwe liked this post
