Boot wont open
Tj0754
C?ID=313219
had car in body shop after a bump no major damage just bumper respray but since I got the car back the boot wont open and two bulbs are out, everything was fine when I dropped it off not sure if its something they have done or a coincidence. im not sure if the boot can be open from the inside to access the motor or if short to ground is just a wire faulty or unplugged
Sunday,13,October,2019,15:17:29:20556
VCDS Version: 19.6.2.0
VIN: WVWZZZ1KZ8W201705   License Plate: RK08WBX
Mileage: 159770km-99276mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 62 72
          76
VIN: WVWZZZ1KZ8W201705   Mileage: 159770km-99276miles
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 KG    HW: 022 906 032 GP
   Component: R32-DQ-EU4          1067
   Revision: 1QH02---    Serial number: VWX7Z0GN3N89BQ
   Coding: 0000178
   Shop #: WSC 01279 785 00200
   VCID: 5AB1B2F5954F359F89-800E
Address 02: Auto Trans        Labels:
   Part No SW: 02E 300 011 CK    HW: 02E 927 770 AE
   Component: GSG DSG         081 1407
   Revision: 04708010    Serial number: 00000711241223
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004744
   VCID: 72E1FA556DFF6DDFA1-8026
   Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 78F5C87D0B83078F9F-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 00000007872158
   Coding: E68F8F2700041500471400001400000000087B075C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: 71E3F55968F956C758-8024
   Component: Wischer 051207 021  0501
   Coding: 00038805
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     121207 046  0204
   Coding: 00207646
01506 - Bulb for Rear Fog; Right (L47)
                    Reset counter: 195
                    Mileage: 159732 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.05 V
                    Reset counter: 195
                    Mileage: 159732 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.05 V
   Component: 5B AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0A3HCW
   Coding: 0013634
   Shop #: WSC 01269 785 00200
   VCID: 6CDDE42D4FDBBB2F6B-8038
   Subsystem 1 - Serial number: 6332MSME343362192
   Subsystem 2 - Serial number: 6342MSME343152381
   Subsystem 3 - Serial number: 6352QSME42593951F
   Subsystem 4 - Serial number: 6362QSME506D12319
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012102
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K6 920 974 B    HW: 1K6 920 974 B
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GN3N89BQ
   Coding: 0005403
   Shop #: WSC 00401 210 93592
   VCID: 336F3F51526524D76A-8066
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K07B2204B5
   Coding: ED837F0E4002020003
   VCID: 3065305DA3731FCF17-8064
                    Reset counter: 235
                    Mileage: 159742 km
                    Time: 17:43:30
01304 - Radio
                    Reset counter: 235
                    Mileage: 159742 km
                    Time: 17:43:30
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   VCID: 36690645411731FF4D-8062
   Component: IMMO            VDD 1216
   Part No SW: 1T0 035 680 A    HW: 1T0 035 680 A
   Component: RNS-MID       H04 1000
   Revision: AB001001    Serial number: VWZ6Z7G7337019
   Coding: 020004000400001200
   Shop #: WSC 01316 785 00200
   VCID: 2C5D242D4F5B7B2F2B-8078
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1220
   Coding: 0000694
   VCID: 39730D797009DE87A0-806C
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.141 H08 1901
   Shop #: WSC 00000 028 00001
   Coding: 819002005103087F2D0484057008DFC690FC00
   VCID: 030FAF9142455457BA-8056
   Component: LIN BACKUP HORN H07 9001
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
00950 - Central Locking Motor - tailgate (V53); UNLOCK
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 14
                    Reset counter: 194
                    Mileage: 159752 km
                    Time: 12:19:43
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Component: Tuer-SG         006 1204
   Coding: 0000950
   VCID: 3A711275750FD59FA9-806E
   Part No: 1T0 907 357
   Coding: 0000004
   VCID: 74EDFC4D17EB63EFB3-8020
   Component: Tuer-SG         006 1206
   Coding: 0000144
   Shop #: WSC 01279 785 1012552
   VCID: 3875087D4B03C78F5F-806C
00098 - Rear Left Central Locking (Safe) Motor (V163)
   Component: Tuer-SG         006 1207
   Coding: 0000144
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 22 Einparkhilfe     0101
   VCID: 2D5B2929B44172273C-8078
End-------------------------(Elapsed Time: 02:51)--------------------------
Based on the fault codes you have there, I'd say you need to get a wiring diagram for this car and attack the trunk and bulb problems with a multimeter.
Tj0754
C?ID=313219
I will see if I can find a drawing i just hope there is a way of opening the boot from the inside
I'm not sure whether the regulations in the UK/EU require it, but here in NAR, it's an absolute requirement for there to be a mechanical release from the inside.
Also see: Where do I get a Wiring Diagram?
siLc
Tallinn, Estonia
C?ID=330192
There is a mechanical release on the inside. Remove a small circular flap from lower rear lid trim and you'll see a small handle to push to one side.
GXCars
C?ID=248011
I had exactly the same issue with one of my old audis after a rear end bump, it was the boot lock itself, the circuit board giot cracked in the accident, new lock and was good as new, try also opening it on the remote key that may also open it as the boot handle is electronically operated
HTH
Tj0754
C?ID=313219
Have tried using the fob but when I unlock the car you cannot hear the boot locking/ unlocking like it should, it was fine before it went for the bumper respray
GXCars
C?ID=248011
Lookimg at the fault codes and the history I would guess the lock is faulty, take it back to the bodyshop and have them put a new lock in it, what happened with ours was that the lock got stressed when the car was hit, this caused a hairline fracture in the board and it wouldnt unlock, try thumping the tailgate on the outside and the bottom with the flat of your hand whilst trying the unlck button (not too hard) it sometime makes enough contact to get the lock to pop and you can get the tailgate open.
Virtually every VW Ive ever owned has had a door lock problem and ive replaced dozens on other VWs over the years they are made in the same factory as Walkers cris packets !
Tj0754
C?ID=313219
The rear door code I don’t understand as that works perfectly and always has
Tj0754
C?ID=313219
What’s the possibility of the car being in the oven has caused a wire to melt?
Tj0754
C?ID=313219
They said they didn’t remove anything just done it while it was still on the car
This bothers me so much.........
00576 - Terminal 15
Tj0754
C?ID=313219
Is that a bad fault to be getting? I’m no auto electrician so I’m not fully aware how major some of the faults are, spoke to garage today they said they scanned it for fault codes and got the errors I got but didn’t scan it before they done my work which to me seems crazy, you think they would scan it 1st to cover themselves and with it being a accident repair shop they have to give a Report to the insurance company, plus they never mentioned any of the faults when the car was collected, I think they know it happened while they had it
DV52
C?ID=194404
Jack: apropos of OP's description of the problem and even more concerning - this bothers me greatly:
                    Fault Frequency: 14
                    Reset counter: 194
                    Mileage: 159752 km
                    Time: 12:19:43
I reckon Uwe's suggestion is prudent : get a wiring diagram & a multi-meter and start chasing wires?
MVB_
C?ID=164610
Based on the scan I would be looking closely at the wiring that goes through the rubber boots for your hatch issues, MK5 tend to have breaks in the wiring inside the rubber boot. Probably failed at the shop because they were the last ones opening and closing the hatch while making repairs to bumper.
GXCars
C?ID=248011
If it was just a bumper they wouldnt have put the car in the oven just the bumper, ovens dont usually melt wiring they normally go up to 60oc which is the same as hot bath water.
If the tailgate was damaged and theyve stripped the lock and boot handle that's a different story
Tj0754
C?ID=313219
They didn’t remove the bumper just done it on the car and put the car in the oven they have told me was only a few paint scratches off the cars bumper no cracks or anything
Tj0754
C?ID=313219
Managed to remove the boot tr but didn’t get chance to test as I only had 30mins spare but noticed that the rear wiper doesn’t work either but will spray the water ok and also notice water droplets on the mechanism for the wiper motor, is there a fuse that would control this also check the wires where they go into the boot lid they seem ok hopefully il get an hour after work tomorrow to get this sorted
Just trace the wires with a tone generator and using WD to verify where everything is and stop the magic answer seeking behavior, don't you think it would take much less time? You have VCDS you could use it with some block values in 0x46 and the aforementioned, no?
Did you sort the ignition switch yet?
