Results 1 to 8 of 8
Thread: Sunroof coding, Passat B8
    Mar 2016
    Slovenia
    After installing AID to my Passat B8, i loost coding for sunroof controler.
    Have someone autoscan with this controler module? Then can i use this coding
    Tnx
    Post your Auto-Scan, then maybe we can find a scan from a similar car for you.
    Mar 2016
    Slovenia
    Saturday,12,October,2019,22:34:07:34340
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ3CZFE   License Plate:
    Mileage: 77187km-47961mi   Repair Order:
    Chassis Type  3C-VW48 (5Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 65 6C BB
              BC CA
    VIN: WVWZZZ3CZFE   Mileage: 77187km-47961miles
    Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 ES    HW: 04L 907 309 R
       Component: R4 2.0l TDI   H21 1989
       Revision: B5H21---
       Coding: 01190012034405083000
       Shop #: WSC 29121 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906026ES 002002
       ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
       VCID: 7F0B74BAE67B58B7DE-802A
    4377 - Please Check Fault Codes in Control Module for Electrical Parking Brake
              U1010 00 [032] - -
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 63534000003493
       Coding: 0EEC6A8F34240B73077F060241C94970562CD0E0608292F11460F0084009
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 3D774EB2ACF78AA78C-8068
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0357395923
       Coding: 000F3E0603
       Shop #: WSC 05311 115 00300
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77FB9C9ACE4B60F796-8022
       Part No SW: 5G1 907 044     HW: 5G1 907 044
       Revision: 00001K10
       Coding: 11020114202100012015504C00101802
       VCID: 65C7C6D264E7E26734-8030
       Air quality sensor:
    328964 - Motor for Front Air Distribution Flap
              B1091 71 [008] - Actuator stuck
                        Fault Frequency: 25
                        Reset counter: 19
                        Mileage: 75153 km
                        Date: 2019.09.30
                        Time: 08:41:13
                        Voltage terminal 30: 14.6 V
                        Outside air temperature: 19.0 °C
                        Interior temperature: 23.0 °C
                        Front air distribution flap: actual value: 0.0 %
                        Front air distribution flap: actual value: 60
                        Front air distribution flap: specified value: 20
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580301151324
       Coding: 00910C46C24102FF43C04004001807081E9E000000000000000000000000
       Shop #: WSC 12345 123 61029
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DF78EB2EC774AA7CC-8028
       Component: WWS    141213  042 0607
       Serial number:         141219085831
       Component: RLHS  037 0059
       Serial number: S3Y16M05D12H12M50S47
       Coding: 028877
       Serial number: 07 11 2014  00000968
       Sun Roof:
    545301 - Databus
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:57:20
    559893 - Databus
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:57:20
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 247
                        Mileage: 75615 km
                        Date: 2019.10.07
                        Time: 14:58:14
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39311500205593
       Coding: 0071151001
       Shop #: WSC 05311 115 00093
       VCID: 40893746DB05E74FE7-8014
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0130
       Coding: 2A40600110FFC428949C804C
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3363688A9AB34CD76A-8066
       Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R2P06CC89
       Coding: 88CCC000000000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 020DFD4E9589355FB1-8056
       Subsystem 1 - Part No SW: -----------    HW: 454 000 401 15
       Serial number: 3576U000000E8C70721G
       Subsystem 2 - Part No SW: -----------    HW: 454 000 301 15
       Serial number: 3586U000000972707211
       Subsystem 3 - Part No SW: -----------    HW: 454 800 701 15
       Serial number: 3516RA0E68E05000000D
       Subsystem 4 - Part No SW: -----------    HW: 454 800 801 15
       Serial number: 3526RE8348B05000000A
       Subsystem 5 - Part No SW: -----------    HW: 454 800 301 15
       Serial number: 3556V36124A05000000
       Part No SW: 5Q0 953 569 B    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0205
       Revision: --------    Serial number: 20160203500079
       Coding: 0400
       Shop #: WSC 46287 002 1048576
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
       ROD: EV_SMLSVALEOMQBLRH.rod
       Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
       Component: KOMBI         405 2170
       Coding: 07AD01902E80000801887E251400000000000000
       VCID: 28598FE653753F0FCF-807C
    10485826 - Internal Control Module Memory Check Sum Error
              B2000 41 [009] - General checksum failure
                        Mileage: 40034 km
                        Date: 2018.02.11
                        Time: 15:12:23
    16776996 - Databus
                        Reset counter: 14
                        Mileage: 60812 km
                        Date: 2019.05.28
                        Time: 21:22:45
       Revision: --------    Serial number: 19121410803720
       Coding: 030300044F087300FF00025A080F00010001070000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72EDAD8EA52905DFA1-8026
       Serial number: 29160000008240116013
       Coding: 2C0000
       Serial number: 2895365303
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 1712201400010411
              U1101 00 [009] - Active
                        Fault Frequency: 73
                        Reset counter: 251
                        Mileage: 60900 km
                        Date: 2019.05.29
                        Time: 23:09:51
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: On
       Serial number: 14000315613005
       Coding: 0000000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71EFA282A02F3EC758-8024
       Serial number: 221214BLL01893
       Coding: 003F1B205400020000001000
       VCID: 428D3D4ED509F55FF1-8016
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000114805
       Coding: 01000010005000
       Shop #: WSC 00015 115 00300
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       VCID: 3B7340AAB2E38497B2-806E
       Serial number: 161214BLG08549
       Coding: 003F1120D400020000001000
       VCID: 418F3242D00FEE47E8-8014
       Coding: 039A00000F200200
       Shop #: WSC 64272 001 1048576
       VCID: 3F8B34BAA6FB98B79E-806A
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Coding: E02400
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
       Part No SW: 3V0 035 021 C    HW: 3V0 035 021
       Component: MU-H-LND-EU   H50 0687
       Serial number: A674I0G2503060
       Coding: 02840101FF0000001111000100090A001F0100B401200000CD
       VCID: 275B8CDA5E6B3077C6-8072
       Component: ABT_High  H42 0022
       Serial number: VWZ8Z9M2300ME3
       Subsystem 2 - Part No SW: V03 959 806 FL    HW: -----------
       Component: ECE 2019  --- 0175
       Component: Gracenote2---  --- 1013
    18 Faults Found:
    1585 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
                        Voltage terminal 30: 12.4 V
    1586 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1587 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1588 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1589 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1590 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1592 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1595 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1652 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1655 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1656 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1657 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1603 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
    1690 - invalid data record
              B2005 00 [009] - -
                        Reset counter: 177
                        Mileage: 68741 km
                        Date: 2019.08.30
                        Time: 20:53:45
              B201A 00 [009] - -
                        Reset counter: 135
                        Mileage: 60900 km
                        Date: 2019.05.29
                        Time: 22:54:05
                        Status_Software_Version_Management-module_name: MDUV101/ABT
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 15
                        Mileage: 60900 km
                        Date: 2019.05.29
                        Time: 22:54:16
                        Software module: status-SW_Status_Consistency: 00 20 00
                        Software module: status-SW_Status_Device:
                        Reset counter: 15
                        Mileage: 60900 km
                        Date: 2019.05.29
                        Time: 22:53:59
    1561 - predictive route data
              B1630 02 [009] - Signal Failure
                        Reset counter: 65
                        Mileage: 62638 km
                        Date: 2019.06.22
                        Time: 17:08:06
                        Voltage terminal 30: 14.3 V
       Serial number: 30000000005415
       ROD: EV_RDKBERU30_006_VW48.rod
       VCID: 34616B969FBD4BEF73-8060
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H07 0100
       Coding: 0184010142002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
       Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0028
       Serial number: 181214BLH19573
       Coding: 000E01200100020000001000
       VCID: 44813B56CF1DFB6FC3-8010
       Component: TSG HBFS      020 0028
       Serial number: 181214BLH19576
    Address CA: Sunroof
    Interface not compatible.
    End-------------------------(Elapsed Time: 05:35)--------------------------
    After installing AID i have this error, befor no errors...
    CA loost coding, i have not suported VCDS, but i wont to make it with VCP, or buy new HEX V2....
    Have someone coding ?
    Mar 2016
    Slovenia
    I dont know what is wrong, in VCP is coding there but when i make standardization for sunroof this open then close.
    But not working when i press switch, i must hold whole time switch for opening that window open ?
    How to make that work with one press to switch ?
    Since we can't see anything about your CA-Sunroof module, it will be very difficult to help you.
  6. #6
    May 2014
    ^^^^ hmm....... so in an attempt to "see" your sun-roof module, do you have an early auto-scan for the vehicle (date-stamped before you started the AID project - but the older the better) ? Perhaps look on your laptop in the directory C:\Ross-Tech\VCDS\scans?
    If so, compare the long-code string for the BCM with your auto-scan above - look particularly @ Byte 1 (and especially @ Bit 7-perhaps?). Or, just post-up the older auto-scan for us to see
  7. #7
    Mar 2016
    Slovenia
    No i dont have. I have older interface HEX+CAN and this module is not suportet, so no old coding in autoscan
    I buy new interface and then i hope that can help here
  8. #8
    Dec 2016
    Amsterdam
    If VCP sees coding thats not zero then nothing is wrong with the sunroof module. Are you sure your sunroof module coding got ‘zeroed’, or is that an assumption? If you have to hold the switch to open or close the sunroof, that usually means it has not stored basic settings. There are some guides here and there, but basically, when the sunroof is closed you can set the basic settings again easily. When the sunroof is closed and no buttons are being pressed, press and hold the button to close the sunroof (NOT the sunscreen) for about 20-30 seconds until the sunroof starts to open. If that happens, you can let go of the close button and dont touch the ignition or any other buttons until the sunroof has finished fully opening and closing and stops moving. Since the sunroof motor draws quite a bit of current which can cause a significant voltage dip; if your vehicle battery is not 100% it is advised to do this with the engine running.
    If you have an electric sunscreen this procedure is the same, except using the close button for the sun screen.
    The procedure is also the same if you have an older controller with a rotary knob for the sunroof control; in that case turning the rotary switch past the idle position (which is the ‘close’ button in this case) is what you use. The rest of the procedure is identical.
    Current:
  9. Likes PetrolDave liked this post
