Results 1 to 2 of 2
Thread: 05 Passat Timing chain tensioner
    Sep 2018
    Hi, and thanks for all your help in the past.
    Come to find out-one of the nylon pads had come off the bottom of the cam timing chain tensioner.
    This had allowed the chain to jump a tooth.
    I replaced the pad and adjusted the timing marks.
    All seemed to be well with not even having to clear any codes.
    Well now, I get the "Check engine" light after 20 or 30 miles.
    Does anyone think I should replace the tensioner?
    Thanks!
    Saturday,12,October,2019,08:01:56:08677
    VIN: WVWRU63BX5P005880   License Plate:
    Mileage: 217220km-134974mi   Repair Order:
    Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWRU63BX5P005880   Mileage: 217220km-134974miles
    Address 01: Engine        Labels: 078-907-551-ATQ.lbl
       Part No: 3B0 907 551 DC
       Component: 2.8L V6/5V      G   0020
       Coding: 07551
       Shop #: WSC 00028
       VCID: 678B4783567FCA6F68D-5160
       WVWRU63BX5P005880     VWZ7Z0D9524430
    16815 - Warm Up Catalyst; Bank 2
                P0431 - 35-00 - Efficiency Below Threshold
    16825 - EVAP Emission Control Sys
                P0441 - 35-00 - Incorrect Flow
    16725 - Camshaft Position Sensor (G40)
                P0341 - 35-10 - Implausible Signal - Intermittent
    Readiness: 0000 0001
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 3B0 927 156 CC
       Component: AG5 01V 2.8l5V  USA 0404
       Coding: 0001104
       Shop #: WSC 00028 028 00001
       VCID: 698F41BB456BFC1F7E9-5160
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       3428
       Coding: 04257
       Shop #: WSC 00028
       VCID: 25170D8BECF3187F9A1-51CE
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 J
       Component: CLIMATRONIC B5GP    0006
       Coding: 17200
       Shop #: WSC 00028
       VCID: 280904BF9BE10517A17-5160
       Part No: 1C0 909 605 C
       Component: 09 AIRBAG VW61 04   0003
       Coding: 12345
       Shop #: WSC 00028
       VCID: 2411108FE7C9E1778DF-513C
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 A
       Component: Lenkradelektronik   0005
       Coding: 00118
       Shop #: WSC 00028
       VCID: 2F3BEFA3BE0F522F60D-5160
    Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
       Part No: 3B0 920 929 B
       Component: KOMBI+WEGFAHRSP VDO V04
       Coding: 15235
       Shop #: WSC 00222
       VCID: 26150A8791F5136793B-513C
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00028
       VCID: 70B92CDF63B10DD7397-513C
    Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
       Part No: 3B1 959 760 E
       Component: °301
       Shop #: WSC 00000 065 00000
       VCID: 2F3BEFA3BB0F522F60D-513C
    01008 - Note; Emergency OFF Switch is Active!
       Part No: 1C0 959 799 C
       Component: 09 Komfortgerát HLO 0004
       Coding: 00258
       Shop #: WSC 00028
       VCID: 372BD7C3465F9AEF38D-4B1E
       Subsystem 1 - Part No: 1C0959801
       Component: 09 Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C0959802A
       Component: 09 Tőrsteuer.BF KLO 0202
       Subsystem 3 - Part No: 1C0959811
       Component: 09 Tőrsteuer.HL KLO 0202
       Subsystem 4 - Part No: 1C0959812
       Component: 09 Tőrsteuer.HR KLO 0202
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 G
       Component:    Radio PM6        0016
       Coding: 04031
       Shop #: WSC 00028
    End----(Elapsed Time: 04:01, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 36: DTCs cleared
    Address 46: DTCs cleared
    Address 56: DTCs cleared
    Seems to be a continuation of this thread:
    https://forums.ross-tech.com/showthread.php?19879
    We generally frown on having multiple threads open regarding the same problem in the same car. Would you prefer I merge them, or close one of them, and if so, which one?
