Results 1 to 2 of 2
Thread: 2012 A6 4G side assist and Engine timer fault
    Jan 2018
    Cheshire UK
    Been fitting a new sub the other day and had the battery terminal on and off whilst doing it. So thought i'd clear some fault codes and am stuck with the 'P150 engine off timer performance' code which will not clear, and why its listed in the 08 HVAC module is unknown as ive seen the P150 code online and is usually listed in the 01 Engine module.
    The 5F module is giving me a comms disruption which i thought was due to the MOST being disconnected but again wont clear.
    The strange thing with the side assist is even though its a retrofit i did nearly 2 years ago its been working perfectly fine with no issues but after clearing the fault codes yesterday the fault suddenly appeared and will not clear. Whether its pure pot luck that i have a faulty lamp all of a sudden i dont know until i swap it with the other side
    Any help with the codes please?
    Friday,11,October,2019,16:51:36:00592
    VIN: WAUZZZ4G7CN173219   License Plate: X9MBX
    Mileage: 62368km-38753mi   Repair Order: Fitted Sub & clearde air susp coding
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 3C 42 44 46 47
              52 53 55 56 5F 62 6C 6D 72 82 A9 C0
    VIN: WAUZZZ4G7CN173219   Mileage: 62368km-38753miles
    Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
       Part No SW: 4G0 907 589 A    HW: 4G0 907 589
       Component: 3.0BTD EDC17  H21 0004
       Revision: 57H21---
       Coding: 122A4012052601020000
       ASAM Dataset: EV_ECM30BTD0114G0907589A 001005
       ROD: EV_ECM30BTD0114G0907589A.rod
       VCID: 323D188CE4AF44970F3-8066
       Part No SW: 4G0 927 158 AB    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1006
       Revision: --H16---
       Coding: 000001
       VCID: 6E85CCFC301720772BB-803A
       Coding: 49A7870192E5E180DB00
       VCID: 3635249C08C758B723B-8062
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Coding: 01B93006000000000000
       Shop #: WSC 03273 003 1048576
       VCID: 76B5E49C48C718B7E3B-8022
       Serial number: 2312000080249013
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Component: KLIMA 4 ZONEN H14 0112
       Serial number: 09111500041327
       Coding: 362209BA310000
       Shop #: WSC 01206 210 13345
       VCID: 6393ADC8EBD59D1FB45-8036
    0276 - Engine Off Timer Performance
              P150A 00 [009] - -
                        Reset counter: 53
                        Mileage: 62368 km
                        Date: 2019.10.11
                        Time: 16:18:01
                        Voltage terminal 30: 13.46 V
    0291 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Sensor für Luftgüte: kein Signal / Kommunikation]
                        Reset counter: 53
                        Mileage: 62368 km
                        Date: 2019.10.11
                        Time: 16:18:01
                        Outside air temperature: 13.0 °C
       Revision: 11012002    Serial number: 00000001674657
       Coding: 2907A01149748FE0178100C7000018005F9DC7080F000101000104546F00
       Shop #: WSC 02313 785 00200
       VCID: 6FBBD1F8379D297F20D-803A
       Component: WWS57X 120309  H35 0080
       Serial number:         120326084537
       Coding: 004DF7
       Component: RLS  H04 0003
       Serial number: 20151070
       Coding: 03512B
       Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
       Component: E1 - LDS  H07 0044
       Serial number: 08 02 2011  00000393
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000029061200010224
       Coding: 110000
       Serial number: 00000030031100010004
       Coding: 110000
       Component: AQ_Hum_Sensor  H03 0005
       Serial number: EA288B2800PAG0MUFU01
       Revision: 11001001    Serial number: 61061302604024
       Coding: A8E308
       VCID: 71BFD78021293F8F369-8024
       Revision: --------    Serial number: 003JG008D7S8
       Coding: 30323436313330303537554A305234473053
       Serial number: 3575HRB405B1AP5SCHQ4
       Serial number: 3585HRB404R1BBH279UR
       Serial number: 3515JRB405F0UJCMJGKI
       Serial number: 3525JRB405D18E5E70ES
       Serial number: 3554VRB4061197FI89RJ
       Serial number: 3564VRB4061197FII8LN
       Revision: 00000000    Serial number: 20120501000043
       Coding: 000035
       VCID: 30391284EA237687797-8064
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
       Component: TDieGb        H79 0416
       Revision: 28460177    Serial number: 658140412596003
       Coding: 73AF11000B012600010000
       Shop #: WSC 00011 888 96745
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 3C2136B436EB82E7D5F-8068
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000502826
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 70B9D2842A233687397-8024
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790879227
       Voltage stabilizer:
       Serial number: 21011200000000000308
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 04028264747464545425363E
       VCID: 33331D881B354D9F045-8066
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0112
       Serial number: 30111300040269
       Coding: 22
       VCID: 3E253CBC20F790F7FBB-806A
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000010457256
       Coding: 00781B0000006001000001010101102030303232203232
       Shop #: WSC 02311 785 00200
       VCID: 77ABE9984FCD61BFF8D-8022
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA7207MWN1
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 33331D881BB54D9F045-8066
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 010 287-03
       Coding: 0001102
       Shop #: WSC 03654 128 28888
       VCID: 30391284E6237687797-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H02 0050
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F09.02.1200H020003CF24763ÿ
       Subsystem 4 - Serial number: F24763ÿ
    02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 53
                        Date: 2012.01.01
                        Time: 00:00:00
       Part No SW: 4G8 959 793 D    HW: 4G8 959 793
       Component: TSG FA        H05 0212
       Coding: 011F1E205E01620002080012
       Shop #: WSC 06745 128 28888
       VCID: 41DF47405189EF0F869-8014
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0008500146
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0176199445
       Coding: 013F162220B93480C120098500010E470000000000000000000000000000
       Shop #: WSC 50394 001 104857
       Subsystem 1 - Part No: 4G0 951 177 A
       Component: Sensor, DWA  005 0002
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00020773168
       Revision: CJ007001    Serial number: 00000000043305
       VCID: 1D67DB308DB1EBEFC21-8048
       Part No SW: 4G8 959 792 D    HW: 4G8 959 792
       Component: TSG BF        H05 0212
       Coding: 011F1E205401620002080002
       VCID: 40D942445A83E607897-8014
       Revision: --------    Serial number: 00000000329638
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0D00ECCC7F0C57B73-807E
       Serial number: 120430-0004-084
       Coding: 1122A6601000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C0106F4C68B126745F-8078
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109C 0F8018881
       Coding: 010103010000000001
       Shop #: WSC 06325 000 00000
       VCID: 2B0305E8C305155F4C5-807E
       Part No SW: 4G0 035 670 P    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 0939
       Revision: --------    Serial number: 190EU0C7502607
       Coding: 050101010103E7FF77088F3E00000003000001000100000202
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Serial number: AUZ8ZDC9401C6WZ
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Serial number: 90349LE10002U
       Component: CD-Database  3638
                        Reset counter: 53
                        Mileage: 62368 km
                        Date: 2019.10.11
                        Time: 16:35:45
                        Bin. Bits: 00000000 00001000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 4G8 959 795 D    HW: 4G8 959 795
       Component: TSG HL        H03 0212
       Coding: 010F1C204001628202080002
       VCID: 43D34D484B95FD1F945-8016
       Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
       Component: TopView       H07 0330
       Revision: 11001001    Serial number: 82330JF0204757
       Coding: 0202000001000000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
       ROD: EV_CamerSysteTopViewAUDI.rod
       VCID: 2E050CFCF09760776BB-807A
    9616786 - Surroundings Camera Front
              B127C F0 [009] - Calibration Failed
                        Reset counter: 50
                        Mileage: 62227 km
                        Date: 2019.08.24
                        Time: 18:59:05
                        Voltage terminal 30: 11.3 V
    9616787 - Surroundings Camera Rear
              B127D F0 [009] - Calibration Failed
                        Reset counter: 50
                        Mileage: 62227 km
                        Date: 2019.08.24
                        Time: 18:59:05
    9616788 - Surroundings Camera Left
              B127E F0 [009] - Calibration Failed
                        Reset counter: 50
                        Mileage: 62227 km
                        Date: 2019.08.24
                        Time: 18:59:05
    9616789 - Surroundings Camera Right
              B127F F0 [009] - Calibration Failed
                        Reset counter: 50
                        Mileage: 62227 km
                        Date: 2019.08.24
                        Time: 18:59:05
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [TopView system not calibrated]
                        Reset counter: 50
                        Mileage: 62227 km
                        Date: 2019.08.24
                        Time: 18:59:05
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0151
       Revision: 14005001    Serial number: 147500731
       Coding: 093205C010
       ROD: EV_HDSGAu571.rod
    0114 - Load Space Cover
              B12EF 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 53
                        Mileage: 62368 km
                        Date: 2019.10.11
                        Time: 16:15:33
                        Voltage terminal 30: 13.57 V
       Component: TSG HR        H03 0212
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 A    HW: 4G0 919 604 A
       Component: HeadUpDisplay X19 0042
       Coding: A20000
       ASAM Dataset: EV_HUDContiC7 001020
       ROD: EV_HUDContiC7.rod
       VCID: 290FFFE0C979074FBE9-807C
       Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120419200783
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 2B0305E8C385155F4C5-807E
    Address C0: Act. for Ext. Noise        Labels:
       VCID: 55F78310BC0173AFCA1-FFFE
       Note: Excessive Comm Errors
    End----------(Elapsed Time: 02:27, VBatt start/end: 13.6V/13.6V)-----------
    Address 08: DTCs cleared
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
    Jan 2018
    Cheshire UK
    anyone have any input??
    A6 BiTdi Avant MTM
