Sunroof coding, Passat B8
eden
Slovenia
C?ID=217860
After installing AID to my Passat B8, i loost coding for sunroof controler.
Have someone autoscan with this controler module? Then can i use this coding
Tnx
Post your Auto-Scan, then maybe we can find a scan from a similar car for you.
eden
Slovenia
C?ID=217860
Saturday,12,October,2019,22:34:07:34340
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZ3CZFE   License Plate:
Mileage: 77187km-47961mi   Repair Order:
Chassis Type  3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C BB
          BC CA
VIN: WVWZZZ3CZFE   Mileage: 77187km-47961miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 1989
   Revision: B5H21---
   Coding: 01190012034405083000
   Shop #: WSC 29121 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
   ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
   VCID: 7F0B74BAE67B58B7DE-802A
4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
          U1010 00 [032] - -
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63534000003493
   Coding: 0EEC6A8F34240B73077F060241C94970562CD0E0608292F11460F0084009
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 3D774EB2ACF78AA78C-8068
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0357395923
   Coding: 000F3E0603
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77FB9C9ACE4B60F796-8022
   Part No SW: 5G1 907 044     HW: 5G1 907 044
   Revision: 00001K10
   Coding: 11020114202100012015504C00101802
   VCID: 65C7C6D264E7E26734-8030
328964 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator stuck
                    Fault Frequency: 25
                    Reset counter: 19
                    Mileage: 75153 km
                    Date: 2019.09.30
                    Time: 08:41:13
                    Voltage terminal 30: 14.6 V
                    Outside air temperature: 19.0 °C
                    Interior temperature: 23.0 °C
                    Front air distribution flap: actual value: 0.0 %
                    Front air distribution flap: actual value: 60
                    Front air distribution flap: specified value: 20
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580301151324
   Coding: 00910C46C24102FF43C04004001807081E9E000000000000000000000000
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DF78EB2EC774AA7CC-8028
   Component: WWS    141213  042 0607
   Serial number:         141219085831
   Component: RLHS  037 0059
   Serial number: S3Y16M05D12H12M50S47
   Coding: 028877
   Light switch:
   Serial number: 07 11 2014  00000968
   Sun Roof:
545301 - Databus
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:57:20
559893 - Databus
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:57:20
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 247
                    Mileage: 75615 km
                    Date: 2019.10.07
                    Time: 14:58:14
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39311500205593
   Coding: 0071151001
   Shop #: WSC 05311 115 00093
   VCID: 40893746DB05E74FE7-8014
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0130
   Coding: 2A40600110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3363688A9AB34CD76A-8066
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2P06CC89
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 020DFD4E9589355FB1-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 000 401 15
   Serial number: 3576U000000E8C70721G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 301 15
   Serial number: 3586U000000972707211
   Subsystem 3 - Part No SW: -----------    HW: 454 800 701 15
   Serial number: 3516RA0E68E05000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 800 801 15
   Serial number: 3526RE8348B05000000A
   Subsystem 5 - Part No SW: -----------    HW: 454 800 301 15
   Serial number: 3556V36124A05000000
   Part No SW: 5Q0 953 569 B    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: --------    Serial number: 20160203500079
   Coding: 0400
   Shop #: WSC 46287 002 1048576
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         405 2170
   Coding: 07AD01902E80000801887E251400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 28598FE653753F0FCF-807C
10485826 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
                    Mileage: 40034 km
                    Date: 2018.02.11
                    Time: 15:12:23
16776996 - Databus
                    Reset counter: 14
                    Mileage: 60812 km
                    Date: 2019.05.28
                    Time: 21:22:45
   Revision: --------    Serial number: 19121410803720
   Coding: 030300044F087300FF00025A080F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EDAD8EA52905DFA1-8026
   Serial number: 29160000008240116013
   Coding: 2C0000
   Serial number: 2895365303
   Analog clock:
   Component: Analoguhr  111 1004
   Serial number: 1712201400010411
          U1101 00 [009] - Active
                    Fault Frequency: 73
                    Reset counter: 251
                    Mileage: 60900 km
                    Date: 2019.05.29
                    Time: 23:09:51
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
   Serial number: 14000315613005
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71EFA282A02F3EC758-8024
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 221214BLL01893
   Coding: 003F1B205400020000001000
   VCID: 428D3D4ED509F55FF1-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000114805
   Coding: 01000010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3B7340AAB2E38497B2-806E
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 161214BLG08549
   Coding: 003F1120D400020000001000
   VCID: 418F3242D00FEE47E8-8014
   Coding: 039A00000F200200
   Shop #: WSC 64272 001 1048576
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3F8B34BAA6FB98B79E-806A
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 021 C    HW: 3V0 035 021
   Component: MU-H-LND-EU   H50 0687
   Serial number: A674I0G2503060
   Coding: 02840101FF0000001111000100090A001F0100B401200000CD
   VCID: 275B8CDA5E6B3077C6-8072
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9M2300ME3
   Subsystem 2 - Part No SW: V03 959 806 FL    HW: -----------
   Component: ECE 2019  --- 0175
   Component: Gracenote2---  --- 1013
18 Faults Found:
1585 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
                    Voltage terminal 30: 12.4 V
1586 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1587 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1588 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1589 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1590 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1592 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1595 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1652 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1655 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1656 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1657 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1603 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
1690 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 177
                    Mileage: 68741 km
                    Date: 2019.08.30
                    Time: 20:53:45
          B201A 00 [009] - -
                    Reset counter: 135
                    Mileage: 60900 km
                    Date: 2019.05.29
                    Time: 22:54:05
                    Status_Software_Version_Management-module_name: MDUV101/ABT
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Reset counter: 15
                    Mileage: 60900 km
                    Date: 2019.05.29
                    Time: 22:54:16
                    Software module: status-SW_Status_Consistency: 00 20 00
                    Software module: status-SW_Status_Device:
15360768 - Component Protection
                    Reset counter: 15
                    Mileage: 60900 km
                    Date: 2019.05.29
                    Time: 22:53:59
1561 - predictive route data
          B1630 02 [009] - Signal Failure
                    Reset counter: 65
                    Mileage: 62638 km
                    Date: 2019.06.22
                    Time: 17:08:06
                    Voltage terminal 30: 14.3 V
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000005415
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: 34616B969FBD4BEF73-8060
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184010142002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 181214BLH19573
   Coding: 000E01200100020000001000
   VCID: 44813B56CF1DFB6FC3-8010
   Component: TSG HBFS      020 0028
   Serial number: 181214BLH19576
Address CA: Sunroof
Interface not compatible.
End-------------------------(Elapsed Time: 05:35)--------------------------
After installing AID i have this error, befor no errors...
CA loost coding, i have not suported VCDS, but i wont to make it with VCP, or buy new HEX V2....
Have someone coding ?
eden
Slovenia
C?ID=217860
I dont know what is wrong, in VCP is coding there but when i make standardization for sunroof this open then close.
But not working when i press switch, i must hold whole time switch for opening that window open ?
How to make that work with one press to switch ?
Since we can't see anything about your CA-Sunroof module, it will be very difficult to help you.
DV52
C?ID=194404
^^^^ hmm....... so in an attempt to "see" your sun-roof module, do you have an early auto-scan for the vehicle (date-stamped before you started the AID project - but the older the better) ? Perhaps look on your laptop in the directory C:\Ross-Tech\VCDS\scans?
If so, compare the long-code string for the BCM with your auto-scan above - look particularly @ Byte 1 (and especially @ Bit 7-perhaps?). Or, just post-up the older auto-scan for us to see
eden
Slovenia
C?ID=217860
No i dont have. I have older interface HEX+CAN and this module is not suportet, so no old coding in autoscan:(
I buy new interface and then i hope that can help here
MasterTommy
Amsterdam
C?ID=295586
If VCP sees coding thats not zero then nothing is wrong with the sunroof module. Are you sure your sunroof module coding got ‘zeroed’, or is that an assumption? If you have to hold the switch to open or close the sunroof, that usually means it has not stored basic settings. There are some guides here and there, but basically, when the sunroof is closed you can set the basic settings again easily. When the sunroof is closed and no buttons are being pressed, press and hold the button to close the sunroof (NOT the sunscreen) for about 20-30 seconds until the sunroof starts to open. If that happens, you can let go of the close button and dont touch the ignition or any other buttons until the sunroof has finished fully opening and closing and stops moving. Since the sunroof motor draws quite a bit of current which can cause a significant voltage dip; if your vehicle battery is not 100% it is advised to do this with the engine running.
If you have an electric sunscreen this procedure is the same, except using the close button for the sun screen.
The procedure is also the same if you have an older controller with a rotary knob for the sunroof control; in that case turning the rotary switch past the idle position (which is the ‘close’ button in this case) is what you use. The rest of the procedure is identical.
