Results 1 to 6 of 6
Thread: Basic Settings on UDS Units and why VCDS fails
    Jun 2017
    Hi all, Hi Ross-Tech,
    It came to my attention that VCDS is not the best tool when it comes to Basic Settings on modern UDS units.
    Other colleagues do have similar experiences regarding complex basic setting procedures that go beyond "Start lighting basic settings" and "Quit basic lighting settings".
    My understanding is that of course all available options that come with ASAM data will show up in the Basic Settings dropdown dialog because ASAM data predefines what is possible for that unit.
    I cannot think of any Basic Setting procedure that does not work properly for old KWP2000/CAN-only units.
    The common answer when it comes to Basic Settings for UDS is "Use ODIS".
    Due to personal curiosity I did some research on that UDS ASAM topic to get a better understanding of everything.
    I found some interesting slides that show a good comparison between KWP2000 and UDS:
    https://slideplayer.com/slide/2496907/
    There are two slides that illustrate the principle of actuator test on KWP2000 and UDS:
    and
    The main statement is that on UDS units the tester itself has to implement the sequence of any test because it is no more implemented as a routine within the control module.
    This could make sense as the sequence could be improved or changed on the tester side when ASAM data is updated, without having the need to update the control module.
    Is this also adaptable for the Basic Settings topic? Does VCDS lack the needed implementations on the tester side for this?
    I'd like to understand where the difficulties are and why ODIS is the place to be for the most newer basic setting routines like Air Suspension Recalibration on Audi B9 or Magnet Ride Recalibration on Audi 8V and so on...
    Cheers,
    hadez16
  2. Likes _Val liked this post
  3. #2
    Feb 2018
    Egypt
    Nobody cares but VCDS is useless when it comes to UDS Units and it can only cause unnecessary harm when running Basic Settings + the lack of adaptation guides and procedures you can end up at the dealer very easily.
    Odis is the future I guess, no longer cheap alternative.
    Quote Originally Posted by 64bit View Post
    Really? I beg to differ. Plenty of people have done various Basic Settings successfully on UDS control modules. Do we have instructions for every possible Basic Setting in every possible control module? No, not even close. But that doesn't make it "useless". If you think it it is useless, perhaps you should sell your VCDS and find an ODIS forum.
    Jun 2017
    That is really something I'd like just to understand. The necessary sequences and stuff for a full support of basic settings are not described in the ASAM dataset?
    If not, that would contradict the whole UDS/ASAM intention for a third party diagnostic tool developer not having the need for reverse engineering anymore....
    No, they are not. The ASAM dataset only defines the functionality available, not how to use it.
    What makes you think it's intended to make life easy for third-party tool developers? IMO, it is not; it's intended to make life easy for the car manufacturers and their suppliers.
  7. Likes hadez16 liked this post
    Jun 2017
    Okay, that is something I didn't know.
    It was my very humble knowledge about the topic that the advantages of the whole ODX/ASAM principle reaches also to the diagnostic tool developers, as all available measures and codings and stuff comes with that set of information.
    My interpretation was that also the necessary sequences for output tests or basic settings are also delivered in some way.
