2013 A4 ABS Coding and Steering Problem
Hi Guys looking for any info on this,
I Had a car come to me for with Steering rack making a Rough Noise when turned...... Also has ABS & Traction Control, lights coming on and off intermittently.
Ive attached a full Auto Scan. Can anyone verify if the ABS is Coded Incorrectly?
Saturday,12,October,2019,14:13:37:13475
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8K2DA197015
Mileage: 290250km-180352mi
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K2DA197015 Mileage: 290250km-180352miles
Address 01: Engine (J623-CJCB) Labels:. 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JP HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9977
Revision: 45H25---
Coding: 12194012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JP 003006
ROD: EV_ECM20TDI01103L906018AC.rod
VCID: 015F85E0618A403FC69-8054
Readiness: 0 0 0 0 X
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Coding: 161544
Shop #: WSC 06335 000 00000
VCID: 005980E46A004937C97-8054
Reset counter: 183
Mileage: 290138 km
Date: 2019.10.08
Time: 02:03:28
Hex Value: 0x0000
Hex Value: 0x0002
Hex Value: 0x1210
Hex Value: 0x10A1
Hex Value: 0x0000
Reset counter: 183
Mileage: 290139 km
Date: 2019.10.09
Time: 23:04:59
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x0227
Hex Value: 0x1695
Hex Value: 0x0000
Part No SW: 8K0 907 064 GC HW: 8K0 907 064 FC
Component: BCM2 2.0 H12 0633
Coding: 03B24000000000000000
VCID: 77ABEB383FCE0E8FF8D-8022
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0513000002675004
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2313000002580001
Part No SW: 8K2 820 043 AH HW: 8K2 820 043 AH
Revision: D0000000 Serial number: 01230120130653
Coding: 342402E000
VCID: 6FBBD358479E464F20D-803A
Fault Status: 01100010
Reset counter: 142
Mileage: 290130 km
Date: 2019.10.08
Time: 00:22:41
Temperature: 16.0°C
Temperature: 45.0°C
Absolute Pres.: 0.8 bar
RPM: 800 /min
Current: 0.000 A
Temperature: 17.0°C
Part No SW: 8K0 907 063 DC HW: 8K0 907 063 DC
Component: BCM1 1.0 H16 0103
Revision: 03016001 Serial number: 00000540180802
Coding: 290000308034A7C00081000000001F1F001D060827080201000008000000020000000020000000
VCID: 73B3DF282BB662AFC45-8026
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 210113 H06 0080
Serial number: SWF13010210253
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20902393
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001701130873
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: E4080C86000000000001
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Serial number: 003KFD97SW53
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 26844 001 1048576
VCID: 48C958C40230B177417-801C
Serial number: 6334MSME7734396CO
Serial number: 6344MSME77414F67P
Serial number: 6352QSME5827317AK
Serial number: 6362QSME02272E7EQ
Serial number: 63732SME532D3D522
Serial number: 63832SME532D3A60%
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130124000197
Coding: 000017
VCID: 4FFB73D8E7DE664F00D-801A
Component: E221 - MFL H03 0004
Part No SW: 8K0 920 982 E HW: 8K0 920 982 E
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UVR59JJ1E
Coding: 3384100002012600010000
VCID: 3635263C7844378723B-8062
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0055
Revision: 1V070026 Serial number: 2641V1311082CD
Coding: 80CF07FF00
VCID: 48C958C402B0B177417-801C
Serial number: 7561689001
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13022002511011200181
Part No SW: 8K0 959 793 S HW: 8K0 959 793 Q
Component: TSG FA H02 0506
Revision: Serial number: 0000049169763
Coding: 011002204001410001
VCID: 50F970A4FAE079B7197-8004
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0019591843
Coding: 100000000001
Shop #: WSC 00078 790 12345
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311C346EB825971DF-8060
Revision: 00002001 Serial number: 0300288094
Coding: 013B062220B900408020023680000000
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 G HW: 8R0 035 223 E
Component: DSP STD H11 0460
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 303910249A2019B7797-8064
Part No SW: 8K0 959 792 S HW: 8K0 959 792 Q
Component: TSG BF H02 0506
Revision: Serial number: 0000049173202
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001235449
ROD: EV_ParkiBrake_AU48.rod
VCID: 3829280472D0C1F7317-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R2 035 186 N HW: 8R2 035 186 N
Component: Concert3 H05 0470
Revision: 00000002 Serial number: AUZ5Z6M1841847
Coding: 0502008201028D00035B071000
VCID: 41DF45E0218A803F869-8014
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000049430143
Coding: 010002204001210001
VCID: 46D556FC08A4A707B3B-8012
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000049430785
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005613577
Coding: 0010320
VCID: 3D2739105172E4DFE21-8068
End----------(Elapsed Time: 01:36, VBatt start/end: 14.5V/14.7V)-----------
